论坛底层软件J5同一个MIPI RX3接口同时接入4路AR0233摄像头,开始同步触发功能后某1/2路摄像头丢帧
guanjun.shi@uaes2024-05-21
152
1. 硬件获取渠道及型号: 自研
2. 系统镜像版本: platform_sdk_20221018
3. 问题模块:摄像头接入模块
4. 问题描述:
J5 MIPI RX3接口通过96712解串器同时接入4路AR0233 RAW数据格式摄像头,配置帧率25fps,通过TROS Sensor Centor启动;在没有开启摄像头同步触发的情况下,4路摄像头帧率正常,开始同步触发后,发现某1路(有时候2路)摄像头的帧率会下降到12~13帧左右。
通过sysfs查看cimdma输入帧率pipe line 2丢帧:
请问可能是什么原因。
5. 摄像头配置:
root@j5dvb:/map/basic_sample_new/config/sensor_center/camera/j5dvb/RX1_RX3# cat hb_j5dev.json
  "config_number": 1,
  "board_name": "xj5dvb",
  "config_0": {
    "comment": "ar0233 and ovx8b raw12 25fps on host1 max9295-max96712",
    "interface_type": "mipi",
    "lpwm_num":4,
    "lpwm_0":{
      "lpwm_index":0,
      "lpwm_enable":"0x2",
      "trigger_mode":2,
      "offset_us":[
      1,
      1,
      1,
      "period_us":[
      40000,
      40000,
      40000,
      40000
      "duty_us":[
      10,
      10,
      10,
      10
    "lpwm_1":{
      "lpwm_index":1,
      "lpwm_enable":"0x0",
      "trigger_mode":2,
      "offset_us":[
      1,
      1,
      1,
      "period_us":[
      40000,
      40000,
      40000,
      40000
      "duty_us":[
      10,
      10,
      10,
      10
    "lpwm_2":{
      "lpwm_index":2,
      "trigger_mode":2,
      "offset_us":[
      1,
      1,
      1,
      "period_us":[
      40000,
      40000,
      40000,
      40000
      "duty_us":[
      10,
      10,
      10,
      10
    "lpwm_3":{
      "lpwm_index":3,
      "lpwm_enable":"0x8",
      "trigger_mode":2,
      "offset_us":[
      1,
      1,
      1,
      "period_us":[
      40000,
      40000,
      40000,
      40000
      "duty_us":[
      10,
      10,
      10,
      10
    "deserial_num": 2,
    "deserial_0": {
      "deserial_name": "max96712",
      "deserial_addr": "0x29",
      "bus_type": 0,
      "bus_num": 5,
      "mfp_index": 4,
      "power_mode": 0,
      "gpio_pin": [
        487,
        331
      "gpio_level": [
        0,
    "deserial_1": {
      "bus_type": 0,
      "bus_num": 3,
      "mfp_index": 8,
      "power_mode": 1,
      "gpio_pin": [
        487,
        331
      "gpio_level": [
        0,
    "port_number": 6,
    "port_0": {
      "dev_port": 0,
      "bus_type": 0,
      "bus_num": 5,
      "entry_num": 1,
      "serial_addr1": "0xff",
      "serial_addr": "0x41",
      "sensor_addr": "0x11",
      "sensor_name": "ar0233",
      "reg_width": 16,
      "extra_mode": 4,
      "config_index": 1280,
      "sensor_mode": 5,
      "fps": 25,
      "resolution": 1280,
      "deserial_index": 0,
      "deserial_port": 0,
      "data_path": "./config/sensor_center/camera/j5dvb/RX1_RX3/cim_config.json",
      "config_path": "/system/etc/cam/hb_mipi_ar0233_raw12_%dfps_%dP.json"
    "port_1": {
      "dev_port": 1,
      "bus_type": 0,
      "bus_num": 5,
      "entry_num": 1,
      "serial_addr": "0x42",
      "sensor_addr": "0x36",
      "sensor_name": "ovx8b",
      "reg_width": 16,
      "extra_mode": 0,
      "config_index": 262,
      "sensor_mode": 5,
      "fps": 25,
      "resolution": 2160,
      "deserial_port": 1,
      "config_path": "/system/etc/cam/hb_mipi_ovx8b_raw12_%dfps_%dP.json"
    "port_2": {
      "dev_port": 2,
      "bus_type": 0,
      "bus_num": 3,
      "deserial_index": 1,
      "deserial_port": 0,
      "entry_num": 3,
      "sensor_mode": 5,
      "reg_width": 16,
      "extra_mode": 5,
      "fps": 25,
      "resolution": 1280,
      "config_path": "/system/etc/cam/hb_mipi_ar0233_raw12_%dfps_%dP.json",
    "port_3": {
      "dev_port": 3,
      "bus_type": 0,
      "bus_num": 3,
      "deserial_port": 1,
      "entry_num": 3,
      "sensor_addr": "0x12",
      "sensor_mode": 5,
      "reg_width": 16,
      "extra_mode": 5,
      "fps": 25,
      "resolution": 1280,
    "port_4": {
      "dev_port": 4,
      "bus_type": 0,
      "bus_num": 3,
      "deserial_port": 2,
      "dev_port": 1,
      "entry_num": 3,
      "serial_addr": "0x43",
      "sensor_addr": "0x13",
      "sensor_mode": 5,
      "reg_width": 16,
      "extra_mode": 5,
      "fps": 25,
      "resolution": 1280,
    "port_5": {
      "dev_port": 5,
      "bus_type": 0,
      "bus_num": 3,
      "deserial_port": 3,
      "dev_port": 1,
      "entry_num": 3,
      "serial_addr": "0x44",
      "sensor_addr": "0x14",
      "sensor_mode": 5,
      "reg_width": 16,
      "extra_mode": 5,
      "fps": 25,
      "resolution": 1280,
  "pipeline0": {
    "cim": {
      "input": {
        "mipi": {
          "enable": 1,
          "width": 1920,
          "height": 1280,
          "format": 44,
          "rx_index": 1,
          "vc_index": 0,
          "channels": 1,
          "raw16_splict": 0,
          "dbg_clear": 0,
          "y_uv_swap": 0,
          "tag_enable": 0,
          "function": {
            "enable_frame_id": 1,
            "enable_bypass": 0,
            "enable_pattern": 0,
            "hdr_mode": 0,
            "set_init_frame_id": 1,
            "set_bypass_channels": 1
      "output": {
        "pym": {
          "pym0_en": 0,
          "pym1_en": 0
        "isp0": {
          "isp_ch0": 1,
          "isp_ch1": 0,
          "isp_ch2": 0,
          "isp_ch3": 0
        "isp1": {
          "isp_ch0": 0,
          "isp_ch1": 0,
          "isp_ch2": 0,
          "isp_ch3": 0
  "pipeline1": {
    "cim": {
      "input": {
        "mipi": {
          "enable": 1,
          "width": 3840,
          "height": 2160,
          "format": 44,
          "rx_index": 1,
          "vc_index": 1,
          "channels": 1,
          "raw16_splict": 0,
          "dbg_clear": 0,
          "y_uv_swap": 0,
          "tag_enable": 0,
          "function": {
            "enable_bypass": 0,
            "hdr_mode": 0,
      "output": {
        "pym": {
          "pym0_en": 0,
          "pym1_en": 0
        "isp0": {
          "isp_ch0": 0,
          "isp_ch1": 1,
          "isp_ch2": 0,
          "isp_ch3": 0
        "isp1": {
          "isp_ch0": 0,
          "isp_ch1": 0,
          "isp_ch2": 0,
          "isp_ch3": 0
  "pipeline2": {
    "cim_dma": {
      "input": {
        "mipi": {
          "enable": 1,
          "width": 1920,
          "height": 1280,
          "format": 44,
          "rx_index": 3,
          "vc_index": 0,
          "raw16_splict": 0,
          "dbg_clear": 0,
          "y_uv_swap": 0,
          "tag_enable": 0,
          "function": {
            "enable_DMA": 1,
            "pack_mode": 1,
            "enable_bypass": 0,
            "enable_id_decoder": 0,
            "set_bypass_channels": 1,
            "enable_pattern": 0
      "output": {
        "ddr": {
          "enable": 1,
          "format": 44,
          "width": 1920,
          "height": 1280,
          "buf_num": 6,
          "cached": 0,
          "use_ispbuf": 1
  "pipeline3": {
    "cim_dma": {
      "input": {
        "mipi": {
          "enable": 1,
          "width": 1920,
          "height": 1280,
          "format": 44,
          "rx_index": 3,
          "vc_index": 1,
          "raw16_splict": 0,
          "dbg_clear": 0,
          "y_uv_swap": 0,
          "tag_enable": 0,
          "function": {
            "enable_DMA": 1,
            "pack_mode": 1,
            "enable_bypass": 0,
            "enable_pattern": 0
      "output": {
        "ddr": {
          "enable": 1,
          "format": 44,
          "width": 1920,
          "height": 1280,
          "buf_num": 6,
          "cached": 0,
          "use_ispbuf": 1
  "pipeline4": {
    "cim_dma": {
      "input": {
        "mipi": {
          "enable": 1,
          "width": 1920,
          "height": 1280,
          "format": 44,
          "rx_index": 3,
          "vc_index": 2,
          "raw16_splict": 0,
          "dbg_clear": 0,
          "y_uv_swap": 0,
          "tag_enable": 0,
          "function": {
            "enable_DMA": 1,
            "pack_mode": 1,
            "enable_bypass": 0,
            "enable_pattern": 0
      "output": {
        "ddr": {
          "enable": 1,
          "format": 44,
          "width": 1920,
          "height": 1280,
          "buf_num": 6,
          "cached": 0,
          "use_ispbuf": 1
  "pipeline5": {
    "cim_dma": {
      "input": {
        "mipi": {
          "enable": 1,
          "width": 1920,
          "height": 1280,
          "format": 44,
          "rx_index": 3,
          "vc_index": 3,
          "raw16_splict": 0,
          "dbg_clear": 0,
          "y_uv_swap": 0,
          "tag_enable": 0,
          "function": {
            "enable_DMA": 1,
            "pack_mode": 1,
            "enable_bypass": 0,
            "enable_pattern": 0
      "output": {
        "ddr": {
          "enable": 1,
          "format": 44,
          "width": 1920,
          "height": 1280,
          "buf_num": 6,
          "cached": 0,
          "use_ispbuf": 1
  "pipeline0": {
    "isp": {
      "hw_id": 0,
      "ctx_id": 0,
      "sched_mode": 1,
      "hdr_mode": 1,
      "width": 1920,
      "height": 1280,
      "frame_rate": 25,
      "input_crop_enable": 0,
      "input_crop_x": 0,
      "input_crop_y": 0,
      "input_crop_width": 0,
      "input_crop_height": 0,
      "output_crop_enable": 0,
      "output_crop_x": 0,
      "output_crop_y": 0,
      "output_crop_width": 0,
      "output_crop_height": 0,
      "isp_stream_output_format": 1,
      "isp_dma_output_format": 0,
      "calib_mode": 1,
      "calib_lname": "/system/etc/cam/lib_ar0233RGGB_Pwl12_WS_Fov100.so",
      "isp_algo_state": 1
    "pym": {
      "pym_config": {
        "pym_hw_id": 0,
        "pym_mode": 4,
        "output_buf_num": 6,
        "time_out": 2000,
        "y_hor_coeff4": 0,
        "y_hor_coeff3": 1,
        "y_hor_coeff2": 1,
        "y_hor_coeff1": 0,
        "y_hor_coeff0": 0,
        "y_ver_coeff4": 0,
        "y_ver_coeff3": 1,
        "y_ver_coeff2": 1,
        "y_ver_coeff1": 0,
        "y_ver_coeff0": 0,
        "c_hor_coeff4": 0,
        "c_hor_coeff3": 1,
        "c_hor_coeff2": 1,
        "c_hor_coeff1": 0,
        "c_hor_coeff0": 0,
        "c_ver_coeff4": 0,
        "c_ver_coeff3": 1,
        "c_ver_coeff2": 1,
        "c_ver_coeff1": 0,
        "c_ver_coeff0": 0,
        "y_right_shift": 2,
        "c_right_shift": 2
      "pym_ctrl": {
        "source_en": 1,
        "src_uv_bypass": 0,
        "src_in_width": 1920,
        "src_in_height": 1280,
        "src_in_stride_y": 1920,
        "src_in_stride_uv": 1920,
        "src_start_top": 0,
        "src_start_left": 0,
        "src_region_width": 1920,
        "src_region_height": 1280,
        "src_out_stride_y": 1920,
        "src_out_stride_uv": 1920,
        "suffix_hb_val": 68,
        "prefix_hb_val": 2,
        "suffix_vb_val": 20,
        "prefix_vb_val": 2,
        "pixel_num_before_sol": 16,
        "gs_max_layer_en": 5,
        "gs_en": 0,
        "gs_uv_bypass": 0,
        "gauss_info": [
            "gs_start_top": 20,
            "gs_start_left": 50,
            "gs_region_width": 480,
            "gs_region_height": 300,
            "gs_stride_y": 480,
            "gs_stride_uv": 480
            "gs_start_top": 10,
            "gs_start_left": 40,
            "gs_region_width": 240,
            "gs_region_height": 130,
            "gs_stride_y": 240,
            "gs_stride_uv": 240
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_region_width": 130,
            "gs_region_height": 70,
            "gs_stride_y": 130,
            "gs_stride_uv": 130
            "gs_start_top": 10,
            "gs_start_left": 0,
            "gs_region_width": 64,
            "gs_region_height": 32,
            "gs_stride_y": 64,
            "gs_stride_uv": 64
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_region_width": 0,
            "gs_region_height": 0,
            "gs_stride_y": 0,
            "gs_stride_uv": 0
        "bl_max_layer_en": 0,
        "bl_en": 0,
        "bl_uv_bypass": 0,
        "bilinear_info": [
            "bl_start_top": 64,
            "bl_start_left": 32,
            "bl_region_width": 320,
            "bl_region_height": 240,
            "bl_stride_y": 320,
            "bl_stride_uv": 320
            "bl_start_top": 6,
            "bl_start_left": 64,
            "bl_region_width": 240,
            "bl_region_height": 80,
            "bl_stride_y": 240,
            "bl_stride_uv": 240
            "bl_start_top": 16,
            "bl_start_left": 8,
            "bl_region_width": 120,
            "bl_region_height": 60,
            "bl_stride_y": 120,
            "bl_stride_uv": 120
            "bl_start_top": 0,
            "bl_start_left": 12,
            "bl_region_width": 48,
            "bl_region_height": 32,
            "bl_stride_y": 48,
            "bl_stride_uv": 48
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_region_width": 0,
            "bl_region_height": 0,
            "bl_stride_y": 0,
            "bl_stride_uv": 0
        "upscale_roi_en": 1,
        "us_roi_uv_bypass": 0,
        "us_roi_start_left": 0,
        "us_roi_start_top": 0,
        "us_roi_region_width": 480,
        "us_roi_region_height": 240,
        "us_roi_stride_y": 640,
        "us_roi_stride_uv": 640,
        "us_roi_out_width": 640,
        "us_roi_out_height": 480,
        "ds_roi_en": 0,
        "ds_roi_uv_bypass": 0,
        "ds_roi": [
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_start_top": 20,
            "ds_roi_start_left": 50,
            "ds_roi_region_width": 900,
            "ds_roi_region_height": 600,
            "ds_roi_stride_y": 800,
            "ds_roi_stride_uv": 800,
            "ds_roi_out_width": 800,
            "ds_roi_out_height": 480
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_start_left": 16,
            "ds_roi_stride_y": 700,
            "ds_roi_stride_uv": 700,
            "ds_roi_out_width": 700,
            "ds_roi_out_height": 500
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_start_top": 8,
            "ds_roi_start_left": 48,
            "ds_roi_region_width": 720,
            "ds_roi_region_height": 480,
            "ds_roi_stride_y": 640,
            "ds_roi_stride_uv": 640,
            "ds_roi_out_width": 640,
            "ds_roi_out_height": 320
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_start_top": 18,
            "ds_roi_start_left": 24,
            "ds_roi_region_width": 520,
            "ds_roi_region_height": 450,
            "ds_roi_stride_y": 320,
            "ds_roi_stride_uv": 320,
            "ds_roi_out_width": 320,
            "ds_roi_out_height": 160
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_start_top": 0,
            "ds_roi_start_left": 0,
            "ds_roi_stride_y": 512,
            "ds_roi_stride_uv": 512,
            "ds_roi_out_width": 512,
            "ds_roi_out_height": 240
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_start_left": 10,
            "ds_roi_stride_y": 122,
            "ds_roi_stride_uv": 122,
            "ds_roi_out_width": 122,
        "pre_line_int_0_set": 0,
        "pre_line_int_1_set": 0,
        "pre_line_int_2_set": 0,
        "pre_line_int_3_set": 0,
        "pre_line_int_4_set": 0,
        "pre_line_int_5_set": 0,
        "pre_line_int_6_set": 0,
        "pre_line_int_7_set": 0
    "gdc": {
      "input_width": 1920,
      "input_height": 1280,
      "output_width": 1920,
      "output_height": 1280,
      "buf_num": 8,
      "fb_buf_num": 8
  "pipeline1": {
    "isp": {
      "hw_id": 0,
      "ctx_id": 1,
      "sched_mode": 1,
      "hdr_mode": 1,
      "width": 3840,
      "height": 2160,
      "frame_rate": 25,
      "input_crop_x": 0,
      "input_crop_y": 0,
      "output_crop_x": 0,
      "output_crop_y": 0,
      "calib_mode": 1,
      "calib_lname": "/system/etc/cam/lib_x8bRGGB_pwl12_PH_Fov120.so",
      "isp_algo_state": 1
    "pym": {
      "pym_config": {
        "pym_hw_id": 0,
        "pym_mode": 4,
        "time_out": 6000,
        "y_hor_coeff4": 0,
        "y_hor_coeff3": 1,
        "y_hor_coeff2": 1,
        "y_hor_coeff1": 0,
        "y_hor_coeff0": 0,
        "y_ver_coeff4": 0,
        "y_ver_coeff3": 1,
        "y_ver_coeff2": 1,
        "y_ver_coeff1": 0,
        "y_ver_coeff0": 0,
        "c_hor_coeff4": 0,
        "c_hor_coeff3": 1,
        "c_hor_coeff2": 1,
        "c_hor_coeff1": 0,
        "c_hor_coeff0": 0,
        "c_ver_coeff4": 0,
        "c_ver_coeff3": 1,
        "c_ver_coeff2": 1,
        "c_ver_coeff1": 0,
        "c_ver_coeff0": 0,
        "y_right_shift": 2,
        "c_right_shift": 2
      "pym_ctrl": {
        "source_en": 1,
        "src_uv_bypass": 0,
        "src_in_width": 3840,
        "src_in_height": 2160,
        "src_in_stride_y": 3840,
        "src_in_stride_uv": 3840,
        "src_start_top": 0,
        "src_region_width": 3840,
        "src_region_height": 2160,
        "src_out_stride_y": 3840,
        "src_out_stride_uv": 3840,
        "prefix_hb_val": 2,
        "prefix_vb_val": 2,
        "gs_en": 31,
        "gs_uv_bypass": 0,
        "gauss_info": [
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_region_width": 1920,
            "gs_region_height": 1080,
            "gs_stride_y": 1920,
            "gs_stride_uv": 1920
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_region_width": 960,
            "gs_region_height": 540,
            "gs_stride_y": 960,
            "gs_stride_uv": 960
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_region_height": 270,
            "gs_stride_y": 480,
            "gs_stride_uv": 480
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_region_height": 134,
            "gs_stride_y": 240,
            "gs_stride_uv": 240
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_region_width": 120,
            "gs_region_height": 60,
            "gs_stride_y": 128,
            "gs_stride_uv": 128
        "bl_max_layer_en": 5,
        "bl_en": 31,
        "bl_uv_bypass": 0,
        "bilinear_info": [
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_region_width": 1920,
            "bl_region_height": 1080,
            "bl_stride_y": 1920,
            "bl_stride_uv": 1920
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_region_width": 960,
            "bl_region_height": 540,
            "bl_stride_y": 960,
            "bl_stride_uv": 960
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_region_width": 480,
            "bl_region_height": 270,
            "bl_stride_y": 480,
            "bl_stride_uv": 480
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_region_height": 134,
            "bl_stride_y": 240,
            "bl_stride_uv": 240
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_stride_y": 128,
            "bl_stride_uv": 128
        "us_roi_region_width": 1920,
        "us_roi_region_height": 1080,
        "us_roi_stride_y": 1920,
        "us_roi_stride_uv": 1920,
        "us_roi_out_width": 1920,
        "us_roi_out_height": 1080,
        "ds_roi_en": 63,
        "ds_roi": [
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_region_width": 1280,
            "ds_roi_region_height": 720,
            "ds_roi_stride_y": 1280,
            "ds_roi_stride_uv": 1280,
            "ds_roi_out_width": 1280,
            "ds_roi_out_height": 720
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
    "gdc": {
      "input_height": 1080,
      "output_height": 1080,
      "buf_num": 8,
      "fb_buf_num": 8
  "pipeline2": {
    "isp": {
      "hw_id": 1,
      "ctx_id": 4,
      "sched_mode": 1,
      "hdr_mode": 1,
      "width": 1920,
      "height": 1280,
      "frame_rate": 25,
      "input_crop_x": 0,
      "input_crop_y": 0,
      "output_crop_x": 0,
      "output_crop_y": 0,
      "calib_mode": 1,
      "isp_algo_state": 1
    "pym": {
      "pym_config": {
        "pym_hw_id": 1,
        "pym_mode": 4,
        "time_out": 2000,
        "y_hor_coeff4": 0,
        "y_hor_coeff3": 1,
        "y_hor_coeff2": 1,
        "y_hor_coeff1": 0,
        "y_hor_coeff0": 0,
        "y_ver_coeff4": 0,
        "y_ver_coeff3": 1,
        "y_ver_coeff2": 1,
        "y_ver_coeff1": 0,
        "y_ver_coeff0": 0,
        "c_hor_coeff4": 0,
        "c_hor_coeff3": 1,
        "c_hor_coeff2": 1,
        "c_hor_coeff1": 0,
        "c_hor_coeff0": 0,
        "c_ver_coeff4": 0,
        "c_ver_coeff3": 1,
        "c_ver_coeff2": 1,
        "c_ver_coeff1": 0,
        "c_ver_coeff0": 0,
        "y_right_shift": 2,
        "c_right_shift": 2
      "pym_ctrl": {
        "source_en": 1,
        "src_uv_bypass": 0,
        "src_start_top": 0,
        "prefix_hb_val": 2,
        "prefix_vb_val": 2,
        "gs_en": 0,
        "gs_uv_bypass": 0,
        "gauss_info": [
            "gs_start_top": 20,
            "gs_stride_y": 480,
            "gs_stride_uv": 480
            "gs_start_top": 10,
            "gs_stride_y": 240,
            "gs_stride_uv": 240
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 130,
            "gs_stride_uv": 130
            "gs_start_top": 10,
            "gs_start_left": 0,
            "gs_stride_y": 64,
            "gs_stride_uv": 64
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 0,
            "gs_stride_uv": 0
        "bl_en": 0,
        "bl_uv_bypass": 0,
        "bilinear_info": [
            "bl_start_top": 64,
            "bl_stride_y": 320,
            "bl_stride_uv": 320
            "bl_start_top": 6,
            "bl_stride_y": 240,
            "bl_stride_uv": 240
            "bl_start_top": 16,
            "bl_start_left": 8,
            "bl_stride_y": 120,
            "bl_stride_uv": 120
            "bl_start_top": 0,
            "bl_stride_y": 48,
            "bl_stride_uv": 48
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_stride_y": 0,
            "bl_stride_uv": 0
        "ds_roi_en": 0,
        "ds_roi": [
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
    "gdc": {
      "buf_num": 8,
      "fb_buf_num": 8
  "pipeline3": {
    "isp": {
      "hw_id": 1,
      "ctx_id": 5,
      "sched_mode": 1,
      "hdr_mode": 1,
      "width": 1920,
      "height": 1280,
      "frame_rate": 25,
      "input_crop_x": 0,
      "input_crop_y": 0,
      "output_crop_x": 0,
      "output_crop_y": 0,
      "calib_mode": 1,
      "isp_algo_state": 1
    "pym": {
      "pym_config": {
        "pym_hw_id": 1,
        "pym_mode": 4,
        "time_out": 2000,
        "y_hor_coeff4": 0,
        "y_hor_coeff3": 1,
        "y_hor_coeff2": 1,
        "y_hor_coeff1": 0,
        "y_hor_coeff0": 0,
        "y_ver_coeff4": 0,
        "y_ver_coeff3": 1,
        "y_ver_coeff2": 1,
        "y_ver_coeff1": 0,
        "y_ver_coeff0": 0,
        "c_hor_coeff4": 0,
        "c_hor_coeff3": 1,
        "c_hor_coeff2": 1,
        "c_hor_coeff1": 0,
        "c_hor_coeff0": 0,
        "c_ver_coeff4": 0,
        "c_ver_coeff3": 1,
        "c_ver_coeff2": 1,
        "c_ver_coeff1": 0,
        "c_ver_coeff0": 0,
        "y_right_shift": 2,
        "c_right_shift": 2
      "pym_ctrl": {
        "source_en": 1,
        "src_uv_bypass": 0,
        "src_start_top": 0,
        "prefix_hb_val": 2,
        "prefix_vb_val": 2,
        "gs_en": 0,
        "gs_uv_bypass": 0,
        "gauss_info": [
            "gs_start_top": 20,
            "gs_stride_y": 480,
            "gs_stride_uv": 480
            "gs_start_top": 10,
            "gs_stride_y": 240,
            "gs_stride_uv": 240
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 130,
            "gs_stride_uv": 130
            "gs_start_top": 10,
            "gs_start_left": 0,
            "gs_stride_y": 64,
            "gs_stride_uv": 64
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 0,
            "gs_stride_uv": 0
        "bl_en": 0,
        "bl_uv_bypass": 0,
        "bilinear_info": [
            "bl_start_top": 64,
            "bl_stride_y": 320,
            "bl_stride_uv": 320
            "bl_start_top": 6,
            "bl_stride_y": 240,
            "bl_stride_uv": 240
            "bl_start_top": 16,
            "bl_start_left": 8,
            "bl_stride_y": 120,
            "bl_stride_uv": 120
            "bl_start_top": 0,
            "bl_stride_y": 48,
            "bl_stride_uv": 48
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_stride_y": 0,
            "bl_stride_uv": 0
        "ds_roi_en": 0,
        "ds_roi": [
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
    "gdc": {
      "buf_num": 8,
      "fb_buf_num": 8
  "pipeline4": {
    "isp": {
      "hw_id": 1,
      "ctx_id": 6,
      "sched_mode": 1,
      "hdr_mode": 1,
      "width": 1920,
      "height": 1280,
      "frame_rate": 25,
      "input_crop_x": 0,
      "input_crop_y": 0,
      "output_crop_x": 0,
      "output_crop_y": 0,
      "calib_mode": 1,
      "isp_algo_state": 1
    "pym": {
      "pym_config": {
        "pym_hw_id": 1,
        "pym_mode": 4,
        "time_out": 2000,
        "y_hor_coeff4": 0,
        "y_hor_coeff3": 1,
        "y_hor_coeff2": 1,
        "y_hor_coeff1": 0,
        "y_hor_coeff0": 0,
        "y_ver_coeff4": 0,
        "y_ver_coeff3": 1,
        "y_ver_coeff2": 1,
        "y_ver_coeff1": 0,
        "y_ver_coeff0": 0,
        "c_hor_coeff4": 0,
        "c_hor_coeff3": 1,
        "c_hor_coeff2": 1,
        "c_hor_coeff1": 0,
        "c_hor_coeff0": 0,
        "c_ver_coeff4": 0,
        "c_ver_coeff3": 1,
        "c_ver_coeff2": 1,
        "c_ver_coeff1": 0,
        "c_ver_coeff0": 0,
        "y_right_shift": 2,
        "c_right_shift": 2
      "pym_ctrl": {
        "source_en": 1,
        "src_uv_bypass": 0,
        "src_start_top": 0,
        "prefix_hb_val": 2,
        "prefix_vb_val": 2,
        "gs_en": 0,
        "gs_uv_bypass": 0,
        "gauss_info": [
            "gs_start_top": 20,
            "gs_stride_y": 480,
            "gs_stride_uv": 480
            "gs_start_top": 10,
            "gs_stride_y": 240,
            "gs_stride_uv": 240
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 130,
            "gs_stride_uv": 130
            "gs_start_top": 10,
            "gs_start_left": 0,
            "gs_stride_y": 64,
            "gs_stride_uv": 64
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 0,
            "gs_stride_uv": 0
        "bl_en": 0,
        "bl_uv_bypass": 0,
        "bilinear_info": [
            "bl_start_top": 64,
            "bl_stride_y": 320,
            "bl_stride_uv": 320
            "bl_start_top": 6,
            "bl_stride_y": 240,
            "bl_stride_uv": 240
            "bl_start_top": 16,
            "bl_start_left": 8,
            "bl_stride_y": 120,
            "bl_stride_uv": 120
            "bl_start_top": 0,
            "bl_stride_y": 48,
            "bl_stride_uv": 48
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_stride_y": 0,
            "bl_stride_uv": 0
        "ds_roi_en": 0,
        "ds_roi": [
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
    "gdc": {
      "buf_num": 8,
      "fb_buf_num": 8
  "pipeline5": {
    "isp": {
      "hw_id": 1,
      "ctx_id": 7,
      "sched_mode": 1,
      "hdr_mode": 1,
      "width": 1920,
      "height": 1280,
      "frame_rate": 25,
      "input_crop_x": 0,
      "input_crop_y": 0,
      "output_crop_x": 0,
      "output_crop_y": 0,
      "calib_mode": 1,
      "isp_algo_state": 1
    "pym": {
      "pym_config": {
        "pym_hw_id": 1,
        "pym_mode": 4,
        "time_out": 2000,
        "y_hor_coeff4": 0,
        "y_hor_coeff3": 1,
        "y_hor_coeff2": 1,
        "y_hor_coeff1": 0,
        "y_hor_coeff0": 0,
        "y_ver_coeff4": 0,
        "y_ver_coeff3": 1,
        "y_ver_coeff2": 1,
        "y_ver_coeff1": 0,
        "y_ver_coeff0": 0,
        "c_hor_coeff4": 0,
        "c_hor_coeff3": 1,
        "c_hor_coeff2": 1,
        "c_hor_coeff1": 0,
        "c_hor_coeff0": 0,
        "c_ver_coeff4": 0,
        "c_ver_coeff3": 1,
        "c_ver_coeff2": 1,
        "c_ver_coeff1": 0,
        "c_ver_coeff0": 0,
        "y_right_shift": 2,
        "c_right_shift": 2
      "pym_ctrl": {
        "source_en": 1,
        "src_uv_bypass": 0,
        "src_start_top": 0,
        "prefix_hb_val": 2,
        "prefix_vb_val": 2,
        "gs_en": 0,
        "gs_uv_bypass": 0,
        "gauss_info": [
            "gs_start_top": 20,
            "gs_stride_y": 480,
            "gs_stride_uv": 480
            "gs_start_top": 10,
            "gs_stride_y": 240,
            "gs_stride_uv": 240
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 130,
            "gs_stride_uv": 130
            "gs_start_top": 10,
            "gs_start_left": 0,
            "gs_stride_y": 64,
            "gs_stride_uv": 64
            "gs_start_top": 0,
            "gs_start_left": 0,
            "gs_stride_y": 0,
            "gs_stride_uv": 0
        "bl_en": 0,
        "bl_uv_bypass": 0,
        "bilinear_info": [
            "bl_start_top": 64,
            "bl_stride_y": 320,
            "bl_stride_uv": 320
            "bl_start_top": 6,
            "bl_stride_y": 240,
            "bl_stride_uv": 240
            "bl_start_top": 16,
            "bl_start_left": 8,
            "bl_stride_y": 120,
            "bl_stride_uv": 120
            "bl_start_top": 0,
            "bl_stride_y": 48,
            "bl_stride_uv": 48
            "bl_start_top": 0,
            "bl_start_left": 0,
            "bl_stride_y": 0,
            "bl_stride_uv": 0
        "ds_roi_en": 0,
        "ds_roi": [
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
            "ds_roi_layer": 0,
            "ds_roi_sel": 0,
    "gdc": {
      "buf_num": 8,
      "fb_buf_num": 8
root@j5dvb:/system/etc/cam# cat hb_mipi_ar0233_raw12_25fps_1280P.json
    "mipi": {
        "base": {
            "lane": 4,
            "datatype":"0x2c",
            "mclk": 24,
            "mipiclk": 4800,
            "fps": 25,
            "width": 2048,
            "height": 1280,
            "linelenth": 2400,
            "framelenth": 1700,
            "settle": 30
        "host": {
            "enable": 1,
            "hsa": 0,
            "hbp": 0,
            "hsd": 0,
            "vc_num": 4,
            "vc0_index": 0,
            "vc1_index": 1,
            "vc2_index": 2,
            "vc3_index": 3
        "dev": {
            "enable": 1,
            "vpg": 0,
            "ipi_lines": 0
  • TROS.Assist
    您好,请确认以下两项:
    1.先确认一下4路sensor使用的同步信号是那一路,你上传的配置中lpwm_enable并没有全部打开,可以先尝试全部打开看是否帧率正常。 "lpwm_enable":"0xf"。
    2.全部打开后,可以量取sedes的fsync pin,看波形周期是否符合预期,不符合预期就需要去检查sedes和sensor的fsync 配置。
    2024-05-21
  • guanjun.shi@uaes
    目前RX3上采用的同步信号为J5_CAM15_TRIG信号,连到了lpwm3 Channel3。该同步信号已经通过示波器确认正常。目前的驱动里似乎没有去配置FSYNC PIN的输出。
    通过一系列测试发现,该现象似乎有摄像头的连接线有关系,再重新连接所有摄像头的接线后,故障消失了。。。。。
    怀疑是Serlizer与Deserlizer之间的通信链路上可能不是很稳定,在之前的使用中,也遇到过手触碰到摄像本体,或者在移动摄像头的时候发生驱动软件报错,但放开后又恢复的现象,但当时没有关注帧率是否下降。
    请问这个是否软件配置上有什么地方需要配置,以提高链路的稳定性?
    2024-05-22
  • TROS.Assist
    通信链路不稳定一般是硬件问题,信道质量较差导致的,软件上面可以尝试延长link_lock的检测时间。
    2024-05-22
