论坛算法工具链sensor center接入真实传感器,Hviz无法可视化
xiangdong.tan@uaes2024-03-15
258
20
TROS-SDK-1.5.6
J5 BSP版本:platform_sdk_20221018
通过说明文档,配置.json,其具体参数如下:
sensor_global.json
  "Sensors": [
      "sensor_name": "dummy_sensor",
      "plugin_info": {
        "libraries": [
          "./lib/libdummy_sensor.so"
        "property_file": "dummy_sensor/dummy_sensor.json",
        "class_name": "DummySensor"
      "frame_adapter_name": [
        "dummy_sensor"
      "raw_adapter_name": [
        "dummy_sensor_raw"
      "run_mode": {
        "run_mode_type": 0,
        "run_mode_type_commit": "0: online_mode, 1: feedback_mode",
        "online_mode": {
          "ts_src": 1,
          "ts_src_commit": "sync_ts source, 0:sensor, 1:os",
          "raw_msg_enable": false,
          "raw_msg_enable_commit": "save raw data which has not processed for recording file"
        "feedback_mode": {
          "ts_src": 2,
          "ts_src_commit": "msg param source, 1:os, 2:pack",
          "feedback_msg_mode": 1,
          "feedback_msg_mode_commit": "feedback mode, 0:pub_sub, 1:req_rep"
      "enable": false
      "sensor_name": "lidar_0",
      "plugin_info": {
        "libraries": [
          "./lib/libpandar128.so"
        "class_name": "Pandar128",
        "property_file": "lidar/pandar128_roof.json"
        "lidar_0"
        "lidar_raw_0"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
          "feedback_msg_mode": 0,
      "hal_info": {
        "hw_type": "eth",
        "packet_buffer_count": 100,
        "hal_clear_buffer_flag": true,
        "hal_clear_buffer_flag_commit": "clear input buffer when start, true:clear buffer, false:do not clear buffer",
        "hal_read_timeout_mode": 0,
        "hal_read_timeout_mode_commit": "packet trigger mode: 0:check every 1ms with sleep, 1:condition notice",
        "hal_read_timeout_ms": 1000,
        "hal_read_timeout_ms_commit": "when ring buffer is empty,wait time(ms)",
        "eth": {
          "max_packet_size": 1500,
          "buffer_size": 1024,
          "buffer_size_commit": "socket recv buffer size,unit KB",
          "network_protocol": "udp",
          "Network protocol_comment": "tcp/udp",
          "system_read_timeout_ms": 10000,
          "src_ip": "192.168.1.201",
          "dest_ip": "192.168.1.102",
          "port": [
            2368,
            10110
        "raw_socket": {
          "port": [
            2368,
            10110
          "block_timeout_ms": 2,
          "block_num": 128,
          "network_card": "eth0"
      "enable": false
      "plugin_info": {
        "libraries": [
          "./lib/libat128.so"
        "class_name": "At128",
        "property_file": "lidar/at128_front.json"
        "lidar_0"
        "lidar_raw_0"
      "raw_adapter_name_commit": "support multi-topic msg receive in feedback_mode",
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "eth",
        "eth": {
          "src_ip": "192.168.1.204",
          "port": [
            2371,
            10000
        "raw_socket": {
          "port": [
            2371,
            10000
          "block_num": 128,
      "enable": false
      "sensor_name": "lidar_1",
      "plugin_info": {
        "libraries": [
          "./lib/librobosense_m1.so"
        "property_file": "lidar/robosenseM1_front.json",
        "class_name": "RobosenseM1"
        "lidar_1"
        "lidar_raw_1"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "eth",
        "eth": {
          "src_ip": "192.168.1.200",
          "port": [
            6699,
            7788
        "raw_socket": {
          "port": [
            2368,
            10110
          "block_num": 128,
      "enable": false
      "sensor_name": "radar_0",
      "plugin_info": {
        "libraries": [
          "./lib/libradar.so"
        "property_file": "radar/radar_0.json",
        "class_name": "RadarDrv"
        "radar_0"
        "radar_raw_0"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "enable": false
      "sensor_name": "radar_1",
      "plugin_info": {
        "libraries": [
          "./lib/libradar.so"
        "property_file": "radar/radar_1.json",
        "radar_1"
        "radar_raw_1"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "enable": false
      "sensor_name": "camera_0",
      "plugin_info": {
        "libraries": [
          "./lib/libcamera.so"
        "property_file": "camera/camera_0.json",
        "class_name": "Camera"
        "camera_0"
        "camera_image_0"
      "group_info": {
        "group_adapter_name": "camera_0",
        "group_adapter_name_commit": "If the group_adapter_name is the same as the frame_adapter_name, pub msg from this sensor",
        "group_id": 0,
        "group_sync_timeout": 50,
        "group_sync_timeout_commit": "get vio data timeout for sync-mult-chan, unit ms",
        "group_sync_difftime": 10,
        "group_sync_difftime_commit": "If the time difference is less than the set value, sync success, unit ms",
        "group_sync_mode": 0,
        "group_sync_mode_commit": "0:msg without sync, 1:discard the no sync frame, 2:interpolation the no sync frame",
        "group_enable": false,
        "group_enable_commit": "group frame switch"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "enable": true
      "sensor_name": "camera_1",
      "plugin_info": {
        "libraries": [
        "property_file": "camera/camera_1.json",
        "camera_1"
        "camera_image_1"
      "group_info": {
        "group_id": 0,
        "group_enable": true,
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "enable": false
      "sensor_name": "camera_2",
      "plugin_info": {
        "libraries": [
        "property_file": "camera/camera_2.json",
        "camera_2"
        "camera_image_2"
      "group_info": {
        "group_id": 0,
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "enable": false
      "sensor_name": "camera_3",
      "plugin_info": {
        "libraries": [
        "property_file": "camera/camera_3.json",
        "camera_3"
        "camera_image_3"
      "group_info": {
        "group_id": 0,
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "enable": false
      "sensor_name": "gnss_0",
      "plugin_info": {
        "libraries": [
          "./lib/libf9k.so"
        "property_file": "gps/gnss_0.json",
        "class_name": "F9kGnss"
        "gnss_0"
        "gnss_raw_0"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "uart",
        "packet_buffer_count": 1000,
        "hal_read_timeout_mode": 1,
        "uart": {
          "dev_node": "/dev/ttyS3",
          "baud_rate": 921600,
          "system_read_timeout_ms": 100,
          "max_packet_size": 128
      "enable": false
      "sensor_name": "gnss_1",
      "plugin_info": {
        "libraries": [
          "./lib/libub482.so"
        "property_file": "gps/gnss_1.json",
        "class_name": "UB482"
        "gnss_1"
        "gnss_raw_1"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "uart",
        "uart": {
          "dev_node": "/dev/ttyUSB0",
          "baud_rate": 115200,
      "enable": false
      "sensor_name": "imu_0",
      "plugin_info": {
        "libraries": [
          "./lib/libf9k.so"
        "property_file": "imu/imu_0.json",
        "class_name": "F9kImu"
        "imu_0"
        "imu_raw_0"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "uart",
        "uart": {
      "enable": false
      "sensor_name": "imu_1",
      "plugin_info": {
        "libraries": [
          "./lib/libf9k.so"
        "property_file": "imu/imu_1.json",
        "imu_1"
        "imu_raw_1"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "uart",
        "uart": {
      "enable": false
      "sensor_name": "imu_2",
      "plugin_info": {
        "libraries": [
          "./lib/libiam20685.so"
        "property_file": "imu/imu_2.json",
        "class_name": "Iam20685"
        "imu_2"
        "imu_raw_2"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "event",
        "event": {
          "sysfs_path": "/sys/devices/virtual/input/iam20685-accel",
          "iam_odr_hz": 50
      "enable": false
      "sensor_name": "imu_3",
      "plugin_info": {
        "libraries": [
          "./lib/libasm330.so"
        "property_file": "imu/imu_3.json",
        "class_name": "ASM330"
        "imu_3"
        "imu_raw_3"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "spi",
        "spi": {
          "max_packet_size": 128,
          "dev_node": "/dev/spidev3.0",
          "speeds": 10000000,
          "mode": 0,
          "bits_per_word": 8
      "enable": false
      "sensor_name": "uss_0",
      "plugin_info": {
        "libraries": [
          "./lib/libuss.so"
        "property_file": "uss/uss_0.json",
        "class_name": "USS"
        "uss_0"
        "uss_raw_0"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "hal_info": {
        "hw_type": "eth",
        "eth": {
          "max_packet_size": 2048,
          "network_protocol": "tcp",
          "system_read_timeout_ms": 1000,
          "src_ip": "192.168.2.50",
          "dest_ip": "127.0.0.1",
          "port": [
            7600
      "enable": false
      "sensor_name": "mic_0",
      "plugin_info": {
        "libraries": [
          "./lib/libmic.so"
        "property_file": "mic/mic_0.json",
        "class_name": "MIC"
        "mic_0"
        "mic_raw_0"
      "run_mode": {
        "run_mode_type": 0,
        "online_mode": {
          "ts_src": 1,
        "feedback_mode": {
          "ts_src": 2,
      "enable": false
  "heartbeat": {
    "enable": false,
    "heartbeat_adapter_name": "/bole/heartbeat/sensors",
    "period_ms": 1000
  "sched_policy_enhancement": {
    "enable": false,
    "sched_policy": 2,
    "sched_policy_commit": "set scheduling policy,1:SCHED_FIFO,2:SCHED_RR",
    "sched_priority": -1,
    "sched_priority_commit": "set scheduling priority,-1:highest priority,1:lowest priority,2:priority value(0-99),The higher value, the higher priority",
    "sched_policy_effective_mode": 1,
    "sched_policy_effective_mode_commit": "the mode of effective of scheduling policy,0:thread,1:process"
  "fps_control": {
    "enable": false,
    "fps_control_adapter_name": [
      "camera_0",
      "camera_1"
    "fps": [
      10,
      20
  "monitor_timeout_ms": 10000,
  "fps_print_interval_ms": 3000,
  "diag_adapter_name": "/bole/event/sensors",
  "command_adapter_name": "/bole/command/sensors",
  "communication_path": "adapter/communication.json",
  "adapter_path": "adapter/adapter.json",
  "adapter_path_comment": "absolute path for adapter.json",
  "time_cost_en": false,
  "process_name": "sensor_center",
  "schedule_group_path": "../sensor_center_module/schedule_config.json",
  "save_backtrace": false,
  "log_mode": 0,
  "log_mode_comment": "0-file sink, 1-tmg sink, 2-sd sink",
  "log_file_save_path": "./sensor_centor.log",
  "log_dump_path": "./log/",
  "log_file_count": 5,
  "log_file_size": 10,
  "log_level": 2
adapter.json
  "adapter_message": [
      "adapter_name": "/bole/heartbeat/sensors",
      "topic_name": "/bole/heartbeat/sensors",
      "enable_pub": true,
      "enable_sub": false,
      "messagedomainid": 0,
      "messagetrantype": 2,
      "messagetrantype_comment": "2 is zmq_tcp, 4 is zmq_ipc",
      "messagenum": 20,
      "participantattr": 3,
      "enable": false
      "adapter_name": "/bole/event/sensors",
      "topic_name": "/bole/event/sensors",
      "enable_pub": true,
      "messagetrantype_comment": "0 is hybrid, 2 is zmq_tcp, 4 is zmq_ipc",
      "messagenum": 20,
      "participantattr": 1,
      "enable": true
      "adapter_name": "/bole/command/sensors",
      "topic_name": "/bole/command/sensors",
      "enable_pub": false,
      "enable_client": false,
      "enable_service": true,
      "messagenum": 20,
      "participantattr": 2,
      "enable": true
      "adapter_name": "dummy_sensor",
      "topic_name": "dummy_sensor",
      "enable_pub": true,
      "enable_service": false,
      "messagenum": 20,
      "plugin_info": {
        "class_name": "hobot::sensors::Adapter"
      "enable": false
      "enable_client": true,
      "messagenum": 20,
      "participantattr": 8,
      "plugin_info": {
      "enable": false
      "adapter_name": "dummy_sensor_raw",
      "topic_name": "dummy_sensor#0",
      "enable_sub": true,
      "messagenum": 20,
      "participantattr": 4,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "lidar_0",
      "topic_name": "lidar_0",
      "enable_pub": true,
      "messagetrantype_comment": "0 is hybrid, 2 is zmq_tcp, 4 is zmq_ipc, 6 is shared-memory",
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "lidar_raw_0",
      "topic_name": "lidar_raw_0#0",
      "enable_sub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "lidar_raw_1",
      "topic_name": "lidar_raw_1#0",
      "enable_sub": true,
      "messagenum": 20,
      "participantattr": 5,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "lidar_1",
      "topic_name": "lidar_1",
      "enable_pub": true,
      "messagetrantype_comment": "2 is zmq_tcp, 4 is zmq_ipc, 6 is shared_memory",
      "messagenum": 8,
      "participantattr_comment": "-1 is without participantattr",
      "plugin_info": {
      "enable": false
      "enable_sub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "radar_0",
      "topic_name": "radar_0",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "radar_raw_0",
      "topic_name": "radar_raw_0#0",
      "enable_sub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "camera_0",
      "topic_name": "camera_0",
      "enable_pub": true,
      "messagetrantype_comment": "6 is shared-memory",
      "messagenum": 1,
      "plugin_info": {
      "enable": true
      "enable_pub": true,
      "messagenum": 1,
      "plugin_info": {
      "enable": false
      "adapter_name": "camera_image_0",
      "topic_name": "camera_image_0#0",
      "enable_sub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "enable_pub": true,
      "messagenum": 0,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "camera_1",
      "topic_name": "camera_1",
      "enable_pub": true,
      "enable_sub": true,
      "messagetrantype": 1,
      "messagetrantype_comment": "1 is inter-commnication",
      "messagenum": 1,
      "plugin_info": {
      "enable": false
      "adapter_name": "gnss_0",
      "topic_name": "/sensor/gnss",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "gnss_raw_0",
      "topic_name": "gnss_raw_0#0",
      "enable_sub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "gnss_1",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "imu_0",
      "topic_name": "/sensor/imu",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "imu_raw_0",
      "topic_name": "imu_raw_0#0",
      "enable_sub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "imu_1",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "imu_2",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "imu_3",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "uss_0",
      "topic_name": "uss_0",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "uss_raw_0",
      "topic_name": "uss_raw_0#0",
      "enable_sub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "messagenum": 20,
      "plugin_info": {
      "enable": false
      "adapter_name": "mic_0",
      "topic_name": "mic_0",
      "enable_pub": true,
      "messagenum": 20,
      "plugin_info": {
      "enable": false
communication.json
  "log_level": "info",
  "tool_switch": 0,
  "shm_option": {
    "shm_size": "100M",
    "block_size": "1M",
    "hbmem_hold_timout_ms" : 10,
    "hbmem_hold_com_buf": 0
  "supported_protocols": [
      "enable": 1,
      "protocol_type": 2,
      "protocol_name": "zmq_tcp",
      "is_in_hybrid": 1,
      "plugin_file": "libplugin-zmq"
  "discovery_option": {
    "discovery_enable": 1,
    "cross_different_subnets": 0,
    "default_eth": "",
    "port_range": "10100-10200",
    "multicast_domain": ""
  "participants": [
      "id": 1,
      "protocol": "zmq_tcp",
      "link_info": "127.0.0.1:8870",
      "link_type": ""
      "id": 2,
      "link_info": "0.0.0.0:5560",
      "link_type": "bind",
      "link_options": {
        "read_failed_times_to_reconnect": -1
      "id": 3,
      "link_info": "192.168.1.12:8871",
      "link_type": "bind"
      "id": 4,
      "link_info": "127.0.0.1:2111",
      "link_type": "bind"
      "id": 5,
      "link_info": "10.64.61.210:8872",
      "link_type": "connect"
      "id": 6,
      "link_info": "0.0.0.0:5906",
      "id": 7,
      "link_type": "bind"
      "id": 8,
      "link_info": "127.0.0.1:3344",
      "link_type": "connect",
      "link_options": {
当前的问题是,板端至上位机,用wireshark抓包是有信息传输的,但是好像都是些测试数据,通过配置HVIZ,HVIZ能看到话题信息,但是解析的数据好像不太对,其中height项的数更像是时间戳信息,然后在HVIZ端无法出图,windows和linux版的HVIZ都试过,都是相同的现象。具体现象见下图:
执行命令如下:
./bin/sensor_center/sensor_center bin/sensor_center/config/sensor_center/sensor_global.json
板端运行终端如下:
麻烦支持一下,谢谢!
征程5技术深度解析
评论10
  • TROS.Assist
    这个应该没有关联性。
    有个hviz-config.json配置文件,我要找工具的人确认一下。
    2024-03-20
  • TROS.Assist
    请贵司与我司对接人联系申请线下支持。
    2024-03-26
    • 默认70848回复TROS.Assist:
      解决了吗?我也碰到这样的问题,hviz是不是应该支持这个原生的协议啊?想让hviz显示bolepack录制的sensorcenter摄像头CameraArryProtoSerializer信息需要怎么弄啊?sensorcenter的adapter中摄像头的class_name:可以配置成其他类型吗?
      2025-01-21
  • xiangdong.tan@uaes
    @TROS.Assist
    你好,请问有反馈了吗?
    2024-03-26
    @TROS.Assist
    更新一个信息,用bolepack工具录的pack 用MatrixCLient打开没有图像。
    2024-03-21
    @TROS.Assist
    知道是camera_frame消息,那对应在HVIZ中的Message Mapping中的,默认的消息类型如下,这里的Message Type应该填什么呢?手动填CameraFrameProto.CameraFrame,报该类型未定义,我们无法确定这个地方该填什么。你们之前回复说这个地方可以不用配置?
    camera_frame.proto原本对应的这个Message Type该是什么呢?
    如果我手写一个module,订阅这个话题去做操作,我也需要知道这个Message Type。
    2024-03-21
    • 默认70848回复xiangdong.tan@uaes:
      2025-01-21
  • TROS.Assist
    camera接到sensor center后sensor center往外发的消息类型:
    camera_frame消息,在camera_frame.proto中定义
    请问你们申请的ar0233 sensor调试结果怎么样呢?
    配了一下单个摄像头的版本,跑的时候发现0233的sensor无法访问,还在查原因。
    2024-03-21
    @TROS.Assist
    在问题描述中我们已说明了在windows和linux版的HVIZ中均无法出图,我们现在可以确定DDR里面是有YUV数据的,通过adapter后的数据有些问题,你说录制pack的方法我们可以尝试,但是并没有解决核心问题,我们想知道camera接到sensor center后sensor center往外发的消息类型是什么,我理解这个消息格式应该是固定的吧,如果不是请告知可以配置什么文件可以切换。请问你们申请的ar0233 sensor调试结果怎么样呢?可否将你们调试过程稍微详细一点告知,谢谢!
    2024-03-21
  • TROS.Assist
    你用的Hviz是windows还是linux?
    如果在 Linux 上由于系统驱动支持不够友好,会有图像硬解失败的情况。
    你可以尝试一下,录制一个pack文件,看看能不打开,确认一下应用打包的图像数据格式是否正确。
    2024-03-21
    @TROS.Assist
    你好,请问有反馈了吗?
    2024-03-21
  • TROS.Assist
    camera_0.json发出来看一下。
    2024-03-18
