论坛算法工具链onnx模型转换:ERROR: list index out of range
cwh123552023-08-08
25
13
用户您好,请详细描述您所遇到的问题:
系统软件版本: (通过 cat /etc/version 获得)
Ai_Toolchain_Package-release-v1.18.2-OE-v2.4.2
openexplorer/ai_toolchain_centos_7_xj3:v1.15.2
  1. 问题涉及的技术领域: (硬件、操作系统、驱动、其他)
算法模型转换
  1. 问题描述:(尽可能详细的描述在进行什么功能的开发或者测试,发现了什么问题,问题现象,并且提供预期的结果)
* 根据文档进行onnx模型转换时,01_check.sh,02_preporcess.sh已经完成,03_build.sh出现下面的错误
input format
错误日志
其他日志见附件
    您好,模型转换使用的yaml配置文件在参数preprocess_on未开启情况下(一般也不建议开启)不会自动对校准数据做预处理以匹配ONNX模型输入尺寸,需要您修改02_preporcess.sh脚本将校准数据处理到对齐ONNX模型输入尺寸并且重新运行才行;
    此外,input_shape配置应和模型真实输入保持一致,不配置的情况下也会自动获取ONNX模型输入
    2023-08-08
    • cwh12355回复颜值即正义:
          1.PadResizeTransformer(target_size=(1, 1382400), pad_value=0., pad_position='bottom_right'),
      前处理成(1, 1382400),还是报错:
      2023-08-08 14:08:50,421 INFO Model has 2 inputs according to model file
      2023-08-08 14:08:50,421 INFO Input shape [1, 1382400] has length: 2, make sure it is a featuremap input
      2023-08-08 14:08:50,421 INFO Input shape [1, 3] has length: 2, make sure it is a featuremap input
      2023-08-08 14:08:50,421 ERROR Parse 'input_parameters' failed!
      2023-08-08 14:08:50,422 ERROR yaml file parse failed. Please double check your config file inputs
      2023-08-08 14:08:50,423 ERROR list index out of range
      2.看python脚本:
       File "/usr/local/lib/python3.6/site-packages/horizon_tc_ui/config/mapper_conf_parser.py", line 598, in _validate_input_type_and_layout
          and input_shape[3] != 1) or (train_layout == "NCHW"
      IndexError: list index out of range
      是需要四维的,但是我的是一维 gray,只取Y方向,因该是不用配置layout,但不配置会报错:
      2023-08-08 14:16:10,129 INFO Model has 2 inputs according to model file
      2023-08-08 14:16:10,129 INFO Input shape [1, 1382400] has length: 2, make sure it is a featuremap input
      2023-08-08 14:16:10,129 INFO Input shape [1, 3] has length: 2, make sure it is a featuremap input
      2023-08-08 14:16:10,129 ERROR Parse 'input_parameters' failed!
      2023-08-08 14:16:10,129 ERROR yaml file parse failed. Please double check your config file inputs
      2023-08-08 14:16:10,131 ERROR Input_layout_rt missing. input 0 input_type_rt is: gray. input_layout_rt is required for this type
      3.关于calibration_parameters:
      cal_data_dir: './calibration_data_gray_uint8;./calibration_data_angle_f32_bin'
      cal_data_type: 'float32;float32'
      calibration_type: 'default'
      cal_data_type和input_type_train必须要相同吗?
      2023-08-08
    • 颜值即正义回复cwh12355:
      您好,1.我们这边测试了一下,能够复现您的问题,您将input_type_rt和input_type_train修改为featuremap,此外校准数据后缀修改为.feature再次尝试
      2.cal_data_type是指二进制校准数据的保存格式,为float32/uint8;input_type_train是指输入数据格式,为rgb/bgr/featuremap/...
      2023-08-08
    • 颜值即正义回复颜值即正义:
      补充:input_type_rt和input_type_train配置为featuremap后无需关注layout是NHWC/NCHW,工具会自动skip,但是需要配置,否则会报错
      2023-08-08
    • cwh12355回复颜值即正义:
      1.input_type_rt和input_type_train修改为featuremap后,在板子上运行的时候的输入的格式还能是gray吗?因为模型的原始输入是两个都是一维的
      single image W = 1440 H = 960 luminance channel (Y) from the planar YUV420 format:
      full input size is 1440 * 960 = 1382400
      normalized ranging from 0.0 to 1.0 in float32 (onnx runner) or ranging from 0 to 255 in uint8 (snpe runner)
      camera calibration angles (roll, pitch, yaw) from liveCalibration: 3 x float32 inputs
      2.校准数据是需要读取图像,将其转换为灰度格式,然后调整其大小为1440x960将图像扁平化为1x1382400的float32的吗?
      3.input_type_rt和input_type_train修改为featuremap后,校准数据后缀修改为.gray可以转换为bin文件,这和校准数据后缀修改为.feature有什么不同吗?
      2023-08-08
    • cwh12355回复颜值即正义:
      我试了一下input_type_rt和input_type_train修改为featuremap,此外校准数据后缀修改为.feature,还是报错:
      error info:
      2023-08-08 16:56:23,043 INFO First calibration picture md5:
      107f1fd6f061b580ed14745b15fa1618 /open_explorer/ai_toolchain/horizon_model_convert_sample/02_selfdrive/01_dmonitor/mapper/calibration_data_angle_f32_bin/001.bin
      2023-08-08 16:56:23,051 INFO *******************************************
      2023-08-08 16:56:23,053 ERROR load cal data for input 'input_img' error
      2023-08-08 16:56:23,055 ERROR cannot reshape array of size 345600 into shape (1,1382400)
      file shape info:
      [root@b0e8718db1d1 calibration_data_featuremap_uint8]# ls -al
      total 135208
      drwxr-xr-x 2 root root 4096 Aug 8 16:53 .
      drwxrwxrwx 14 1010 1011 4096 Aug 8 16:53 ..
      -rw-r--r-- 1 root root 1382400 Aug 8 16:53 00000.feature
      -rw-r--r-- 1 root root 1382400 Aug 8 16:53 00001.feature
      因为02.preprocess.sh里边是针对生成gray的,需要改为生成featuremap吗?
      2023-08-08
    • 颜值即正义回复cwh12355:
      您好,1.修改为featuremap后,板端运行输入格式就不能是gray了,参考 4.1.1.6. 模型量化与编译 — Horizon Open Explorer 转换内部过程解读;如果您希望板端输入gray格式的数据,建议您调整一下模型输入例如为1x1440x960x1,因为input_type_train/rt=gray需要指定四维
      2.对的,需要您在02_preprocess.sh脚本里修改--pic_ext为.feature,并且需要将uint8的校准数据除255转为float32
      3.后缀为.gray以uint8保存为二进制bin文件,后缀为.feature以float32保存为二进制bin文件
      2023-08-08
    • 颜值即正义回复cwh12355:
      对的,这里的报错是因为校准数据尺寸和模型输入不匹配,需要调整一下校准数据的预处理。如果不是特别需求,建议您使用Resize而不是PadResize,因为使用Padresize resize后的图像映射回原图需要手动减去Padding的部分
      2023-08-08
    • cwh12355回复颜值即正义:
      您好,我按照配置:
      cal_data_dir: './calibration_data_featuremap_uint8;./calibration_data_angle_f32_bin'
      cal_data_type: 'uint8;float32'
      input_parameters:
      input_name: "input_img;calib"
      input_type_rt: 'gray;gray'
      input_layout_rt: 'NHWC;NHWC'
      input_shape: '1x1440x960x1;1x1x3x1'
      input_type_train: 'gray;gray'
      input_layout_train: 'NHWC;NHWC'
      norm_type: 'no_preprocess;no_preprocess'
      mean_value: 'NULL;NULL'
      scale_value: 'NULL;NULL'
      按照上面的配置后,input_shape报错不匹配:
        File "/usr/local/lib/python3.6/site-packages/horizon_nn/parser/onnx_parser.py", line 119, in update_input_shapes
      self.final_input_shapes[input_name]))
      ValueError: Input shape of input_img has a dimension [1, 1440, 960, 1] different from [1, 1382400] which is parsered from onnx.
      这里面还有什么没有配置和修改的吗?谢谢
      2023-08-09
    • 颜值即正义回复cwh12355:
      您好,如果期望板端以gray格式输入,yaml配置没有问题,但是您需要调整的是ONNX模型的输入,使ONNX模型的输入数据以1x1440x960x1排布
      2023-08-09
    • cwh12355回复颜值即正义:
      1.我理解的是要修改onnx本身模型吗还是修改cal_data_dir到1x1440x960x1。
      2.如果需要修改onnx本身模型的话,需要做什么工作。
      2023-08-09
    • 颜值即正义回复cwh12355:
      对的,需要稍微修改模型就好。在导出ONNX模型时,对于输入分支input_img使用torch.randn(1, 1440, 960, 1)进行trace,在此之前还需要你进到模型源码,找到forward函数,在输入分支input_img后添加reshape节点,reshape成1x1382400,后续模型就无需修改。具体操作和细节还需要您去学习了解~
      2023-08-09
    问卷链接:地平线算法工具链使用满意度反馈
    2023-08-08
