论坛底层软件J5同时点亮ovx8b和imx390,只收到imx390的图像数据
szc2024-01-05
189
J5同时点亮ovx8b和imx390,只收到imx390的图像数据。
查询CIM 0 到 3,没有input fps
cat /sys/devices/platform/soc/47010000.cam_sys/47060000.cim/fps
单个点亮ovx8b或者单个点亮imx390都是可以成功收到图像数据,并且在hbplayer中显示。从log看,ovx8b的寄存器配置成功,不知道为什么没有收到图像数据。
配置文件如下
hb_j5dev.json:
"config_number":1,
"board_name":"j5dvb",
"config_0":{
"comment": "ovx8b and imx390",
"init_in_seq": 1,
"interface_type": "mipi",
        "lpwm_num":0,
        "lpwm_0":{
            "lpwm_index":0,
            "lpwm_enable":"0xf",
            "trigger_mode":8,
            "offset_us":[
            1,
            1,
            1,
            "period_us":[
            33333,
            33333,
            33333,
            33333
            "duty_us":[
            10,
            10,
            10,
            10
"deserial_num":2,
"deserial_0":{
"deserial_name":"max9296",
"deserial_addr":"0x48",
"bus_type":0,
"bus_num":1,
"power_mode":0,
"gpio_pin":[453,309],
"gpio_level":[0,0]
"deserial_1":{
"deserial_name":"max96712",
"deserial_addr":"0x29",
"bus_type":0,
"bus_num":6,
      "power_mode":0,
      "gpio_pin":[456],
      "gpio_level":[0]
"port_number":2,
"port_0":{
"dev_port":0,
"bus_type":0,
"bus_num":1,
"entry_num":0,
"serial_addr":"0x40",
"sensor_name":"ovx8b",
"sensor_addr":"0x36",
"reg_width":16,
"extra_mode":0,
"config_index":516,
"sensor_mode":5,
"fps":30,
"resolution":2160,
"deserial_index":0,
"deserial_port":0,
"data_path":"/userdata/app/bin/vps/vpm/cfg/sen_ovx8b_imx390/cim_config.json",
"config_path":"/system/etc/cam/hb_mipi_ovx8b_raw12_%dfps_%dP.json"
"port_1":{
"dev_port":1,
"bus_type":0,
"bus_num":6,
"entry_num":3,
"serial_addr":"0x41",
"sensor_addr":"0x6d",
"sensor_name":"imx390",
"reg_width":16,
"extra_mode":2,
"config_index":0,
"sensor_mode":0,
"fps":30,
"resolution":1080,
"deserial_index":1,
"deserial_port":0,
"config_path":"/app/bin/vps/vpm/cfg/evm/sen_cimdma_pym2_1080p_imx390_gdc_nano/hb_mipi_imx390c_yuv422_%dfps_%dP.json",
"config_path+":"./hb_mipi_fscam_%dfps_%dP.json"
cim_config.json:
"pipeline0":{
"cim": {
"input": {
"mipi": {
"enable": 1,
"width": 3840,
"height": 2160,
"format": 44,
"rx_index": 0,
"vc_index": 0,
"channels": 1,
"raw16_splict": 0,
"dbg_clear": 0,
"y_uv_swap": 0,
"tag_enable": 0,
"function": {
"enable_frame_id": 1,
"enable_bypass": 0,
"enable_pattern": 0,
"hdr_mode": 0,
"set_init_frame_id": 1,
"set_bypass_channels": 1
"output": {
"pym": {
"pym0_en": 0,
"pym1_en": 0
"isp0": {
"isp_ch0": 1,
"isp_ch1": 0,
"isp_ch2": 0,
"isp_ch3": 0
"isp1":{
"isp_ch0": 0,
"isp_ch1": 0,
"isp_ch2": 0,
"isp_ch3": 0
"cim_dma": {
"input": {
"mipi": {
"enable": 1,
"width": 3840,
"height": 2160,
"format": 44,
"vc_index": 0,
"rx_index": 1,
"raw16_splict": 0,
"dbg_clear": 0,
"y_uv_swap": 0,
"tag_enable": 0,
"function": {
"enable_DMA": 1,
"pack_mode": 0,
"enable_bypass": 0,
"enable_id_decoder": 0,
"output": {
"ddr": {
"enable": 1,
"format": 44,
"width": 3840,
"height": 2160,
"buf_num": 6,
"cached": 0,
"use_ispbuf": 1
"pipeline1":{
"cim_dma": {
"input": {
"mipi": {
"enable": 1,
"width": 1921,
"height": 1080,
"format": 30,
"vc_index": 0,
"rx_index": 3,
"raw16_splict": 0,
"dbg_clear": 0,
"y_uv_swap": 0,
"tag_enable": 0,
"function": {
"enable_DMA": 1,
"pack_mode": 0,
"enable_bypass": 0,
"set_bypass_channels": 0
"output": {
"ddr": {
"enable": 1,
"format": 30,
"width": 1936,
"height": 1080,
"buf_num": 6,
"cached": 0,
"use_ispbuf": 0
vpm_config.json:
"pipeline0": {
"isp": {
"hw_id":0,
"ctx_id": 0,
"sched_mode":2,
"hdr_mode": 1,
"width": 3840,
"height": 2160,
"frame_rate": 30,
"input_crop_enable": 0,
"input_crop_x": 0,
"input_crop_y": 0,
"input_crop_width": 0,
"input_crop_height": 0,
"output_crop_enable": 0,
"output_crop_x": 0,
"output_crop_y": 0,
"output_crop_width": 0,
"output_crop_height": 0,
"isp_stream_output_format": 1,
"isp_dma_output_format": 0,
"calib_mode": 1,
"calib_lname": "/system/etc/cam/lib_x8bRGGB_pwl12_PH_Fov120.so",
"isp_algo_state": 1
"pym": {
"pym_config": {
"pym_hw_id":0,
"pym_mode": 1,
"output_buf_num": 6,
"time_out": 2000,
"y_hor_coeff4": 0,
"y_hor_coeff3": 1,
"y_hor_coeff2": 1,
"y_hor_coeff1": 0,
"y_hor_coeff0": 0,
"y_ver_coeff4": 0,
"y_ver_coeff3": 1,
"y_ver_coeff2": 1,
"y_ver_coeff1": 0,
"y_ver_coeff0": 0,
"c_hor_coeff4": 0,
"c_hor_coeff3": 1,
"c_hor_coeff2": 1,
"c_hor_coeff1": 0,
"c_hor_coeff0": 0,
"c_ver_coeff4": 0,
"c_ver_coeff3": 1,
"c_ver_coeff2": 1,
"c_ver_coeff1": 0,
"c_ver_coeff0": 0,
"y_right_shift": 2,
"c_right_shift": 2
"pym_ctrl": {
"source_en": 1,
"src_uv_bypass": 0,
"src_in_width": 3840,
"src_in_height": 2160,
"src_in_stride_y": 3840,
"src_in_stride_uv": 3840,
"src_start_top": 0,
"src_start_left": 0,
"src_region_width": 3840,
"src_region_height": 2160,
"src_out_stride_y": 3840,
"src_out_stride_uv": 3840,
"suffix_hb_val": 68,
"prefix_hb_val": 2,
"suffix_vb_val": 20,
"prefix_vb_val": 2,
"pixel_num_before_sol": 16,
"gs_max_layer_en": 5,
"gs_en": 31,
"gs_uv_bypass": 0,
"gauss_info": [
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_width": 1920,
"gs_region_height": 1080,
"gs_stride_y": 1920,
"gs_stride_uv": 1920
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_width": 960,
"gs_region_height": 540,
"gs_stride_y": 960,
"gs_stride_uv": 960
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_width": 480,
"gs_region_height": 270,
"gs_stride_y": 480,
"gs_stride_uv": 480
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_width": 240,
"gs_region_height": 134,
"gs_stride_y": 240,
"gs_stride_uv": 240
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_width": 120,
"gs_region_height": 60,
"gs_stride_y": 128,
"gs_stride_uv": 128
"bl_max_layer_en": 5,
"bl_en": 31,
"bl_uv_bypass": 0,
"bilinear_info": [
"bl_start_top": 0,
"bl_start_left": 0,
"bl_region_width": 1920,
"bl_region_height": 1080,
"bl_stride_y": 1920,
"bl_stride_uv": 1920
"bl_start_top": 0,
"bl_start_left": 0,
"bl_region_width": 960,
"bl_region_height": 540,
"bl_stride_y": 960,
"bl_stride_uv": 960
"bl_start_top": 0,
"bl_start_left": 0,
"bl_region_width": 480,
"bl_region_height": 270,
"bl_stride_y": 480,
"bl_stride_uv": 480
"bl_start_top": 0,
"bl_start_left": 0,
"bl_region_width": 240,
"bl_region_height": 134,
"bl_stride_y":240,
"bl_stride_uv": 240
"bl_start_top": 0,
"bl_start_left": 0,
"bl_region_width": 120,
"bl_region_height": 60,
"bl_stride_y": 128,
"bl_stride_uv": 128
"upscale_roi_en": 1,
"us_roi_uv_bypass": 0,
"us_roi_start_left": 0,
"us_roi_start_top": 0,
"us_roi_region_width": 1920,
"us_roi_region_height": 1080,
"us_roi_stride_y": 1920,
"us_roi_stride_uv": 1920,
"us_roi_out_width": 1920,
"us_roi_out_height": 1080,
"ds_roi_en": 63,
"ds_roi_uv_bypass": 0,
"ds_roi": [
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_start_top": 0,
"ds_roi_start_left": 0,
"ds_roi_region_width": 1280,
"ds_roi_region_height": 720,
"ds_roi_stride_y": 1280,
"ds_roi_stride_uv": 1280,
"ds_roi_out_width": 1280,
"ds_roi_out_height": 720
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"pre_line_int_0_set": 0,
"pre_line_int_1_set": 0,
"pre_line_int_2_set": 0,
"pre_line_int_3_set": 0,
"pre_line_int_4_set": 0,
"pre_line_int_5_set": 0,
"pre_line_int_6_set": 0,
"pre_line_int_7_set": 0
"gdc": {
"input_width": 1920,
"input_height": 1080,
"output_width": 1920,
"output_height": 1080,
"buf_num": 8,
"fb_buf_num": 8
"pipeline1": {
"pym": {
"pym_config": {
"pym_hw_id":2,
"pym_mode": 2,
"time_out": 6000,
"y_hor_coeff4": 0,
"y_hor_coeff3": 1,
"y_hor_coeff2": 1,
"y_hor_coeff1": 0,
"y_hor_coeff0": 0,
"y_ver_coeff4": 0,
"y_ver_coeff3": 1,
"y_ver_coeff2": 1,
"y_ver_coeff1": 0,
"y_ver_coeff0": 0,
"c_hor_coeff4": 0,
"c_hor_coeff3": 1,
"c_hor_coeff2": 1,
"c_hor_coeff1": 0,
"c_hor_coeff0": 0,
"c_ver_coeff4": 0,
"c_ver_coeff3": 1,
"c_ver_coeff2": 1,
"c_ver_coeff1": 0,
"c_ver_coeff0": 0,
"y_right_shift": 2,
"c_right_shift": 2
"pym_ctrl": {
"source_en": 1,
"src_uv_bypass": 0,
"src_in_width": 1936,
"src_in_height": 1080,
"src_in_stride_y": 1936,
"src_in_stride_uv": 1936,
"src_start_top": 0,
"src_region_width": 1936,
"src_region_height": 1080,
"src_out_stride_y": 1936,
"src_out_stride_uv": 1936,
"prefix_hb_val": 2,
"prefix_vb_val": 2,
"gs_en": 0,
"gs_uv_bypass": 0,
"gauss_info": [
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_height": 512,
"gs_stride_y": 960,
"gs_stride_uv": 960
"gs_start_top": 10,
"gs_start_left": 40,
"gs_region_height": 130,
"gs_stride_y": 240,
"gs_stride_uv": 240
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_width": 130,
"gs_region_height": 70,
"gs_stride_y": 130,
"gs_stride_uv": 130
"gs_start_top": 10,
"gs_start_left": 0,
"gs_region_width": 64,
"gs_region_height": 32,
"gs_stride_y": 64,
"gs_stride_uv": 64
"gs_start_top": 0,
"gs_start_left": 0,
"gs_region_width": 0,
"gs_region_height": 0,
"gs_stride_y": 0,
"gs_stride_uv": 0
"bl_max_layer_en": 0,
"bl_en": 0,
"bl_uv_bypass": 0,
"bilinear_info": [
"bl_start_top": 64,
"bl_start_left": 32,
"bl_region_width": 320,
"bl_region_height": 240,
"bl_stride_y": 320,
"bl_stride_uv": 320
"bl_start_top": 6,
"bl_start_left": 64,
"bl_region_height": 80,
"bl_stride_y": 240,
"bl_stride_uv": 240
"bl_start_top": 16,
"bl_start_left": 8,
"bl_stride_y": 120,
"bl_stride_uv": 120
"bl_start_top": 0,
"bl_start_left": 12,
"bl_region_width": 48,
"bl_region_height": 32,
"bl_stride_y":48,
"bl_stride_uv": 48
"bl_start_top": 0,
"bl_start_left": 0,
"bl_region_width": 0,
"bl_region_height": 0,
"bl_stride_y": 0,
"bl_stride_uv": 0
"upscale_roi_en": 0,
"ds_roi_en": 1,
"ds_roi": [
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_region_width": 1872,
"ds_roi_region_height": 1008,
"ds_roi_stride_y": 960,
"ds_roi_stride_uv": 960,
"ds_roi_out_width": 960,
"ds_roi_out_height": 512
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_start_top": 20,
"ds_roi_start_left": 16,
"ds_roi_region_width": 900,
"ds_roi_region_height": 600,
"ds_roi_stride_y": 700,
"ds_roi_stride_uv": 700,
"ds_roi_out_width": 700,
"ds_roi_out_height": 500
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_start_top": 8,
"ds_roi_start_left": 48,
"ds_roi_region_width": 720,
"ds_roi_region_height": 480,
"ds_roi_stride_y": 640,
"ds_roi_stride_uv": 640,
"ds_roi_out_width": 640,
"ds_roi_out_height": 320
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_start_top": 18,
"ds_roi_start_left": 24,
"ds_roi_region_width": 520,
"ds_roi_region_height": 450,
"ds_roi_stride_y": 320,
"ds_roi_stride_uv": 320,
"ds_roi_out_width": 320,
"ds_roi_out_height": 160
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_stride_y": 512,
"ds_roi_stride_uv": 512,
"ds_roi_out_width": 512,
"ds_roi_out_height": 240
"ds_roi_layer": 0,
"ds_roi_sel": 0,
"ds_roi_start_left": 10,
"ds_roi_stride_y": 122,
"ds_roi_stride_uv": 122,
"ds_roi_out_width": 122,
"gdc": {
"input_width": 1936,
"buf_num": 8,
"fb_buf_num": 8
logcat 日志如下:
01-01 08:56:08.161 I/    ( 1723): [3369.652344][GDC]:[gdc_entity_parser_config][244]--- gdc info in ---
01-01 08:56:08.161 W/    ( 1723): [3369.652344][GDC]:[gdc_entity_parser_config][291]node is NULL error
01-01 08:56:08.161 W/    ( 1723): [3369.652344][GDC]:[gdc_entity_parser_config][297]node is NULL error
01-01 08:56:08.161 W/    ( 1723): [3369.652588][GDC]:[gdc_entity_parser_config][303]node is NULL error
01-01 08:56:08.161 W/    ( 1723): [3369.652588][GDC]:[gdc_entity_parser_config][309]node is NULL error
01-01 08:56:08.161 W/    ( 1723): [3369.652588][GDC]:[gdc_entity_parser_config][315]node is NULL error
01-01 08:56:08.161 I/    ( 1723): [3369.652588][VIN]:[hb_vin_init][923]cam init begin cam_index 0 cfg_file /userdata/app/bin/vps/vpm/cfg/sen_ovx8b_imx390/hb_j5dev.json
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_board_parse_cfg][693]config_number = 1
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_board_parse_cfg][706]board_name = j5dvb
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_board_parse_cfg][709]node is config_0
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_board_parse_cfg][716]interface_type = mipi
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_board_parse_cfg][726]lpwm_num = 0
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_board_parse_cfg][738]deserial_num = 2
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_board_parse_cfg][744]init_in_seq = 1
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][262]deserial_index 0 bus_type = 0
01-01 08:56:08.161 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][267]deserial_index 0 bus_num = 1
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][278]deserial_index 0 serial_addr = 0x48
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][283]deserial_index 0 deserial_name = max9296
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][299]deserial_index 0 power_mode = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][310]array_index 0 gpio_pin 453
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][310]array_index 1 gpio_pin 309
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][322]deserial_index 0 array_index 0 gpio_level 0
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][322]deserial_index 0 array_index 1 gpio_level 0
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][262]deserial_index 1 bus_type = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][267]deserial_index 1 bus_num = 6
01-01 08:56:08.162 I/    ( 1723): [3369.653076][VIN]:[hb_vin_deserial_parse_cfg][278]deserial_index 1 serial_addr = 0x29
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_deserial_parse_cfg][283]deserial_index 1 deserial_name = max96712
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_deserial_parse_cfg][299]deserial_index 1 power_mode = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_deserial_parse_cfg][310]array_index 0 gpio_pin 456
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_deserial_parse_cfg][322]deserial_index 1 array_index 0 gpio_level 0
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_board_parse_cfg][757]port_number = 2
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][359]port_index 0 bus_type = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][364]port 0 bus_num = 1
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][374]port 0 dev_port = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][386]port_index 0 sensor_addr = 0x36
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][398]port_index 0 serial_addr = 0x40
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][421]port_index 0 sensor_name = ovx8b
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][436]port_index 0 sensor_mode = 5
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][441]port_index 0 config_index = 516
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][451]port_index 0 entry_num = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][471]port_index 0 reg_width = 16
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][477]port_index 0 config_path = /system/etc/cam/hb_mipi_ovx8b_raw12_%dfps_%dP.json
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][482]port_index 0 data_path = /userdata/app/bin/vps/vpm/cfg/sen_ovx8b_imx390/cim_config.json
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][490]port_index 0 fps = 30
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][519]port_index 0 resolution = 2160
01-01 08:56:08.162 I/    ( 1723): [3369.653320][VIN]:[hb_vin_port_parse_cfg][525]port_index 0 extra_mode = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653564][VIN]:[hb_vin_port_parse_cfg][535]port_index 0 deserial_index = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653564][VIN]:[hb_vin_port_parse_cfg][542]port_index 0 deserial_port = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653564][hb mipi]:mipi cfg: /system/etc/cam/hb_mipi_ovx8b_raw12_30fps_2160P.json
01-01 08:56:08.162 I/    ( 1723): [3369.653564][VIN]:[hb_vin_port_parse_cfg][359]port_index 1 bus_type = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653564][VIN]:[hb_vin_port_parse_cfg][364]port 1 bus_num = 6
01-01 08:56:08.162 I/    ( 1723): [3369.653564][VIN]:[hb_vin_port_parse_cfg][374]port 1 dev_port = 1
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][386]port_index 1 sensor_addr = 0x6d
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][398]port_index 1 serial_addr = 0x41
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][421]port_index 1 sensor_name = imx390
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][436]port_index 1 sensor_mode = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][441]port_index 1 config_index = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][451]port_index 1 entry_num = 3
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][471]port_index 1 reg_width = 16
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][477]port_index 1 config_path = /app/bin/vps/vpm/cfg/evm/sen_cimdma_pym2_1080p_imx390_gdc_nano/hb_mipi_imx390c_yuv422_%dfps_%dP.json
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][482]port_index 1 data_path = /userdata/app/bin/vps/vpm/cfg/sen_ovx8b_imx390/cim_config.json
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][490]port_index 1 fps = 30
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][519]port_index 1 resolution = 1080
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][525]port_index 1 extra_mode = 2
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][535]port_index 1 deserial_index = 1
01-01 08:56:08.162 I/    ( 1723): [3369.653809][VIN]:[hb_vin_port_parse_cfg][542]port_index 1 deserial_port = 0
01-01 08:56:08.162 I/    ( 1723): [3369.653809][hb mipi]:mipi cfg: /app/bin/vps/vpm/cfg/evm/sen_cimdma_pym2_1080p_imx390_gdc_nano/hb_mipi_imx390c_yuv422_30fps_1080P.json
01-01 08:56:08.168 I/    ( 1723): [3369.659668][hb_i2c]:[hb_vin_i2c_init][58]bus 1 cam_bus_cnt[bus] 1 cam_fd[bus] 8
01-01 08:56:08.168 I/    ( 1723): [3369.659912][hb_i2c]:[hb_vin_i2c_init][58]bus 6 cam_bus_cnt[bus] 1 cam_fd[bus] 11
01-01 08:56:08.169 I/    ( 1723): [3369.660400][hb cim]:filebuf read size : 1
01-01 08:56:08.169 I/    ( 1723): [3369.660400][cim hal]:pipe(0) cim_entity_create done !
01-01 08:56:08.169 W/    ( 1723): [3369.660645][hb cim utils]:skip_frame has empty json value
01-01 08:56:08.169 W/    ( 1723): [3369.660645][hb cim utils]:input_fps has empty json value
01-01 08:56:08.169 W/    ( 1723): [3369.660645][hb cim utils]:output_fps has empty json value
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:===cim cfg input info====
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.enable(1)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.rx_index (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.vc_index (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.channels (1)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.tag_enable (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.height (2160)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.width (3840)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.format (44)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.raw16_splict (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.dbg_clear (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:mipi.y_uv_swap (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.enable_bypass (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.enable_frame_id (1)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.enable_pattern (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.hdr_mode (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.set_init_frame_id (1)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.set_bypass_channels (1)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.skip_frame (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.input_fps (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:func.output_fps (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:===cim cfg output info===
01-01 08:56:08.169 I/    ( 1723): [3369.660645][cim hal]:out pym pym0_en (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out pym pym1_en (0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[0] isp_ch0(1)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[0] isp_ch1(0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[0] isp_ch2(0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[0] isp_ch3(0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[1] isp_ch0(0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[1] isp_ch1(0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[1] isp_ch2(0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:out isp[1] isp_ch3(0)
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:--cim_entity_parser_config out--
01-01 08:56:08.169 I/    ( 1723): [3369.660889][cim hal]:cim_entity_init in.
01-01 08:56:08.170 I/    ( 1723): [3369.661865][cim hal]:pipe(0) cim_entity_init out.
01-01 08:56:08.170 I/    ( 1723): [3369.661865][hb_i2c]:[hb_vin_i2c_init][58]bus 1 cam_bus_cnt[bus] 2 cam_fd[bus] 8
01-01 08:56:08.171 I/    ( 1723): [3369.662354][cam utility]:/dev/port_0 success sensor_info->sen_devfd 13===
01-01 08:56:08.171 I/    ( 1723): [3369.662354][ovx8b]:deserial_serial_setting X3_config OK!
01-01 08:56:08.171 I/    ( 1723): [3369.662842][ovx8b]:write serdes 1@0x36: 0x0103=0x01
01-01 08:56:08.171 I/    ( 1723): [3369.663086][ovx8b]:write serdes 1@0x36: 0x3208=0x05
01-01 08:56:08.172 I/    ( 1723): [3369.663330][ovx8b]:write serdes 1@0x36: 0x4620=0x04
01-01 08:56:08.172 I/    ( 1723): [3369.663330][ovx8b]:write serdes 1@0x36: 0x3208=0x15
01-01 08:56:08.172 I/    ( 1723): [3369.663574][ovx8b]:write serdes 1@0x36: 0x0301=0x88
01-01 08:56:08.172 I/    ( 1723): [3369.663574][ovx8b]:write serdes 1@0x36: 0x0302=0x31
01-01 08:56:08.172 I/    ( 1723): [3369.663818][ovx8b]:write serdes 1@0x36: 0x0304=0x00
01-01 08:56:08.172 I/    ( 1723): [3369.664062][ovx8b]:write serdes 1@0x36: 0x0305=0x5c
01-01 08:56:08.173 I/    ( 1723): [3369.664062][ovx8b]:write serdes 1@0x36: 0x0307=0x00
01-01 08:56:08.173 I/    ( 1723): [3369.664307][ovx8b]:write serdes 1@0x36: 0x0309=0x03
01-01 08:56:08.173 I/    ( 1723): [3369.664551][ovx8b]:write serdes 1@0x36: 0x0316=0x00
01-01 08:56:08.173 I/    ( 1723): [3369.664551][ovx8b]:write serdes 1@0x36: 0x0317=0x00
01-01 08:56:08.173 I/    ( 1723): [3369.664795][ovx8b]:write serdes 1@0x36: 0x0318=0x00
01-01 08:56:08.173 I/    ( 1723): [3369.665039][ovx8b]:write serdes 1@0x36: 0x0320=0x12
01-01 08:56:08.174 I/    ( 1723): [3369.665039][ovx8b]:write serdes 1@0x36: 0x0321=0x31
01-01 08:56:08.174 I/    ( 1723): [3369.665283][ovx8b]:write serdes 1@0x36: 0x0322=0x02
01-01 08:56:08.174 I/    ( 1723): [3369.665283][ovx8b]:write serdes 1@0x36: 0x0323=0x02
01-01 08:56:08.174 I/    ( 1723): [3369.665527][ovx8b]:write serdes 1@0x36: 0x0324=0x01
01-01 08:56:08.174 I/    ( 1723): [3369.665771][ovx8b]:write serdes 1@0x36: 0x0325=0x95
01-01 08:56:08.174 I/    ( 1723): [3369.665771][ovx8b]:write serdes 1@0x36: 0x0326=0xce
01-01 08:56:08.175 I/    ( 1723): [3369.666016][ovx8b]:write serdes 1@0x36: 0x0327=0x04
01-01 08:56:08.175 I/    ( 1723): [3369.666260][ovx8b]:write serdes 1@0x36: 0x0329=0x02
01-01 08:56:08.175 I/    ( 1723): [3369.666260][ovx8b]:write serdes 1@0x36: 0x032a=0x04
01-01 08:56:08.175 I/    ( 1723): [3369.666504][ovx8b]:write serdes 1@0x36: 0x032b=0x04
01-01 08:56:08.175 I/    ( 1723): [3369.666504][ovx8b]:write serdes 1@0x36: 0x032c=0x02
01-01 08:56:08.175 I/    ( 1723): [3369.666748][ovx8b]:write serdes 1@0x36: 0x0331=0x04
01-01 08:56:08.175 I/    ( 1723): [3369.666992][ovx8b]:write serdes 1@0x36: 0x0405=0x22
01-01 08:56:08.176 I/    ( 1723): [3369.666992][ovx8b]:write serdes 1@0x36: 0x0406=0x5f
01-01 08:56:08.176 I/    ( 1723): [3369.667236][ovx8b]:write serdes 1@0x36: 0x0408=0xe7
01-01 08:56:08.176 I/    ( 1723): [3369.667236][ovx8b]:write serdes 1@0x36: 0x0409=0xff
01-01 08:56:08.176 I/    ( 1723): [3369.667480][ovx8b]:write serdes 1@0x36: 0x040a=0x2b
01-01 08:56:08.176 I/    ( 1723): [3369.667725][ovx8b]:write serdes 1@0x36: 0x040b=0x32
01-01 08:56:08.176 I/    ( 1723): [3369.667725][ovx8b]:write serdes 1@0x36: 0x040c=0x28
01-01 08:56:08.177 I/    ( 1723): [3369.668213][ovx8b]:write serdes 1@0x36: 0x040d=0x5a
01-01 08:56:08.177 I/    ( 1723): [3369.668457][ovx8b]:write serdes 1@0x36: 0x040e=0x0c
01-01 08:56:08.177 I/    ( 1723): [3369.668457][ovx8b]:write serdes 1@0x36: 0x0441=0x00
01-01 08:56:08.177 I/    ( 1723): [3369.668701][ovx8b]:write serdes 1@0x36: 0x280b=0x00
01-01 08:56:08.177 I/    ( 1723): [3369.668701][ovx8b]:write serdes 1@0x36: 0x3002=0xf8
01-01 08:56:08.177 I/    ( 1723): [3369.668945][ovx8b]:write serdes 1@0x36: 0x3012=0x41
01-01 08:56:08.178 I/    ( 1723): [3369.669189][ovx8b]:write serdes 1@0x36: 0x3015=0x08
01-01 08:56:08.178 I/    ( 1723): [3369.669189][ovx8b]:write serdes 1@0x36: 0x3016=0xd0
01-01 08:56:08.178 I/    ( 1723): [3369.669434][ovx8b]:write serdes 1@0x36: 0x3018=0xf0
01-01 08:56:08.178 I/    ( 1723): [3369.669678][ovx8b]:write serdes 1@0x36: 0x301a=0xb0
01-01 08:56:08.178 I/    ( 1723): [3369.669678][ovx8b]:write serdes 1@0x36: 0x301e=0x30
01-01 08:56:08.178 I/    ( 1723): [3369.669922][ovx8b]:write serdes 1@0x36: 0x301f=0x61
01-01 08:56:08.178 I/    ( 1723): [3369.669922][ovx8b]:write serdes 1@0x36: 0x3020=0x01
01-01 08:56:08.179 I/    ( 1723): [3369.670166][ovx8b]:write serdes 1@0x36: 0x3022=0x88
01-01 08:56:08.179 I/    ( 1723): [3369.670410][ovx8b]:write serdes 1@0x36: 0x3023=0x80
01-01 08:56:08.179 I/    ( 1723): [3369.670410][ovx8b]:write serdes 1@0x36: 0x3024=0x80
01-01 08:56:08.179 I/    ( 1723): [3369.670654][ovx8b]:write serdes 1@0x36: 0x3028=0x30
01-01 08:56:08.179 I/    ( 1723): [3369.670654][ovx8b]:write serdes 1@0x36: 0x3701=0x22
01-01 08:56:08.179 I/    ( 1723): [3369.670898][ovx8b]:write serdes 1@0x36: 0x3703=0x3c
01-01 08:56:08.180 I/    ( 1723): [3369.671143][ovx8b]:write serdes 1@0x36: 0x3705=0x00
01-01 08:56:08.180 I/    ( 1723): [3369.671143][ovx8b]:write serdes 1@0x36: 0x3706=0x2f
01-01 08:56:08.180 I/    ( 1723): [3369.671387][ovx8b]:write serdes 1@0x36: 0x3709=0x62
01-01 08:56:08.180 I/    ( 1723): [3369.671631][ovx8b]:write serdes 1@0x36: 0x370a=0x00
01-01 08:56:08.180 I/    ( 1723): [3369.671631][ovx8b]:write serdes 1@0x36: 0x370b=0x75
01-01 08:56:08.180 I/    ( 1723): [3369.671875][ovx8b]:write serdes 1@0x36: 0x370d=0x00
01-01 08:56:08.181 I/    ( 1723): [3369.671875][ovx8b]:write serdes 1@0x36: 0x3712=0x13
01-01 08:56:08.181 I/    ( 1723): [3369.672119][ovx8b]:write serdes 1@0x36: 0x3714=0x02
01-01 08:56:08.181 I/    ( 1723): [3369.672363][ovx8b]:write serdes 1@0x36: 0x3717=0x02
01-01 08:56:08.181 I/    ( 1723): [3369.672363][ovx8b]:write serdes 1@0x36: 0x3718=0x72
01-01 08:56:08.181 I/    ( 1723): [3369.672607][ovx8b]:write serdes 1@0x36: 0x371d=0x00
01-01 08:56:08.181 I/    ( 1723): [3369.672607][ovx8b]:write serdes 1@0x36: 0x3720=0x03
01-01 08:56:08.181 I/    ( 1723): [3369.672852][ovx8b]:write serdes 1@0x36: 0x372c=0x10
01-01 08:56:08.182 I/    ( 1723): [3369.673096][ovx8b]:write serdes 1@0x36: 0x3738=0x2c
01-01 08:56:08.182 I/    ( 1723): [3369.673096][ovx8b]:write serdes 1@0x36: 0x3739=0x2c
01-01 08:56:08.182 I/    ( 1723): [3369.673584][ovx8b]:write serdes 1@0x36: 0x373a=0x27
01-01 08:56:08.182 I/    ( 1723): [3369.673828][ovx8b]:write serdes 1@0x36: 0x373b=0x27
01-01 08:56:08.182 I/    ( 1723): [3369.673828][ovx8b]:write serdes 1@0x36: 0x373f=0x26
01-01 08:56:08.182 I/    ( 1723): [3369.674072][ovx8b]:write serdes 1@0x36: 0x3740=0x26
01-01 08:56:08.183 I/    ( 1723): [3369.674072][ovx8b]:write serdes 1@0x36: 0x3741=0x21
01-01 08:56:08.183 I/    ( 1723): [3369.674316][ovx8b]:write serdes 1@0x36: 0x3742=0x21
01-01 08:56:08.183 I/    ( 1723): [3369.674561][ovx8b]:write serdes 1@0x36: 0x374b=0x03
01-01 08:56:08.183 I/    ( 1723): [3369.674561][ovx8b]:write serdes 1@0x36: 0x3752=0x03
01-01 08:56:08.183 I/    ( 1723): [3369.674805][ovx8b]:write serdes 1@0x36: 0x3758=0x00
01-01 08:56:08.183 I/    ( 1723): [3369.674805][ovx8b]:write serdes 1@0x36: 0x3759=0x2f
01-01 08:56:08.184 I/    ( 1723): [3369.675049][ovx8b]:write serdes 1@0x36: 0x376c=0x07
01-01 08:56:08.184 I/    ( 1723): [3369.675293][ovx8b]:write serdes 1@0x36: 0x376d=0x08
01-01 08:56:08.184 I/    ( 1723): [3369.675293][ovx8b]:write serdes 1@0x36: 0x376e=0x08
01-01 08:56:08.184 I/    ( 1723): [3369.675537][ovx8b]:write serdes 1@0x36: 0x376f=0x08
01-01 08:56:08.184 I/    ( 1723): [3369.675781][ovx8b]:write serdes 1@0x36: 0x3777=0x00
01-01 08:56:08.184 I/    ( 1723): [3369.675781][ovx8b]:write serdes 1@0x36: 0x3779=0x02
01-01 08:56:08.184 I/    ( 1723): [3369.676025][ovx8b]:write serdes 1@0x36: 0x377a=0x00
01-01 08:56:08.185 I/    ( 1723): [3369.676270][ovx8b]:write serdes 1@0x36: 0x377b=0x00
01-01 08:56:08.185 I/    ( 1723): [3369.676270][ovx8b]:write serdes 1@0x36: 0x3781=0x02
01-01 08:56:08.185 I/    ( 1723): [3369.676514][ovx8b]:write serdes 1@0x36: 0x3782=0x05
01-01 08:56:08.185 I/    ( 1723): [3369.676514][ovx8b]:write serdes 1@0x36: 0x3783=0x02
01-01 08:56:08.185 I/    ( 1723): [3369.676758][ovx8b]:write serdes 1@0x36: 0x3785=0x10
01-01 08:56:08.185 I/    ( 1723): [3369.677002][ovx8b]:write serdes 1@0x36: 0x3797=0x00
01-01 08:56:08.186 I/    ( 1723): [3369.677002][ovx8b]:write serdes 1@0x36: 0x3798=0x00
01-01 08:56:08.186 I/    ( 1723): [3369.677246][ovx8b]:write serdes 1@0x36: 0x3799=0x00
01-01 08:56:08.186 I/    ( 1723): [3369.677490][ovx8b]:write serdes 1@0x36: 0x379c=0x58
01-01 08:56:08.186 I/    ( 1723): [3369.677490][ovx8b]:write serdes 1@0x36: 0x379e=0x00
01-01 08:56:08.186 I/    ( 1723): [3369.677734][ovx8b]:write serdes 1@0x36: 0x379f=0x00
01-01 08:56:08.186 I/    ( 1723): [3369.677734][ovx8b]:write serdes 1@0x36: 0x37a0=0x00
01-01 08:56:08.187 I/    ( 1723): [3369.677979][ovx8b]:write serdes 1@0x36: 0x37bc=0x22
01-01 08:56:08.187 I/    ( 1723): [3369.678223][ovx8b]:write serdes 1@0x36: 0x37bd=0x01
01-01 08:56:08.187 I/    ( 1723): [3369.678223][ovx8b]:write serdes 1@0x36: 0x37be=0x01
01-01 08:56:08.187 I/    ( 1723): [3369.678711][ovx8b]:write serdes 1@0x36: 0x37c0=0x01
01-01 08:56:08.187 I/    ( 1723): [3369.678711][ovx8b]:write serdes 1@0x36: 0x37c4=0x34
01-01 08:56:08.187 I/    ( 1723): [3369.678955][ovx8b]:write serdes 1@0x36: 0x37c5=0x34
01-01 08:56:08.188 I/    ( 1723): [3369.679199][ovx8b]:write serdes 1@0x36: 0x37c6=0x2f
01-01 08:56:08.188 I/    ( 1723): [3369.679199][ovx8b]:write serdes 1@0x36: 0x37c7=0x2f
01-01 08:56:08.188 I/    ( 1723): [3369.679443][ovx8b]:write serdes 1@0x36: 0x37d0=0x00
01-01 08:56:08.188 I/    ( 1723): [3369.679688][ovx8b]:write serdes 1@0x36: 0x37d1=0x2f
01-01 08:56:08.188 I/    ( 1723): [3369.679688][ovx8b]:write serdes 1@0x36: 0x37d2=0x00
01-01 08:56:08.188 I/    ( 1723): [3369.679932][ovx8b]:write serdes 1@0x36: 0x37d3=0x61
01-01 08:56:08.188 I/    ( 1723): [3369.679932][ovx8b]:write serdes 1@0x36: 0x37d4=0x00
01-01 08:56:08.189 I/    ( 1723): [3369.680176][ovx8b]:write serdes 1@0x36: 0x37d5=0x2f
01-01 08:56:08.189 I/    ( 1723): [3369.680420][ovx8b]:write serdes 1@0x36: 0x37d8=0x01
01-01 08:56:08.189 I/    ( 1723): [3369.680420][ovx8b]:write serdes 1@0x36: 0x37db=0x00
01-01 08:56:08.189 I/    ( 1723): [3369.680664][ovx8b]:write serdes 1@0x36: 0x3c0b=0x26
01-01 08:56:08.189 I/    ( 1723): [3369.680908][ovx8b]:write serdes 1@0x36: 0x3c12=0x88
01-01 08:56:08.189 I/    ( 1723): [3369.680908][ovx8b]:write serdes 1@0x36: 0x3c21=0x00
01-01 08:56:08.190 I/    ( 1723): [3369.681152][ovx8b]:write serdes 1@0x36: 0x3c3c=0x00
01-01 08:56:08.190 I/    ( 1723): [3369.681152][ovx8b]:write serdes 1@0x36: 0x3c55=0x20
01-01 08:56:08.190 I/    ( 1723): [3369.681396][ovx8b]:write serdes 1@0x36: 0x3c5b=0x20
01-01 08:56:08.190 I/    ( 1723): [3369.681641][ovx8b]:write serdes 1@0x36: 0x3c61=0x80
01-01 08:56:08.190 I/    ( 1723): [3369.681641][ovx8b]:write serdes 1@0x36: 0x3c6f=0x3a
01-01 08:56:08.190 I/    ( 1723): [3369.681885][ovx8b]:write serdes 1@0x36: 0x3c70=0x62
01-01 08:56:08.191 I/    ( 1723): [3369.681885][ovx8b]:write serdes 1@0x36: 0x3106=0x10
01-01 08:56:08.191 I/    ( 1723): [3369.682129][ovx8b]:write serdes 1@0x36: 0x320e=0x00
01-01 08:56:08.191 I/    ( 1723): [3369.682373][ovx8b]:write serdes 1@0x36: 0x320f=0x00
01-01 08:56:08.191 I/    ( 1723): [3369.682373][ovx8b]:write serdes 1@0x36: 0x3211=0x61
01-01 08:56:08.191 I/    ( 1723): [3369.682617][ovx8b]:write serdes 1@0x36: 0x3215=0xcd
01-01 08:56:08.191 I/    ( 1723): [3369.682861][ovx8b]:write serdes 1@0x36: 0x3304=0x04
01-01 08:56:08.191 I/    ( 1723): [3369.682861][ovx8b]:write serdes 1@0x36: 0x3306=0x03
01-01 08:56:08.192 I/    ( 1723): [3369.683105][ovx8b]:write serdes 1@0x36: 0x3307=0x00
01-01 08:56:08.192 I/    ( 1723): [3369.683105][ovx8b]:write serdes 1@0x36: 0x3308=0x00
01-01 08:56:08.192 I/    ( 1723): [3369.683350][ovx8b]:write serdes 1@0x36: 0x3309=0x00
01-01 08:56:08.192 I/    ( 1723): [3369.683594][ovx8b]:write serdes 1@0x36: 0x330a=0x00
01-01 08:56:08.192 I/    ( 1723): [3369.683594][ovx8b]:write serdes 1@0x36: 0x330b=0x00
01-01 08:56:08.192 I/    ( 1723): [3369.684082][ovx8b]:write serdes 1@0x36: 0x330c=0x00
01-01 08:56:08.193 I/    ( 1723): [3369.684082][ovx8b]:write serdes 1@0x36: 0x330d=0x00
01-01 08:56:08.193 I/    ( 1723): [3369.684326][ovx8b]:write serdes 1@0x36: 0x330e=0x00
01-01 08:56:08.193 I/    ( 1723): [3369.684570][ovx8b]:write serdes 1@0x36: 0x330f=0x00
01-01 08:56:08.193 I/    ( 1723): [3369.684570][ovx8b]:write serdes 1@0x36: 0x3310=0x06
01-01 08:56:08.193 I/    ( 1723): [3369.684814][ovx8b]:write serdes 1@0x36: 0x3311=0x05
01-01 08:56:08.193 I/    ( 1723): [3369.685059][ovx8b]:write serdes 1@0x36: 0x3312=0x55
01-01 08:56:08.194 I/    ( 1723): [3369.685059][ovx8b]:write serdes 1@0x36: 0x3313=0x02
01-01 08:56:08.194 I/    ( 1723): [3369.685303][ovx8b]:write serdes 1@0x36: 0x3314=0xaa
01-01 08:56:08.194 I/    ( 1723): [3369.685303][ovx8b]:write serdes 1@0x36: 0x3315=0x07
01-01 08:56:08.194 I/    ( 1723): [3369.685547][ovx8b]:write serdes 1@0x36: 0x3316=0xf0
01-01 08:56:08.194 I/    ( 1723): [3369.685791][ovx8b]:write serdes 1@0x36: 0x3317=0x00
01-01 08:56:08.194 I/    ( 1723): [3369.685791][ovx8b]:write serdes 1@0x36: 0x3318=0x00
01-01 08:56:08.194 I/    ( 1723): [3369.686035][ovx8b]:write serdes 1@0x36: 0x3400=0x08
01-01 08:56:08.195 I/    ( 1723): [3369.686035][ovx8b]:write serdes 1@0x36: 0x3408=0x01
01-01 08:56:08.195 I/    ( 1723): [3369.686279][ovx8b]:write serdes 1@0x36: 0x3501=0x00
01-01 08:56:08.195 I/    ( 1723): [3369.686523][ovx8b]:write serdes 1@0x36: 0x3502=0x08
01-01 08:56:08.195 I/    ( 1723): [3369.686523][ovx8b]:write serdes 1@0x36: 0x3508=0x01
01-01 08:56:08.195 I/    ( 1723): [3369.686768][ovx8b]:write serdes 1@0x36: 0x3509=0x00
01-01 08:56:08.195 I/    ( 1723): [3369.687012][ovx8b]:write serdes 1@0x36: 0x350a=0x01
01-01 08:56:08.196 I/    ( 1723): [3369.687012][ovx8b]:write serdes 1@0x36: 0x350b=0x00
01-01 08:56:08.196 I/    ( 1723): [3369.687256][ovx8b]:write serdes 1@0x36: 0x350c=0x00
01-01 08:56:08.196 I/    ( 1723): [3369.687256][ovx8b]:write serdes 1@0x36: 0x3588=0x01
01-01 08:56:08.196 I/    ( 1723): [3369.687500][ovx8b]:write serdes 1@0x36: 0x3589=0x00
01-01 08:56:08.196 I/    ( 1723): [3369.687744][ovx8b]:write serdes 1@0x36: 0x358a=0x01
01-01 08:56:08.196 I/    ( 1723): [3369.687744][ovx8b]:write serdes 1@0x36: 0x358b=0x00
01-01 08:56:08.197 I/    ( 1723): [3369.687988][ovx8b]:write serdes 1@0x36: 0x358c=0x00
01-01 08:56:08.197 I/    ( 1723): [3369.687988][ovx8b]:write serdes 1@0x36: 0x3541=0x00
01-01 08:56:08.197 I/    ( 1723): [3369.688232][ovx8b]:write serdes 1@0x36: 0x3542=0x04
01-01 08:56:08.197 I/    ( 1723): [3369.688477][ovx8b]:write serdes 1@0x36: 0x3548=0x01
01-01 08:56:08.197 I/    ( 1723): [3369.688477][ovx8b]:write serdes 1@0x36: 0x3549=0x00
01-01 08:56:08.197 I/    ( 1723): [3369.688721][ovx8b]:write serdes 1@0x36: 0x354a=0x01
01-01 08:56:08.197 I/    ( 1723): [3369.689209][ovx8b]:write serdes 1@0x36: 0x354b=0x00
01-01 08:56:08.198 I/    ( 1723): [3369.689209][ovx8b]:write serdes 1@0x36: 0x354c=0x00
01-01 08:56:08.198 I/    ( 1723): [3369.689453][ovx8b]:write serdes 1@0x36: 0x35c1=0x00
01-01 08:56:08.198 I/    ( 1723): [3369.689453][ovx8b]:write serdes 1@0x36: 0x35c2=0x02
01-01 08:56:08.198 I/    ( 1723): [3369.689697][ovx8b]:write serdes 1@0x36: 0x35c7=0x00
01-01 08:56:08.198 I/    ( 1723): [3369.689941][ovx8b]:write serdes 1@0x36: 0x35c8=0x01
01-01 08:56:08.198 I/    ( 1723): [3369.689941][ovx8b]:write serdes 1@0x36: 0x35c9=0x00
01-01 08:56:08.199 I/    ( 1723): [3369.690186][ovx8b]:write serdes 1@0x36: 0x35ca=0x01
01-01 08:56:08.199 I/    ( 1723): [3369.690430][ovx8b]:write serdes 1@0x36: 0x35cb=0x00
01-01 08:56:08.199 I/    ( 1723): [3369.690430][ovx8b]:write serdes 1@0x36: 0x35cc=0x00
01-01 08:56:08.199 I/    ( 1723): [3369.690674][ovx8b]:write serdes 1@0x36: 0x3600=0xff
01-01 08:56:08.199 I/    ( 1723): [3369.690674][ovx8b]:write serdes 1@0x36: 0x3604=0x91
01-01 08:56:08.199 I/    ( 1723): [3369.690918][ovx8b]:write serdes 1@0x36: 0x3605=0x2c
01-01 08:56:08.200 I/    ( 1723): [3369.691162][ovx8b]:write serdes 1@0x36: 0x3607=0x0a
01-01 08:56:08.200 I/    ( 1723): [3369.691162][ovx8b]:write serdes 1@0x36: 0x3609=0x00
01-01 08:56:08.200 I/    ( 1723): [3369.691406][ovx8b]:write serdes 1@0x36: 0x360a=0x00
01-01 08:56:08.200 I/    ( 1723): [3369.691406][ovx8b]:write serdes 1@0x36: 0x360e=0x1b
01-01 08:56:08.200 I/    ( 1723): [3369.691650][ovx8b]:write serdes 1@0x36: 0x3611=0x3f
01-01 08:56:08.200 I/    ( 1723): [3369.691895][ovx8b]:write serdes 1@0x36: 0x3613=0x00
01-01 08:56:08.200 I/    ( 1723): [3369.691895][ovx8b]:write serdes 1@0x36: 0x3616=0x8a
01-01 08:56:08.201 I/    ( 1723): [3369.692139][ovx8b]:write serdes 1@0x36: 0x361a=0x01
01-01 08:56:08.201 I/    ( 1723): [3369.692383][ovx8b]:write serdes 1@0x36: 0x361c=0x70
01-01 08:56:08.201 I/    ( 1723): [3369.692383][ovx8b]:write serdes 1@0x36: 0x361d=0x00
01-01 08:56:08.201 I/    ( 1723): [3369.692627][ovx8b]:write serdes 1@0x36: 0x361e=0xdc
01-01 08:56:08.201 I/    ( 1723): [3369.692871][ovx8b]:write serdes 1@0x36: 0x361f=0x42
01-01 08:56:08.201 I/    ( 1723): [3369.692871][ovx8b]:write serdes 1@0x36: 0x362c=0x82
01-01 08:56:08.202 I/    ( 1723): [3369.693115][ovx8b]:write serdes 1@0x36: 0x3639=0x7b
01-01 08:56:08.202 I/    ( 1723): [3369.693115][ovx8b]:write serdes 1@0x36: 0x363f=0x20
01-01 08:56:08.202 I/    ( 1723): [3369.693359][ovx8b]:write serdes 1@0x36: 0x3643=0x2a
01-01 08:56:08.202 I/    ( 1723): [3369.693604][ovx8b]:write serdes 1@0x36: 0x3646=0x0c
01-01 08:56:08.202 I/    ( 1723): [3369.693604][ovx8b]:write serdes 1@0x36: 0x3647=0xa0
01-01 08:56:08.202 I/    ( 1723): [3369.693848][ovx8b]:write serdes 1@0x36: 0x3648=0x00
01-01 08:56:08.203 I/    ( 1723): [3369.693848][ovx8b]:write serdes 1@0x36: 0x3649=0x00
01-01 08:56:08.203 I/    ( 1723): [3369.694092][ovx8b]:write serdes 1@0x36: 0x364a=0x00
01-01 08:56:08.203 I/    ( 1723): [3369.694580][ovx8b]:write serdes 1@0x36: 0x364b=0x00
01-01 08:56:08.203 I/    ( 1723): [3369.694580][ovx8b]:write serdes 1@0x36: 0x364e=0x12
01-01 08:56:08.203 I/    ( 1723): [3369.694824][ovx8b]:write serdes 1@0x36: 0x364f=0x12
01-01 08:56:08.203 I/    ( 1723): [3369.695068][ovx8b]:write serdes 1@0x36: 0x3653=0x07
01-01 08:56:08.204 I/    ( 1723): [3369.695068][ovx8b]:write serdes 1@0x36: 0x3654=0x07
01-01 08:56:08.204 I/    ( 1723): [3369.695312][ovx8b]:write serdes 1@0x36: 0x3655=0x07
01-01 08:56:08.204 I/    ( 1723): [3369.695312][ovx8b]:write serdes 1@0x36: 0x3656=0x07
01-01 08:56:08.204 I/    ( 1723): [3369.695557][ovx8b]:write serdes 1@0x36: 0x3657=0x04
01-01 08:56:08.204 I/    ( 1723): [3369.695801][ovx8b]:write serdes 1@0x36: 0x3658=0x04
01-01 08:56:08.204 I/    ( 1723): [3369.695801][ovx8b]:write serdes 1@0x36: 0x3659=0x04
01-01 08:56:08.204 I/    ( 1723): [3369.696045][ovx8b]:write serdes 1@0x36: 0x365a=0x04
01-01 08:56:08.205 I/    ( 1723): [3369.696045][ovx8b]:write serdes 1@0x36: 0x365c=0x12
01-01 08:56:08.205 I/    ( 1723): [3369.696289][ovx8b]:write serdes 1@0x36: 0x365f=0x01
01-01 08:56:08.205 I/    ( 1723): [3369.696533][ovx8b]:write serdes 1@0x36: 0x3661=0x1c
01-01 08:56:08.205 I/    ( 1723): [3369.696533][ovx8b]:write serdes 1@0x36: 0x3663=0x00
01-01 08:56:08.205 I/    ( 1723): [3369.696777][ovx8b]:write serdes 1@0x36: 0x3664=0x00
01-01 08:56:08.205 I/    ( 1723): [3369.697021][ovx8b]:write serdes 1@0x36: 0x3668=0x08
01-01 08:56:08.206 I/    ( 1723): [3369.697021][ovx8b]:write serdes 1@0x36: 0x3669=0x08
01-01 08:56:08.206 I/    ( 1723): [3369.697266][ovx8b]:write serdes 1@0x36: 0x366b=0x00
01-01 08:56:08.206 I/    ( 1723): [3369.697266][ovx8b]:write serdes 1@0x36: 0x3800=0x00
01-01 08:56:08.206 I/    ( 1723): [3369.697510][ovx8b]:write serdes 1@0x36: 0x3801=0x00
01-01 08:56:08.206 I/    ( 1723): [3369.697754][ovx8b]:write serdes 1@0x36: 0x3802=0x00
01-01 08:56:08.206 I/    ( 1723): [3369.697754][ovx8b]:write serdes 1@0x36: 0x3803=0x04
01-01 08:56:08.207 I/    ( 1723): [3369.697998][ovx8b]:write serdes 1@0x36: 0x3804=0x0f
01-01 08:56:08.207 I/    ( 1723): [3369.698242][ovx8b]:write serdes 1@0x36: 0x3805=0x1f
01-01 08:56:08.207 I/    ( 1723): [3369.698242][ovx8b]:write serdes 1@0x36: 0x3806=0x08
01-01 08:56:08.207 I/    ( 1723): [3369.698486][ovx8b]:write serdes 1@0x36: 0x3807=0x7b
01-01 08:56:08.207 I/    ( 1723): [3369.698486][ovx8b]:write serdes 1@0x36: 0x3808=0x0f
01-01 08:56:08.207 I/    ( 1723): [3369.698730][ovx8b]:write serdes 1@0x36: 0x3809=0x00
01-01 08:56:08.207 I/    ( 1723): [3369.698975][ovx8b]:write serdes 1@0x36: 0x380a=0x08
01-01 08:56:08.208 I/    ( 1723): [3369.698975][ovx8b]:write serdes 1@0x36: 0x380b=0x70
01-01 08:56:08.208 I/    ( 1723): [3369.699219][ovx8b]:write serdes 1@0x36: 0x380c=0x03
01-01 08:56:08.208 I/    ( 1723): [3369.699219][ovx8b]:write serdes 1@0x36: 0x380d=0xdc
01-01 08:56:08.208 I/    ( 1723): [3369.699463][ovx8b]:write serdes 1@0x36: 0x380e=0x04
01-01 08:56:08.208 I/    ( 1723): [3369.699951][ovx8b]:write serdes 1@0x36: 0x380f=0x66
01-01 08:56:08.208 I/    ( 1723): [3369.699951][ovx8b]:write serdes 1@0x36: 0x3810=0x00
01-01 08:56:08.209 I/    ( 1723): [3369.700195][ovx8b]:write serdes 1@0x36: 0x3811=0x08
01-01 08:56:08.209 I/    ( 1723): [3369.700439][ovx8b]:write serdes 1@0x36: 0x3812=0x00
01-01 08:56:08.209 I/    ( 1723): [3369.700439][ovx8b]:write serdes 1@0x36: 0x3813=0x04
01-01 08:56:08.209 I/    ( 1723): [3369.700684][ovx8b]:write serdes 1@0x36: 0x3816=0x01
01-01 08:56:08.209 I/    ( 1723): [3369.700684][ovx8b]:write serdes 1@0x36: 0x3817=0x01
01-01 08:56:08.209 I/    ( 1723): [3369.700928][ovx8b]:write serdes 1@0x36: 0x381c=0x18
01-01 08:56:08.210 I/    ( 1723): [3369.701172][ovx8b]:write serdes 1@0x36: 0x381e=0x01
01-01 08:56:08.210 I/    ( 1723): [3369.701172][ovx8b]:write serdes 1@0x36: 0x381f=0x01
01-01 08:56:08.210 I/    ( 1723): [3369.701416][ovx8b]:write serdes 1@0x36: 0x3820=0x00
01-01 08:56:08.210 I/    ( 1723): [3369.701660][ovx8b]:write serdes 1@0x36: 0x3821=0x19
01-01 08:56:08.210 I/    ( 1723): [3369.701660][ovx8b]:write serdes 1@0x36: 0x3822=0x03
01-01 08:56:08.210 I/    ( 1723): [3369.701904][ovx8b]:write serdes 1@0x36: 0x3828=0x36
01-01 08:56:08.211 I/    ( 1723): [3369.701904][ovx8b]:write serdes 1@0x36: 0x3832=0x00
01-01 08:56:08.211 I/    ( 1723): [3369.702148][ovx8b]:write serdes 1@0x36: 0x3834=0x00
01-01 08:56:08.211 I/    ( 1723): [3369.702393][ovx8b]:write serdes 1@0x36: 0x383d=0x00
01-01 08:56:08.211 I/    ( 1723): [3369.702393][ovx8b]:write serdes 1@0x36: 0x3847=0x04
01-01 08:56:08.211 I/    ( 1723): [3369.702637][ovx8b]:write serdes 1@0x36: 0x3848=0x60
01-01 08:56:08.211 I/    ( 1723): [3369.702881][ovx8b]:write serdes 1@0x36: 0x384c=0x01
01-01 08:56:08.211 I/    ( 1723): [3369.702881][ovx8b]:write serdes 1@0x36: 0x384d=0xee
01-01 08:56:08.212 I/    ( 1723): [3369.703125][ovx8b]:write serdes 1@0x36: 0x3850=0x00
01-01 08:56:08.212 I/    ( 1723): [3369.703369][ovx8b]:write serdes 1@0x36: 0x3851=0x42
01-01 08:56:08.212 I/    ( 1723): [3369.703369][ovx8b]:write serdes 1@0x36: 0x3852=0x00
01-01 08:56:08.212 I/    ( 1723): [3369.703613][ovx8b]:write serdes 1@0x36: 0x3853=0x40
01-01 08:56:08.212 I/    ( 1723): [3369.703613][ovx8b]:write serdes 1@0x36: 0x3858=0x04
01-01 08:56:08.212 I/    ( 1723): [3369.703857][ovx8b]:write serdes 1@0x36: 0x385b=0x04
01-01 08:56:08.213 I/    ( 1723): [3369.704102][ovx8b]:write serdes 1@0x36: 0x385c=0x60
01-01 08:56:08.213 I/    ( 1723): [3369.704102][ovx8b]:write serdes 1@0x36: 0x388c=0x01
01-01 08:56:08.213 I/    ( 1723): [3369.704346][ovx8b]:write serdes 1@0x36: 0x388d=0xee
01-01 08:56:08.213 I/    ( 1723): [3369.704590][ovx8b]:write serdes 1@0x36: 0x3b40=0x0f
01-01 08:56:08.213 I/    ( 1723): [3369.704590][ovx8b]:write serdes 1@0x36: 0x3b41=0x80
01-01 08:56:08.213 I/    ( 1723): [3369.705078][ovx8b]:write serdes 1@0x36: 0x3b42=0x00
01-01 08:56:08.214 I/    ( 1723): [3369.705078][ovx8b]:write serdes 1@0x36: 0x3b43=0x80
01-01 08:56:08.214 I/    ( 1723): [3369.705322][ovx8b]:write serdes 1@0x36: 0x3b4b=0x27
01-01 08:56:08.214 I/    ( 1723): [3369.705566][ovx8b]:write serdes 1@0x36: 0x3b4c=0x00
01-01 08:56:08.214 I/    ( 1723): [3369.705566][ovx8b]:write serdes 1@0x36: 0x3b4d=0x00
01-01 08:56:08.214 I/    ( 1723): [3369.705811][ovx8b]:write serdes 1@0x36: 0x3b82=0xe8
01-01 08:56:08.214 I/    ( 1723): [3369.706055][ovx8b]:write serdes 1@0x36: 0x3b85=0xe8
01-01 08:56:08.215 I/    ( 1723): [3369.706055][ovx8b]:write serdes 1@0x36: 0x3d8a=0x03
01-01 08:56:08.215 I/    ( 1723): [3369.706299][ovx8b]:write serdes 1@0x36: 0x3d8b=0xff
01-01 08:56:08.215 I/    ( 1723): [3369.706299][ovx8b]:write serdes 1@0x36: 0x4307=0x03
01-01 08:56:08.215 I/    ( 1723): [3369.706543][ovx8b]:write serdes 1@0x36: 0x4308=0x13
01-01 08:56:08.215 I/    ( 1723): [3369.706787][ovx8b]:write serdes 1@0x36: 0x430a=0x13
01-01 08:56:08.215 I/    ( 1723): [3369.706787][ovx8b]:write serdes 1@0x36: 0x430d=0x93
01-01 08:56:08.216 I/    ( 1723): [3369.707031][ovx8b]:write serdes 1@0x36: 0x430e=0x14
01-01 08:56:08.216 I/    ( 1723): [3369.707275][ovx8b]:write serdes 1@0x36: 0x430f=0x57
01-01 08:56:08.216 I/    ( 1723): [3369.707275][ovx8b]:write serdes 1@0x36: 0x4310=0x95
01-01 08:56:08.216 I/    ( 1723): [3369.707520][ovx8b]:write serdes 1@0x36: 0x4311=0x16
01-01 08:56:08.216 I/    ( 1723): [3369.707520][ovx8b]:write serdes 1@0x36: 0x4316=0x00
01-01 08:56:08.216 I/    ( 1723): [3369.707764][ovx8b]:write serdes 1@0x36: 0x4317=0x38
01-01 08:56:08.216 I/    ( 1723): [3369.708008][ovx8b]:write serdes 1@0x36: 0x4318=0x12
01-01 08:56:08.217 I/    ( 1723): [3369.708008][ovx8b]:write serdes 1@0x36: 0x4319=0x03
01-01 08:56:08.217 I/    ( 1723): [3369.708252][ovx8b]:write serdes 1@0x36: 0x431b=0x00
01-01 08:56:08.217 I/    ( 1723): [3369.708496][ovx8b]:write serdes 1@0x36: 0x431d=0x2a
01-01 08:56:08.217 I/    ( 1723): [3369.708496][ovx8b]:write serdes 1@0x36: 0x431e=0x11
01-01 08:56:08.217 I/    ( 1723): [3369.708740][ovx8b]:write serdes 1@0x36: 0x431f=0x20
01-01 08:56:08.217 I/    ( 1723): [3369.708984][ovx8b]:write serdes 1@0x36: 0x4320=0x01
01-01 08:56:08.218 I/    ( 1723): [3369.708984][ovx8b]:write serdes 1@0x36: 0x4323=0x80
01-01 08:56:08.218 I/    ( 1723): [3369.709229][ovx8b]:write serdes 1@0x36: 0x4502=0xf2
01-01 08:56:08.218 I/    ( 1723): [3369.709229][ovx8b]:write serdes 1@0x36: 0x4503=0x4e
01-01 08:56:08.218 I/    ( 1723): [3369.709473][ovx8b]:write serdes 1@0x36: 0x4505=0x00
01-01 08:56:08.218 I/    ( 1723): [3369.709717][ovx8b]:write serdes 1@0x36: 0x4506=0x64
01-01 08:56:08.218 I/    ( 1723): [3369.709717][ovx8b]:write serdes 1@0x36: 0x4508=0x10
01-01 08:56:08.219 I/    ( 1723): [3369.709961][ovx8b]:write serdes 1@0x36: 0x4509=0x00
01-01 08:56:08.219 I/    ( 1723): [3369.710449][ovx8b]:write serdes 1@0x36: 0x450a=0x00
01-01 08:56:08.219 I/    ( 1723): [3369.710449][ovx8b]:write serdes 1@0x36: 0x4581=0xc7
01-01 08:56:08.219 I/    ( 1723): [3369.710693][ovx8b]:write serdes 1@0x36: 0x4583=0x07
01-01 08:56:08.219 I/    ( 1723): [3369.710693][ovx8b]:write serdes 1@0x36: 0x4584=0xec
01-01 08:56:08.219 I/    ( 1723): [3369.710938][ovx8b]:write serdes 1@0x36: 0x4585=0x09
01-01 08:56:08.220 I/    ( 1723): [3369.711182][ovx8b]:write serdes 1@0x36: 0x4586=0xae
01-01 08:56:08.220 I/    ( 1723): [3369.711182][ovx8b]:write serdes 1@0x36: 0x458f=0x00
01-01 08:56:08.220 I/    ( 1723): [3369.711426][ovx8b]:write serdes 1@0x36: 0x4590=0x20
01-01 08:56:08.220 I/    ( 1723): [3369.711670][ovx8b]:write serdes 1@0x36: 0x4597=0x00
01-01 08:56:08.220 I/    ( 1723): [3369.711670][ovx8b]:write serdes 1@0x36: 0x4599=0x0f
01-01 08:56:08.220 I/    ( 1723): [3369.711914][ovx8b]:write serdes 1@0x36: 0x459a=0x0f
01-01 08:56:08.221 I/    ( 1723): [3369.712158][ovx8b]:write serdes 1@0x36: 0x4602=0x00
01-01 08:56:08.221 I/    ( 1723): [3369.712158][ovx8b]:write serdes 1@0x36: 0x4603=0x13
01-01 08:56:08.221 I/    ( 1723): [3369.712402][ovx8b]:write serdes 1@0x36: 0x4604=0x00
01-01 08:56:08.221 I/    ( 1723): [3369.712402][ovx8b]:write serdes 1@0x36: 0x460a=0x30
01-01 08:56:08.221 I/    ( 1723): [3369.712646][ovx8b]:write serdes 1@0x36: 0x4610=0x00
01-01 08:56:08.221 I/    ( 1723): [3369.712891][ovx8b]:write serdes 1@0x36: 0x4611=0xe0
01-01 08:56:08.221 I/    ( 1723): [3369.712891][ovx8b]:write serdes 1@0x36: 0x4612=0x01
01-01 08:56:08.222 I/    ( 1723): [3369.713135][ovx8b]:write serdes 1@0x36: 0x4613=0x00
01-01 08:56:08.222 I/    ( 1723): [3369.713379][ovx8b]:write serdes 1@0x36: 0x4614=0x00
01-01 08:56:08.222 I/    ( 1723): [3369.713379][ovx8b]:write serdes 1@0x36: 0x4615=0xe0
01-01 08:56:08.222 I/    ( 1723): [3369.713623][ovx8b]:write serdes 1@0x36: 0x4616=0x01
01-01 08:56:08.222 I/    ( 1723): [3369.713623][ovx8b]:write serdes 1@0x36: 0x4617=0x00
01-01 08:56:08.222 I/    ( 1723): [3369.713867][ovx8b]:write serdes 1@0x36: 0x4700=0xe0
01-01 08:56:08.223 I/    ( 1723): [3369.714111][ovx8b]:write serdes 1@0x36: 0x4800=0x04
01-01 08:56:08.223 I/    ( 1723): [3369.714111][ovx8b]:write serdes 1@0x36: 0x480a=0x22
01-01 08:56:08.223 I/    ( 1723): [3369.714355][ovx8b]:write serdes 1@0x36: 0x480e=0x04
01-01 08:56:08.223 I/    ( 1723): [3369.714600][ovx8b]:write serdes 1@0x36: 0x4813=0xe4
01-01 08:56:08.223 I/    ( 1723): [3369.714600][ovx8b]:write serdes 1@0x36: 0x4814=0x2a
01-01 08:56:08.223 I/    ( 1723): [3369.714844][ovx8b]:write serdes 1@0x36: 0x481f=0x30
01-01 08:56:08.224 I/    ( 1723): [3369.715088][ovx8b]:write serdes 1@0x36: 0x4833=0x15
01-01 08:56:08.224 I/    ( 1723): [3369.715088][ovx8b]:write serdes 1@0x36: 0x4837=0x07
01-01 08:56:08.224 I/    ( 1723): [3369.715576][ovx8b]:write serdes 1@0x36: 0x484b=0x47
01-01 08:56:08.224 I/    ( 1723): [3369.715576][ovx8b]:write serdes 1@0x36: 0x484f=0x00
01-01 08:56:08.224 I/    ( 1723): [3369.715820][ovx8b]:write serdes 1@0x36: 0x4850=0x47
01-01 08:56:08.224 I/    ( 1723): [3369.716064][ovx8b]:write serdes 1@0x36: 0x4861=0xcc
01-01 08:56:08.225 I/    ( 1723): [3369.716064][ovx8b]:write serdes 1@0x36: 0x4884=0x08
01-01 08:56:08.225 I/    ( 1723): [3369.716309][ovx8b]:write serdes 1@0x36: 0x4889=0x00
01-01 08:56:08.225 I/    ( 1723): [3369.716553][ovx8b]:write serdes 1@0x36: 0x4d00=0x4a
01-01 08:56:08.225 I/    ( 1723): [3369.716553][ovx8b]:write serdes 1@0x36: 0x4d01=0x18
01-01 08:56:08.225 I/    ( 1723): [3369.716797][ovx8b]:write serdes 1@0x36: 0x4d05=0xff
01-01 08:56:08.225 I/    ( 1723): [3369.716797][ovx8b]:write serdes 1@0x36: 0x4d06=0x88
01-01 08:56:08.226 I/    ( 1723): [3369.717041][ovx8b]:write serdes 1@0x36: 0x4d08=0x23
01-01 08:56:08.226 I/    ( 1723): [3369.717285][ovx8b]:write serdes 1@0x36: 0x4d09=0xdf
01-01 08:56:08.226 I/    ( 1723): [3369.717285][ovx8b]:write serdes 1@0x36: 0x4d15=0x7d
01-01 08:56:08.226 I/    ( 1723): [3369.717529][ovx8b]:write serdes 1@0x36: 0x4d1a=0x20
01-01 08:56:08.226 I/    ( 1723): [3369.717773][ovx8b]:write serdes 1@0x36: 0x4d34=0x7d
01-01 08:56:08.226 I/    ( 1723): [3369.717773][ovx8b]:write serdes 1@0x36: 0x4d3c=0x7d
01-01 08:56:08.227 I/    ( 1723): [3369.718018][ovx8b]:write serdes 1@0x36: 0x4d3e=0x4a
01-01 08:56:08.227 I/    ( 1723): [3369.718262][ovx8b]:write serdes 1@0x36: 0x4d3f=0x18
01-01 08:56:08.227 I/    ( 1723): [3369.718262][ovx8b]:write serdes 1@0x36: 0x4d40=0xbb
01-01 08:56:08.227 I/    ( 1723): [3369.718506][ovx8b]:write serdes 1@0x36: 0x4d41=0xde
01-01 08:56:08.227 I/    ( 1723): [3369.718506][ovx8b]:write serdes 1@0x36: 0x4d42=0x93
01-01 08:56:08.227 I/    ( 1723): [3369.718750][ovx8b]:write serdes 1@0x36: 0x4d43=0xff
01-01 08:56:08.227 I/    ( 1723): [3369.718994][ovx8b]:write serdes 1@0x36: 0x4d5a=0x10
01-01 08:56:08.228 I/    ( 1723): [3369.718994][ovx8b]:write serdes 1@0x36: 0x4f00=0x3f
01-01 08:56:08.228 I/    ( 1723): [3369.719238][ovx8b]:write serdes 1@0x36: 0x4f01=0xff
01-01 08:56:08.228 I/    ( 1723): [3369.719482][ovx8b]:write serdes 1@0x36: 0x4f02=0xff
01-01 08:56:08.228 I/    ( 1723): [3369.719482][ovx8b]:write serdes 1@0x36: 0x4f03=0x2d
01-01 08:56:08.228 I/    ( 1723): [3369.719727][ovx8b]:write serdes 1@0x36: 0x4f04=0x00
01-01 08:56:08.228 I/    ( 1723): [3369.719727][ovx8b]:write serdes 1@0x36: 0x6a00=0x00
01-01 08:56:08.229 I/    ( 1723): [3369.719971][ovx8b]:write serdes 1@0x36: 0x6a01=0x20
01-01 08:56:08.229 I/    ( 1723): [3369.720215][ovx8b]:write serdes 1@0x36: 0x6a02=0x00
01-01 08:56:08.229 I/    ( 1723): [3369.720215][ovx8b]:write serdes 1@0x36: 0x6a03=0x20
01-01 08:56:08.229 I/    ( 1723): [3369.720459][ovx8b]:write serdes 1@0x36: 0x6a04=0x02
01-01 08:56:08.229 I/    ( 1723): [3369.720947][ovx8b]:write serdes 1@0x36: 0x6a05=0x80
01-01 08:56:08.229 I/    ( 1723): [3369.720947][ovx8b]:write serdes 1@0x36: 0x6a06=0x01
01-01 08:56:08.230 I/    ( 1723): [3369.721191][ovx8b]:write serdes 1@0x36: 0x6a07=0xe0
01-01 08:56:08.230 I/    ( 1723): [3369.721436][ovx8b]:write serdes 1@0x36: 0x6a08=0xcf
01-01 08:56:08.230 I/    ( 1723): [3369.721436][ovx8b]:write serdes 1@0x36: 0x6a09=0x01
01-01 08:56:08.230 I/    ( 1723): [3369.721680][ovx8b]:write serdes 1@0x36: 0x6a0a=0x40
01-01 08:56:08.230 I/    ( 1723): [3369.721680][ovx8b]:write serdes 1@0x36: 0x6a20=0x00
01-01 08:56:08.230 I/    ( 1723): [3369.721924][ovx8b]:write serdes 1@0x36: 0x6a21=0x02
01-01 08:56:08.231 I/    ( 1723): [3369.722168][ovx8b]:write serdes 1@0x36: 0x6a22=0x00
01-01 08:56:08.231 I/    ( 1723): [3369.722168][ovx8b]:write serdes 1@0x36: 0x6a23=0x00
01-01 08:56:08.231 I/    ( 1723): [3369.722412][ovx8b]:write serdes 1@0x36: 0x6a24=0x00
01-01 08:56:08.231 I/    ( 1723): [3369.722656][ovx8b]:write serdes 1@0x36: 0x6a25=0x00
01-01 08:56:08.231 I/    ( 1723): [3369.722656][ovx8b]:write serdes 1@0x36: 0x6a26=0x00
01-01 08:56:08.231 I/    ( 1723): [3369.722900][ovx8b]:write serdes 1@0x36: 0x6a27=0x00
01-01 08:56:08.232 I/    ( 1723): [3369.722900][ovx8b]:write serdes 1@0x36: 0x6a28=0x00
01-01 08:56:08.232 I/    ( 1723): [3369.723145][ovx8b]:write serdes 1@0x36: 0x6a29=0x01
01-01 08:56:08.232 I/    ( 1723): [3369.723389][ovx8b]:write serdes 1@0x36: 0x5180=0x80
01-01 08:56:08.232 I/    ( 1723): [3369.723389][ovx8b]:write serdes 1@0x36: 0x5181=0x0b
01-01 08:56:08.232 I/    ( 1723): [3369.723633][ovx8b]:write serdes 1@0x36: 0x5182=0xf0
01-01 08:56:08.232 I/    ( 1723): [3369.723877][ovx8b]:write serdes 1@0x36: 0x5183=0x20
01-01 08:56:08.232 I/    ( 1723): [3369.723877][ovx8b]:write serdes 1@0x36: 0x5184=0x86
01-01 08:56:08.233 I/    ( 1723): [3369.724121][ovx8b]:write serdes 1@0x36: 0x5188=0x85
01-01 08:56:08.233 I/    ( 1723): [3369.724365][ovx8b]:write serdes 1@0x36: 0x518c=0x81
01-01 08:56:08.233 I/    ( 1723): [3369.724365][ovx8b]:write serdes 1@0x36: 0x5190=0x86
01-01 08:56:08.233 I/    ( 1723): [3369.724609][ovx8b]:write serdes 1@0x36: 0x5194=0x85
01-01 08:56:08.233 I/    ( 1723): [3369.724609][ovx8b]:write serdes 1@0x36: 0x5198=0x81
01-01 08:56:08.233 I/    ( 1723): [3369.724854][ovx8b]:write serdes 1@0x36: 0x519c=0x86
01-01 08:56:08.234 I/    ( 1723): [3369.725098][ovx8b]:write serdes 1@0x36: 0x51a0=0x85
01-01 08:56:08.234 I/    ( 1723): [3369.725098][ovx8b]:write serdes 1@0x36: 0x51a4=0x86
01-01 08:56:08.234 I/    ( 1723): [3369.725342][ovx8b]:write serdes 1@0x36: 0x51a8=0x82
01-01 08:56:08.234 I/    ( 1723): [3369.725586][ovx8b]:write serdes 1@0x36: 0x51ac=0x84
01-01 08:56:08.234 I/    ( 1723): [3369.725586][ovx8b]:write serdes 1@0x36: 0x5d0d=0x0a
01-01 08:56:08.234 I/    ( 1723): [3369.725830][ovx8b]:write serdes 1@0x36: 0x5d0e=0x0a
01-01 08:56:08.235 I/    ( 1723): [3369.725830][ovx8b]:write serdes 1@0x36: 0x5d0f=0x0a
01-01 08:56:08.235 I/    ( 1723): [3369.726318][ovx8b]:write serdes 1@0x36: 0x5d11=0x10
01-01 08:56:08.235 I/    ( 1723): [3369.726562][ovx8b]:write serdes 1@0x36: 0x5d12=0x10
01-01 08:56:08.235 I/    ( 1723): [3369.726562][ovx8b]:write serdes 1@0x36: 0x5d13=0x10
01-01 08:56:08.235 I/    ( 1723): [3369.726807][ovx8b]:write serdes 1@0x36: 0x5d15=0x05
01-01 08:56:08.235 I/    ( 1723): [3369.727051][ovx8b]:write serdes 1@0x36: 0x5d16=0x05
01-01 08:56:08.236 I/    ( 1723): [3369.727051][ovx8b]:write serdes 1@0x36: 0x5d17=0x05
01-01 08:56:08.236 I/    ( 1723): [3369.727295][ovx8b]:write serdes 1@0x36: 0x5d1f=0x81
01-01 08:56:08.236 I/    ( 1723): [3369.727539][ovx8b]:write serdes 1@0x36: 0x5300=0xc2
01-01 08:56:08.236 I/    ( 1723): [3369.727539][ovx8b]:write serdes 1@0x36: 0x5314=0x70
01-01 08:56:08.236 I/    ( 1723): [3369.727783][ovx8b]:write serdes 1@0x36: 0x5315=0x70
01-01 08:56:08.236 I/    ( 1723): [3369.727783][ovx8b]:write serdes 1@0x36: 0x5316=0x73
01-01 08:56:08.237 I/    ( 1723): [3369.728027][ovx8b]:write serdes 1@0x36: 0x5317=0xff
01-01 08:56:08.237 I/    ( 1723): [3369.728271][ovx8b]:write serdes 1@0x36: 0x5b80=0x00
01-01 08:56:08.237 I/    ( 1723): [3369.728271][ovx8b]:write serdes 1@0x36: 0x5b84=0x03
01-01 08:56:08.237 I/    ( 1723): [3369.728516][ovx8b]:write serdes 1@0x36: 0x5b85=0x9a
01-01 08:56:08.237 I/    ( 1723): [3369.728760][ovx8b]:write serdes 1@0x36: 0x5b8e=0x20
01-01 08:56:08.237 I/    ( 1723): [3369.728760][ovx8b]:write serdes 1@0x36: 0x5b92=0x60
01-01 08:56:08.238 I/    ( 1723): [3369.729004][ovx8b]:write serdes 1@0x36: 0x5b93=0x10
01-01 08:56:08.238 I/    ( 1723): [3369.729004][ovx8b]:write serdes 1@0x36: 0x5b96=0x60
01-01 08:56:08.238 I/    ( 1723): [3369.729248][ovx8b]:write serdes 1@0x36: 0x5b97=0x40
01-01 08:56:08.238 I/    ( 1723): [3369.729492][ovx8b]:write serdes 1@0x36: 0x5b98=0x00
01-01 08:56:08.238 I/    ( 1723): [3369.729492][ovx8b]:write serdes 1@0x36: 0x5b99=0x80
01-01 08:56:08.238 I/    ( 1723): [3369.729736][ovx8b]:write serdes 1@0x36: 0x5b9a=0x80
01-01 08:56:08.238 I/    ( 1723): [3369.729980][ovx8b]:write serdes 1@0x36: 0x5b9b=0x40
01-01 08:56:08.239 I/    ( 1723): [3369.729980][ovx8b]:write serdes 1@0x36: 0x5b9c=0x00
01-01 08:56:08.239 I/    ( 1723): [3369.730225][ovx8b]:write serdes 1@0x36: 0x5b9d=0x00
01-01 08:56:08.239 I/    ( 1723): [3369.730469][ovx8b]:write serdes 1@0x36: 0x5b9e=0x80
01-01 08:56:08.239 I/    ( 1723): [3369.730469][ovx8b]:write serdes 1@0x36: 0x5b9f=0x80
01-01 08:56:08.239 I/    ( 1723): [3369.730713][ovx8b]:write serdes 1@0x36: 0x5ba0=0x00
01-01 08:56:08.239 I/    ( 1723): [3369.730713][ovx8b]:write serdes 1@0x36: 0x5ba1=0x00
01-01 08:56:08.240 I/    ( 1723): [3369.730957][ovx8b]:write serdes 1@0x36: 0x5ba2=0x00
01-01 08:56:08.240 I/    ( 1723): [3369.731445][ovx8b]:write serdes 1@0x36: 0x5ba3=0x80
01-01 08:56:08.240 I/    ( 1723): [3369.731445][ovx8b]:write serdes 1@0x36: 0x5ba4=0x80
01-01 08:56:08.240 I/    ( 1723): [3369.731689][ovx8b]:write serdes 1@0x36: 0x5ba5=0x00
01-01 08:56:08.240 I/    ( 1723): [3369.731934][ovx8b]:write serdes 1@0x36: 0x5ba6=0x00
01-01 08:56:08.240 I/    ( 1723): [3369.731934][ovx8b]:write serdes 1@0x36: 0x5ba7=0x00
01-01 08:56:08.241 I/    ( 1723): [3369.732178][ovx8b]:write serdes 1@0x36: 0x5bae=0x02
01-01 08:56:08.241 I/    ( 1723): [3369.732178][ovx8b]:write serdes 1@0x36: 0x5baf=0x00
01-01 08:56:08.241 I/    ( 1723): [3369.732422][ovx8b]:write serdes 1@0x36: 0x5bb0=0x02
01-01 08:56:08.241 I/    ( 1723): [3369.732666][ovx8b]:write serdes 1@0x36: 0x5bb1=0x76
01-01 08:56:08.241 I/    ( 1723): [3369.732666][ovx8b]:write serdes 1@0x36: 0x5bb2=0x03
01-01 08:56:08.241 I/    ( 1723): [3369.732910][ovx8b]:write serdes 1@0x36: 0x5bb3=0x08
01-01 08:56:08.242 I/    ( 1723): [3369.733154][ovx8b]:write serdes 1@0x36: 0x5bb4=0x04
01-01 08:56:08.242 I/    ( 1723): [3369.733154][ovx8b]:write serdes 1@0x36: 0x5bb5=0x67
01-01 08:56:08.242 I/    ( 1723): [3369.733398][ovx8b]:write serdes 1@0x36: 0x5bba=0x10
01-01 08:56:08.242 I/    ( 1723): [3369.733643][ovx8b]:write serdes 1@0x36: 0x5bbe=0x0a
01-01 08:56:08.242 I/    ( 1723): [3369.733643][ovx8b]:write serdes 1@0x36: 0x5c00=0x00
01-01 08:56:08.242 I/    ( 1723): [3369.733887][ovx8b]:write serdes 1@0x36: 0x5c04=0x03
01-01 08:56:08.243 I/    ( 1723): [3369.733887][ovx8b]:write serdes 1@0x36: 0x5c05=0x9a
01-01 08:56:08.243 I/    ( 1723): [3369.734131][ovx8b]:write serdes 1@0x36: 0x5c0e=0x20
01-01 08:56:08.243 I/    ( 1723): [3369.734375][ovx8b]:write serdes 1@0x36: 0x5c12=0x60
01-01 08:56:08.243 I/    ( 1723): [3369.734375][ovx8b]:write serdes 1@0x36: 0x5c13=0x10
01-01 08:56:08.243 I/    ( 1723): [3369.734619][ovx8b]:write serdes 1@0x36: 0x5c16=0x60
01-01 08:56:08.243 I/    ( 1723): [3369.734863][ovx8b]:write serdes 1@0x36: 0x5c17=0x40
01-01 08:56:08.243 I/    ( 1723): [3369.734863][ovx8b]:write serdes 1@0x36: 0x5c18=0x00
01-01 08:56:08.244 I/    ( 1723): [3369.735107][ovx8b]:write serdes 1@0x36: 0x5c19=0x80
01-01 08:56:08.244 I/    ( 1723): [3369.735107][ovx8b]:write serdes 1@0x36: 0x5c1a=0x80
01-01 08:56:08.244 I/    ( 1723): [3369.735352][ovx8b]:write serdes 1@0x36: 0x5c1b=0x40
01-01 08:56:08.244 I/    ( 1723): [3369.735596][ovx8b]:write serdes 1@0x36: 0x5c1c=0x00
01-01 08:56:08.244 I/    ( 1723): [3369.735596][ovx8b]:write serdes 1@0x36: 0x5c1d=0x00
01-01 08:56:08.244 I/    ( 1723): [3369.735840][ovx8b]:write serdes 1@0x36: 0x5c1e=0x80
01-01 08:56:08.245 I/    ( 1723): [3369.736084][ovx8b]:write serdes 1@0x36: 0x5c1f=0x80
01-01 08:56:08.245 I/    ( 1723): [3369.736084][ovx8b]:write serdes 1@0x36: 0x5c20=0x00
01-01 08:56:08.245 I/    ( 1723): [3369.736328][ovx8b]:write serdes 1@0x36: 0x5c21=0x00
01-01 08:56:08.245 I/    ( 1723): [3369.736816][ovx8b]:write serdes 1@0x36: 0x5c22=0x00
01-01 08:56:08.245 I/    ( 1723): [3369.736816][ovx8b]:write serdes 1@0x36: 0x5c23=0x80
01-01 08:56:08.245 I/    ( 1723): [3369.737061][ovx8b]:write serdes 1@0x36: 0x5c24=0x80
01-01 08:56:08.246 I/    ( 1723): [3369.737305][ovx8b]:write serdes 1@0x36: 0x5c25=0x00
01-01 08:56:08.246 I/    ( 1723): [3369.737305][ovx8b]:write serdes 1@0x36: 0x5c26=0x00
01-01 08:56:08.246 I/    ( 1723): [3369.737549][ovx8b]:write serdes 1@0x36: 0x5c27=0x00
01-01 08:56:08.246 I/    ( 1723): [3369.737549][ovx8b]:write serdes 1@0x36: 0x5c2e=0x02
01-01 08:56:08.246 I/    ( 1723): [3369.737793][ovx8b]:write serdes 1@0x36: 0x5c2f=0x00
01-01 08:56:08.246 I/    ( 1723): [3369.738037][ovx8b]:write serdes 1@0x36: 0x5c30=0x02
01-01 08:56:08.247 I/    ( 1723): [3369.738037][ovx8b]:write serdes 1@0x36: 0x5c31=0x76
01-01 08:56:08.247 I/    ( 1723): [3369.738281][ovx8b]:write serdes 1@0x36: 0x5c32=0x03
01-01 08:56:08.247 I/    ( 1723): [3369.738525][ovx8b]:write serdes 1@0x36: 0x5c33=0x08
01-01 08:56:08.247 I/    ( 1723): [3369.738525][ovx8b]:write serdes 1@0x36: 0x5c34=0x04
01-01 08:56:08.247 I/    ( 1723): [3369.738770][ovx8b]:write serdes 1@0x36: 0x5c35=0x67
01-01 08:56:08.247 I/    ( 1723): [3369.738770][ovx8b]:write serdes 1@0x36: 0x5c3a=0x10
01-01 08:56:08.248 I/    ( 1723): [3369.739014][ovx8b]:write serdes 1@0x36: 0x5c3e=0x0a
01-01 08:56:08.248 I/    ( 1723): [3369.739258][ovx8b]:write serdes 1@0x36: 0x5c80=0x00
01-01 08:56:08.248 I/    ( 1723): [3369.739258][ovx8b]:write serdes 1@0x36: 0x5c84=0x03
01-01 08:56:08.248 I/    ( 1723): [3369.739502][ovx8b]:write serdes 1@0x36: 0x5c85=0x9a
01-01 08:56:08.248 I/    ( 1723): [3369.739746][ovx8b]:write serdes 1@0x36: 0x5c8e=0x20
01-01 08:56:08.248 I/    ( 1723): [3369.739746][ovx8b]:write serdes 1@0x36: 0x5c92=0x60
01-01 08:56:08.249 I/    ( 1723): [3369.739990][ovx8b]:write serdes 1@0x36: 0x5c93=0x10
01-01 08:56:08.249 I/    ( 1723): [3369.740234][ovx8b]:write serdes 1@0x36: 0x5c96=0x60
01-01 08:56:08.249 I/    ( 1723): [3369.740234][ovx8b]:write serdes 1@0x36: 0x5c97=0x40
01-01 08:56:08.249 I/    ( 1723): [3369.740479][ovx8b]:write serdes 1@0x36: 0x5c98=0x00
01-01 08:56:08.249 I/    ( 1723): [3369.740479][ovx8b]:write serdes 1@0x36: 0x5c99=0x80
01-01 08:56:08.249 I/    ( 1723): [3369.740723][ovx8b]:write serdes 1@0x36: 0x5c9a=0x80
01-01 08:56:08.250 I/    ( 1723): [3369.740967][ovx8b]:write serdes 1@0x36: 0x5c9b=0x40
01-01 08:56:08.250 I/    ( 1723): [3369.740967][ovx8b]:write serdes 1@0x36: 0x5c9c=0x00
01-01 08:56:08.250 I/    ( 1723): [3369.741211][ovx8b]:write serdes 1@0x36: 0x5c9d=0x00
01-01 08:56:08.250 I/    ( 1723): [3369.741455][ovx8b]:write serdes 1@0x36: 0x5c9e=0x80
01-01 08:56:08.250 I/    ( 1723): [3369.741455][ovx8b]:write serdes 1@0x36: 0x5c9f=0x80
01-01 08:56:08.250 I/    ( 1723): [3369.741943][ovx8b]:write serdes 1@0x36: 0x5ca0=0x00
01-01 08:56:08.250 I/    ( 1723): [3369.742188][ovx8b]:write serdes 1@0x36: 0x5ca1=0x00
01-01 08:56:08.251 I/    ( 1723): [3369.742188][ovx8b]:write serdes 1@0x36: 0x5ca2=0x00
01-01 08:56:08.251 I/    ( 1723): [3369.742432][ovx8b]:write serdes 1@0x36: 0x5ca3=0x80
01-01 08:56:08.251 I/    ( 1723): [3369.742432][ovx8b]:write serdes 1@0x36: 0x5ca4=0x80
01-01 08:56:08.251 I/    ( 1723): [3369.742676][ovx8b]:write serdes 1@0x36: 0x5ca5=0x00
01-01 08:56:08.251 I/    ( 1723): [3369.742920][ovx8b]:write serdes 1@0x36: 0x5ca6=0x00
01-01 08:56:08.251 I/    ( 1723): [3369.742920][ovx8b]:write serdes 1@0x36: 0x5ca7=0x00
01-01 08:56:08.252 I/    ( 1723): [3369.743164][ovx8b]:write serdes 1@0x36: 0x5cae=0x02
01-01 08:56:08.252 I/    ( 1723): [3369.743408][ovx8b]:write serdes 1@0x36: 0x5caf=0x00
01-01 08:56:08.252 I/    ( 1723): [3369.743408][ovx8b]:write serdes 1@0x36: 0x5cb0=0x02
01-01 08:56:08.252 I/    ( 1723): [3369.743652][ovx8b]:write serdes 1@0x36: 0x5cb1=0x76
01-01 08:56:08.252 I/    ( 1723): [3369.743652][ovx8b]:write serdes 1@0x36: 0x5cb2=0x03
01-01 08:56:08.252 I/    ( 1723): [3369.743896][ovx8b]:write serdes 1@0x36: 0x5cb3=0x08
01-01 08:56:08.253 I/    ( 1723): [3369.744141][ovx8b]:write serdes 1@0x36: 0x5cb4=0x04
01-01 08:56:08.253 I/    ( 1723): [3369.744141][ovx8b]:write serdes 1@0x36: 0x5cb5=0x67
01-01 08:56:08.253 I/    ( 1723): [3369.744385][ovx8b]:write serdes 1@0x36: 0x5cba=0x10
01-01 08:56:08.253 I/    ( 1723): [3369.744629][ovx8b]:write serdes 1@0x36: 0x5cbe=0x0a
01-01 08:56:08.253 I/    ( 1723): [3369.744629][ovx8b]:write serdes 1@0x36: 0x6006=0x00
01-01 08:56:08.253 I/    ( 1723): [3369.744873][ovx8b]:write serdes 1@0x36: 0x6007=0x3c
01-01 08:56:08.254 I/    ( 1723): [3369.744873][ovx8b]:write serdes 1@0x36: 0x6008=0x03
01-01 08:56:08.254 I/    ( 1723): [3369.745117][ovx8b]:write serdes 1@0x36: 0x6009=0x20
01-01 08:56:08.254 I/    ( 1723): [3369.745361][ovx8b]:write serdes 1@0x36: 0x600a=0x00
01-01 08:56:08.254 I/    ( 1723): [3369.745361][ovx8b]:write serdes 1@0x36: 0x600b=0x3c
01-01 08:56:08.254 I/    ( 1723): [3369.745605][ovx8b]:write serdes 1@0x36: 0x600c=0x03
01-01 08:56:08.254 I/    ( 1723): [3369.745850][ovx8b]:write serdes 1@0x36: 0x600d=0x20
01-01 08:56:08.254 I/    ( 1723): [3369.745850][ovx8b]:write serdes 1@0x36: 0x6016=0x00
01-01 08:56:08.255 I/    ( 1723): [3369.746094][ovx8b]:write serdes 1@0x36: 0x6026=0x00
01-01 08:56:08.255 I/    ( 1723): [3369.746338][ovx8b]:write serdes 1@0x36: 0x6027=0x3c
01-01 08:56:08.255 I/    ( 1723): [3369.746338][ovx8b]:write serdes 1@0x36: 0x6028=0x03
01-01 08:56:08.255 I/    ( 1723): [3369.746582][ovx8b]:write serdes 1@0x36: 0x6029=0x20
01-01 08:56:08.255 I/    ( 1723): [3369.746582][ovx8b]:write serdes 1@0x36: 0x602a=0x00
01-01 08:56:08.255 I/    ( 1723): [3369.746826][ovx8b]:write serdes 1@0x36: 0x602b=0x3c
01-01 08:56:08.256 I/    ( 1723): [3369.747314][ovx8b]:write serdes 1@0x36: 0x602c=0x03
01-01 08:56:08.256 I/    ( 1723): [3369.747314][ovx8b]:write serdes 1@0x36: 0x602d=0x20
01-01 08:56:08.256 I/    ( 1723): [3369.747559][ovx8b]:write serdes 1@0x36: 0x6036=0x01
01-01 08:56:08.256 I/    ( 1723): [3369.747803][ovx8b]:write serdes 1@0x36: 0x6046=0x00
01-01 08:56:08.256 I/    ( 1723): [3369.747803][ovx8b]:write serdes 1@0x36: 0x6047=0x3c
01-01 08:56:08.256 I/    ( 1723): [3369.748047][ovx8b]:write serdes 1@0x36: 0x6048=0x03
01-01 08:56:08.257 I/    ( 1723): [3369.748047][ovx8b]:write serdes 1@0x36: 0x6049=0x20
01-01 08:56:08.257 I/    ( 1723): [3369.748291][ovx8b]:write serdes 1@0x36: 0x604a=0x00
01-01 08:56:08.257 I/    ( 1723): [3369.748535][ovx8b]:write serdes 1@0x36: 0x604b=0x3c
01-01 08:56:08.257 I/    ( 1723): [3369.748535][ovx8b]:write serdes 1@0x36: 0x604c=0x03
01-01 08:56:08.257 I/    ( 1723): [3369.748779][ovx8b]:write serdes 1@0x36: 0x604d=0x20
01-01 08:56:08.257 I/    ( 1723): [3369.749023][ovx8b]:write serdes 1@0x36: 0x6056=0x02
01-01 08:56:08.258 I/    ( 1723): [3369.749023][ovx8b]:write serdes 1@0x36: 0x6067=0x3c
01-01 08:56:08.258 I/    ( 1723): [3369.749268][ovx8b]:write serdes 1@0x36: 0x6068=0x03
01-01 08:56:08.258 I/    ( 1723): [3369.749268][ovx8b]:write serdes 1@0x36: 0x6069=0x20
01-01 08:56:08.258 I/    ( 1723): [3369.749512][ovx8b]:write serdes 1@0x36: 0x606a=0x00
01-01 08:56:08.258 I/    ( 1723): [3369.749756][ovx8b]:write serdes 1@0x36: 0x606b=0x3c
01-01 08:56:08.258 I/    ( 1723): [3369.749756][ovx8b]:write serdes 1@0x36: 0x606c=0x03
01-01 08:56:08.259 I/    ( 1723): [3369.750000][ovx8b]:write serdes 1@0x36: 0x606d=0x20
01-01 08:56:08.259 I/    ( 1723): [3369.750244][ovx8b]:write serdes 1@0x36: 0x6076=0x03
01-01 08:56:08.259 I/    ( 1723): [3369.750244][ovx8b]:write serdes 1@0x36: 0x6086=0x00
01-01 08:56:08.259 I/    ( 1723): [3369.750488][ovx8b]:write serdes 1@0x36: 0x6087=0x3c
01-01 08:56:08.259 I/    ( 1723): [3369.750488][ovx8b]:write serdes 1@0x36: 0x6088=0x03
01-01 08:56:08.259 I/    ( 1723): [3369.750732][ovx8b]:write serdes 1@0x36: 0x6089=0x20
01-01 08:56:08.259 I/    ( 1723): [3369.750977][ovx8b]:write serdes 1@0x36: 0x608a=0x00
01-01 08:56:08.260 I/    ( 1723): [3369.750977][ovx8b]:write serdes 1@0x36: 0x608b=0x3c
01-01 08:56:08.260 I/    ( 1723): [3369.751221][ovx8b]:write serdes 1@0x36: 0x608c=0x03
01-01 08:56:08.260 I/    ( 1723): [3369.751465][ovx8b]:write serdes 1@0x36: 0x608d=0x20
01-01 08:56:08.260 I/    ( 1723): [3369.751465][ovx8b]:write serdes 1@0x36: 0x6096=0x04
01-01 08:56:08.260 I/    ( 1723): [3369.751709][ovx8b]:write serdes 1@0x36: 0x5e00=0x00
01-01 08:56:08.260 I/    ( 1723): [3369.751953][ovx8b]:write serdes 1@0x36: 0x5e01=0x08
01-01 08:56:08.261 I/    ( 1723): [3369.751953][ovx8b]:write serdes 1@0x36: 0x5e02=0x09
01-01 08:56:08.261 I/    ( 1723): [3369.752441][ovx8b]:write serdes 1@0x36: 0x5e03=0x0a
01-01 08:56:08.261 I/    ( 1723): [3369.752441][ovx8b]:write serdes 1@0x36: 0x5e04=0x0b
01-01 08:56:08.261 I/    ( 1723): [3369.752686][ovx8b]:write serdes 1@0x36: 0x5e05=0x0c
01-01 08:56:08.261 I/    ( 1723): [3369.752930][ovx8b]:write serdes 1@0x36: 0x5e06=0x0c
01-01 08:56:08.261 I/    ( 1723): [3369.752930][ovx8b]:write serdes 1@0x36: 0x5e07=0x0c
01-01 08:56:08.262 I/    ( 1723): [3369.753174][ovx8b]:write serdes 1@0x36: 0x5e08=0x0c
01-01 08:56:08.262 I/    ( 1723): [3369.753418][ovx8b]:write serdes 1@0x36: 0x5e09=0x0c
01-01 08:56:08.262 I/    ( 1723): [3369.753418][ovx8b]:write serdes 1@0x36: 0x5e0a=0x0d
01-01 08:56:08.262 I/    ( 1723): [3369.753662][ovx8b]:write serdes 1@0x36: 0x5e0b=0x0d
01-01 08:56:08.262 I/    ( 1723): [3369.753662][ovx8b]:write serdes 1@0x36: 0x5e0c=0x0d
01-01 08:56:08.262 I/    ( 1723): [3369.753906][ovx8b]:write serdes 1@0x36: 0x5e0d=0x0d
01-01 08:56:08.263 I/    ( 1723): [3369.754150][ovx8b]:write serdes 1@0x36: 0x5e0e=0x0d
01-01 08:56:08.263 I/    ( 1723): [3369.754150][ovx8b]:write serdes 1@0x36: 0x5e0f=0x0e
01-01 08:56:08.263 I/    ( 1723): [3369.754395][ovx8b]:write serdes 1@0x36: 0x5e10=0x0e
01-01 08:56:08.263 I/    ( 1723): [3369.754639][ovx8b]:write serdes 1@0x36: 0x5e11=0x0e
01-01 08:56:08.263 I/    ( 1723): [3369.754639][ovx8b]:write serdes 1@0x36: 0x5e12=0x0e
01-01 08:56:08.263 I/    ( 1723): [3369.754883][ovx8b]:write serdes 1@0x36: 0x5e13=0x0f
01-01 08:56:08.264 I/    ( 1723): [3369.755127][ovx8b]:write serdes 1@0x36: 0x5e14=0x0f
01-01 08:56:08.264 I/    ( 1723): [3369.755127][ovx8b]:write serdes 1@0x36: 0x5e15=0x10
01-01 08:56:08.264 I/    ( 1723): [3369.755371][ovx8b]:write serdes 1@0x36: 0x5e16=0x11
01-01 08:56:08.264 I/    ( 1723): [3369.755371][ovx8b]:write serdes 1@0x36: 0x5e17=0x11
01-01 08:56:08.264 I/    ( 1723): [3369.755615][ovx8b]:write serdes 1@0x36: 0x5e18=0x12
01-01 08:56:08.264 I/    ( 1723): [3369.755859][ovx8b]:write serdes 1@0x36: 0x5e19=0x12
01-01 08:56:08.264 I/    ( 1723): [3369.755859][ovx8b]:write serdes 1@0x36: 0x5e1a=0x13
01-01 08:56:08.265 I/    ( 1723): [3369.756104][ovx8b]:write serdes 1@0x36: 0x5e1b=0x13
01-01 08:56:08.265 I/    ( 1723): [3369.756348][ovx8b]:write serdes 1@0x36: 0x5e1c=0x14
01-01 08:56:08.265 I/    ( 1723): [3369.756348][ovx8b]:write serdes 1@0x36: 0x5e1d=0x14
01-01 08:56:08.265 I/    ( 1723): [3369.756592][ovx8b]:write serdes 1@0x36: 0x5e1e=0x16
01-01 08:56:08.265 I/    ( 1723): [3369.756836][ovx8b]:write serdes 1@0x36: 0x5e1f=0x16
01-01 08:56:08.266 I/    ( 1723): [3369.756836][ovx8b]:write serdes 1@0x36: 0x5e20=0x16
01-01 08:56:08.266 I/    ( 1723): [3369.757080][ovx8b]:write serdes 1@0x36: 0x5e21=0x08
01-01 08:56:08.266 I/    ( 1723): [3369.757324][ovx8b]:write serdes 1@0x36: 0x5e22=0x00
01-01 08:56:08.266 I/    ( 1723): [3369.757324][ovx8b]:write serdes 1@0x36: 0x5e23=0x01
01-01 08:56:08.266 I/    ( 1723): [3369.757812][ovx8b]:write serdes 1@0x36: 0x5e24=0x00
01-01 08:56:08.266 I/    ( 1723): [3369.757812][ovx8b]:write serdes 1@0x36: 0x5e25=0x00
01-01 08:56:08.266 I/    ( 1723): [3369.758057][ovx8b]:write serdes 1@0x36: 0x5e26=0x00
01-01 08:56:08.267 I/    ( 1723): [3369.758301][ovx8b]:write serdes 1@0x36: 0x5e27=0x40
01-01 08:56:08.267 I/    ( 1723): [3369.758301][ovx8b]:write serdes 1@0x36: 0x5e28=0x00
01-01 08:56:08.267 I/    ( 1723): [3369.758545][ovx8b]:write serdes 1@0x36: 0x5e29=0x00
01-01 08:56:08.267 I/    ( 1723): [3369.758789][ovx8b]:write serdes 1@0x36: 0x5e2a=0x40
01-01 08:56:08.267 I/    ( 1723): [3369.758789][ovx8b]:write serdes 1@0x36: 0x5e2b=0x00
01-01 08:56:08.267 I/    ( 1723): [3369.759033][ovx8b]:write serdes 1@0x36: 0x5e2c=0x00
01-01 08:56:08.268 I/    ( 1723): [3369.759277][ovx8b]:write serdes 1@0x36: 0x5e2d=0x40
01-01 08:56:08.268 I/    ( 1723): [3369.759277][ovx8b]:write serdes 1@0x36: 0x5e2e=0x00
01-01 08:56:08.268 I/    ( 1723): [3369.759521][ovx8b]:write serdes 1@0x36: 0x5e2f=0x00
01-01 08:56:08.268 I/    ( 1723): [3369.759521][ovx8b]:write serdes 1@0x36: 0x5e30=0x40
01-01 08:56:08.268 I/    ( 1723): [3369.759766][ovx8b]:write serdes 1@0x36: 0x5e31=0x00
01-01 08:56:08.268 I/    ( 1723): [3369.760010][ovx8b]:write serdes 1@0x36: 0x5e32=0x00
01-01 08:56:08.269 I/    ( 1723): [3369.760010][ovx8b]:write serdes 1@0x36: 0x5e33=0x40
01-01 08:56:08.269 I/    ( 1723): [3369.760254][ovx8b]:write serdes 1@0x36: 0x5e34=0x00
01-01 08:56:08.269 I/    ( 1723): [3369.760498][ovx8b]:write serdes 1@0x36: 0x5e35=0x00
01-01 08:56:08.269 I/    ( 1723): [3369.760498][ovx8b]:write serdes 1@0x36: 0x5e36=0x40
01-01 08:56:08.269 I/    ( 1723): [3369.760742][ovx8b]:write serdes 1@0x36: 0x5e37=0x00
01-01 08:56:08.269 I/    ( 1723): [3369.760742][ovx8b]:write serdes 1@0x36: 0x5e38=0x00
01-01 08:56:08.270 I/    ( 1723): [3369.760986][ovx8b]:write serdes 1@0x36: 0x5e39=0x40
01-01 08:56:08.270 I/    ( 1723): [3369.761230][ovx8b]:write serdes 1@0x36: 0x5e3a=0x00
01-01 08:56:08.270 I/    ( 1723): [3369.761230][ovx8b]:write serdes 1@0x36: 0x5e3b=0x00
01-01 08:56:08.270 I/    ( 1723): [3369.761475][ovx8b]:write serdes 1@0x36: 0x5e3c=0x40
01-01 08:56:08.270 I/    ( 1723): [3369.761719][ovx8b]:write serdes 1@0x36: 0x5e3d=0x00
01-01 08:56:08.270 I/    ( 1723): [3369.761719][ovx8b]:write serdes 1@0x36: 0x5e3e=0x00
01-01 08:56:08.271 I/    ( 1723): [3369.761963][ovx8b]:write serdes 1@0x36: 0x5e3f=0x40
01-01 08:56:08.271 I/    ( 1723): [3369.762207][ovx8b]:write serdes 1@0x36: 0x5e40=0x00
01-01 08:56:08.271 I/    ( 1723): [3369.762207][ovx8b]:write serdes 1@0x36: 0x5e41=0x00
01-01 08:56:08.271 I/    ( 1723): [3369.762451][ovx8b]:write serdes 1@0x36: 0x5e42=0x40
01-01 08:56:08.271 I/    ( 1723): [3369.762451][ovx8b]:write serdes 1@0x36: 0x5e43=0x00
01-01 08:56:08.271 I/    ( 1723): [3369.762695][ovx8b]:write serdes 1@0x36: 0x5e44=0x00
01-01 08:56:08.272 I/    ( 1723): [3369.763184][ovx8b]:write serdes 1@0x36: 0x5e45=0x40
01-01 08:56:08.272 I/    ( 1723): [3369.763184][ovx8b]:write serdes 1@0x36: 0x5e46=0x00
01-01 08:56:08.272 I/    ( 1723): [3369.763428][ovx8b]:write serdes 1@0x36: 0x5e47=0x00
01-01 08:56:08.272 I/    ( 1723): [3369.763672][ovx8b]:write serdes 1@0x36: 0x5e48=0x40
01-01 08:56:08.272 I/    ( 1723): [3369.763672][ovx8b]:write serdes 1@0x36: 0x5e49=0x00
01-01 08:56:08.272 I/    ( 1723): [3369.763916][ovx8b]:write serdes 1@0x36: 0x5e4a=0x00
01-01 08:56:08.272 I/    ( 1723): [3369.763916][ovx8b]:write serdes 1@0x36: 0x5e4b=0x40
01-01 08:56:08.273 I/    ( 1723): [3369.764160][ovx8b]:write serdes 1@0x36: 0x5e4c=0x00
01-01 08:56:08.273 I/    ( 1723): [3369.764404][ovx8b]:write serdes 1@0x36: 0x5e4d=0x00
01-01 08:56:08.273 I/    ( 1723): [3369.764404][ovx8b]:write serdes 1@0x36: 0x5e4e=0x40
01-01 08:56:08.273 I/    ( 1723): [3369.764648][ovx8b]:write serdes 1@0x36: 0x5e4f=0x00
01-01 08:56:08.273 I/    ( 1723): [3369.764893][ovx8b]:write serdes 1@0x36: 0x5e50=0x00
01-01 08:56:08.273 I/    ( 1723): [3369.764893][ovx8b]:write serdes 1@0x36: 0x5e51=0x40
01-01 08:56:08.274 I/    ( 1723): [3369.765137][ovx8b]:write serdes 1@0x36: 0x5e52=0x00
01-01 08:56:08.274 I/    ( 1723): [3369.765381][ovx8b]:write serdes 1@0x36: 0x5e53=0x00
01-01 08:56:08.274 I/    ( 1723): [3369.765381][ovx8b]:write serdes 1@0x36: 0x5e54=0x40
01-01 08:56:08.274 I/    ( 1723): [3369.765625][ovx8b]:write serdes 1@0x36: 0x5e55=0x00
01-01 08:56:08.274 I/    ( 1723): [3369.765625][ovx8b]:write serdes 1@0x36: 0x5e56=0x00
01-01 08:56:08.274 I/    ( 1723): [3369.765869][ovx8b]:write serdes 1@0x36: 0x5e57=0x40
01-01 08:56:08.275 I/    ( 1723): [3369.766113][ovx8b]:write serdes 1@0x36: 0x5e58=0x00
01-01 08:56:08.275 I/    ( 1723): [3369.766113][ovx8b]:write serdes 1@0x36: 0x5e59=0x00
01-01 08:56:08.275 I/    ( 1723): [3369.766357][ovx8b]:write serdes 1@0x36: 0x5e5a=0x80
01-01 08:56:08.275 I/    ( 1723): [3369.766602][ovx8b]:write serdes 1@0x36: 0x5e5b=0x00
01-01 08:56:08.275 I/    ( 1723): [3369.766602][ovx8b]:write serdes 1@0x36: 0x5e5c=0x00
01-01 08:56:08.275 I/    ( 1723): [3369.766846][ovx8b]:write serdes 1@0x36: 0x5e5d=0x80
01-01 08:56:08.276 I/    ( 1723): [3369.766846][ovx8b]:write serdes 1@0x36: 0x5e5e=0x00
01-01 08:56:08.276 I/    ( 1723): [3369.767090][ovx8b]:write serdes 1@0x36: 0x5e5f=0x01
01-01 08:56:08.276 I/    ( 1723): [3369.767334][ovx8b]:write serdes 1@0x36: 0x5e60=0x00
01-01 08:56:08.276 I/    ( 1723): [3369.767334][ovx8b]:write serdes 1@0x36: 0x5e61=0x00
01-01 08:56:08.276 I/    ( 1723): [3369.767578][ovx8b]:write serdes 1@0x36: 0x5e62=0x01
01-01 08:56:08.276 I/    ( 1723): [3369.767822][ovx8b]:write serdes 1@0x36: 0x5e63=0x00
01-01 08:56:08.277 I/    ( 1723): [3369.767822][ovx8b]:write serdes 1@0x36: 0x5e64=0x00
01-01 08:56:08.277 I/    ( 1723): [3369.768311][ovx8b]:write serdes 1@0x36: 0x5e65=0x01
01-01 08:56:08.277 I/    ( 1723): [3369.768555][ovx8b]:write serdes 1@0x36: 0x5e66=0x00
01-01 08:56:08.277 I/    ( 1723): [3369.768555][ovx8b]:write serdes 1@0x36: 0x5e67=0x00
01-01 08:56:08.277 I/    ( 1723): [3369.768799][ovx8b]:write serdes 1@0x36: 0x5e68=0x01
01-01 08:56:08.277 I/    ( 1723): [3369.768799][ovx8b]:write serdes 1@0x36: 0x5e69=0x00
01-01 08:56:08.278 I/    ( 1723): [3369.769043][ovx8b]:write serdes 1@0x36: 0x5e6a=0x00
01-01 08:56:08.278 I/    ( 1723): [3369.769287][ovx8b]:write serdes 1@0x36: 0x5e6b=0x01
01-01 08:56:08.278 I/    ( 1723): [3369.769287][ovx8b]:write serdes 1@0x36: 0x5e6c=0x00
01-01 08:56:08.278 I/    ( 1723): [3369.769531][ovx8b]:write serdes 1@0x36: 0x5e6d=0x00
01-01 08:56:08.278 I/    ( 1723): [3369.769775][ovx8b]:write serdes 1@0x36: 0x5e6e=0x01
01-01 08:56:08.278 I/    ( 1723): [3369.769775][ovx8b]:write serdes 1@0x36: 0x5e6f=0x00
01-01 08:56:08.278 I/    ( 1723): [3369.770020][ovx8b]:write serdes 1@0x36: 0x5e70=0x00
01-01 08:56:08.279 I/    ( 1723): [3369.770264][ovx8b]:write serdes 1@0x36: 0x5e71=0x01
01-01 08:56:08.279 I/    ( 1723): [3369.770264][ovx8b]:write serdes 1@0x36: 0x5e72=0x00
01-01 08:56:08.279 I/    ( 1723): [3369.770508][ovx8b]:write serdes 1@0x36: 0x5e73=0x00
01-01 08:56:08.279 I/    ( 1723): [3369.770508][ovx8b]:write serdes 1@0x36: 0x5e74=0x00
01-01 08:56:08.279 I/    ( 1723): [3369.770752][ovx8b]:write serdes 1@0x36: 0x5e75=0x80
01-01 08:56:08.279 I/    ( 1723): [3369.770996][ovx8b]:write serdes 1@0x36: 0x5e76=0x00
01-01 08:56:08.280 I/    ( 1723): [3369.770996][ovx8b]:write serdes 1@0x36: 0x5e77=0x00
01-01 08:56:08.280 I/    ( 1723): [3369.771240][ovx8b]:write serdes 1@0x36: 0x5e78=0x80
01-01 08:56:08.280 I/    ( 1723): [3369.771484][ovx8b]:write serdes 1@0x36: 0x5e79=0x00
01-01 08:56:08.280 I/    ( 1723): [3369.771484][ovx8b]:write serdes 1@0x36: 0x5e7a=0x00
01-01 08:56:08.280 I/    ( 1723): [3369.771729][ovx8b]:write serdes 1@0x36: 0x5e7b=0x80
01-01 08:56:08.280 I/    ( 1723): [3369.771729][ovx8b]:write serdes 1@0x36: 0x5e7c=0x00
01-01 08:56:08.281 I/    ( 1723): [3369.771973][ovx8b]:write serdes 1@0x36: 0x5e7d=0x00
01-01 08:56:08.281 I/    ( 1723): [3369.772217][ovx8b]:write serdes 1@0x36: 0x5e7e=0x80
01-01 08:56:08.281 I/    ( 1723): [3369.772217][ovx8b]:write serdes 1@0x36: 0x5e7f=0x00
01-01 08:56:08.281 I/    ( 1723): [3369.772461][ovx8b]:write serdes 1@0x36: 0x5e80=0x00
01-01 08:56:08.281 I/    ( 1723): [3369.772705][ovx8b]:write serdes 1@0x36: 0x5e81=0x80
01-01 08:56:08.281 I/    ( 1723): [3369.772705][ovx8b]:write serdes 1@0x36: 0x5e82=0x00
01-01 08:56:08.282 I/    ( 1723): [3369.772949][ovx8b]:write serdes 1@0x36: 0x5e83=0x00
01-01 08:56:08.282 I/    ( 1723): [3369.773193][ovx8b]:write serdes 1@0x36: 0x5e84=0x3f
01-01 08:56:08.282 I/    ( 1723): [3369.773193][ovx8b]:write serdes 1@0x36: 0x5f00=0x02
01-01 08:56:08.282 I/    ( 1723): [3369.773682][ovx8b]:write serdes 1@0x36: 0x5f01=0x08
01-01 08:56:08.282 I/    ( 1723): [3369.773682][ovx8b]:write serdes 1@0x36: 0x5f02=0x09
01-01 08:56:08.282 I/    ( 1723): [3369.773926][ovx8b]:write serdes 1@0x36: 0x5f03=0x0a
01-01 08:56:08.283 I/    ( 1723): [3369.774170][ovx8b]:write serdes 1@0x36: 0x5f04=0x0b
01-01 08:56:08.283 I/    ( 1723): [3369.774170][ovx8b]:write serdes 1@0x36: 0x5f05=0x0c
01-01 08:56:08.283 I/    ( 1723): [3369.774414][ovx8b]:write serdes 1@0x36: 0x5f06=0x0c
01-01 08:56:08.283 I/    ( 1723): [3369.774658][ovx8b]:write serdes 1@0x36: 0x5f07=0x0c
01-01 08:56:08.283 I/    ( 1723): [3369.774658][ovx8b]:write serdes 1@0x36: 0x5f08=0x0c
01-01 08:56:08.283 I/    ( 1723): [3369.774902][ovx8b]:write serdes 1@0x36: 0x5f09=0x0c
01-01 08:56:08.283 I/    ( 1723): [3369.774902][ovx8b]:write serdes 1@0x36: 0x5f0a=0x0d
01-01 08:56:08.284 I/    ( 1723): [3369.775146][ovx8b]:write serdes 1@0x36: 0x5f0b=0x0d
01-01 08:56:08.284 I/    ( 1723): [3369.775391][ovx8b]:write serdes 1@0x36: 0x5f0c=0x0d
01-01 08:56:08.284 I/    ( 1723): [3369.775391][ovx8b]:write serdes 1@0x36: 0x5f0d=0x0d
01-01 08:56:08.284 I/    ( 1723): [3369.775635][ovx8b]:write serdes 1@0x36: 0x5f0e=0x0d
01-01 08:56:08.284 I/    ( 1723): [3369.775879][ovx8b]:write serdes 1@0x36: 0x5f0f=0x0e
01-01 08:56:08.284 I/    ( 1723): [3369.775879][ovx8b]:write serdes 1@0x36: 0x5f10=0x0e
01-01 08:56:08.285 I/    ( 1723): [3369.776123][ovx8b]:write serdes 1@0x36: 0x5f11=0x0e
01-01 08:56:08.285 I/    ( 1723): [3369.776367][ovx8b]:write serdes 1@0x36: 0x5f12=0x0e
01-01 08:56:08.285 I/    ( 1723): [3369.776367][ovx8b]:write serdes 1@0x36: 0x5f13=0x0f
01-01 08:56:08.285 I/    ( 1723): [3369.776611][ovx8b]:write serdes 1@0x36: 0x5f14=0x0f
01-01 08:56:08.285 I/    ( 1723): [3369.776611][ovx8b]:write serdes 1@0x36: 0x5f15=0x10
01-01 08:56:08.285 I/    ( 1723): [3369.776855][ovx8b]:write serdes 1@0x36: 0x5f16=0x11
01-01 08:56:08.286 I/    ( 1723): [3369.777100][ovx8b]:write serdes 1@0x36: 0x5f17=0x11
01-01 08:56:08.286 I/    ( 1723): [3369.777100][ovx8b]:write serdes 1@0x36: 0x5f18=0x12
01-01 08:56:08.286 I/    ( 1723): [3369.777344][ovx8b]:write serdes 1@0x36: 0x5f19=0x12
01-01 08:56:08.286 I/    ( 1723): [3369.777588][ovx8b]:write serdes 1@0x36: 0x5f1a=0x13
01-01 08:56:08.286 I/    ( 1723): [3369.777588][ovx8b]:write serdes 1@0x36: 0x5f1b=0x13
01-01 08:56:08.286 I/    ( 1723): [3369.777832][ovx8b]:write serdes 1@0x36: 0x5f1c=0x14
01-01 08:56:08.287 I/    ( 1723): [3369.777832][ovx8b]:write serdes 1@0x36: 0x5f1d=0x14
01-01 08:56:08.287 I/    ( 1723): [3369.778076][ovx8b]:write serdes 1@0x36: 0x5f1e=0x16
01-01 08:56:08.287 I/    ( 1723): [3369.778320][ovx8b]:write serdes 1@0x36: 0x5f1f=0x16
01-01 08:56:08.287 I/    ( 1723): [3369.778320][ovx8b]:write serdes 1@0x36: 0x5f20=0x16
01-01 08:56:08.287 I/    ( 1723): [3369.778809][ovx8b]:write serdes 1@0x36: 0x5f21=0x08
01-01 08:56:08.287 I/    ( 1723): [3369.779053][ovx8b]:write serdes 1@0x36: 0x5f22=0x00
01-01 08:56:08.288 I/    ( 1723): [3369.779053][ovx8b]:write serdes 1@0x36: 0x5f23=0x01
01-01 08:56:08.288 I/    ( 1723): [3369.779297][ovx8b]:write serdes 1@0x36: 0x5f24=0x00
01-01 08:56:08.288 I/    ( 1723): [3369.779541][ovx8b]:write serdes 1@0x36: 0x5f25=0x00
01-01 08:56:08.288 I/    ( 1723): [3369.779541][ovx8b]:write serdes 1@0x36: 0x5f26=0x02
01-01 08:56:08.288 I/    ( 1723): [3369.779785][ovx8b]:write serdes 1@0x36: 0x5f27=0x00
01-01 08:56:08.288 I/    ( 1723): [3369.779785][ovx8b]:write serdes 1@0x36: 0x5f28=0x00
01-01 08:56:08.288 I/    ( 1723): [3369.780029][ovx8b]:write serdes 1@0x36: 0x5f29=0x02
01-01 08:56:08.289 I/    ( 1723): [3369.780273][ovx8b]:write serdes 1@0x36: 0x5f2a=0x00
01-01 08:56:08.289 I/    ( 1723): [3369.780518][ovx8b]:write serdes 1@0x36: 0x5f2b=0x00
01-01 08:56:08.289 I/    ( 1723): [3369.780518][ovx8b]:write serdes 1@0x36: 0x5f2c=0x02
01-01 08:56:08.289 I/    ( 1723): [3369.780762][ovx8b]:write serdes 1@0x36: 0x5f2d=0x00
01-01 08:56:08.289 I/    ( 1723): [3369.780762][ovx8b]:write serdes 1@0x36: 0x5f2e=0x00
01-01 08:56:08.290 I/    ( 1723): [3369.781006][ovx8b]:write serdes 1@0x36: 0x5f2f=0x02
01-01 08:56:08.290 I/    ( 1723): [3369.781250][ovx8b]:write serdes 1@0x36: 0x5f30=0x00
01-01 08:56:08.290 I/    ( 1723): [3369.781250][ovx8b]:write serdes 1@0x36: 0x5f31=0x00
01-01 08:56:08.290 I/    ( 1723): [3369.781494][ovx8b]:write serdes 1@0x36: 0x5f32=0x02
01-01 08:56:08.290 I/    ( 1723): [3369.781738][ovx8b]:write serdes 1@0x36: 0x5f33=0x00
01-01 08:56:08.290 I/    ( 1723): [3369.781738][ovx8b]:write serdes 1@0x36: 0x5f34=0x00
01-01 08:56:08.290 I/    ( 1723): [3369.781982][ovx8b]:write serdes 1@0x36: 0x5f35=0x02
01-01 08:56:08.291 I/    ( 1723): [3369.781982][ovx8b]:write serdes 1@0x36: 0x5f36=0x00
01-01 08:56:08.291 I/    ( 1723): [3369.782227][ovx8b]:write serdes 1@0x36: 0x5f37=0x00
01-01 08:56:08.291 I/    ( 1723): [3369.782471][ovx8b]:write serdes 1@0x36: 0x5f38=0x02
01-01 08:56:08.291 I/    ( 1723): [3369.782471][ovx8b]:write serdes 1@0x36: 0x5f39=0x00
01-01 08:56:08.291 I/    ( 1723): [3369.782715][ovx8b]:write serdes 1@0x36: 0x5f3a=0x00
01-01 08:56:08.291 I/    ( 1723): [3369.782959][ovx8b]:write serdes 1@0x36: 0x5f3b=0x02
01-01 08:56:08.292 I/    ( 1723): [3369.782959][ovx8b]:write serdes 1@0x36: 0x5f3c=0x00
01-01 08:56:08.292 I/    ( 1723): [3369.783203][ovx8b]:write serdes 1@0x36: 0x5f3d=0x00
01-01 08:56:08.292 I/    ( 1723): [3369.783203][ovx8b]:write serdes 1@0x36: 0x5f3e=0x02
01-01 08:56:08.292 I/    ( 1723): [3369.783447][ovx8b]:write serdes 1@0x36: 0x5f3f=0x00
01-01 08:56:08.292 I/    ( 1723): [3369.783691][ovx8b]:write serdes 1@0x36: 0x5f40=0x00
01-01 08:56:08.292 I/    ( 1723): [3369.783691][ovx8b]:write serdes 1@0x36: 0x5f41=0x02
01-01 08:56:08.293 I/    ( 1723): [3369.784180][ovx8b]:write serdes 1@0x36: 0x5f42=0x00
01-01 08:56:08.293 I/    ( 1723): [3369.784424][ovx8b]:write serdes 1@0x36: 0x5f43=0x00
01-01 08:56:08.293 I/    ( 1723): [3369.784424][ovx8b]:write serdes 1@0x36: 0x5f44=0x02
01-01 08:56:08.293 I/    ( 1723): [3369.784668][ovx8b]:write serdes 1@0x36: 0x5f45=0x00
01-01 08:56:08.293 I/    ( 1723): [3369.784912][ovx8b]:write serdes 1@0x36: 0x5f46=0x00
01-01 08:56:08.293 I/    ( 1723): [3369.784912][ovx8b]:write serdes 1@0x36: 0x5f47=0x04
01-01 08:56:08.294 I/    ( 1723): [3369.785156][ovx8b]:write serdes 1@0x36: 0x5f48=0x00
01-01 08:56:08.294 I/    ( 1723): [3369.785156][ovx8b]:write serdes 1@0x36: 0x5f49=0x00
01-01 08:56:08.294 I/    ( 1723): [3369.785400][ovx8b]:write serdes 1@0x36: 0x5f4a=0x04
01-01 08:56:08.294 I/    ( 1723): [3369.785645][ovx8b]:write serdes 1@0x36: 0x5f4b=0x00
01-01 08:56:08.294 I/    ( 1723): [3369.785645][ovx8b]:write serdes 1@0x36: 0x5f4c=0x00
01-01 08:56:08.294 I/    ( 1723): [3369.785889][ovx8b]:write serdes 1@0x36: 0x5f4d=0x04
01-01 08:56:08.295 I/    ( 1723): [3369.786133][ovx8b]:write serdes 1@0x36: 0x5f4e=0x00
01-01 08:56:08.295 I/    ( 1723): [3369.786133][ovx8b]:write serdes 1@0x36: 0x5f4f=0x00
01-01 08:56:08.295 I/    ( 1723): [3369.786377][ovx8b]:write serdes 1@0x36: 0x5f50=0x04
01-01 08:56:08.295 I/    ( 1723): [3369.786621][ovx8b]:write serdes 1@0x36: 0x5f51=0x00
01-01 08:56:08.295 I/    ( 1723): [3369.786621][ovx8b]:write serdes 1@0x36: 0x5f52=0x00
01-01 08:56:08.295 I/    ( 1723): [3369.786865][ovx8b]:write serdes 1@0x36: 0x5f53=0x04
01-01 08:56:08.295 I/    ( 1723): [3369.786865][ovx8b]:write serdes 1@0x36: 0x5f54=0x00
01-01 08:56:08.296 I/    ( 1723): [3369.787109][ovx8b]:write serdes 1@0x36: 0x5f55=0x00
01-01 08:56:08.296 I/    ( 1723): [3369.787354][ovx8b]:write serdes 1@0x36: 0x5f56=0x04
01-01 08:56:08.296 I/    ( 1723): [3369.787354][ovx8b]:write serdes 1@0x36: 0x5f57=0x00
01-01 08:56:08.296 I/    ( 1723): [3369.787598][ovx8b]:write serdes 1@0x36: 0x5f58=0x00
01-01 08:56:08.296 I/    ( 1723): [3369.787842][ovx8b]:write serdes 1@0x36: 0x5f59=0x04
01-01 08:56:08.296 I/    ( 1723): [3369.787842][ovx8b]:write serdes 1@0x36: 0x5f5a=0x00
01-01 08:56:08.297 I/    ( 1723): [3369.788086][ovx8b]:write serdes 1@0x36: 0x5f5b=0x00
01-01 08:56:08.297 I/    ( 1723): [3369.788086][ovx8b]:write serdes 1@0x36: 0x5f5c=0x04
01-01 08:56:08.297 I/    ( 1723): [3369.788330][ovx8b]:write serdes 1@0x36: 0x5f5d=0x00
01-01 08:56:08.297 I/    ( 1723): [3369.788574][ovx8b]:write serdes 1@0x36: 0x5f5e=0x00
01-01 08:56:08.297 I/    ( 1723): [3369.788574][ovx8b]:write serdes 1@0x36: 0x5f5f=0x08
01-01 08:56:08.297 I/    ( 1723): [3369.788818][ovx8b]:write serdes 1@0x36: 0x5f60=0x00
01-01 08:56:08.298 I/    ( 1723): [3369.789062][ovx8b]:write serdes 1@0x36: 0x5f61=0x00
01-01 08:56:08.298 I/    ( 1723): [3369.789062][ovx8b]:write serdes 1@0x36: 0x5f62=0x08
01-01 08:56:08.298 I/    ( 1723): [3369.789551][ovx8b]:write serdes 1@0x36: 0x5f63=0x00
01-01 08:56:08.298 I/    ( 1723): [3369.789795][ovx8b]:write serdes 1@0x36: 0x5f64=0x00
01-01 08:56:08.298 I/    ( 1723): [3369.789795][ovx8b]:write serdes 1@0x36: 0x5f65=0x08
01-01 08:56:08.298 I/    ( 1723): [3369.790039][ovx8b]:write serdes 1@0x36: 0x5f66=0x00
01-01 08:56:08.299 I/    ( 1723): [3369.790039][ovx8b]:write serdes 1@0x36: 0x5f67=0x00
01-01 08:56:08.299 I/    ( 1723): [3369.790283][ovx8b]:write serdes 1@0x36: 0x5f68=0x08
01-01 08:56:08.299 I/    ( 1723): [3369.790527][ovx8b]:write serdes 1@0x36: 0x5f69=0x00
01-01 08:56:08.299 I/    ( 1723): [3369.790527][ovx8b]:write serdes 1@0x36: 0x5f6a=0x00
01-01 08:56:08.299 I/    ( 1723): [3369.790771][ovx8b]:write serdes 1@0x36: 0x5f6b=0x08
01-01 08:56:08.299 I/    ( 1723): [3369.791016][ovx8b]:write serdes 1@0x36: 0x5f6c=0x00
01-01 08:56:08.300 I/    ( 1723): [3369.791016][ovx8b]:write serdes 1@0x36: 0x5f6d=0x00
01-01 08:56:08.300 I/    ( 1723): [3369.791260][ovx8b]:write serdes 1@0x36: 0x5f6e=0x10
01-01 08:56:08.300 I/    ( 1723): [3369.791260][ovx8b]:write serdes 1@0x36: 0x5f6f=0x00
01-01 08:56:08.300 I/    ( 1723): [3369.791504][ovx8b]:write serdes 1@0x36: 0x5f70=0x00
01-01 08:56:08.300 I/    ( 1723): [3369.791748][ovx8b]:write serdes 1@0x36: 0x5f71=0x10
01-01 08:56:08.300 I/    ( 1723): [3369.791748][ovx8b]:write serdes 1@0x36: 0x5f72=0x00
01-01 08:56:08.301 I/    ( 1723): [3369.791992][ovx8b]:write serdes 1@0x36: 0x5f73=0x00
01-01 08:56:08.301 I/    ( 1723): [3369.792236][ovx8b]:write serdes 1@0x36: 0x5f74=0x10
01-01 08:56:08.301 I/    ( 1723): [3369.792236][ovx8b]:write serdes 1@0x36: 0x5f75=0x00
01-01 08:56:08.301 I/    ( 1723): [3369.792480][ovx8b]:write serdes 1@0x36: 0x5f76=0x00
01-01 08:56:08.301 I/    ( 1723): [3369.792725][ovx8b]:write serdes 1@0x36: 0x5f77=0x10
01-01 08:56:08.301 I/    ( 1723): [3369.792725][ovx8b]:write serdes 1@0x36: 0x5f78=0x00
01-01 08:56:08.302 I/    ( 1723): [3369.792969][ovx8b]:write serdes 1@0x36: 0x5f79=0x00
01-01 08:56:08.302 I/    ( 1723): [3369.792969][ovx8b]:write serdes 1@0x36: 0x5f7a=0x20
01-01 08:56:08.302 I/    ( 1723): [3369.793213][ovx8b]:write serdes 1@0x36: 0x5f7b=0x00
01-01 08:56:08.302 I/    ( 1723): [3369.793457][ovx8b]:write serdes 1@0x36: 0x5f7c=0x00
01-01 08:56:08.302 I/    ( 1723): [3369.793457][ovx8b]:write serdes 1@0x36: 0x5f7d=0x20
01-01 08:56:08.302 I/    ( 1723): [3369.793701][ovx8b]:write serdes 1@0x36: 0x5f7e=0x00
01-01 08:56:08.302 I/    ( 1723): [3369.793945][ovx8b]:write serdes 1@0x36: 0x5f7f=0x00
01-01 08:56:08.303 I/    ( 1723): [3369.793945][ovx8b]:write serdes 1@0x36: 0x5f80=0x20
01-01 08:56:08.303 I/    ( 1723): [3369.794189][ovx8b]:write serdes 1@0x36: 0x5f81=0x00
01-01 08:56:08.303 I/    ( 1723): [3369.794678][ovx8b]:write serdes 1@0x36: 0x5f82=0x00
01-01 08:56:08.303 I/    ( 1723): [3369.794678][ovx8b]:write serdes 1@0x36: 0x5f83=0x00
01-01 08:56:08.303 I/    ( 1723): [3369.794922][ovx8b]:write serdes 1@0x36: 0x5f84=0xff
01-01 08:56:08.303 I/    ( 1723): [3369.794922][ovx8b]:write serdes 1@0x36: 0x5240=0x0f
01-01 08:56:08.304 I/    ( 1723): [3369.795166][ovx8b]:write serdes 1@0x36: 0x5241=0x00
01-01 08:56:08.304 I/    ( 1723): [3369.795410][ovx8b]:write serdes 1@0x36: 0x5242=0x00
01-01 08:56:08.304 I/    ( 1723): [3369.795410][ovx8b]:write serdes 1@0x36: 0x5243=0x00
01-01 08:56:08.304 I/    ( 1723): [3369.795654][ovx8b]:write serdes 1@0x36: 0x5244=0x00
01-01 08:56:08.304 I/    ( 1723): [3369.795898][ovx8b]:write serdes 1@0x36: 0x5245=0x00
01-01 08:56:08.304 I/    ( 1723): [3369.795898][ovx8b]:write serdes 1@0x36: 0x5246=0x00
01-01 08:56:08.305 I/    ( 1723): [3369.796143][ovx8b]:write serdes 1@0x36: 0x5247=0x00
01-01 08:56:08.305 I/    ( 1723): [3369.796143][ovx8b]:write serdes 1@0x36: 0x5248=0x00
01-01 08:56:08.305 I/    ( 1723): [3369.796387][ovx8b]:write serdes 1@0x36: 0x5249=0x00
01-01 08:56:08.305 I/    ( 1723): [3369.796631][ovx8b]:write serdes 1@0x36: 0x5440=0x0f
01-01 08:56:08.305 I/    ( 1723): [3369.796631][ovx8b]:write serdes 1@0x36: 0x5441=0x00
01-01 08:56:08.305 I/    ( 1723): [3369.796875][ovx8b]:write serdes 1@0x36: 0x5442=0x00
01-01 08:56:08.306 I/    ( 1723): [3369.797119][ovx8b]:write serdes 1@0x36: 0x5443=0x00
01-01 08:56:08.306 I/    ( 1723): [3369.797119][ovx8b]:write serdes 1@0x36: 0x5444=0x00
01-01 08:56:08.306 I/    ( 1723): [3369.797363][ovx8b]:write serdes 1@0x36: 0x5445=0x00
01-01 08:56:08.306 I/    ( 1723): [3369.797607][ovx8b]:write serdes 1@0x36: 0x5446=0x00
01-01 08:56:08.306 I/    ( 1723): [3369.797607][ovx8b]:write serdes 1@0x36: 0x5447=0x00
01-01 08:56:08.306 I/    ( 1723): [3369.797852][ovx8b]:write serdes 1@0x36: 0x5448=0x00
01-01 08:56:08.307 I/    ( 1723): [3369.797852][ovx8b]:write serdes 1@0x36: 0x5449=0x00
01-01 08:56:08.307 I/    ( 1723): [3369.798096][ovx8b]:write serdes 1@0x36: 0x5640=0x0f
01-01 08:56:08.307 I/    ( 1723): [3369.798340][ovx8b]:write serdes 1@0x36: 0x5641=0x00
01-01 08:56:08.307 I/    ( 1723): [3369.798340][ovx8b]:write serdes 1@0x36: 0x5642=0x00
01-01 08:56:08.307 I/    ( 1723): [3369.798584][ovx8b]:write serdes 1@0x36: 0x5643=0x00
01-01 08:56:08.307 I/    ( 1723): [3369.798828][ovx8b]:write serdes 1@0x36: 0x5644=0x00
01-01 08:56:08.307 I/    ( 1723): [3369.798828][ovx8b]:write serdes 1@0x36: 0x5645=0x00
01-01 08:56:08.308 I/    ( 1723): [3369.799072][ovx8b]:write serdes 1@0x36: 0x5646=0x00
01-01 08:56:08.308 I/    ( 1723): [3369.799316][ovx8b]:write serdes 1@0x36: 0x5647=0x00
01-01 08:56:08.308 I/    ( 1723): [3369.799316][ovx8b]:write serdes 1@0x36: 0x5648=0x00
01-01 08:56:08.308 I/    ( 1723): [3369.799561][ovx8b]:write serdes 1@0x36: 0x5649=0x00
01-01 08:56:08.308 I/    ( 1723): [3369.799561][ovx8b]:write serdes 1@0x36: 0x5840=0x0f
01-01 08:56:08.308 I/    ( 1723): [3369.800049][ovx8b]:write serdes 1@0x36: 0x5841=0x00
01-01 08:56:08.309 I/    ( 1723): [3369.800293][ovx8b]:write serdes 1@0x36: 0x5842=0x00
01-01 08:56:08.309 I/    ( 1723): [3369.800293][ovx8b]:write serdes 1@0x36: 0x5843=0x00
01-01 08:56:08.309 I/    ( 1723): [3369.800537][ovx8b]:write serdes 1@0x36: 0x5844=0x00
01-01 08:56:08.309 I/    ( 1723): [3369.800781][ovx8b]:write serdes 1@0x36: 0x5845=0x00
01-01 08:56:08.309 I/    ( 1723): [3369.800781][ovx8b]:write serdes 1@0x36: 0x5846=0x00
01-01 08:56:08.309 I/    ( 1723): [3369.801025][ovx8b]:write serdes 1@0x36: 0x5847=0x00
01-01 08:56:08.310 I/    ( 1723): [3369.801025][ovx8b]:write serdes 1@0x36: 0x5848=0x00
01-01 08:56:08.310 I/    ( 1723): [3369.801270][ovx8b]:write serdes 1@0x36: 0x5849=0x00
01-01 08:56:08.310 I/    ( 1723): [3369.801514][ovx8b]:write serdes 1@0x36: 0x5000=0x8f
01-01 08:56:08.310 I/    ( 1723): [3369.801514][ovx8b]:write serdes 1@0x36: 0x5001=0x75
01-01 08:56:08.310 I/    ( 1723): [3369.801758][ovx8b]:write serdes 1@0x36: 0x5002=0x7f
01-01 08:56:08.310 I/    ( 1723): [3369.802002][ovx8b]:write serdes 1@0x36: 0x5003=0x3e
01-01 08:56:08.311 I/    ( 1723): [3369.802002][ovx8b]:write serdes 1@0x36: 0x5004=0x1e
01-01 08:56:08.311 I/    ( 1723): [3369.802246][ovx8b]:write serdes 1@0x36: 0x5005=0x1e
01-01 08:56:08.311 I/    ( 1723): [3369.802246][ovx8b]:write serdes 1@0x36: 0x5006=0x1e
01-01 08:56:08.311 I/    ( 1723): [3369.802490][ovx8b]:write serdes 1@0x36: 0x5007=0x1e
01-01 08:56:08.311 I/    ( 1723): [3369.802734][ovx8b]:write serdes 1@0x36: 0x5008=0x00
01-01 08:56:08.311 I/    ( 1723): [3369.802734][ovx8b]:write serdes 1@0x36: 0x500c=0x00
01-01 08:56:08.312 I/    ( 1723): [3369.802979][ovx8b]:write serdes 1@0x36: 0x5019=0x00
01-01 08:56:08.312 I/    ( 1723): [3369.803223][ovx8b]:write serdes 1@0x36: 0x501a=0xff
01-01 08:56:08.312 I/    ( 1723): [3369.803223][ovx8b]:write serdes 1@0x36: 0x501b=0xff
01-01 08:56:08.312 I/    ( 1723): [3369.803467][ovx8b]:write serdes 1@0x36: 0x501d=0x00
01-01 08:56:08.312 I/    ( 1723): [3369.803467][ovx8b]:write serdes 1@0x36: 0x501e=0x40
01-01 08:56:08.312 I/    ( 1723): [3369.803711][ovx8b]:write serdes 1@0x36: 0x501f=0x00
01-01 08:56:08.312 I/    ( 1723): [3369.803955][ovx8b]:write serdes 1@0x36: 0x5021=0x00
01-01 08:56:08.313 I/    ( 1723): [3369.803955][ovx8b]:write serdes 1@0x36: 0x5022=0x01
01-01 08:56:08.313 I/    ( 1723): [3369.804199][ovx8b]:write serdes 1@0x36: 0x5023=0x74
01-01 08:56:08.313 I/    ( 1723): [3369.804443][ovx8b]:write serdes 1@0x36: 0x5025=0x00
01-01 08:56:08.313 I/    ( 1723): [3369.804443][ovx8b]:write serdes 1@0x36: 0x5026=0x40
01-01 08:56:08.313 I/    ( 1723): [3369.804688][ovx8b]:write serdes 1@0x36: 0x5027=0x00
01-01 08:56:08.313 I/    ( 1723): [3369.805176][ovx8b]:write serdes 1@0x36: 0x5070=0x00
01-01 08:56:08.314 I/    ( 1723): [3369.805176][ovx8b]:write serdes 1@0x36: 0x5074=0x04
01-01 08:56:08.314 I/    ( 1723): [3369.805420][ovx8b]:write serdes 1@0x36: 0x4001=0x2b
01-01 08:56:08.314 I/    ( 1723): [3369.805420][ovx8b]:write serdes 1@0x36: 0x4009=0x07
01-01 08:56:08.314 I/    ( 1723): [3369.805664][ovx8b]:write serdes 1@0x36: 0x400a=0x08
01-01 08:56:08.314 I/    ( 1723): [3369.805908][ovx8b]:write serdes 1@0x36: 0x400b=0x04
01-01 08:56:08.314 I/    ( 1723): [3369.805908][ovx8b]:write serdes 1@0x36: 0x400c=0x1b
01-01 08:56:08.315 I/    ( 1723): [3369.806152][ovx8b]:write serdes 1@0x36: 0x400d=0x18
01-01 08:56:08.315 I/    ( 1723): [3369.806396][ovx8b]:write serdes 1@0x36: 0x4012=0x00
01-01 08:56:08.315 I/    ( 1723): [3369.806396][ovx8b]:write serdes 1@0x36: 0x4014=0x0f
01-01 08:56:08.315 I/    ( 1723): [3369.806641][ovx8b]:write serdes 1@0x36: 0x4015=0xff
01-01 08:56:08.315 I/    ( 1723): [3369.806641][ovx8b]:write serdes 1@0x36: 0x4018=0x12
01-01 08:56:08.315 I/    ( 1723): [3369.806885][ovx8b]:write serdes 1@0x36: 0x4021=0x05
01-01 08:56:08.316 I/    ( 1723): [3369.807129][ovx8b]:write serdes 1@0x36: 0x4026=0x00
01-01 08:56:08.316 I/    ( 1723): [3369.807129][ovx8b]:write serdes 1@0x36: 0x4027=0x40
01-01 08:56:08.316 I/    ( 1723): [3369.807373][ovx8b]:write serdes 1@0x36: 0x4028=0x00
01-01 08:56:08.316 I/    ( 1723): [3369.807617][ovx8b]:write serdes 1@0x36: 0x4029=0x40
01-01 08:56:08.316 I/    ( 1723): [3369.807617][ovx8b]:write serdes 1@0x36: 0x402a=0x00
01-01 08:56:08.316 I/    ( 1723): [3369.807861][ovx8b]:write serdes 1@0x36: 0x402b=0x40
01-01 08:56:08.317 I/    ( 1723): [3369.807861][ovx8b]:write serdes 1@0x36: 0x402c=0x00
01-01 08:56:08.317 I/    ( 1723): [3369.808105][ovx8b]:write serdes 1@0x36: 0x402d=0x40
01-01 08:56:08.317 I/    ( 1723): [3369.808350][ovx8b]:write serdes 1@0x36: 0x402e=0x00
01-01 08:56:08.317 I/    ( 1723): [3369.808350][ovx8b]:write serdes 1@0x36: 0x402f=0x00
01-01 08:56:08.317 I/    ( 1723): [3369.808594][ovx8b]:write serdes 1@0x36: 0x4030=0x00
01-01 08:56:08.317 I/    ( 1723): [3369.808838][ovx8b]:write serdes 1@0x36: 0x4031=0x00
01-01 08:56:08.317 I/    ( 1723): [3369.808838][ovx8b]:write serdes 1@0x36: 0x407e=0xcc
01-01 08:56:08.318 I/    ( 1723): [3369.809082][ovx8b]:write serdes 1@0x36: 0x407f=0x18
01-01 08:56:08.318 I/    ( 1723): [3369.809326][ovx8b]:write serdes 1@0x36: 0x4640=0x40
01-01 08:56:08.318 I/    ( 1723): [3369.809326][ovx8b]:write serdes 1@0x36: 0x4641=0x11
01-01 08:56:08.318 I/    ( 1723): [3369.809570][ovx8b]:write serdes 1@0x36: 0x4642=0x0e
01-01 08:56:08.318 I/    ( 1723): [3369.809570][ovx8b]:write serdes 1@0x36: 0x4643=0xee
01-01 08:56:08.318 I/    ( 1723): [3369.809814][ovx8b]:write serdes 1@0x36: 0x4646=0x0f
01-01 08:56:08.319 I/    ( 1723): [3369.810059][ovx8b]:write serdes 1@0x36: 0x4648=0x00
01-01 08:56:08.319 I/    ( 1723): [3369.810059][ovx8b]:write serdes 1@0x36: 0x4649=0x03
01-01 08:56:08.319 I/    ( 1723): [3369.810547][ovx8b]:write serdes 1@0x36: 0x380e=0x04
01-01 08:56:08.319 I/    ( 1723): [3369.810791][ovx8b]:write serdes 1@0x36: 0x380f=0x66
01-01 08:56:08.319 I/    ( 1723): [3369.810791][ovx8b]:write serdes 1@0x36: 0x380c=0x09
01-01 08:56:08.319 I/    ( 1723): [3369.811035][ovx8b]:write serdes 1@0x36: 0x380d=0xc8
01-01 08:56:08.320 I/    ( 1723): [3369.811035][ovx8b]:write serdes 1@0x36: 0x384c=0x05
01-01 08:56:08.320 I/    ( 1723): [3369.811279][ovx8b]:write serdes 1@0x36: 0x384d=0xf0
01-01 08:56:08.320 I/    ( 1723): [3369.811523][ovx8b]:write serdes 1@0x36: 0x388c=0x03
01-01 08:56:08.320 I/    ( 1723): [3369.811523][ovx8b]:write serdes 1@0x36: 0x388d=0xf0
01-01 08:56:08.320 I/    ( 1723): [3369.811768][ovx8b]:write serdes 1@0x36: 0x0305=0x42
01-01 08:56:08.320 I/    ( 1723): [3369.812012][ovx8b]:write serdes 1@0x36: 0x0307=0x03
01-01 08:56:08.321 I/    ( 1723): [3369.812012][ovx8b]:write serdes 1@0x36: 0x0325=0x54
01-01 08:56:08.321 I/    ( 1723): [3369.812256][ovx8b]:write serdes 1@0x36: 0x0326=0xde
01-01 08:56:08.321 I/    ( 1723): [3369.812500][ovx8b]:write serdes 1@0x36: 0x0327=0x09
01-01 08:56:08.321 I/    ( 1723): [3369.812500][ovx8b]:write serdes 1@0x36: 0x032a=0x09
01-01 08:56:08.321 I/    ( 1723): [3369.812744][ovx8b]:write serdes 1@0x36: 0x4837=0x28
01-01 08:56:08.321 I/    ( 1723): [3369.812744][ovx8b]:write serdes 1@0x36: 0x4603=0x11
01-01 08:56:08.322 I/    ( 1723): [3369.812988][ovx8b]:write serdes 1@0x36: 0x3501=0x04
01-01 08:56:08.322 I/    ( 1723): [3369.813232][ovx8b]:write serdes 1@0x36: 0x3502=0x00
01-01 08:56:08.322 I/    ( 1723): [3369.813232][ovx8b]:write serdes 1@0x36: 0x3541=0x00
01-01 08:56:08.322 I/    ( 1723): [3369.813477][ovx8b]:write serdes 1@0x36: 0x3542=0x0f
01-01 08:56:08.322 I/    ( 1723): [3369.813721][ovx8b]:write serdes 1@0x36: 0x35c1=0x00
01-01 08:56:08.322 I/    ( 1723): [3369.813721][ovx8b]:write serdes 1@0x36: 0x35c2=0x02
01-01 08:56:08.322 I/    ( 1723): [3369.813965][ovx8b]:write serdes 1@0x36: 0x350a=0x0f
01-01 08:56:08.323 I/    ( 1723): [3369.813965][ovx8b]:write serdes 1@0x36: 0x350b=0x00
01-01 08:56:08.323 I/    ( 1723): [3369.814209][ovx8b]:write serdes 1@0x36: 0x4317=0x08
01-01 08:56:08.323 I/    ( 1723): [3369.814453][ovx8b]:write serdes 1@0x36: 0x430f=0x27
01-01 08:56:08.580 I/    ( 1723): [3370.071533][ovx8b]:HMAX = 5032, VMAX = 1126, width = 3840, height = 2160, lines_per_second = 6756, xclk = 24, fps = 6.000672
01-01 08:56:08.580 I/    ( 1723): [3370.071533][ovx8b]:sensor data bits fill pwl 20bit
01-01 08:56:08.580 I/    ( 1723): [3370.071777][ovx8b]:enter userspace_control enalbe = 64
01-01 08:56:08.580 I/    ( 1723): [3370.071777][cam utility]:start ptf 281473538712000
01-01 08:56:08.580 I/    ( 1723): [3370.072021][mipi host]:mipi host0 init begin
01-01 08:56:08.580 I/    ( 1723): [3370.072021][cam utility]: start fe pthread 0
01-01 08:56:08.582 I/    ( 1723): [3370.073242][mipi host]:mipi host0 init end
01-01 08:56:08.582 I/    ( 1723): [3370.073242][mipi dev]:mipi dev0 init begin
01-01 08:56:08.583 I/    ( 1723): [3370.074707][mipi dev]:mipi dev0 init end
01-01 08:56:08.683 I/    ( 1723): [3370.174805][hb mipi]:hb_vin_mipi_init 0 end
01-01 08:56:08.683 I/    ( 1723): [3370.174805][hb cim]:filebuf read size : 1
01-01 08:56:08.683 I/    ( 1723): [3370.175049][cim_dma hal]:pipe(1) cim_dma_entity_create done !
01-01 08:56:08.683 I/    ( 1723): [3370.175049][cim_dma hal]:--cim_dma_entity_parser_config in--
01-01 08:56:08.683 W/    ( 1723): [3370.175049][hb cim utils]:channels has empty json value
01-01 08:56:08.683 W/    ( 1723): [3370.175049][hb cim utils]:enable_pattern has empty json value
01-01 08:56:08.683 W/    ( 1723): [3370.175049][hb cim utils]:skip_frame has empty json value
01-01 08:56:08.683 W/    ( 1723): [3370.175049][hb cim utils]:input_fps has empty json value
01-01 08:56:08.683 W/    ( 1723): [3370.175049][hb cim utils]:output_fps has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:stride has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:out_buf_noinvalid has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:out_buf_noncached has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:water_level_mark has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:embeded_data_en has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:embeded_dependence has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:embeded_width has empty json value
01-01 08:56:08.684 W/    ( 1723): [3370.175049][hb cim utils]:embeded_height has empty json value
01-01 08:56:08.684 I/    ( 1723): [3370.175049][cim_dma hal]:===cim_dma cfg input info====
01-01 08:56:08.684 I/    ( 1723): [3370.175049][cim_dma hal]:mipi.enable(1)
01-01 08:56:08.684 I/    ( 1723): [3370.175049][cim_dma hal]:mipi.vc_index (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175049][cim_dma hal]:mipi.mipi_rx_index (3)
01-01 08:56:08.684 I/    ( 1723): [3370.175049][cim_dma hal]:mipi.format (30)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:mipi.height (1080)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:mipi.width (1921)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:mipi.raw16_splict (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:mipi.dbg_clear (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:mipi.y_uv_swap (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.enable_bypass (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.enable_frame_id (1)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.enable_DMA (1)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.pack_mode (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.set_init_frame_id (1)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.set_bypass_channels (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.skip_frame (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.input_fps (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:func.output_fps (0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:===cim_dma cfg ddr output info===
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr enable(1)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr width(1936)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr height(1080)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr format(30)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr stride(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr buf_num(6)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr out_buf_noncached(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr out_buf_noinvalid(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr use_ispbuf(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr water_level_mark(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr embeded_data_en(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr embeded_dependence(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr embeded_width(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:out ddr embeded_height(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:===cim_dma cfg tx output info===
01-01 08:56:08.684 I/    ( 1723): [3370.175293][cim_dma hal]:tx.enable(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175537][cim_dma hal]:tx.index(0)
01-01 08:56:08.684 I/    ( 1723): [3370.175537][cim_dma hal]:--cim_dma_entity_parser_config out--size = 200
01-01 08:56:08.684 I/    ( 1723): [3370.176025]mgr create done! pipeline_id = 1, buffer_type = 23
01-01 08:56:08.685 I/    ( 1723): [3370.176270][cim_dma hal]:cim_dma_capture_buf_mgr_init done.
01-01 08:56:08.685 I/    ( 1723): [3370.176270][cim_dma hal]:pipe(1) cim_dma_entity_init out.
01-01 08:56:08.685 I/    ( 1723): [3370.176514][hb_i2c]:[hb_vin_i2c_init][58]bus 6 cam_bus_cnt[bus] 2 cam_fd[bus] 11
01-01 08:56:08.685 I/    ( 1723): [3370.176758][cam utility]:/dev/port_1 success sensor_info->sen_devfd 25===
01-01 08:56:09.696 I/    ( 1723): [3371.187744][imx390]:---sensor_init 787 -----
01-01 08:56:09.696 I/    ( 1723): [3371.187988][hb_pwm]:hb_pwm_init: open /dev/hobot-lpwm0 sucessfully
01-01 08:56:09.696 I/    ( 1723): [3371.187988][imx390]:---sensor_init 794 -----
01-01 08:56:09.696 I/    ( 1723): [3371.187988][mipi host]:mipi host3 init begin
01-01 08:56:10.210 I/    ( 1723): [3371.701416][mipi host]:mipi host3 init end
01-01 08:56:10.210 I/    ( 1723): [3371.701416][mipi dev]:mipi dev0 init begin
01-01 08:56:10.210 I/    ( 1723): [3371.701660][mipi dev]:mipi dev0 init end
01-01 08:56:10.310 I/    ( 1723): [3371.801758][hb mipi]:hb_vin_mipi_init 3 end
01-01 08:56:10.310 I/    ( 1723): [3371.801758][VIN]:[hb_vin_init][1063]vps cam init done.Time cost(2149)ms.
01-01 08:56:10.310 I/    ( 1723): [3371.801859]hb_vio_init[643] L: vio process mode:0 [0:signal, 1:multi]
01-01 08:56:10.311 I/    ( 1723): [3371.802979][VPM pipeline]:[vio_pipeline_parser][111]Vpm pipeline parse done.
01-01 08:56:10.313 I/    ( 1723): [3371.804199][VPM pipeline]:[vio_pipeline_create][538]pipe (0) create done!
01-01 08:56:10.313 I/    ( 1723): [3371.804199][VPM pipeline]:[vio_pipeline_entity_create][292]pipe(0) vio_pipeline_entity_create in
01-01 08:56:10.313 I/    ( 1723): [3371.804199][ISP]:[isp_entity_parser_config][687]--- isp_entity_parser_config ---
01-01 08:56:10.313 W/    ( 1723): [3371.804199][ISP]:[isp_entity_parser_config][709]isp pattern control null. set as normal.
01-01 08:56:10.313 W/    ( 1723): [3371.804199][ISP]:[isp_entity_parser_config][807]isp in_buf_noclean null.set default 0
01-01 08:56:10.313 W/    ( 1723): [3371.804199][ISP]:[isp_entity_parser_config][814]isp in_buf_noncached null.set default 0
01-01 08:56:10.313 W/    ( 1723): [3371.804199][ISP]:[isp_entity_parser_config][821]isp out_buf_noinvalid null.set default 0
01-01 08:56:10.313 W/    ( 1723): [3371.804199][ISP]:[isp_entity_parser_config][828]isp out_buf_noncached null.set default 0
01-01 08:56:10.313 W/    ( 1723): [3371.804199][ISP]:[isp_entity_parser_config][835]isp_inner_module_bypass null.
01-01 08:56:10.313 E/    ( 1723): [3371.804199][ISP]:[cjson_string_dup][545]json file path /system/etc/cam/lib_x8bRGGB_pwl12_PH_Fov120.so length 46 limit 100
01-01 08:56:10.313 I/    ( 1723): [3371.804443][ISP]:[isp_pub_attr_info_print][18]Hw id = 0
01-01 08:56:10.313 I/    ( 1723): Ctx id = 0
01-01 08:56:10.313 I/    ( 1723): Test_pattern = 0
01-01 08:56:10.313 I/    ( 1723): hdr_mode = 1
01-01 08:56:10.313 I/    ( 1723): size width = 3840
01-01 08:56:10.313 I/    ( 1723): size height = 2160
01-01 08:56:10.313 I/    ( 1723): frame_rate = 30
01-01 08:56:10.313 I/    ( 1723): input_crop enable = 0
01-01 08:56:10.313 I/    ( 1723): input_crop rect x = 0
01-01 08:56:10.313 I/    ( 1723): input_crop rect y = 0
01-01 08:56:10.313 I/    ( 1723): input_crop rect w = 0
01-01 08:56:10.313 I/    ( 1723): input_crop rect h = 0
01-01 08:56:10.313 I/    ( 1723): output_crop enable = 0
01-01 08:56:10.313 I/    ( 1723): output_crop rect x = 0
01-01 08:56:10.313 I/    ( 1723): output_crop rect y = 0
01-01 08:56:10.313 I/    ( 1723): output_crop rect w = 0
01-01 08:56:10.313 I/    ( 1723): output_crop rect h = 0
01-01 08:56:10.313 I/    ( 1723): [3371.804443][ISP]:[isp_cfg_info_print][62]dev_sched_mode = 2
01-01 08:56:10.313 I/    ( 1723): stream_output_mode = 1
01-01 08:56:10.313 I/    ( 1723): axi_output_mode = 0
01-01 08:56:10.313 I/    ( 1723): [3371.804443][ISP]:[isp_cfg_info_print][68]isp_calib_type(1)
01-01 08:56:10.313 I/    ( 1723): [3371.804443][ISP]:[isp_cfg_info_print][69]isp_calib_lib_name(/system/etc/cam/lib_x8bRGGB_pwl12_PH_Fov120.so)
01-01 08:56:10.313 I/    ( 1723): [3371.804443][ISP]:[isp_cfg_info_print][70]isp_algo_state(1)
01-01 08:56:10.313 I/    ( 1723): [3371.804443][ISP]:[isp_entity_parser_config][874]--- isp_entity_parser_config done ---
01-01 08:56:10.313 I/    ( 1723): [3371.804443][PYM]:[pym_entity_create][406]pipe(0) pym entity_create done !
01-01 08:56:10.313 I/    ( 1723): [3371.804443][PYM]:[pym_entity_parser_config][1836]pym_entity_parser_config in.
01-01 08:56:10.313 W/    ( 1723): [3371.804443][VPM UIILS]:[hb_utils_get_json_value][50]out_buf_noinvalid has empty json value
01-01 08:56:10.313 W/    ( 1723): [3371.804443][VPM UIILS]:[hb_utils_get_json_value][50]out_buf_noncached has empty json value
01-01 08:56:10.313 W/    ( 1723): [3371.804443][VPM UIILS]:[hb_utils_get_json_value][50]in_buf_noclean has empty json value
01-01 08:56:10.313 W/    ( 1723): [3371.804443][VPM UIILS]:[hb_utils_get_json_value][50]in_buf_noncached has empty json value
01-01 08:56:10.313 W/    ( 1723): [3371.804443][VPM UIILS]:[hb_utils_get_json_value][50]pingpong_ring has empty json value
01-01 08:56:10.313 W/    ( 1723): [3371.804443][VPM UIILS]:[hb_utils_get_json_value][50]layer_num_transfer_gdc has empty json value
01-01 08:56:10.313 W/    ( 1723): [3371.804688][VPM UIILS]:[hb_utils_get_json_value][50]buf_consecutive has empty json value
01-01 08:56:10.314 I/    ( 1723): [3371.804932][PYM]:[pym_cfg_info_print][1754]--- pym_p_ctrl_info_print in ! ---
01-01 08:56:10.314 I/    ( 1723): [3371.804932][PYM]:[pym_cfg_info_print][1757]pym_id = 0
01-01 08:56:10.314 I/    ( 1723): [3371.804932][PYM]:[pym_cfg_info_print][1758]pym_mode = 1
01-01 08:56:10.314 I/    ( 1723): [3371.804932][PYM]:[pym_cfg_info_print][1759]output_buf_num = 6
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1760]timeout = 2000
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1761]data_format = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1762]out_buf_noinvalid = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1763]out_buf_noncached = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1764]in_buf_noclean = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1765]in_buf_noncached = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1766]pingpong_ring = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1767]buf_consecutive = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1768]layer_num_transfer_gdc = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[0] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[0] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[0] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[0] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[1] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[1] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[1] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[1] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[2] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[2] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[2] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[2] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[3] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[3] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[3] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[3] = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[4] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[4] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[4] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805176][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[4] = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print][1777]y_right_shift = 2
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print][1778]c_right_shift = 2
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1654]pixel_num_before_sol = 16
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1655]pic_width = 3840
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1656]pic_height = 2160
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1657]suffix_hb_val = 68
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1658]prefix_hb_val = 2
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1659]suffix_vb_val = 20
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1660]prefix_vb_val = 2
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1662]us_roi_en = 1
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1663]us_roi_uv_bypass= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1664]us_roi_info.start_top= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1665]us_roi_info.start_left= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1666]us_roi_info.stride_uv= 1920
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1667]us_roi_info.stride_y= 1920
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1668]us_roi_info.step_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1669]us_roi_info.step_h= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1670]us_roi_info.out_width= 1920
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1671]us_roi_info.out_height= 1080
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1672]us_roi_info.phase_y_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_us][1673]us_roi_info.phase_y_h= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_ds][1681]ds_roi_en = 63
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_ds][1682]ds_roi_uv_bypass = 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[0]= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[0]= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[0].start_top= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[0].start_left= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805420][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[0].region_width= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[0].region_height= 720
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[0].stride_uv= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[0].stride_y= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[0].step_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[0].step_h= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[0].out_width= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[0].out_height= 720
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[0].phase_y_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[0].phase_y_h= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[1]= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[1]= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[1].start_top= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[1].start_left= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[1].region_width= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[1].region_height= 720
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[1].stride_uv= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[1].stride_y= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[1].step_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[1].step_h= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[1].out_width= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805664][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[1].out_height= 720
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[1].phase_y_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[1].phase_y_h= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[2]= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[2]= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[2].start_top= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[2].start_left= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[2].region_width= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[2].region_height= 720
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[2].stride_uv= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[2].stride_y= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[2].step_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[2].step_h= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[2].out_width= 1280
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[2].out_height= 720
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[2].phase_y_v= 0
01-01 08:56:10.314 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[2].phase_y_h= 0
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[3]= 0
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[3]= 0
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[3].start_top= 0
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[3].start_left= 0
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[3].region_width= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[3].region_height= 720
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[3].stride_uv= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[3].stride_y= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.805908][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[3].step_v= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[3].step_h= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[3].out_width= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[3].out_height= 720
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[3].phase_y_v= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[3].phase_y_h= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[4]= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[4]= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[4].start_top= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[4].start_left= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[4].region_width= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[4].region_height= 720
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[4].stride_uv= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[4].stride_y= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[4].step_v= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[4].step_h= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[4].out_width= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[4].out_height= 720
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[4].phase_y_v= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[4].phase_y_h= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[5]= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[5]= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[5].start_top= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[5].start_left= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[5].region_width= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[5].region_height= 720
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[5].stride_uv= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[5].stride_y= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806152][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[5].step_v= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[5].step_h= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[5].out_width= 1280
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[5].out_height= 720
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[5].phase_y_v= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[5].phase_y_h= 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1707]src_bypass_uv = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1708]src_en = 1
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1709]src_in_stride_y = 3840
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1710]src_in_stride_uv = 3840
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1711]src_info.start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1712]src_info.start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1713]src_info.region_width = 3840
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1714]src_info.region_height = 2160
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1715]src_info.stride_y = 3840
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_src][1716]src_info.stride_uv = 3840
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1724]gs_max_layer_en = 5
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1725]gs_en = 31
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1726]gs_bypass_uv = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[0].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[0].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[0].region_width = 1920
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[0].region_height = 1080
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[0].stride_y = 1920
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[0].stride_uv = 1920
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[1].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[1].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[1].region_width = 960
01-01 08:56:10.315 I/    ( 1723): [3371.806396][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[1].region_height = 540
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[1].stride_y = 960
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[1].stride_uv = 960
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[2].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[2].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[2].region_width = 480
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[2].region_height = 270
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[2].stride_y = 480
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[2].stride_uv = 480
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[3].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[3].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[3].region_width = 240
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[3].region_height = 134
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[3].stride_y = 240
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[3].stride_uv = 240
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[4].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[4].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[4].region_width = 120
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[4].region_height = 60
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[4].stride_y = 128
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[4].stride_uv = 128
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1735]bl_max_layer_en = 5
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1736]bl_en = 31
01-01 08:56:10.315 I/    ( 1723): [3371.806641][PYM]:[pym_cfg_info_print_bl_gs][1737]bl_bypass_uv = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[0].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[0].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[0].region_width = 1920
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[0].region_height = 1080
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[0].stride_y = 1920
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[0].stride_uv = 1920
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[1].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[1].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[1].region_width = 960
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[1].region_height = 540
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[1].stride_y = 960
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[1].stride_uv = 960
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[2].start_left = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[2].start_top = 0
01-01 08:56:10.315 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[2].region_width = 480
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[2].region_height = 270
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[2].stride_y = 480
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[2].stride_uv = 480
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[3].start_left = 0
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[3].start_top = 0
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[3].region_width = 240
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[3].region_height = 134
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[3].stride_y = 240
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[3].stride_uv = 240
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[4].start_left = 0
01-01 08:56:10.316 I/    ( 1723): [3371.806885][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[4].start_top = 0
01-01 08:56:10.316 I/    ( 1723): [3371.807129][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[4].region_width = 120
01-01 08:56:10.316 I/    ( 1723): [3371.807129][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[4].region_height = 60
01-01 08:56:10.316 I/    ( 1723): [3371.807129][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[4].stride_y = 128
01-01 08:56:10.316 I/    ( 1723): [3371.807129][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[4].stride_uv = 128
01-01 08:56:10.316 I/    ( 1723): [3371.807129][PYM]:[pym_cfg_info_print][1789]--- pym_p_ctrl_info_print out ---
01-01 08:56:10.316 I/    ( 1723): [3371.807129][PYM]:[pym_entity_parser_config][1871]pym_entity_parser_config done. pym_cfg size(820)
01-01 08:56:10.316 I/    ( 1723): [3371.807129][GDC]:[gdc_entity_parser_config][244]--- gdc info in ---
01-01 08:56:10.316 W/    ( 1723): [3371.807129][GDC]:[gdc_entity_parser_config][291]node is NULL error
01-01 08:56:10.316 W/    ( 1723): [3371.807129][GDC]:[gdc_entity_parser_config][297]node is NULL error
01-01 08:56:10.316 W/    ( 1723): [3371.807129][GDC]:[gdc_entity_parser_config][303]node is NULL error
01-01 08:56:10.316 W/    ( 1723): [3371.807129][GDC]:[gdc_entity_parser_config][309]node is NULL error
01-01 08:56:10.316 W/    ( 1723): [3371.807129][GDC]:[gdc_entity_parser_config][315]node is NULL error
01-01 08:56:10.316 I/    ( 1723): [3371.808105][VPM buf mgr]:[buffer_mgr_create][149]mgr create done. pipeline_id = 0, buffer_type = 21
01-01 08:56:10.317 W/    ( 1723): [WARN][3371.80798][1723:1723][MEM_MANAGER] Memory module has been opened.
01-01 08:56:10.317 I/    ( 1723): [3371.808105][PYM]:[pym_buf_size_calculate][395]pym size calculate out total : 32161792
01-01 08:56:10.317 I/    ( 1723): [3371.808350][PYM]:[pym_entity_init][634]Pipe(0) pym src out w x h = 3840 x 2160. offset size 0 8294400 total_size 32161792
01-01 08:56:10.317 I/    ( 1723): [3371.808594][VPM buf mgr]:[offset_conv_pym_address][434]check : src_out buffer 3840 x 2160  stride 3840
01-01 08:56:10.317 I/    ( 1723): [3371.808838][VPM buf mgr]:[offset_conv_pym_address][434]check : src_out buffer 3840 x 2160  stride 3840
01-01 08:56:10.318 I/    ( 1723): [3371.809082][VPM buf mgr]:[offset_conv_pym_address][434]check : src_out buffer 3840 x 2160  stride 3840
01-01 08:56:10.318 I/    ( 1723): [3371.809326][VPM buf mgr]:[offset_conv_pym_address][434]check : src_out buffer 3840 x 2160  stride 3840
01-01 08:56:10.318 I/    ( 1723): [3371.809326][PYM]:[pym_entity_init_req_buf][560]Pipe(0) Pym 0 otf mode 1 configed.
01-01 08:56:10.318 I/    ( 1723): [3371.809326][PYM]:[pym_entity_init][653]Pipe(0) Pym 0 entity init done.
01-01 08:56:10.318 V/    ( 1723): hb_cal_open_lib -- 112
01-01 08:56:10.318 V/    ( 1723): hb_cal_open_lib -- 122
01-01 08:56:10.318 E/    ( 1723): calibration of the 69 is not existance
01-01 08:56:10.318 E/    ( 1723): calibration of the 70 is not existance
01-01 08:56:10.318 E/    ( 1723): calibration of the 132 is not existance
01-01 08:56:10.318 E/    ( 1723): calibration of the 133 is not existance
01-01 08:56:10.318 E/    ( 1723): calibration of the 134 is not existance
01-01 08:56:10.318 E/    ( 1723): calibration of the 135 is not existance
01-01 08:56:10.318 E/    ( 1723): calibration of the 136 is not existance
01-01 08:56:10.318 E/    ( 1723): calibration of the 137 is not existance
01-01 08:56:10.318 V/    ( 1723): hb_isp_calib_init--263 name lib_x8bRGGB_pwl12_PH_Fov120_v.0.22.4.29, pstr (nil), plut 0xaaaae5359ea0,tsize 39192, port 0, num 138!
01-01 08:56:10.319 V/    ( 1723): port0 hb_isp_update_calib done.
01-01 08:56:10.340 D/    ( 1723): pipeline_id = 0, hw_id = 0, ctx_id = 0, open end!
01-01 08:56:10.340 W/    ( 1723): [WARN][3371.83195][1723:1723][MEM_MANAGER] Memory module has been opened.
01-01 08:56:10.340 D/    ( 1723): hb_mem_module_open success version: 0.2.0
01-01 08:56:10.341 I/    ( 1723): [3371.832031][ISP]:[isp_entity_init][297]Pipe(0) hw_id = 0, set isp_dev_sched_mode 2
01-01 08:56:10.341 I/    ( 1723): [3371.832520][ISP]:[isp_entity_init][307]Pipe(0) isp algo init done.
01-01 08:56:10.341 I/    ( 1723): [3371.832520][ISP]:[isp_entity_init][310]Pipe(0) isp entity init done.
01-01 08:56:10.353 I/    ( 1723): [3371.843994][GDC]:[gdc_calc_buf_size][371]Gdc cfg In(1920x1080)buf alloc adjust(1920x1088)size: y(2088960)total(3133440)
01-01 08:56:10.353 I/    ( 1723): [3371.843994][VPM buf mgr]:[buffer_mgr_create][149]mgr create done. pipeline_id = 0, buffer_type = 12
01-01 08:56:10.353 I/    ( 1723): [3371.843994][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.353 I/    ( 1723): [3371.844971][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (40) vaddr 0xffff9ceab000 paddr = d5bb3000
01-01 08:56:10.354 I/    ( 1723): [3371.845215][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.354 I/    ( 1723): [3371.845703][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (41) vaddr 0xffff9cbae000 paddr = d5eb0000
01-01 08:56:10.354 I/    ( 1723): [3371.845947][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.355 I/    ( 1723): [3371.846436][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (42) vaddr 0xffff9c8b1000 paddr = d61ad000
01-01 08:56:10.355 I/    ( 1723): [3371.846680][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.356 I/    ( 1723): [3371.847168][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (43) vaddr 0xffff9c5b4000 paddr = d64aa000
01-01 08:56:10.356 I/    ( 1723): [3371.847412][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.356 I/    ( 1723): [3371.847900][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (44) vaddr 0xffff9c2b7000 paddr = d67a7000
01-01 08:56:10.357 I/    ( 1723): [3371.848145][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.357 I/    ( 1723): [3371.848633][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (45) vaddr 0xffff9bfba000 paddr = d6aa4000
01-01 08:56:10.357 I/    ( 1723): [3371.848877][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.358 I/    ( 1723): [3371.849365][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (46) vaddr 0xffff9bcbd000 paddr = d6da1000
01-01 08:56:10.358 I/    ( 1723): [3371.849609][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.359 I/    ( 1723): [3371.850342][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3133440) fd (47) vaddr 0xffff9b9c0000 paddr = d709e000
01-01 08:56:10.359 I/    ( 1723): [3371.850586][GDC]:[gdc_calc_buf_size][371]Gdc cfg In(1920x1080)buf alloc adjust(1920x1080)size: y(2073600)total(3110400)
01-01 08:56:10.359 I/    ( 1723): [3371.850586][VPM buf mgr]:[buffer_mgr_create][149]mgr create done. pipeline_id = 0, buffer_type = 15
01-01 08:56:10.359 I/    ( 1723): [3371.850586][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.360 I/    ( 1723): [3371.851074][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (48) vaddr 0xffff9b6c8000 paddr = d739b000
01-01 08:56:10.360 I/    ( 1723): [3371.851318][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.360 I/    ( 1723): [3371.851807][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (49) vaddr 0xffff9b3d0000 paddr = d7693000
01-01 08:56:10.360 I/    ( 1723): [3371.851807][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.361 I/    ( 1723): [3371.852295][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (50) vaddr 0xffff9b0d8000 paddr = d798b000
01-01 08:56:10.361 I/    ( 1723): [3371.852295][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.361 I/    ( 1723): [3371.852783][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (51) vaddr 0xffff9ade0000 paddr = d7c83000
01-01 08:56:10.361 I/    ( 1723): [3371.853027][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.362 I/    ( 1723): [3371.853516][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (52) vaddr 0xffff9aae8000 paddr = d7f7b000
01-01 08:56:10.362 I/    ( 1723): [3371.853516][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.363 I/    ( 1723): [3371.854004][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (53) vaddr 0xffff9a7f0000 paddr = d8273000
01-01 08:56:10.363 I/    ( 1723): [3371.854004][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.363 I/    ( 1723): [3371.854736][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (54) vaddr 0xffff9a4f8000 paddr = d856b000
01-01 08:56:10.363 I/    ( 1723): [3371.854736][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.364 I/    ( 1723): [3371.855469][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3110400) fd (55) vaddr 0xffff9a200000 paddr = d8863000
01-01 08:56:10.364 I/    ( 1723): [3371.855469][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.364 I/    ( 1723): [3371.855713][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(40960) fd (56) vaddr 0xffff9a1f6000 paddr = d8b5b000
01-01 08:56:10.364 I/    ( 1723): [3371.855713][GDC]:[gdc_entity_init][533]Pipe(0) Gdc entity init done.
01-01 08:56:10.364 I/    ( 1723): [3371.855713][VPM pipeline]:[vio_pipeline_init][507]pipe(0) pipeline_init success out
01-01 08:56:10.364 I/    ( 1723): [3371.855713][VPM interface]:[hb_vpm_init_pipeline][117]pipeline(0) init done !
01-01 08:56:10.365 I/    ( 1723): [3371.856934][VPM pipeline]:[vio_pipeline_create][538]pipe (1) create done!
01-01 08:56:10.365 W/    ( 1723): [3371.856934][VPM pipeline]:[vio_entity_parser][195]no isp config found.
01-01 08:56:10.365 I/    ( 1723): [3371.856934][VPM pipeline]:[vio_pipeline_entity_create][292]pipe(1) vio_pipeline_entity_create in
01-01 08:56:10.365 I/    ( 1723): [3371.856934][PYM]:[pym_entity_create][406]pipe(1) pym entity_create done !
01-01 08:56:10.365 I/    ( 1723): [3371.856934][PYM]:[pym_entity_parser_config][1836]pym_entity_parser_config in.
01-01 08:56:10.365 W/    ( 1723): [3371.856934][VPM UIILS]:[hb_utils_get_json_value][50]out_buf_noinvalid has empty json value
01-01 08:56:10.365 W/    ( 1723): [3371.856934][VPM UIILS]:[hb_utils_get_json_value][50]out_buf_noncached has empty json value
01-01 08:56:10.365 W/    ( 1723): [3371.856934][VPM UIILS]:[hb_utils_get_json_value][50]in_buf_noclean has empty json value
01-01 08:56:10.365 W/    ( 1723): [3371.856934][VPM UIILS]:[hb_utils_get_json_value][50]in_buf_noncached has empty json value
01-01 08:56:10.365 W/    ( 1723): [3371.856934][VPM UIILS]:[hb_utils_get_json_value][50]pingpong_ring has empty json value
01-01 08:56:10.366 W/    ( 1723): [3371.856934][VPM UIILS]:[hb_utils_get_json_value][50]layer_num_transfer_gdc has empty json value
01-01 08:56:10.366 W/    ( 1723): [3371.857178][VPM UIILS]:[hb_utils_get_json_value][50]buf_consecutive has empty json value
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1754]--- pym_p_ctrl_info_print in ! ---
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1757]pym_id = 2
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1758]pym_mode = 2
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1759]output_buf_num = 6
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1760]timeout = 6000
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1761]data_format = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1762]out_buf_noinvalid = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1763]out_buf_noncached = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1764]in_buf_noclean = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1765]in_buf_noncached = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1766]pingpong_ring = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1767]buf_consecutive = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1768]layer_num_transfer_gdc = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[0] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[0] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[0] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[0] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[1] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[1] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[1] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[1] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[2] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[2] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[2] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[2] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857666][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[3] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[3] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[3] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[3] = 1
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1771]y_hor_coeff[4] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1772]y_ver_coeff[4] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1773]c_hor_coeff[4] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1774]c_ver_coeff[4] = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1777]y_right_shift = 2
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print][1778]c_right_shift = 2
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1654]pixel_num_before_sol = 16
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1655]pic_width = 1936
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1656]pic_height = 1080
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1657]suffix_hb_val = 68
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1658]prefix_hb_val = 2
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1659]suffix_vb_val = 20
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1660]prefix_vb_val = 2
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1662]us_roi_en = 0
01-01 08:56:10.366 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1663]us_roi_uv_bypass= 0
01-01 08:56:10.367 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1664]us_roi_info.start_top= 0
01-01 08:56:10.367 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1665]us_roi_info.start_left= 0
01-01 08:56:10.367 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1666]us_roi_info.stride_uv= 1920
01-01 08:56:10.367 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1667]us_roi_info.stride_y= 1920
01-01 08:56:10.367 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1668]us_roi_info.step_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.857910][PYM]:[pym_cfg_info_print_us][1669]us_roi_info.step_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_us][1670]us_roi_info.out_width= 1920
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_us][1671]us_roi_info.out_height= 1080
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_us][1672]us_roi_info.phase_y_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_us][1673]us_roi_info.phase_y_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1681]ds_roi_en = 1
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1682]ds_roi_uv_bypass = 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[0]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[0]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[0].start_top= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[0].start_left= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[0].region_width= 1872
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[0].region_height= 1008
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[0].stride_uv= 960
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[0].stride_y= 960
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[0].step_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[0].step_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[0].out_width= 960
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[0].out_height= 512
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[0].phase_y_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[0].phase_y_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[1]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[1]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[1].start_top= 20
01-01 08:56:10.367 I/    ( 1723): [3371.858154][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[1].start_left= 16
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[1].region_width= 900
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[1].region_height= 600
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[1].stride_uv= 700
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[1].stride_y= 700
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[1].step_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[1].step_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[1].out_width= 700
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[1].out_height= 500
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[1].phase_y_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[1].phase_y_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[2]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[2]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[2].start_top= 8
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[2].start_left= 48
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[2].region_width= 720
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[2].region_height= 480
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[2].stride_uv= 640
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[2].stride_y= 640
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[2].step_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[2].step_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[2].out_width= 640
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[2].out_height= 320
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[2].phase_y_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[2].phase_y_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[3]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858398][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[3]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[3].start_top= 18
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[3].start_left= 24
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[3].region_width= 520
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[3].region_height= 450
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[3].stride_uv= 320
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[3].stride_y= 320
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[3].step_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[3].step_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[3].out_width= 320
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[3].out_height= 160
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[3].phase_y_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[3].phase_y_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[4]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[4]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[4].start_top= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[4].start_left= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[4].region_width= 520
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[4].region_height= 450
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[4].stride_uv= 512
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[4].stride_y= 512
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[4].step_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[4].step_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[4].out_width= 512
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[4].out_height= 240
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[4].phase_y_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[4].phase_y_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1685]ds_roi_sel[5]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858643][PYM]:[pym_cfg_info_print_ds][1686]ds_roi_layer[5]= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1687]ds_roi_info[5].start_top= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1688]ds_roi_info[5].start_left= 10
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1689]ds_roi_info[5].region_width= 520
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1690]ds_roi_info[5].region_height= 450
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1691]ds_roi_info[5].stride_uv= 122
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1692]ds_roi_info[5].stride_y= 122
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1693]ds_roi_info[5].step_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1694]ds_roi_info[5].step_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1695]ds_roi_info[5].out_width= 122
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1696]ds_roi_info[5].out_height= 32
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1697]ds_roi_info[5].phase_y_v= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_ds][1698]ds_roi_info[5].phase_y_h= 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1707]src_bypass_uv = 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1708]src_en = 1
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1709]src_in_stride_y = 1936
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1710]src_in_stride_uv = 1936
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1711]src_info.start_left = 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1712]src_info.start_top = 0
01-01 08:56:10.367 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1713]src_info.region_width = 1936
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1714]src_info.region_height = 1080
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1715]src_info.stride_y = 1936
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_src][1716]src_info.stride_uv = 1936
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_bl_gs][1724]gs_max_layer_en = 5
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_bl_gs][1725]gs_en = 0
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_bl_gs][1726]gs_bypass_uv = 0
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[0].start_left = 0
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[0].start_top = 0
01-01 08:56:10.368 I/    ( 1723): [3371.858887][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[0].region_width = 960
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[0].region_height = 512
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[0].stride_y = 960
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[0].stride_uv = 960
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[1].start_left = 40
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[1].start_top = 10
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[1].region_width = 240
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[1].region_height = 130
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[1].stride_y = 240
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[1].stride_uv = 240
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[2].start_left = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[2].start_top = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[2].region_width = 130
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[2].region_height = 70
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[2].stride_y = 130
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[2].stride_uv = 130
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[3].start_left = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[3].start_top = 10
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[3].region_width = 64
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[3].region_height = 32
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[3].stride_y = 64
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[3].stride_uv = 64
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1728]gs_info[4].start_left = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1729]gs_info[4].start_top = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1730]gs_info[4].region_width = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1731]gs_info[4].region_height = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1732]gs_info[4].stride_y = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859131][PYM]:[pym_cfg_info_print_bl_gs][1733]gs_info[4].stride_uv = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1735]bl_max_layer_en = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1736]bl_en = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1737]bl_bypass_uv = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[0].start_left = 32
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[0].start_top = 64
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[0].region_width = 320
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[0].region_height = 240
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[0].stride_y = 320
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[0].stride_uv = 320
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[1].start_left = 64
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[1].start_top = 6
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[1].region_width = 240
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[1].region_height = 80
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[1].stride_y = 240
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[1].stride_uv = 240
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[2].start_left = 8
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[2].start_top = 16
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[2].region_width = 120
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[2].region_height = 60
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[2].stride_y = 120
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[2].stride_uv = 120
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[3].start_left = 12
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[3].start_top = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[3].region_width = 48
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[3].region_height = 32
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[3].stride_y = 48
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[3].stride_uv = 48
01-01 08:56:10.368 I/    ( 1723): [3371.859375][PYM]:[pym_cfg_info_print_bl_gs][1739]bl_info[4].start_left = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859619][PYM]:[pym_cfg_info_print_bl_gs][1740]bl_info[4].start_top = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859619][PYM]:[pym_cfg_info_print_bl_gs][1741]bl_info[4].region_width = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859619][PYM]:[pym_cfg_info_print_bl_gs][1742]bl_info[4].region_height = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859619][PYM]:[pym_cfg_info_print_bl_gs][1743]bl_info[4].stride_y = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859619][PYM]:[pym_cfg_info_print_bl_gs][1744]bl_info[4].stride_uv = 0
01-01 08:56:10.368 I/    ( 1723): [3371.859619][PYM]:[pym_cfg_info_print][1789]--- pym_p_ctrl_info_print out ---
01-01 08:56:10.368 I/    ( 1723): [3371.859619][PYM]:[pym_entity_parser_config][1871]pym_entity_parser_config done. pym_cfg size(820)
01-01 08:56:10.368 I/    ( 1723): [3371.859619][GDC]:[gdc_entity_parser_config][244]--- gdc info in ---
01-01 08:56:10.368 W/    ( 1723): [3371.859619][GDC]:[gdc_entity_parser_config][291]node is NULL error
01-01 08:56:10.368 W/    ( 1723): [3371.859619][GDC]:[gdc_entity_parser_config][297]node is NULL error
01-01 08:56:10.368 W/    ( 1723): [3371.859619][GDC]:[gdc_entity_parser_config][303]node is NULL error
01-01 08:56:10.368 W/    ( 1723): [3371.859619][GDC]:[gdc_entity_parser_config][309]node is NULL error
01-01 08:56:10.368 W/    ( 1723): [3371.859619][GDC]:[gdc_entity_parser_config][315]node is NULL error
01-01 08:56:10.369 I/    ( 1723): [3371.860107][VPM buf mgr]:[buffer_mgr_create][149]mgr create done. pipeline_id = 1, buffer_type = 21
01-01 08:56:10.369 I/    ( 1723): [3371.860107][PYM]:[pym_buf_size_calculate][395]pym size calculate out total : 3874816
01-01 08:56:10.369 I/    ( 1723): [3371.860107][PYM]:[pym_entity_init][634]Pipe(1) pym src out w x h = 1936 x 1080. offset size 0 2090880 total_size 3874816
01-01 08:56:10.369 I/    ( 1723): [3371.860596][VPM buf mgr]:[offset_conv_pym_address][434]check : src_out buffer 1936 x 1080  stride 1936
01-01 08:56:10.369 I/    ( 1723): [3371.860840][VPM buf mgr]:[offset_conv_pym_address][434]check : src_out buffer 1936 x 1080  stride 1936
01-01 08:56:10.393 I/    ( 1723): [3371.884033][VPM buf mgr]:[offset_conv_pym_address][434]check : src_out buffer 1936 x 1080  stride 1936
01-01 08:56:10.393 I/    ( 1723): [3371.884033][PYM]:[pym_entity_init_req_buf][557]Pipe(1) Pym 2 junction mode 2 configed buf num 6.
01-01 08:56:10.393 I/    ( 1723): [3371.884033][PYM]:[pym_entity_init][653]Pipe(1) Pym 2 entity init done.
01-01 08:56:10.393 I/    ( 1723): [3371.884277][GDC]:[gdc_calc_buf_size][371]Gdc cfg In(1936x1080)buf alloc adjust(1936x1088)size: y(2106368)total(3159552)
01-01 08:56:10.393 I/    ( 1723): [3371.884277][VPM buf mgr]:[buffer_mgr_create][149]mgr create done. pipeline_id = 1, buffer_type = 12
01-01 08:56:10.393 I/    ( 1723): [3371.884277][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.393 I/    ( 1723): [3371.884766][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (66) vaddr 0xffff988c6000 paddr = da191000
01-01 08:56:10.394 I/    ( 1723): [3371.885010][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.394 I/    ( 1723): [3371.885498][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (67) vaddr 0xffff985c2000 paddr = da495000
01-01 08:56:10.394 I/    ( 1723): [3371.885742][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.395 I/    ( 1723): [3371.886230][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (68) vaddr 0xffff982be000 paddr = da799000
01-01 08:56:10.395 I/    ( 1723): [3371.886475][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.396 I/    ( 1723): [3371.887207][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (69) vaddr 0xffff97fba000 paddr = daa9d000
01-01 08:56:10.396 I/    ( 1723): [3371.887451][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.396 I/    ( 1723): [3371.887939][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (70) vaddr 0xffff97cb6000 paddr = dada1000
01-01 08:56:10.397 I/    ( 1723): [3371.888184][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.397 I/    ( 1723): [3371.888916][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (71) vaddr 0xffff979b2000 paddr = db0a5000
01-01 08:56:10.398 I/    ( 1723): [3371.889160][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.398 I/    ( 1723): [3371.889648][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (72) vaddr 0xffff976ae000 paddr = db3a9000
01-01 08:56:10.398 I/    ( 1723): [3371.889893][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.399 I/    ( 1723): [3371.890381][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3159552) fd (73) vaddr 0xffff973aa000 paddr = db6ad000
01-01 08:56:10.399 I/    ( 1723): [3371.890625][GDC]:[gdc_calc_buf_size][371]Gdc cfg In(1936x1080)buf alloc adjust(1936x1080)size: y(2090880)total(3136320)
01-01 08:56:10.399 I/    ( 1723): [3371.890625][VPM buf mgr]:[buffer_mgr_create][149]mgr create done. pipeline_id = 1, buffer_type = 15
01-01 08:56:10.399 I/    ( 1723): [3371.890625][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.400 I/    ( 1723): [3371.891113][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (74) vaddr 0xffff970ac000 paddr = db9b1000
01-01 08:56:10.400 I/    ( 1723): [3371.891113][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.400 I/    ( 1723): [3371.891602][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (75) vaddr 0xffff96dae000 paddr = dbcaf000
01-01 08:56:10.400 I/    ( 1723): [3371.891602][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.401 I/    ( 1723): [3371.892578][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (76) vaddr 0xffff96ab0000 paddr = dbfad000
01-01 08:56:10.401 I/    ( 1723): [3371.892578][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.402 I/    ( 1723): [3371.893066][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (77) vaddr 0xffff967b2000 paddr = dc2ab000
01-01 08:56:10.402 I/    ( 1723): [3371.893066][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.402 I/    ( 1723): [3371.893799][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (78) vaddr 0xffff964b4000 paddr = dc5a9000
01-01 08:56:10.402 I/    ( 1723): [3371.893799][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.403 I/    ( 1723): [3371.894287][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (79) vaddr 0xffff961b6000 paddr = dc8a7000
01-01 08:56:10.403 I/    ( 1723): [3371.894287][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.403 I/    ( 1723): [3371.894775][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (80) vaddr 0xffff95eb8000 paddr = dcba5000
01-01 08:56:10.403 I/    ( 1723): [3371.894775][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.404 I/    ( 1723): [3371.895508][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(3136320) fd (81) vaddr 0xffff95bba000 paddr = dcea3000
01-01 08:56:10.404 I/    ( 1723): [3371.895508][VPM buf mgr]:[vpm_hb_mem_alloc_phy][303]vpm_hb_mem_alloc_phy alloc cached buffer
01-01 08:56:10.404 I/    ( 1723): [3371.895508][VPM buf mgr]:[vpm_hb_mem_alloc_phy][318]Alloc size(40960) fd (82) vaddr 0xffff95bb0000 paddr = dd1a1000
01-01 08:56:10.404 I/    ( 1723): [3371.895508][GDC]:[gdc_entity_init][533]Pipe(1) Gdc entity init done.
01-01 08:56:10.404 I/    ( 1723): [3371.895508][VPM pipeline]:[vio_pipeline_init][507]pipe(1) pipeline_init success out
01-01 08:56:10.404 I/    ( 1723): [3371.895508][VPM interface]:[hb_vpm_init_pipeline][117]pipeline(1) init done !
01-01 08:56:10.404 I/    ( 1723): [3371.895752][VPM interface]:[hb_vpm_start_pipeline][222]vio pipeline(0) try to start.
01-01 08:56:10.404 I/    ( 1723): [3371.895996][PYM]:[pym_entity_start][1890]pipe(0)pym_entity_start in !
01-01 08:56:10.427 I/    ( 1723): [3371.918945][PYM]:[pym_entity_start][1905]Pipe(0)pym0 entity start Done.
01-01 08:56:10.427 D/    ( 1723): isp_pipe = 0 , dev mode = 2, size(3840*2160) !
01-01 08:56:10.443 I/    ( 1723): [3371.933838][ISP]:[isp_entity_start][905]Pipe(0) isp set pub attr done.
01-01 08:56:10.443 I/    ( 1723): [3371.934326][ISP]:[isp_entity_start][921]Pipe(0) isp_pipe_start done.
01-01 08:56:10.443 I/    ( 1723): [3371.934326][ISP]:[isp_entity_start][940]Pipe(0)isp_calib_update isp_channel = 0, hw_id = 0, ctx_id = 0
01-01 08:56:10.444 I/    ( 1723): [3371.935059][ISP]:[isp_entity_start][949]Pipe(0) isp ctx 0 algo start done.
01-01 08:56:10.444 I/    ( 1723): [3371.935059][ISP]:[isp_entity_start][951]Pipe(0) isp entity start done.
01-01 08:56:10.444 I/    ( 1723): [3371.935059][VIN]:[hb_vin_start][1156]cam port0 start begin
01-01 08:56:10.444 I/    ( 1723): [3371.935303][ovx8b]:write x8b 1@0x36: 0x0100=0x0001
01-01 08:56:10.444 I/    ( 1723): [3371.935303][mipi host]:mipi host0 start begin
01-01 08:56:10.445 I/    ( 1723): [3371.936523][mipi host]:mipi host0 start end
01-01 08:56:10.445 I/    ( 1723): [3371.936523][mipi dev]:mipi dev0 start begin
01-01 08:56:10.445 I/    ( 1723): [3371.936523][mipi dev]:mipi dev0 start end
01-01 08:56:10.445 I/    ( 1723): [3371.936523][hb mipi]:hb_vin_mipi_start 0 end
01-01 08:56:10.445 I/    ( 1723): [3371.936523][VIN]:[hb_vin_start][1215]cam port0 start end
01-01 08:56:10.445 I/    ( 1723): [3371.936523][VIN]:[hb_vin_start][1218]vin cam start done.Time cost(1)ms.
01-01 08:56:10.445 I/    ( 1723): [3371.936523][VPM interface]:[hb_vpm_start_pipeline][222]vio pipeline(1) try to start.
01-01 08:56:10.445 I/    ( 1723): [3371.936523][PYM]:[pym_entity_start][1890]pipe(1)pym_entity_start in !
01-01 08:56:10.448 I/    ( 1723): [3371.939697][PYM]:[pym_entity_start][1905]Pipe(1)pym2 entity start Done.
01-01 08:56:10.448 I/    ( 1723): [3371.939697][VIN]:[hb_vin_start][1156]cam port1 start begin
01-01 08:56:10.448 I/    ( 1723): [3371.939941][cim_dma hal]:pipe(1)cim_dma_entity_start in !
01-01 08:56:10.451 I/    ( 1723): [3371.942383][cim_dma hal]:pipe(1)cim_dma_entity_start CIM_IOC_STREAM Done !
01-01 08:56:10.462 I/    ( 1723): [3371.953125][mipi host]:mipi host3 start begin
01-01 08:56:10.975 I/    ( 1723): [3372.466064][mipi host]:mipi host3 start end
01-01 08:56:10.975 I/    ( 1723): [3372.466553][mipi dev]:mipi dev0 start begin
01-01 08:56:10.975 I/    ( 1723): [3372.466553][mipi dev]:mipi dev0 start end
01-01 08:56:10.975 I/    ( 1723): [3372.466553][hb mipi]:hb_vin_mipi_start 3 end
01-01 08:56:10.975 I/    ( 1723): [3372.466553][VIN]:[hb_vin_start][1215]cam port1 start end
01-01 08:56:10.975 I/    ( 1723): [3372.466553][VIN]:[hb_vin_start][1218]vin cam start done.Time cost(527)ms.
01-01 08:56:10.975 I/    ( 1723): [3372.466553][VIO TEST UIIL COMM]:[vpm_test_calculate_fps][779]Pipe(0)Time cost fps measure start
01-01 08:56:10.975 I/    ( 1723): [3372.466797][VIO TEST UIIL COMM]:[vpm_test_calculate_fps][779]Pipe(1)Time cost fps measure start
01-01 08:56:12.977 E/    ( 1723): [3374.468506][VPM dev_ioctl]:[vio_dev_node_dqbuf_poll][213]dev poll Timeout(2000): 0, Success
01-01 08:56:12.977 E/    ( 1723): [3374.468506][VPM UIILS]:[hb_utils_send_sfmu_msg][92]hb_send_sfmu_msg,eventId=62,sub_event_number=1
01-01 08:56:12.977 E/    ( 1723): [3374.468750][VPM UIILS]:[hb_utils_send_sfmu_msg][94]hb_send_sfmu_msg, return = 0
01-01 08:56:12.977 E/    ( 1723): [3374.468750][PYM]:[pym_capture_dqbuf][2018]pipe(0)pym buf(21) dq failed index 0
01-01 08:56:12.977 E/    ( 1723): [3374.468750][VPM UIILS]:[hb_utils_send_sfmu_msg][92]hb_send_sfmu_msg,eventId=90,sub_event_number=2
01-01 08:56:12.977 E/    ( 1723): [3374.468750][PYM]:[pym_entity_get_buf][2176]Pipe(0)Pym 0 get cap buf failed pipe_state:2
01-01 08:56:12.977 E/    ( 1723): [3374.468750][VPM UIILS]:[hb_utils_send_sfmu_msg][92]hb_send_sfmu_msg,eventId=90,sub_event_number=8
01-01 08:56:12.977 E/    ( 1723): [3374.468750][VPM pipeline]:[vio_pipeline_get_data][984]Pipe(0)pym get buf failed type(21)
01-01 08:56:14.980 E/    ( 1723): [3376.471436][VPM dev_ioctl]:[vio_dev_node_dqbuf_poll][213]dev poll Timeout(2000): 0, Success
01-01 08:56:14.980 E/    ( 1723): [3376.471436][VPM UIILS]:[hb_utils_send_sfmu_msg][92]hb_send_sfmu_msg,eventId=62,sub_event_number=1
01-01 08:56:14.980 E/    ( 1723): [3376.471436][VPM UIILS]:[hb_utils_send_sfmu_msg][94]hb_send_sfmu_msg, return = 0
01-01 08:56:14.980 E/    ( 1723): [3376.471436][PYM]:[pym_capture_dqbuf][2018]pipe(0)pym buf(21) dq failed index 0
01-01 08:56:14.980 E/    ( 1723): [3376.471436][VPM UIILS]:[hb_utils_send_sfmu_msg][92]hb_send_sfmu_msg,eventId=90,sub_event_number=2
01-01 08:56:14.980 E/    ( 1723): [3376.471436][PYM]:[pym_entity_get_buf][2176]Pipe(0)Pym 0 get cap buf failed pipe_state:2
01-01 08:56:14.980 E/    ( 1723): [3376.471436][VPM UIILS]:[hb_utils_send_sfmu_msg][92]hb_send_sfmu_msg,eventId=90,sub_event_number=8
01-01 08:56:14.980 E/    ( 1723): [3376.471436][VPM pipeline]:[vio_pipeline_get_data][984]Pipe(0)pym get buf failed type(21)
    您好: 此处看您的x8b配置,应该是使能的同步功能,但lpwm_num设为0,未开启lpwm输出,这里您单独点亮x8b的配置有么? 是否有按您的硬件将相应的lpwm输出使能? 谢谢~
    2024-01-08
    • szc回复只蓝片羽:
      单独点亮x8b的配置是仿照sen_cim_isp0_pym0_4k_ovx8b用例写的。修改了bus和camera的i2c address。 lpwm_num 设置成0或者1,都可以收到图像。 具体配置如下 hb_j5dev.json { "config_number":1, "board_name":"j5dvb", "config_0":{ "comment": "ovx8b(sensing) rggb 3840x2160 pwl raw12 30fps on host1 max9296", "interface_type": "mipi", "lpwm_num":0, "lpwm_0":{ "lpwm_index":1, "lpwm_enable":"0xf", "trigger_mode":8, "offset_us":[ 1, 1, 1, 1 ], "period_us":[ 33333, 33333, 33333, 33333 ], "duty_us":[ 10, 10, 10, 10 ] }, "deserial_num":1, "deserial_0":{ "deserial_name":"max9296", "deserial_addr":"0x48", "bus_type":0, "bus_num":1, "power_mode":0, "gpio_pin":[453,309], "gpio_level":[0,0] }, "port_number":1, "port_0":{ "dev_port":0, "bus_type":0, "bus_num":1, "entry_num":0, "serial_addr":"0x40", "sensor_addr":"0x36", "sensor_name":"ovx8b", "reg_width":16, "extra_mode":0, "config_index":516, "sensor_mode":5, "fps":30, "resolution":2160, "deserial_index":0, "deserial_port":0, "data_path":"/userdata/app/bin/vps/vpm/cfg/sen_cim_isp0_pym0_4k_ovx8b/cim_config.json", "config_path":"/system/etc/cam/hb_mipi_ovx8b_raw12_%dfps_%dP.json" } } } cim_config.json { "pipeline0":{ "cim": { "input": { "mipi": { "enable": 1, "width": 3840, "height": 2160, "format": 44, "rx_index": 0, "vc_index": 0, "channels": 1, "raw16_splict": 0, "dbg_clear": 0, "y_uv_swap": 0, "tag_enable": 0, "function": { "enable_frame_id": 1, "enable_bypass": 0, "enable_pattern": 0, "hdr_mode": 0, "set_init_frame_id": 1, "set_bypass_channels": 1 } } }, "output": { "pym": { "pym0_en": 0, "pym1_en": 0 }, "isp0": { "isp_ch0": 1, "isp_ch1": 0, "isp_ch2": 0, "isp_ch3": 0 }, "isp1":{ "isp_ch0": 0, "isp_ch1": 0, "isp_ch2": 0, "isp_ch3": 0 } } }, "cim_dma": { "input": { "mipi": { "enable": 1, "width": 3840, "height": 2160, "format": 44, "vc_index": 0, "rx_index": 1, "raw16_splict": 0, "dbg_clear": 0, "y_uv_swap": 0, "tag_enable": 0, "function": { "enable_frame_id": 1, "enable_DMA": 1, "pack_mode": 0, "enable_bypass": 0, "enable_id_decoder": 0, "set_init_frame_id": 1, "set_bypass_channels": 1 } } }, "output": { "ddr": { "enable": 1, "format": 44, "width": 3840, "height": 2160, "buf_num": 6, "cached": 0, "use_ispbuf": 1 } } } } } vpm_config.json { "pipeline0": { "isp": { "hw_id":0, "ctx_id": 0, "sched_mode":2, "hdr_mode": 1, "width": 3840, "height": 2160, "frame_rate": 30, "input_crop_enable": 0, "input_crop_x": 0, "input_crop_y": 0, "input_crop_width": 0, "input_crop_height": 0, "output_crop_enable": 0, "output_crop_x": 0, "output_crop_y": 0, "output_crop_width": 0, "output_crop_height": 0, "isp_stream_output_format": 1, "isp_dma_output_format": 0, "calib_mode": 1, "calib_lname": "/system/etc/cam/lib_x8bRGGB_pwl12_PH_Fov120.so", "isp_algo_state": 1 }, "pym": { "pym_config": { "pym_hw_id":0, "pym_mode": 1, "output_buf_num": 6, "time_out": 2000, "y_hor_coeff4": 0, "y_hor_coeff3": 1, "y_hor_coeff2": 1, "y_hor_coeff1": 0, "y_hor_coeff0": 0, "y_ver_coeff4": 0, "y_ver_coeff3": 1, "y_ver_coeff2": 1, "y_ver_coeff1": 0, "y_ver_coeff0": 0, "c_hor_coeff4": 0, "c_hor_coeff3": 1, "c_hor_coeff2": 1, "c_hor_coeff1": 0, "c_hor_coeff0": 0, "c_ver_coeff4": 0, "c_ver_coeff3": 1, "c_ver_coeff2": 1, "c_ver_coeff1": 0, "c_ver_coeff0": 0, "y_right_shift": 2, "c_right_shift": 2 }, "pym_ctrl": { "source_en": 1, "src_uv_bypass": 0, "src_in_width": 3840, "src_in_height": 2160, "src_in_stride_y": 3840, "src_in_stride_uv": 3840, "src_start_top": 0, "src_start_left": 0, "src_region_width": 3840, "src_region_height": 2160, "src_out_stride_y": 3840, "src_out_stride_uv": 3840, "suffix_hb_val": 68, "prefix_hb_val": 2, "suffix_vb_val": 20, "prefix_vb_val": 2, "pixel_num_before_sol": 16, "gs_max_layer_en": 5, "gs_en": 31, "gs_uv_bypass": 0, "gauss_info": [ { "gs_start_top": 0, "gs_start_left": 0, "gs_region_width": 1920, "gs_region_height": 1080, "gs_stride_y": 1920, "gs_stride_uv": 1920 }, { "gs_start_top": 0, "gs_start_left": 0, "gs_region_width": 960, "gs_region_height": 540, "gs_stride_y": 960, "gs_stride_uv": 960 }, { "gs_start_top": 0, "gs_start_left": 0, "gs_region_width": 480, "gs_region_height": 270, "gs_stride_y": 480, "gs_stride_uv": 480 }, { "gs_start_top": 0, "gs_start_left": 0, "gs_region_width": 240, "gs_region_height": 134, "gs_stride_y": 240, "gs_stride_uv": 240 }, { "gs_start_top": 0, "gs_start_left": 0, "gs_region_width": 120, "gs_region_height": 60, "gs_stride_y": 128, "gs_stride_uv": 128 } ], "bl_max_layer_en": 5, "bl_en": 31, "bl_uv_bypass": 0, "bilinear_info": [ { "bl_start_top": 0, "bl_start_left": 0, "bl_region_width": 1920, "bl_region_height": 1080, "bl_stride_y": 1920, "bl_stride_uv": 1920 }, { "bl_start_top": 0, "bl_start_left": 0, "bl_region_width": 960, "bl_region_height": 540, "bl_stride_y": 960, "bl_stride_uv": 960 }, { "bl_start_top": 0, "bl_start_left": 0, "bl_region_width": 480, "bl_region_height": 270, "bl_stride_y": 480, "bl_stride_uv": 480 }, { "bl_start_top": 0, "bl_start_left": 0, "bl_region_width": 240, "bl_region_height": 134, "bl_stride_y":240, "bl_stride_uv": 240 }, { "bl_start_top": 0, "bl_start_left": 0, "bl_region_width": 120, "bl_region_height": 60, "bl_stride_y": 128, "bl_stride_uv": 128 } ], "upscale_roi_en": 1, "us_roi_uv_bypass": 0, "us_roi_start_left": 0, "us_roi_start_top": 0, "us_roi_region_width": 1920, "us_roi_region_height": 1080, "us_roi_stride_y": 1920, "us_roi_stride_uv": 1920, "us_roi_out_width": 1920, "us_roi_out_height": 1080, "ds_roi_en": 63, "ds_roi_uv_bypass": 0, "ds_roi": [ { "ds_roi_layer": 0, "ds_roi_sel": 0, "ds_roi_start_top": 0, "ds_roi_start_left": 0, "ds_roi_region_width": 1280, "ds_roi_region_height": 720, "ds_roi_stride_y": 1280, "ds_roi_stride_uv": 1280, "ds_roi_out_width": 1280, "ds_roi_out_height": 720 }, { "ds_roi_layer": 0, "ds_roi_sel": 0, "ds_roi_start_top": 0, "ds_roi_start_left": 0, "ds_roi_region_width": 1280, "ds_roi_region_height": 720, "ds_roi_stride_y": 1280, "ds_roi_stride_uv": 1280, "ds_roi_out_width": 1280, "ds_roi_out_height": 720 }, { "ds_roi_layer": 0, "ds_roi_sel": 0, "ds_roi_start_top": 0, "ds_roi_start_left": 0, "ds_roi_region_width": 1280, "ds_roi_region_height": 720, "ds_roi_stride_y": 1280, "ds_roi_stride_uv": 1280, "ds_roi_out_width": 1280, "ds_roi_out_height": 720 }, { "ds_roi_layer": 0, "ds_roi_sel": 0, "ds_roi_start_top": 0, "ds_roi_start_left": 0, "ds_roi_region_width": 1280, "ds_roi_region_height": 720, "ds_roi_stride_y": 1280, "ds_roi_stride_uv": 1280, "ds_roi_out_width": 1280, "ds_roi_out_height": 720 }, { "ds_roi_layer": 0, "ds_roi_sel": 0, "ds_roi_start_top": 0, "ds_roi_start_left": 0, "ds_roi_region_width": 1280, "ds_roi_region_height": 720, "ds_roi_stride_y": 1280, "ds_roi_stride_uv": 1280, "ds_roi_out_width": 1280, "ds_roi_out_height": 720 }, { "ds_roi_layer": 0, "ds_roi_sel": 0, "ds_roi_start_top": 0, "ds_roi_start_left": 0, "ds_roi_region_width": 1280, "ds_roi_region_height": 720, "ds_roi_stride_y": 1280, "ds_roi_stride_uv": 1280, "ds_roi_out_width": 1280, "ds_roi_out_height": 720 } ], "pre_line_int_0_set": 0, "pre_line_int_1_set": 0, "pre_line_int_2_set": 0, "pre_line_int_3_set": 0, "pre_line_int_4_set": 0, "pre_line_int_5_set": 0, "pre_line_int_6_set": 0, "pre_line_int_7_set": 0 } }, "gdc": { "input_width": 1920, "input_height": 1080, "output_width": 1920, "output_height": 1080, "buf_num": 8, "fb_buf_num": 8 } } }
      2024-01-09
    • szc回复只蓝片羽:
      这个评论中怎么换行?我是换行的,但是显示的就没有换行。
      2024-01-09
  • szc
    具体配置如下
    hb_j5dev.json
    "config_number":1,
    "config_0":{
    "lpwm_num":0,
    "lpwm_0":{
    "lpwm_index":1,
    "trigger_mode":8,
    "offset_us":[
    1,
    1,
    1,
    "period_us":[
    33333,
    33333,
    33333,
    33333
    "duty_us":[
    10,
    10,
    10,
    10
    "deserial_num":1,
    "deserial_0":{
    "bus_type":0,
    "bus_num":1,
    "power_mode":0,
    "gpio_level":[0,0]
    "port_number":1,
    "port_0":{
    "dev_port":0,
    "bus_type":0,
    "bus_num":1,
    "entry_num":0,
    "reg_width":16,
    "extra_mode":0,
    "config_index":516,
    "sensor_mode":5,
    "fps":30,
    "resolution":2160,
    "deserial_index":0,
    "deserial_port":0,
    cim_config.json
    "pipeline0":{
    "cim": {
    "input": {
    "mipi": {
    "enable": 1,
    "width": 3840,
    "height": 2160,
    "format": 44,
    "rx_index": 0,
    "vc_index": 0,
    "channels": 1,
    "raw16_splict": 0,
    "dbg_clear": 0,
    "y_uv_swap": 0,
    "tag_enable": 0,
    "function": {
    "enable_bypass": 0,
    "hdr_mode": 0,
    "output": {
    "pym": {
    "pym0_en": 0,
    "pym1_en": 0
    "isp0": {
    "isp_ch0": 1,
    "isp_ch1": 0,
    "isp_ch2": 0,
    "isp_ch3": 0
    "isp1":{
    "isp_ch0": 0,
    "isp_ch1": 0,
    "isp_ch2": 0,
    "isp_ch3": 0
    "cim_dma": {
    "input": {
    "mipi": {
    "enable": 1,
    "width": 3840,
    "height": 2160,
    "format": 44,
    "vc_index": 0,
    "rx_index": 1,
    "raw16_splict": 0,
    "dbg_clear": 0,
    "y_uv_swap": 0,
    "tag_enable": 0,
    "function": {
    "enable_DMA": 1,
    "pack_mode": 0,
    "enable_bypass": 0,
    "output": {
    "ddr": {
    "enable": 1,
    "format": 44,
    "width": 3840,
    "height": 2160,
    "buf_num": 6,
    "cached": 0,
    "use_ispbuf": 1
    vpm_config.json
    "pipeline0": {
    "isp": {
    "hw_id":0,
    "ctx_id": 0,
    "sched_mode":2,
    "hdr_mode": 1,
    "width": 3840,
    "height": 2160,
    "frame_rate": 30,
    "input_crop_x": 0,
    "input_crop_y": 0,
    "output_crop_x": 0,
    "output_crop_y": 0,
    "calib_mode": 1,
    "isp_algo_state": 1
    "pym": {
    "pym_config": {
    "pym_hw_id":0,
    "pym_mode": 1,
    "time_out": 2000,
    "y_hor_coeff4": 0,
    "y_hor_coeff3": 1,
    "y_hor_coeff2": 1,
    "y_hor_coeff1": 0,
    "y_hor_coeff0": 0,
    "y_ver_coeff4": 0,
    "y_ver_coeff3": 1,
    "y_ver_coeff2": 1,
    "y_ver_coeff1": 0,
    "y_ver_coeff0": 0,
    "c_hor_coeff4": 0,
    "c_hor_coeff3": 1,
    "c_hor_coeff2": 1,
    "c_hor_coeff1": 0,
    "c_hor_coeff0": 0,
    "c_ver_coeff4": 0,
    "c_ver_coeff3": 1,
    "c_ver_coeff2": 1,
    "c_ver_coeff1": 0,
    "c_ver_coeff0": 0,
    "y_right_shift": 2,
    "c_right_shift": 2
    "pym_ctrl": {
    "source_en": 1,
    "src_uv_bypass": 0,
    "src_start_top": 0,
    "prefix_hb_val": 2,
    "prefix_vb_val": 2,
    "gs_en": 31,
    "gs_uv_bypass": 0,
    "gauss_info": [
    "gs_start_top": 0,
    "gs_start_left": 0,
    "gs_start_top": 0,
    "gs_start_left": 0,
    "gs_stride_y": 960,
    "gs_stride_uv": 960
    "gs_start_top": 0,
    "gs_start_left": 0,
    "gs_stride_y": 480,
    "gs_stride_uv": 480
    "gs_start_top": 0,
    "gs_start_left": 0,
    "gs_stride_y": 240,
    "gs_stride_uv": 240
    "gs_start_top": 0,
    "gs_start_left": 0,
    "gs_stride_y": 128,
    "gs_stride_uv": 128
    "bl_en": 31,
    "bl_uv_bypass": 0,
    "bilinear_info": [
    "bl_start_top": 0,
    "bl_start_left": 0,
    "bl_start_top": 0,
    "bl_start_left": 0,
    "bl_stride_y": 960,
    "bl_stride_uv": 960
    "bl_start_top": 0,
    "bl_start_left": 0,
    "bl_stride_y": 480,
    "bl_stride_uv": 480
    "bl_start_top": 0,
    "bl_start_left": 0,
    "bl_stride_y":240,
    "bl_stride_uv": 240
    "bl_start_top": 0,
    "bl_start_left": 0,
    "bl_stride_y": 128,
    "bl_stride_uv": 128
    "ds_roi_en": 63,
    "ds_roi": [
    "ds_roi_layer": 0,
    "ds_roi_sel": 0,
    "ds_roi_layer": 0,
    "ds_roi_sel": 0,
    "ds_roi_layer": 0,
    "ds_roi_sel": 0,
    "ds_roi_layer": 0,
    "ds_roi_sel": 0,
    "ds_roi_layer": 0,
    "ds_roi_sel": 0,
    "ds_roi_layer": 0,
    "ds_roi_sel": 0,
    "gdc": {
    "buf_num": 8,
    "fb_buf_num": 8
    2024-01-09
    • TROS.Enid回复szc:
      init_in_seq": 1, 下面增加下面参数试试: "port_mask":3,
      2024-01-30
