论坛底层软件ov x 8b摄像头,配置fps是30, 错误是cim ipi0 height error
szc2024-11-08
69
1. 硬件获取渠道及型号:
立昇智能科技提供的J5 SOM EDK
2. 系统镜像版本:
3. 问题模块:
vpm
4. 问题描述:
为了避开敏感词汇, ov x 8b 中间加了空格
rx0连接ov x 8b摄像头,配置的fps是30,图像宽和高是3840*2160. 地平线soc接收图像数据时,有下面错误打印
[ 2888.834420] cim ipi0 height error
[ 2888.834430] [S0] vio_push_drop_info frame id 1
[ 2888.848325] [S0][G1]vio_check_drop_info frame id 1, drop_flag 1
摄像头配置的是3840和2160. 通过调试命令查看如下。 附件是配置文件和log。清帮忙看下,如何确定高度的大小。
root@j5dvb:~# cat /sys/devices/platform/soc/47010000.cam_sys/47060000.cim/regdump && dmesg -c|grep DUMP|grep IMG|grep IPI
[ 3107.950914] [DUMP] reg:[CIM_IPI0_IMG_SIZE][0x0010], value:[0x0F000870]
[ 3107.950924] [DUMP] reg:[CIM_IPI1_IMG_SIZE][0x0018], value:[0x01400010]
[ 3107.950934] [DUMP] reg:[CIM_IPI2_IMG_SIZE][0x0020], value:[0x01400010]
[ 3107.950942] [DUMP] reg:[CIM_IPI3_IMG_SIZE][0x0028], value:[0x01400010]
[ 3107.950951] [DUMP] reg:[CIM_IPI4_IMG_SIZE][0x0030], value:[0x01400010]
[ 3107.950960] [DUMP] reg:[CIM_IPI5_IMG_SIZE][0x0038], value:[0x01400010]
[ 3107.950969] [DUMP] reg:[CIM_IPI6_IMG_SIZE][0x0040], value:[0x01400010]
[ 3107.950977] [DUMP] reg:[CIM_IPI7_IMG_SIZE][0x0048], value:[0x01400010]
root@j5dvb:~# cat /sys/devices/platform/soc/47010000.cam_sys/47060000.cim/regdump && dmesg -c|grep DUMP|grep DBG|grep IPI
[ 3171.471684] [DUMP] reg:[CIM_IPI0_DBG][0x0600], value:[0x0F0007E8]
[ 3171.471688] [DUMP] reg:[CIM_IPI1_DBG][0x0604], value:[0x00000000]
[ 3171.471692] [DUMP] reg:[CIM_IPI2_DBG][0x0608], value:[0x00000000]
[ 3171.471696] [DUMP] reg:[CIM_IPI3_DBG][0x060C], value:[0x00000000]
[ 3171.471700] [DUMP] reg:[CIM_IPI4_DBG][0x0610], value:[0x00000000]
[ 3171.471703] [DUMP] reg:[CIM_IPI5_DBG][0x0614], value:[0x00000000]
[ 3171.471707] [DUMP] reg:[CIM_IPI6_DBG][0x0618], value:[0x00000000]
[ 3171.471711] [DUMP] reg:[CIM_IPI7_DBG][0x061C], value:[0x00000000]
[ 3180.453167] [DUMP] reg:[CIM_IPI0_DBG][0x0600], value:[0x0F0003C6]
[ 3180.453171] [DUMP] reg:[CIM_IPI1_DBG][0x0604], value:[0x00000000]
[ 3180.453175] [DUMP] reg:[CIM_IPI2_DBG][0x0608], value:[0x00000000]
[ 3180.453179] [DUMP] reg:[CIM_IPI3_DBG][0x060C], value:[0x00000000]
[ 3180.453183] [DUMP] reg:[CIM_IPI4_DBG][0x0610], value:[0x00000000]
[ 3180.453187] [DUMP] reg:[CIM_IPI5_DBG][0x0614], value:[0x00000000]
[ 3180.453191] [DUMP] reg:[CIM_IPI6_DBG][0x0618], value:[0x00000000]
[ 3180.453195] [DUMP] reg:[CIM_IPI7_DBG][0x061C], value:[0x00000000]
    "fps":32,
    你的fps要设置32的吗
    2024-11-08
    • szc回复费小财:
      不用,设置成30,也是一样的错误 cim ipi0 height error。
      2024-11-08
    • 费小财回复szc:
      你配置20,或者25 试试,另外你 这个模组之前有跑过吗,确定出来的数据尺寸是没问题的吧
      2024-11-08
    • szc回复费小财:
      没有20,25的摄像头配置。 配置fps 6是可以收到图像,宽度和高度同样是配置的3840和2160. 30fps和6fps配置摄像头宽度和高度的寄存器值是相同的。
      2024-11-08
    • szc回复szc:
      有什么办法查soc 收到的height是多少吗
      2024-11-08
    • 只蓝片羽回复szc:
      您好:您这个CIM报错的信息中应该就带有相应的实际收到的宽高信息,可以报错上下发出来看一下。
      2024-11-08
    • szc回复只蓝片羽:
      dmesg中错误信息如下,反复的打印。logcat中没有看到错误信息,附件有logcat log。没有看到宽和高信息
      [ 2888.867740] cim ipi0 height error
      [ 2888.867748] [S0] vio_push_drop_info frame id 2
      [ 2888.881631] [S0][G1]vio_check_drop_info frame id 2, drop_flag 1
      [ 2888.901061] cim ipi0 height error
      [ 2888.901070] [S0] vio_push_drop_info frame id 3
      [ 2888.914951] [S0][G1]vio_check_drop_info frame id 3, drop_flag 1
      [ 2888.934327] cim ipi0 height error
      [ 2888.934336] [S0] vio_push_drop_info frame id 4
      [ 2888.948217] [S0][G1]vio_check_drop_info frame id 4, drop_flag 1
      [ 2888.967766] cim ipi0 height error
      [ 2888.967774] [S0] vio_push_drop_info frame id 5
      [ 2888.981713] [S0][G1]vio_check_drop_info frame id 5, drop_flag 1
      [ 2889.001088] cim ipi0 height error
      [ 2889.001097] [S0] vio_push_drop_info frame id 6
      [ 2889.014974] [S0][G1]vio_check_drop_info frame id 6, drop_flag 1
      [ 2889.034764] cim ipi0 height error
      2024-11-08
    • szc回复szc:
      需要配置什么,获取更详细的日志信息吗
      2024-11-08
    • szc回复szc:
      通过修改摄像头寄存器配置,关闭 statistics 和embedded。然后soc不再显示错误
      2024-11-12
