论坛算法工具链把模型转换为QAT状态时报错
把模型转换为QAT状态时报错
UtGA6SPbn2024-10-21
120
1. 芯片型号:X3
2. 天工开物开发包 OpenExplorer 版本:horizon_xj3_open_explorer_v2.6.6
3. 问题定位:改造浮点模型并完成训练后,尝试进行Calibration时报错
报错信息如下,X3不支持包含leakyrelu的模型进行prepare_qat_fx吗?
 File "float_calib.py", line 59, in
  calib_model = prepare_qat_fx(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/utils/typeguard.py", line 1076, in wrapper
  retval = func(*args, **kwargs)
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/quantize_fx.py", line 626, in prepare_qat_fx
  model = _prepare_fx(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/quantize_fx.py", line 327, in _prepare_fx
  prepared = quantizer.prepare(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/fx/quantize.py", line 517, in prepare
  return self._prepare(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/fx/quantize.py", line 490, in _prepare
  self._qat_swap_modules(model, hybrid, opset_version)
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/fx/quantize.py", line 83, in _qat_swap_modules
  convert(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/quantize.py", line 766, in convert
  _convert(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/quantize.py", line 952, in _convert
  _convert(
  _convert(
  _convert(
 [Previous line repeated 1 more time]
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/quantize.py", line 962, in _convert
  reassign[name] = swap_module(mod, mapping, swapped_modules)
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/quantize.py", line 878, in swap_module
  new_mod = mapping[type(mod)].from_float(mod)
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/nn/qat/leakyrelu.py", line 53, in from_float
  qat_mod = cls(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/nn/qat/leakyrelu.py", line 27, in __init__
  self.lut = SegmentLUT(
 File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/nn/qat/segment_lut.py", line 34, in __init__
  assert self.activated(), "SegmentLUT only support march in {}!".format(
AssertionError: SegmentLUT only support march in ('bayes', 'bayes-e', 'meta', 'nash', 'nash-e', 'nash-m', 'nash-p')!
  • J6标定问题
    是不支持,参考4.2.7.2.4. torch.nn Module 类,
    2024-10-22
    • UtGA6SPbn回复J6标定问题:
      感谢回复
      2024-10-22
  • J6标定问题
    收到,我们先分析一下
    2024-10-21
