论坛算法工具链训练bev_mt_lss
训练bev_mt_lss
llll2023-07-18
90
1.芯片型号:4090
2.天工开物开发包OpenExplorer版本:J5_OE_1.1.57等
3.问题定位:学习bev_mt_lss时,跑浮点训练时
4.问题具体描述:根据文档设置之后,在提供的docke里面跑train.py,出现如下问题
File "/usr/local/lib/python3.8/dist-packages/hat/engine/ddp_trainer.py", line 420, in _with_exception
fn(*args)
File "/mnt/yrfs/J5/bev_release_package/tools/train.py", line 187, in train_entrance
trainer = build_from_registry(trainer)
File "/usr/local/lib/python3.8/dist-packages/hat/registry.py", line 250, in build_from_registry
return _impl(x)
File "/usr/local/lib/python3.8/dist-packages/hat/registry.py", line 210, in _impl
build_x = dict(((key, _impl(value)) for key, value in x.items())) # noqa
File "/usr/local/lib/python3.8/dist-packages/hat/registry.py", line 210, in <genexpr>
File "/usr/local/lib/python3.8/dist-packages/hat/registry.py", line 193, in _impl
x = type(x)((_impl(x_i) for x_i in x))
File "/usr/local/lib/python3.8/dist-packages/hat/registry.py", line 193, in <genexpr>
File "/usr/local/lib/python3.8/dist-packages/hat/registry.py", line 227, in _impl
_raise_invalid_type_error(object_type)
File "/usr/local/lib/python3.8/dist-packages/hat/registry.py", line 75, in _raise_invalid_type_error
raise TypeError(
TypeError: BevRotate has not registered in any of registry ['HAT_OBJECT_REGISTRY'] and is not a class, which is not allowed
ERROR:__main__:launch trainer failed! process 0 terminated with exit code 1
File "/usr/lib/python3.8/runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.8/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/root/.vscode-server/extensions/ms-python.python-2023.12.0/pythonFiles/lib/python/debugpy/adapter/../../debugpy/launcher/../../debugpy/__main__.py", line 39, in <module>
cli.main()
File "/root/.vscode-server/extensions/ms-python.python-2023.12.0/pythonFiles/lib/python/debugpy/adapter/../../debugpy/launcher/../../debugpy/../debugpy/server/cli.py", line 430, in main
run()
File "/root/.vscode-server/extensions/ms-python.python-2023.12.0/pythonFiles/lib/python/debugpy/adapter/../../debugpy/launcher/../../debugpy/../debugpy/server/cli.py", line 284, in run_file
runpy.run_path(target, run_name="__main__")
File "/root/.vscode-server/extensions/ms-python.python-2023.12.0/pythonFiles/lib/python/debugpy/_vendored/pydevd/_pydevd_bundle/pydevd_runpy.py", line 321, in run_path
return _run_module_code(code, init_globals, run_name,
File "/root/.vscode-server/extensions/ms-python.python-2023.12.0/pythonFiles/lib/python/debugpy/_vendored/pydevd/_pydevd_bundle/pydevd_runpy.py", line 135, in _run_module_code
_run_code(code, mod_globals, init_globals,
File "/root/.vscode-server/extensions/ms-python.python-2023.12.0/pythonFiles/lib/python/debugpy/_vendored/pydevd/_pydevd_bundle/pydevd_runpy.py", line 124, in _run_code
File "/mnt/yrfs/J5/bev_release_package/tools/train.py", line 279, in <module>
train(
File "/mnt/yrfs/J5/bev_release_package/tools/train.py", line 274, in train
raise e
File "/mnt/yrfs/J5/bev_release_package/tools/train.py", line 257, in train
launch(
File "/usr/local/lib/python3.8/dist-packages/hat/engine/ddp_trainer.py", line 376, in launch
mp.spawn(
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 240, in spawn
return start_processes(fn, args, nprocs, join, daemon, start_method='spawn')
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 198, in start_processes
while not context.join():
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 149, in join
raise ProcessExitedException(
torch.multiprocessing.spawn.ProcessExitedException: process 0 terminated with exit code 1
    你好,从J5 OE1.1.57开始,bev会合入OE包,部分类的名称和路径也发生了变化,如果你使用的是1.1.57的docker,请配套使用1.1.57版本OE包ddk\samples\ai_toolchain\horizon_model_train_sample\scripts目录下的bev参考算法
    2023-07-18
    • llll回复颜值即正义:
      oe包为1.1个G 这里面为空
      2023-07-19
  • llll
    OE包为1.1个G 这里面为空
    2023-07-19
    • 颜值即正义回复llll:
      请比对一下你的OE压缩包md5:76ab34abb9fc4bce3e0ba8870f24fe13
      2023-07-19
