论坛底层软件图像显示
图像显示
默认569922024-10-29
82
【问题模块】:视频显示、idutx、MIPI TX
【问题描述】:
我们想让J5输出一张图片或者一段视频,MIPI TX0 -> max9295 -> max9296 -> 转HDMI -> LCD屏,参考指导手册的这部分:
但是后面的例程是通过RX3接收:/app/scripts/j5_idu_trloop.sh r3;我们的9296是接到MIPI RX2接口上,只要把r3改成r2就可以了吗?不是的话应该如何实现?
hbplayer需要怎么设置才能采集到图像?
另外如果我想直接通过LCD屏显示图像,有哪些方式可以实现?
    你这个看着还是配置文件不对的,或者你可以看下直接改配置文件试试
    2024-10-30
    • 默认56992回复费小财:
      如何修改配置文件?配置文件在什么位置?
      2024-10-30
    • 费小财回复默认56992:
      跑的时候有个脚本路径,你可以看下json文件的
      2024-11-04
  • 默认56992
    使用/app/scripts/j5_idu_trloop.sh idu0测试报错如下,请问原因是什么?如何修改?
    root@j5dvb:~# /app/scripts/j5_idu_trloop.sh idu0
    >> J5 loopback tx0_idu0yuv_rx0_cim_isp0_pym0_1080p: IDU0(TX0) API0 -> max9295e/max9296 -> RX0
    /dev/idu0_cdev
    J5 2.0 Board Test
    /dev/idu0_cdev
    /dev/idu1_cdev
    /dev/fb0
    /dev/fb1
    /dev/fb2
    /dev/fb3
    Run IPI IDU0 30 API0
    Note: Google Test filter = DisplayTest.test_display_ipi_output
    [==========] Running 1 test from 1 test suite.
    [----------] Global test environment set-up.
    [----------] 1 test from DisplayTest
    Setup DisplayTest test case
    [ RUN ] DisplayTest.test_display_ipi_output
    [DisplayTest] Input yuv file /app/bin/libdisp/./res/video/input_1920x1080_nv12_0.yuv for yuv layer 0.
    [DisplayTest] Input yuv file (null) for yuv layer 1.
    [DisplayTest] Input rgb file /app/bin/libdisp/./res/video/input_1920x1080_argb8888_0.rgb for rgb layer 0.
    [DisplayTest] Input rgb file (null) for rgb layer 1.
    [DisplayTest] Cfg file /app/bin/libdisp/./res/cfg/idu_pre.json.
    [DisplayTest] Frame size = 3110400, Width = 1920, Height = 1080, bytesPerPix = 1.500000. PixFmt = 6.
    [DisplayTest] Enable yuv layer 0.
    [DisplayTest] Frame size = 8294400, Width = 1920, Height = 1080, bytesPerPix = 4.000000. PixFmt = 4.
    [DisplayTest] Enable rgb layer 0.
    [INFO][][src/idu_interface.c:1874] libdisp:##idu config file is /app/bin/libdisp/./res/cfg/idu_pre.json##
    [INFO][][src/idu_interface.c:4272] libdisp:idu_parser_configfile_id ## idu_parser_configfile:0xaaab0035abf0
    [WARNING][][src/idu_interface.c:3997] libdisp:getJsonNodeValue: cant get 'one_shot_en' from json file, set 0 as default!
    [WARNING][][src/idu_interface.c:4202] libdisp:parse_configfile_trigger_cfg: no trigger cfg find from json file!
    [WARNING][][src/idu_interface.c:3997] libdisp:getJsonNodeValue: cant get 'trigger_en' from json file, set 0 as default!
    [WARNING][][src/idu_interface.c:3997] libdisp:getJsonNodeValue: cant get 'trigger_mode' from json file, set 0 as default!
    [WARNING][][src/idu_interface.c:3997] libdisp:getJsonNodeValue: cant get 'offset_us' from json file, set 0 as default!
    [WARNING][][src/idu_interface.c:3997] libdisp:getJsonNodeValue: cant get 'period_us' from json file, set 0 as default!
    [WARNING][][src/idu_interface.c:3997] libdisp:getJsonNodeValue: cant get 'pps_period_sec' from json file, set 0 as default!
    [WARNING][][src/idu_interface.c:3997] libdisp:getJsonNodeValue: cant get 'frame_skip' from json file, set 0 as default!
    [INFO][][src/idu_interface.c:4308] libdisp:idu_parser_configfile_id: idu_parser_configfile end success!
    [INFO][][src/idu_interface.c:3893] libdisp:hb_disp_set_timing_id done!
    [DEBUG][][src/idu_interface.c:2048] libdisp:hb_disp_init_trigger_cfg: not enable, drop.
    [INFO][][src/idu_interface.c:306] idu0 diag thread started
    [INFO][][src/idu_interface.c:2459] libdisp:hb_disp_start: idu start done
    [INFO][][src/idu_interface.c:2757] libdisp:hb_disp_layer_on: layer 0 is on!
    [INFO][][src/idu_interface.c:2818] libdisp:hb_disp_layer_off: layer 1 is off!!
    [INFO][][src/idu_interface.c:2757] libdisp:hb_disp_layer_on: layer 2 is on!
    [INFO][][src/idu_interface.c:2818] libdisp:hb_disp_layer_off: layer 3 is off!!
    set vidoe buffer
    [DisplayTest] Update rgb layer 0 ret = 1.
    Run tx0_idu0yuv_rx0_cim_isp0_pym0_1080p
    Note: Google Test filter = VpmPymTest.vin_pym
    [----------] 1 test from VpmPymTest
    [ RUN ] VpmPymTest.vin_pym
    SetUp VpmPymTest case
    [14:35:26]dump_server_thread_start[287] viomonitor L: wait new socket connect.
    src/vpm_pym_case.cpp:2060: Failure
    Expected equality of these values:
    hb_cam_init(cam_index, cam_cfg_file)
    Which is: -214
    TearDown VpmPymTest case
    [ FAILED ] VpmPymTest.vin_pym (229 ms)
    [----------] 1 test from VpmPymTest (229 ms total)
    [----------] Global test environment tear-down
    [==========] 1 test from 1 test suite ran. (229 ms total)
    [ PASSED ] 0 tests.
    [ FAILED ] 1 test, listed below:
    1 FAILED TEST
    Terminated
    >> J5 loopback tx0_idu0yuv_rx0_cim_isp0_pym0_1080p: FAIL(1)
    2024-10-29
    你好,sample跑起来了吗?
    J5没办法直接接LCD显示屏,因为没有DSI口
    2024-12-17
  • 小助手
    2026-03-10
