论坛算法工具链J5板子BSP镜像版本查询 ,apa 样例部署到板子上运行失败
默认506242024-05-20
142
1. 硬件获取渠道及型号:
2. 系统镜像版本: cat /etc/version
gonghongyan@soc debug 20230317-134731
root@j5dvb:~# cat /proc/version
Linux version 5.10.59-rt52 (gonghongyan@soc) (aarch64-linux-gnu-gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #4 SMP PREEMPT_RT Fri Mar 17 13:49:41 CST 2023
3. 问题模块: J5板子BSP镜像版本查询
4. 问题描述: J5板子BSP镜像版本查询
5. 示例代码: apa 样例执行失败
第一次执行:
 ./init.sh -l
[W][1632][01-01][08:04:02:272][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can0]
[W][1632][01-01][08:04:02:272][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can1]
[W][1632][01-01][08:04:02:272][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can2]
[W][1632][01-01][08:04:02:272][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can3]
[E][1632][01-01][08:04:02:272][udp_server_unix.cpp:119][mainboard2][communication] UdpServerMulticastUnix::Init IP_ADD_MEMBERSHIP failed 19. You need to execute the command in the terminal first: route add -net 224.0.0.0 netmask 255.255.255.0 eth0(device network card name)!!!
[E][1632][01-01][08:04:02:272][udp_server_unix.cpp:228][mainboard2][communication] UdpServerUnix::Init MakeSocket failed. udp_server_type_ 0
第二次 增添路由,看脚本J5并没有增添路由,只是在J3情况下增添,为规避错误特增添路由,执行弹出如下错误,且执行后与主机PC断连接,查看所连接网口地址已改变为初始值
root@j5dvb:/userdata/sample_j5/apa# route add -net 224.0.0.0 netmask 255.255.255.0 eth0
root@j5dvb:/userdata/sample_j5/apa# ./init.sh -l
j5dvb
[W][1644][01-01][08:07:45:183][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can0]
[W][1644][01-01][08:07:45:183][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can1]
[W][1644][01-01][08:07:45:183][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can2]
[W][1644][01-01][08:07:45:183][discovery_utils.cpp:249][mainboard2][communication] if_addr_struct->ifa_addr is NULL and its ifa name is [can3]
[W][1661][01-01][08:07:45:501][types.cpp:489][mainboard2][communication] communication is already been initialized!!
[W][1661][01-01][08:07:45:502][adapter_manager.cc:377][mainboard2][sensor_center] communication has been init: communication has been initialized
[W][1661][01-01][08:07:45:503][adapter_manager.cc:204][mainboard2][sensor_center] adapter /bole/event/sensors is not enable.
[W][1661][01-01][08:07:45:503][adapter_manager.cc:204][mainboard2][sensor_center] adapter /bole/command/sensors is not enable.
[W][1661][01-01][08:07:45:509][separatedthread_executor.cpp:137][mainboard2][default] Check thread name length exceed the maximum value(15), intercept thread name is: sc_TimerM_check
[W][1661][01-01][08:07:45:509][separatedthread_executor.cpp:150][mainboard2][default] Exec thread name length exceed the maximum value(15), intercept thread name is: sc_TimerMa_exec
[W][1661][01-01][08:07:45:510][sensor_center.cpp:1958][mainboard2][sensor_center] get cmd adapter: /bole/command/sensors failed, command_adapter is disable
[W][1661][01-01][08:07:45:511][camera.cpp:225][mainboard2][sensor_center] Cannot find null
[W][1661][01-01][08:07:45:564][camera.cpp:225][mainboard2][sensor_center] Cannot find null
[W][1661][01-01][08:07:45:565][camera.cpp:225][mainboard2][sensor_center] Cannot find null
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_4 disabled
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_5 disabled
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_6 disabled
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_7 disabled
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_8 disabled
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_9 disabled
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_10 disabled
[W][1661][01-01][08:07:45:573][sensor_module.cpp:139][mainboard2][apa] [1661] - sub_camera_11 disabled
[EasyDNN]: EasyDNN version = 1.7.3_(1.17.3 DNN)
[BPU_PLAT]BPU Platform Version(1.3.3)!
  • luoyuhao
    我在使用天准的域控时遇到了同样的问题,我的解决方法是输入 route add -net 224.0.0.0 netmask 255.255.255.0 eth1
    2024-05-24
  • 默认50624
    第二次执行,路由已添加
    2024-05-27
