论坛算法工具链BEV模型编译报错
BEV模型编译报错
默认435202024-07-01
94
1. 芯片型号:J5
2. 天工开物开发包 OpenExplorer 版本:horizon_j5_open_explorer_v1.1.74-py38_20240319
3. 问题定位:模型转换、板端部署
4. 问题具体描述:
你好。我在对bev_ipm_efficientnetb0_multitask_nuscenes这个例子修改并做模型编译(PC)时遇到了问题
在scripts下运行命令:
python3 tools/compile_perf.py --config configs/bev/bev_ipm_efficientnetb0_multitask_nuscenes.py --out-dir ./tmp_models/compile --opt 3
在deploy_inputs中直接传入torch.randn 类型的img和points
comile的配置如下
compile_dir = os.path.join(ckpt_dir, "compile")
compile_cfg = dict(
  march=march,
  name=task_name + "_model",
  out_dir=compile_dir,
  hbm=os.path.join(compile_dir, "model.hbm"),
  layer_details=True,
  input_source="pyramid",
  opt="O3",
直接将 "points"传入view_transformer.py中的WrappingTransformer->_spatial_transfom函数
转换时报错
WARNING: model has multiple input tensors that are ('arg0[img]', 'arg0[points]')
INFO: launch 4 threads for optimization
WARNING: the model has 2 inputs, but given 1 sources types. all inputs will be set as the same input type
Network Architecture Error:
Expected data shape range of model input tensor from pyramid "arg0[points]" is [[1, 4096],[1, 65536],[1, 65536],[1, 3]], but the data shape is [2,256,2,256]
  • 默认43520
    points 用placeholder,问题已解决
    2024-07-01
