论坛底层软件样例执行时,J5 板子异常断连接
样例执行时,J5 板子异常断连接
默认506242024-05-21
107
1. 硬件获取渠道及型号:
2. 系统镜像版本: https://developer.horizon.auto/developerForum?fullPath=/home/community/bbsdetail?bid=580381685466353664
3. 问题模块: tros.a 中提供的apa 样例执行失败
4. 问题描述:
root@j5dvb:/userdata/apa/output/apa# route add -net 224.0.0.0 netmask 255.255.255.0 eth0
root@j5dvb:/userdata/apa/output/apa# export LD_LIBRARY_PATH=./bin:$LD_LIBRARY_PATH
root@j5dvb:/userdata/apa/output/apa# ./init.sh -l
j5dvb
[W][1669][01-01][08:21:13:118][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can0]
[W][1669][01-01][08:21:13:118][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can1]
[W][1669][01-01][08:21:13:118][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can2]
[W][1669][01-01][08:21:13:118][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can3]
[W][1686][01-01][08:21:13:329][types.cpp:489][mainboard2][communication] communication is already been initialized!!
[W][1686][01-01][08:21:13:330][adapter_manager.cc:377][mainboard2][sensor_center] communication has been init: communication has been initialized
[W][1686][01-01][08:21:13:331][adapter_manager.cc:204][mainboard2][sensor_center] adapter /bole/event/sensors is not enable.
[W][1686][01-01][08:21:13:331][adapter_manager.cc:204][mainboard2][sensor_center] adapter /bole/command/sensors is not enable.
[W][1686][01-01][08:21:13:346][separatedthread_executor.cpp:137][mainboard2][default] Check thread name length exceed the maximum value(15), intercept thread name is: sc_TimerM_check
[W][1686][01-01][08:21:13:347][separatedthread_executor.cpp:150][mainboard2][default] Exec thread name length exceed the maximum value(15), intercept thread name is: sc_TimerMa_exec
[W][1686][01-01][08:21:13:347][sensor_center.cpp:1958][mainboard2][sensor_center] get cmd adapter: /bole/command/sensors failed, command_adapter is disable
[W][1686][01-01][08:21:13:349][camera.cpp:225][mainboard2][sensor_center] Cannot find null
[W][1686][01-01][08:21:13:400][camera.cpp:225][mainboard2][sensor_center] Cannot find null
[W][1686][01-01][08:21:13:401][camera.cpp:225][mainboard2][sensor_center] Cannot find null
[W][1686][01-01][08:21:13:408][sensor_module.cpp:139][mainboard2][apa] [1686] - sub_camera_4 disabled
[EasyDNN]: EasyDNN version = 1.7.3_(1.17.3 DNN)
[BPU_PLAT]BPU Platform Version(1.3.3)!
Connection reset by 192.168.1.10 port 22
板子自动断连接,样例没有正常执行下去
5. 示例代码:
评论6
  • TROS.Assist
    请问你们的使用的SDK是哪个版本
    可以参考:https://developer.horizon.auto/developerForum?fullPath=/home/community/bbsdetail?bid=533471443514531840
    跑一下4camera_sample。
    2024-05-21
  • 默认50624
    cat /etc/version
    gonghongyan@soc debug 20230317-134731
    root@j5dvb:~# cat /proc/version
    Linux version 5.10.59-rt52 (gonghongyan@soc) (aarch64-linux-gnu-gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #4 SMP PREEMPT_RT Fri Mar 17 13:49:41 CST 2023
    基于天准提供的包TZTEK_TROS_R3.0_v1.3.0_Release 中提供的样例跑的
    2024-05-22
  • TROS.Assist
    麻烦按照参考文档跑一下
    2024-05-22
  • 默认50624
    咨询了天准,他们那也没有4camera_sample样例,只有apn
    2024-05-24
  • TROS.Assist
    这个需要您和天准沟通。j5开发板上应该是好的,但不确定硬件是否一样
    2024-05-30
  • TROS.Assist
    您好,鉴于长时间未收到您的答复,我们暂时将该问题做关闭处理,如您仍有相同问题,请重新开贴子进行提问,祝您工作愉快!
    2024-06-04
