论坛算法工具链horizon_nn.build_onnx报错
Osborn282023-08-18
28
docker image: openexplorer/ai_toolchain_ubuntu_20_xj3_cpu:v2.6.2b
hb_mapper makertbin报错如何,其中Add_601是Conv的输出
WARNING: Sub_903 not supported by BPU
Layer ArgMax_907
When keep_score != keep_index, the number of channels of output is expected to be 1*group_num (group_num=1), but 2048 provided.
WARNING: ReduceSum_905 not supported by BPU
WARNING: ReduceMax_902 not supported by BPU
Layer ArgMax_907
2023-08-18 11:13:34,069 ERROR *** ERROR-OCCUR-DURING {horizon_nn.build_onnx} ***, error message: There is no input Add_38_onnx::Add_601_x_scale1 in the calibration data set.
2023-08-18 11:13:34,083 INFO [Fri Aug 18 11:13:34 2023] End to calibrate the model.
2023-08-18 11:13:34,086 INFO [Fri Aug 18 11:13:34 2023] End to Horizon NN Model Convert.
    你好,麻烦提供一下onnx模型和对应的yaml文件,我们来复现一下你的问题
    2023-08-18
    • Osborn28回复颜值即正义:
      您好,从这个报错能给一些提示信息吗?大概是哪些排查方向呢。这个报错有点看不明白,因为是模型的中间某个算子,模型可视化来看参数都是明确的,没太理解这个x_scale1是个啥?
      2023-08-18
    • 颜值即正义回复Osborn28:
      会从模型合法性(onnxruntime1.2.0能否成功推理)、内部新版本是否已解决等角度分析
      2023-08-18
