论坛算法工具链J5,BEV训练求助
J5,BEV训练求助
Quinn2023-08-31
91
2.天工开物开发包OpenExplorer版本:horizon_j5_open_explorer_v1.1.62-py38_20230802
3.问题定位:bev_mt_lss模型训练出现错误KeyError: 'ego2global_translation'
4.问题具体描述:训练BEV时,报KeyError: 'ego2global_translation',这是因为什么?
2023-08-31 14:00:56,859 ERROR [ddp_trainer.py:429] Node[0] Traceback (most recent call last):
File "/usr/local/lib/python3.8/dist-packages/hat/engine/ddp_trainer.py", line 425, in _with_exception
fn(*args)
File "/horizon/horizon_j5_open_explorer_v1.1.62-py38_20230802/ddk/samples/ai_toolchain/horizon_model_train_sample/scripts/tools/train.py", line 186, in train_entrance
trainer.fit()
File "/usr/local/lib/python3.8/dist-packages/hat/engine/loop_base.py", line 500, in fit
_, (batch, _is_last_batch) = next(self.data_loader_pr)
File "/usr/local/lib/python3.8/dist-packages/hat/profiler/profilers.py", line 103, in profile_iterable
value = next(iterator)
File "/usr/local/lib/python3.8/dist-packages/hat/utils/generator.py", line 22, in prefetch_iterator
last = next(it)
File "/root/.local/lib/python3.8/site-packages/torch/utils/data/dataloader.py", line 628, in __next__
data = self._next_data()
File "/root/.local/lib/python3.8/site-packages/torch/utils/data/dataloader.py", line 1333, in _next_data
return self._process_data(data)
File "/root/.local/lib/python3.8/site-packages/torch/utils/data/dataloader.py", line 1359, in _process_data
data.reraise()
File "/root/.local/lib/python3.8/site-packages/torch/_utils.py", line 543, in reraise
raise exception
KeyError: Caught KeyError in DataLoader worker process 0.
Original Traceback (most recent call last):
File "/root/.local/lib/python3.8/site-packages/torch/utils/data/_utils/worker.py", line 302, in _worker_loop
data = fetcher.fetch(index)
File "/root/.local/lib/python3.8/site-packages/torch/utils/data/_utils/fetch.py", line 58, in fetch
data = [self.dataset[idx] for idx in possibly_batched_index]
File "/root/.local/lib/python3.8/site-packages/torch/utils/data/_utils/fetch.py", line 58, in <listcomp>
File "/usr/local/lib/python3.8/dist-packages/hat/data/datasets/nuscenes_dataset.py", line 1397, in __getitem__
data = self.sampler(sample)
File "/usr/local/lib/python3.8/dist-packages/hat/data/datasets/nuscenes_dataset.py", line 1501, in __call__
self._get_map_info(sample)
File "/usr/local/lib/python3.8/dist-packages/hat/data/datasets/nuscenes_dataset.py", line 1471, in _get_map_info
sample["ego2global_translation"],
ERROR:__main__:train failed! process 0 terminated with exit code 1
File "tools/train.py", line 287, in <module>
raise e
File "tools/train.py", line 273, in <module>
train(
File "tools/train.py", line 254, in train
launch(
File "/usr/local/lib/python3.8/dist-packages/hat/engine/ddp_trainer.py", line 394, in launch
mp.spawn(
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 240, in spawn
return start_processes(fn, args, nprocs, join, daemon, start_method='spawn')
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 198, in start_processes
while not context.join():
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 149, in join
raise ProcessExitedException(
torch.multiprocessing.spawn.ProcessExitedException: process 0 terminated with exit code 1
    您好,'ego2global_translation'是nuscenes数据集中的坐标系转换矩阵,报错的原因可能是因为您这边的训练数据准备不当,请按照文档https://developer.horizon.cc/forumDetail/143772473308124163进行nuscene数据的准备工作。
    2023-08-31
    • Quinn回复颜值即正义:
      结果可视化时,如何生成单应矩阵homography.npy
      python3 tools/infer.py --config configs/bev/petr_efficientnetb3_nuscenes.py --model-inputs imagedir:$imgs_dir_PATH$,homo:$homography.npy$
      2023-08-31
    • 颜值即正义回复Quinn:
      homo矩阵的获取请参考这篇文章https://developer.horizon.cc/forumDetail/173442588425246790
      2023-08-31
    • Quinn回复颜值即正义:
      明白了,谢谢
      2023-09-01
