论坛算法工具链J5 RTX 4090 训练 报错:RuntimeError: nvrtc: error: invalid value for --gpu-architecture (-arch)
淼淼Mark2023-07-11
57
15
2.天工开物开发包OpenExplorer版本:J5_oe_1.1.52a
3.问题定位:qat模型训练:calibration训练和qat训练
4.问题具体描述
2023-07-11 11:12:58,659 INFO [logger.py:147] Node[0] ==================================================BEGIN QAT STAGE==================================================
2023-07-11 11:12:58,700 INFO [thread_init.py:38] Node[0] init torch_num_thread is `12`,opencv_num_thread is `12`,openblas_num_thread is `12`,mkl_num_thread is `12`,omp_num_thread is `12`,
2023-07-11 11:12:58,926 INFO [converters.py:56] Node[0] Successfully convert float model to qat model.
2023-07-11 11:12:58,927 WARNING [hash.py:218] Node[0] Don not found hash value in name of /open_explorer/work_dir/114/qat_train_hat_env/calibration_checkpoint/calibration-checkpoint-last.pth.tar, will skip check hash...
2023-07-11 11:12:58,956 WARNING [checkpoint.py:44] Node[0] module. is not at the beginning of state dict
2023-07-11 11:12:59,035 INFO [checkpoint.py:177] Node[0] state_dict in checkpoint num: 1076
2023-07-11 11:12:59,039 INFO [checkpoint.py:178] Node[0] state_dict in model num: 1076
2023-07-11 11:12:59,039 WARNING [checkpoint.py:179] Node[0] miss_key num: 0
2023-07-11 11:12:59,039 WARNING [checkpoint.py:182] Node[0] unexpect_key num: 0
2023-07-11 11:12:59,039 INFO [converters.py:248] Node[0] Load the checkpoint successfully from /open_explorer/work_dir/114/qat_train_hat_env/calibration_checkpoint/calibration-checkpoint-last.pth.tar
2023-07-11 11:13:03,578 INFO [loop_base.py:372] Node[0] Start DistributedDataParallelTrainer loop from epoch 0, num_epochs=10
2023-07-11 11:13:03,579 INFO [grad_scale.py:54] Node[0] [GradScale] []
2023-07-11 11:13:03,581 INFO [monitor.py:107] Node[0] Epoch[0] Begin ==================================================
2023-07-11 11:13:30,340 ERROR [ddp_trainer.py:363] Node[0] Traceback (most recent call last):
File "/usr/local/lib/python3.8/dist-packages/hat/engine/ddp_trainer.py", line 359, in _with_exception
fn(*args)
File "/open_explorer/project/ObjectDetection/tools/train.py", line 187, in train_entrance
trainer.fit()
File "/usr/local/lib/python3.8/dist-packages/hat/engine/loop_base.py", line 433, in fit
self.batch_processor(
File "/usr/local/lib/python3.8/dist-packages/hat/engine/processors/processor.py", line 442, in __call__
model_outs = model(*_as_list(batch_i))
File "/usr/local/lib/python3.8/dist-packages/hat/utils/module_patch.py", line 46, in _wrap
return fn(self, *args, **kwargs)
File "/root/.local/lib/python3.8/site-packages/torch/nn/modules/module.py", line 1102, in _call_impl
return forward_call(*input, **kwargs)
File "/root/.local/lib/python3.8/site-packages/torch/nn/parallel/distributed.py", line 886, in forward
output = self.module(*inputs[0], **kwargs[0])
File "/usr/local/lib/python3.8/dist-packages/hat/models/structures/detectors/centerpoint.py", line 99, in forward
input_features = self.reader(
File "/usr/local/lib/python3.8/dist-packages/hat/models/task_modules/lidar/pillar_encoder.py", line 222, in forward
features = self._extract_feature(features)
File "/usr/local/lib/python3.8/dist-packages/hat/models/task_modules/lidar/pillar_encoder.py", line 237, in _extract_feature
features = pfn(features)
File "/usr/local/lib/python3.8/dist-packages/hat/models/task_modules/lidar/pillar_encoder.py", line 81, in forward
x = self.linear(inputs)
File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/nn/qat/conv2d.py", line 221, in forward
return self.activation_post_process(out)
File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/fake_quantize.py", line 207, in forward
self.activation_post_process(x.detach())
File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/observer.py", line 322, in forward
(self.min_val, self.max_val,) = compute_moving_average(
nvrtc compilation failed:
#define NAN __int_as_float(0x7fffffff)
#define POS_INFINITY __int_as_float(0x7f800000)
#define NEG_INFINITY __int_as_float(0xff800000)
template<typename T>
__device__ T maximum(T a, T b) {
return isnan(a) ? a : (a > b ? a : b);
__device__ T minimum(T a, T b) {
return isnan(a) ? a : (a < b ? a : b);
extern "C" __global__
void fused_sub_mul_add_sub_mul_add(float* told_min_1, double vaveraging_constant_1, float* tcurrent_min_1, float* told_max_1, float* tcurrent_max_1, float* aten_add_1, float* aten_add) {
if ((long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x)<64ll ? 1 : 0) {
float told_max_1_1 = __ldg(told_max_1 + (long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x));
float v = __ldg(tcurrent_max_1 + (long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x));
aten_add[(long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x)] = told_max_1_1 + (v - told_max_1_1) * (float)(vaveraging_constant_1);
float told_min_1_1 = __ldg(told_min_1 + (long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x));
float v_1 = __ldg(tcurrent_min_1 + (long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x));
aten_add_1[(long long)(threadIdx.x) + 512ll * (long long)(blockIdx.x)] = told_min_1_1 + (v_1 - told_min_1_1) * (float)(vaveraging_constant_1);
ERROR:__main__:launch trainer failed! process 0 terminated with exit code 1
File "/open_explorer/project/ObjectDetection/tools/train.py", line 278, in <module>
train(
File "/open_explorer/project/ObjectDetection/tools/train.py", line 273, in train
raise e
File "/open_explorer/project/ObjectDetection/tools/train.py", line 256, in train
launch(
File "/usr/local/lib/python3.8/dist-packages/hat/engine/ddp_trainer.py", line 328, in launch
mp.spawn(
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 230, in spawn
return start_processes(fn, args, nprocs, join, daemon, start_method='spawn')
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 188, in start_processes
while not context.join():
File "/root/.local/lib/python3.8/site-packages/torch/multiprocessing/spawn.py", line 139, in join
raise ProcessExitedException(
torch.multiprocessing.spawn.ProcessExitedException: process 0 terminated with exit code 1
    您好,根据报错”RuntimeError: nvrtc: error: invalid value for --gpu-architecture (-arch)“来看可能是cuda和显卡的兼容问题,如果您使用OE包提供的docker环境进行开发,可以使用nvidia-smi命令来查看Cuda版本,并使用”pip list |grep torch“来查看是否安装了匹配版本的torch,如不匹配则需要前往官网 PyTorch 安装升级。
    2023-07-11
    • 淼淼Mark回复颜值即正义:
      您好:cuda 11.1 仍然报如下错误
      root@sh8:/open_explorer/project/ObjectDetection# pip list | grep torch
      horizon-plugin-pytorch 1.6.3+cu111.torch1102
      horizon-torch-samples 1.2.0+openexplore1.6.29
      torch 1.10.2+cu111
      torchmetrics 0.5.0
      torchvision 0.11.3+cu111
      root@sh8:/open_explorer/project/ObjectDetection# nvcc -V
      nvcc: NVIDIA (R) Cuda compiler driver
      Copyright (c) 2005-2020 NVIDIA Corporation
      Built on Mon_Oct_12_20:09:46_PDT_2020
      Cuda compilation tools, release 11.1, V11.1.105
      Build cuda_11.1.TC455_06.29190527_0
      2023-07-11 17:42:26,980 INFO [grad_scale.py:54] Node[0] [GradScale] []
      2023-07-11 17:42:26,983 INFO [monitor.py:107] Node[0] Epoch[0] Begin ==================================================
      2023-07-11 17:42:54,196 ERROR [ddp_trainer.py:363] Node[0] Traceback (most recent call last):
      fn(*args)
      trainer.fit()
      template
      template
      File "tools/train.py", line 278, in
      train(
      File "tools/train.py", line 273, in train
      raise e
      File "tools/train.py", line 256, in train
      launch(
      mp.spawn(
      2023-07-11
    • 颜值即正义回复淼淼Mark:
      您好,除了calibration阶段和qat训练阶段,请问您在浮点模型训练阶段有遇到相同的报错吗?
      2023-07-11
    • 颜值即正义回复淼淼Mark:
      您好,您这边可以用单卡跑一下,看是否会报错,排除一下多进程的问题
      2023-07-11
    • 淼淼Mark回复颜值即正义:
      1 float训练正常,没有问题。就是calibration和qat训练的问题。
      2 单卡也报同样的错误
      2023-07-12
    • 颜值即正义回复淼淼Mark:
      您好,这边麻烦您使用命令pip list |grep horizon,提供一下输出信息;此外如果方便的话,可以提供一下您使用的GPU驱动版本号和显卡的具体型号吗,我们这边分析一下~~
      2023-07-12
    • 颜值即正义回复颜值即正义:
      您可参考下图:
      2023-07-12
    • 颜值即正义回复淼淼Mark:
      2023-07-12
    • 淼淼Mark回复颜值即正义:
      这是 grep horizon的结果
      root@sh8:/open_explorer/project# pip list |grep horizon
      horizon-nn 0.18.3
      horizon-perception-proto 0.0.1b202305260839+b8f70c0
      horizon-tc-ui 1.17.5
      显卡:
      GPU 00000000:B2:00.0
      Product Name : NVIDIA GeForce RTX 4090
      Product Brand : GeForce
      Product Architecture : Ada Lovelace
      Display Mode : Disabled
      Display Active : Disabled
      Persistence Mode : Disabled
      MIG Mode
      Current : N/A
      Pending : N/A
      Accounting Mode : Disabled
      Accounting Mode Buffer Size : 4000
      Driver Model
      Current : N/A
      Pending : N/A
      Serial Number : N/A
      GPU UUID : GPU-e590ba61-f1a1-c060-e4f8-d34974843fb8
      Minor Number : 7
      宿主机:
      驱动:
      NVIDIA-SMI 525.125.06 Driver Version: 525.125.06 CUDA Version: 12.0 |
      | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
      | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
      | | | MIG M. |
      nvcc -V
      gj@sh8:~$ nvcc -V
      Copyright (c) 2005-2022 NVIDIA Corporation
      Built on Wed_Sep_21_10:33:58_PDT_2022
      Cuda compilation tools, release 11.8, V11.8.89
      Build cuda_11.8.r11.8/compiler.31833905_0
      2023-07-12
    • 淼淼Mark回复颜值即正义:
      还有个奇怪的现象: calibration 每次都是到了80出错:
      2023-07-12 13:39:28,272 INFO [loop_base.py:431] Node[0] 20 / 5231
      2023-07-12 13:39:36,577 INFO [loop_base.py:431] Node[0] 40 / 5231
      2023-07-12 13:39:49,262 INFO [loop_base.py:431] Node[0] 60 / 5231
      2023-07-12 13:40:01,262 INFO [loop_base.py:431] Node[0] 80 / 5231
      /usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/observer.py:821: UserWarning: Compute amax failed
      warnings.warn("Compute amax failed")
      /usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/quantization/observer.py:182: UserWarning: must run observer before calling calculate_qparams. Returning default scale and zero point
      warnings.warn(
      2023-07-12 13:40:09,291 ERROR [train.py:270] Node[0] launch trainer failed! The following operation failed in the TorchScript interpreter.
      Traceback of TorchScript (most recent call last):
      2023-07-12
    • 淼淼Mark回复颜值即正义:
      这个代码在之前的3070和3090都是能正常训练的,只是换了新的4090才遇到这个问题
      2023-07-12
    • 淼淼Mark回复颜值即正义:
      您好,初步分析可能是模型中存在NaN或者inf这样的数值异常层,建议您先参考 4.2.4.5. 分析工具使用指南 — Horizon Open Explorer 进行debug~~
      这个我验证了:不是的,我只用的一个数据,然后用了您推荐的工具统计了最大最小 没有出现异常的NaN或inf
      2023-07-12
    • 颜值即正义回复淼淼Mark:
      您好,4090不在我们明确支持的范围内,在使用上可能会存在cuda版本冲突或调用上的问题,建议您使用最新OE1.1.57版本的docker进行尝试,获取路径为 地平线征程®️5 OpenExplorer算法工具链 版本发布 (horizon.ai) 。如果使用最新版本的docker后问题仍无法解决,这边建议您更换显卡,使用3090等明确支持的显卡进行开发~~
      2023-07-12
    问卷链接:https://wenjuan.feishu.cn/m/?t=st64p6krU3Ji-yvhv
    2023-07-11
  • 张飞飞96
    请问这个问题有解决了吗
    2024-03-01
