论坛算法工具链使用docker1.1.45版本 是否支持openmp
xiaodong2023-07-17
69
2.天工开物开发包OpenExplorer版本:例如J5_OE_1.1.45等
3.问题定位:能否使用openmp并行开发
4.问题具体描述:cmakelist 添加openmp 报错 错误如下:
-- Check for working CXX compiler: /opt/gcc-ubuntu-9.3.0-2020.03-x86_64-aarch64-linux-gnu/bin/aarch64-linux-gnu-g++
-- Check for working CXX compiler: /opt/gcc-ubuntu-9.3.0-2020.03-x86_64-aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- DEPS_ROOT: /mnt/XiaoDong/20230717/deps_gcc9.3/aarch64
-- RELEASE_ROOT: /usr/local
-- HOST_PACKAGE_DIR: /root/.horizon/ddk/j5_aarch64
CMake Error at /cmake-3.14.5-Linux-x86_64/share/cmake-3.14/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Could NOT find OpenMP_CXX (missing: OpenMP_CXX_FLAGS OpenMP_CXX_LIB_NAMES)
Call Stack (most recent call first):
/cmake-3.14.5-Linux-x86_64/share/cmake-3.14/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
/cmake-3.14.5-Linux-x86_64/share/cmake-3.14/Modules/FindOpenMP.cmake:474 (find_package_handle_standard_args)
CMakeLists.txt:29 (FIND_PACKAGE)
-- Configuring incomplete, errors occurred!
See also "/mnt/XiaoDong/20230717/build/CMakeFiles/CMakeOutput.log".
See also "/mnt/XiaoDong/20230717/build/CMakeFiles/CMakeError.log".
make: *** No targets specified and no makefile found. Stop.
root@107:/mnt/XiaoDong/20230717# sh build.sh
    你好,gcc9.3应该是自带支持openmp的,无需特殊配置,编译的时候加上-fopenmp参数看看,头文件使用#include
    2023-07-17
    • xiaodong回复颜值即正义:
      你不能拿百度搜索到直接回复的 你这是直接给别人挖坑的
      2023-07-18
    问卷链接:https://wenjuan.feishu.cn/m/cfm?t=st64p6krU3Ji-yvhv
    2023-07-17
  • xiaodong
    cmake写法如下 :
    if(OPENMP_FOUND)
    find_package(OpenMP REQUIRED)
    message("OPENMP FOUND")
    set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} ${OpenMP_C_FLAGS}")
    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${OpenMP_CXX_FLAGS}")
    set(CMAKE_EXE_LINKER_FLAGS "${CMAKE_EXE_LINKER_FLAGS} ${OpenMP_EXE_LINKER_FLAGS}")
    else()
    message("NOT OPENMP FOUND")
    endif()
    显示结果不支持 openmp:
    root@107:/mnt/XiaoDong/20230718-gj# sh build.sh
    -- The CXX compiler identification is GNU 9.3.0
    NOT OPENMP FOUND
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /mnt/XiaoDong/20230718-gj/build
    2023-07-18
