论坛算法工具链hb_model_modifier删除dequantize节点,hb_model_modifier.log没有记录到删除dequantize节点的scale值
XSXXH2023-09-19
61
1.芯片型号:J5等
2.天工开物开发包OpenExplorer版本:J5_OE_1.1.60
3.问题定位:hb_model_modifier.log没有记录到删除dequantize节点的scale值
4.问题具体描述:对build.sh生成的 xxxx.bin 进行hb_model_modifier model.bin -a Dequantize 删除模型尾部dequantize节点,hb_model_modifier.log没有记录到删除dequantize节点的scale值 。hb_model_modifier.log记录的内容如下(这是表明该dequantize节点无法被删除吗):2023-09-19 11:15:11,811 file: tool_utils.py func: tool_utils line No: 73 log will be stored in /open_explorer/ddk/samples/ai_toolchain/horizon_model_convert_sample/07_segmentation/ufldv2_0919/mapper/model_output/hb_model_modifier.log
2023-09-19 11:15:13,452 file: hb_model_modifier.py func: hb_model_modifier line No: 390 storing info of model: ufldv2_tus18_0919_nv12.bin
2023-09-19 11:15:13,452 file: hb_model_modifier.py func: hb_model_modifier line No: 393 --------input----------
2023-09-19 11:15:13,452 file: hb_model_modifier.py func: hb_model_modifier line No: 395 name: "input"
type {
elem_type: INT8
dim: 1
dim: 320
dim: 800
dim: 3
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 396 --------output----------
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 398 name: "loc_row"
type {
elem_type: FLOAT
dim: 1
dim: 100
dim: 56
dim: 4
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 398 name: "loc_col"
type {
elem_type: FLOAT
dim: 1
dim: 100
dim: 41
dim: 4
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 398 name: "exist_row"
type {
elem_type: FLOAT
dim: 1
dim: 2
dim: 56
dim: 4
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 398 name: "exist_col"
type {
elem_type: FLOAT
dim: 1
dim: 2
dim: 41
dim: 4
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 399 --------value_info----------
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 401 name: "Gemm_51_nhwc2nchw_transposed_output0"
type {
elem_type: INT32
dim: 1
dim: 39576
dim: 1
dim: 1
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 401 name: "replaced_onnx::Slice_198"
type {
elem_type: FLOAT
dim: 1
dim: 39576
dim: 1
dim: 1
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 401 name: "onnx::Reshape_203_reshape"
type {
elem_type: FLOAT
dim: 1
dim: 22400
dim: 1
dim: 1
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 401 name: "onnx::Reshape_210_reshape"
type {
elem_type: FLOAT
dim: 1
dim: 16400
dim: 1
dim: 1
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 401 name: "onnx::Reshape_217_reshape"
type {
elem_type: FLOAT
dim: 1
dim: 448
dim: 1
dim: 1
2023-09-19 11:15:13,460 file: hb_model_modifier.py func: hb_model_modifier line No: 401 name: "onnx::Reshape_224_reshape"
type {
elem_type: FLOAT
dim: 1
dim: 328
dim: 1
dim: 1
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 402 --------node----------
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 404 input: "input"
output: "Gemm_51_nhwc2nchw_transposed_output0"
op_type: "BPU"
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 404 input: "Gemm_51_nhwc2nchw_transposed_output0"
input: "Gemm_51_x_scale"
output: "replaced_onnx::Slice_198"
op_type: "Dequantize"
attribute {
type: INT
i: 2
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 404 input: "replaced_onnx::Slice_198"
input: "onnx::Slice_200"
input: "onnx::Slice_201"
input: "Slice_56_Slice_56_Slice_56_Slice_56_Slice_56_Slice_56_Slice_56_Slice_56_Slice_56_onnx::Slice_199_new_axes"
input: "onnx::Slice_199"
output: "onnx::Reshape_203_reshape"
op_type: "Slice"
attribute {
type: INT
i: 5
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 404 input: "onnx::Reshape_203_reshape"
input: "Reshape_58_pos_shape_info"
output: "loc_row"
op_type: "Reshape"
input: "onnx::Slice_208"
input: "Slice_63_Slice_63_Slice_63_Slice_63_Slice_63_Slice_63_Slice_63_Slice_63_Slice_63_onnx::Slice_199_new_axes"
output: "onnx::Reshape_210_reshape"
op_type: "Slice"
attribute {
type: INT
i: 5
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 404 input: "onnx::Reshape_210_reshape"
input: "Reshape_65_pos_shape_info"
output: "loc_col"
op_type: "Reshape"
input: "onnx::Slice_215"
input: "Slice_70_Slice_70_Slice_70_Slice_70_Slice_70_Slice_70_Slice_70_Slice_70_Slice_70_onnx::Slice_199_new_axes"
output: "onnx::Reshape_217_reshape"
op_type: "Slice"
attribute {
type: INT
i: 5
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 404 input: "onnx::Reshape_217_reshape"
input: "Reshape_72_pos_shape_info"
output: "exist_row"
op_type: "Reshape"
input: "onnx::Slice_221"
input: "onnx::Slice_222"
input: "Slice_77_Slice_77_Slice_77_Slice_77_Slice_77_Slice_77_Slice_77_Slice_77_Slice_77_onnx::Slice_199_new_axes"
output: "onnx::Reshape_224_reshape"
op_type: "Slice"
attribute {
type: INT
i: 5
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 404 input: "onnx::Reshape_224_reshape"
input: "Reshape_79_pos_shape_info"
output: "exist_col"
op_type: "Reshape"
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 405 --------input_type----------
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 407 7
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 408 --------input_layout----------
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 410 2
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 99 Tool will remove ['Dequantize'] nodes from this model
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 107 Nodes that will be removed from this model: ['replaced_onnx::Slice_198_HzDequantize']
2023-09-19 11:15:13,461 file: hb_model_modifier.py func: hb_model_modifier line No: 116 Node replaced_onnx::Slice_198_HzDequantize is not adjacent to input or output. It can not be removed! Skipped!
2023-09-19 11:15:17,721 file: hb_model_modifier.py func: hb_model_modifier line No: 129 modified model saved as ufldv2_tus18_0919_nv12_modified.bin
    你好,'replaced_onnx::Slice_198_HzDequantize'节点未紧挨着输入或输出,无法删除,所以也就没有记录对应的scale和zero_point信息
    2023-09-19
    • XSXXH回复颜值即正义:
      就是dequantize节点必须紧挨着output或者input,间隔了一个节点都不行,这意思把
      2023-09-19
    • 颜值即正义回复XSXXH:
      对的
      2023-09-19
  • XSXXH
    估计是没靠近输入或者输出节点的原因
    2023-09-19
    问卷链接:地平线算法工具链使用满意度反馈
    2023-09-19
