论坛算法工具链bev_ipm的onnx进行PTQ时的yaml文件问题
Durrrrui2023-06-27
79
对于bev_ipm模型,其输入为6x3x256x704的环视相机和6x128x128x2的点坐标。
在生成calibration_data的时候,我对应生成两个文件夹包含6x3x256x704和6x128x128x2的二进制信息。
进行ptq过程出现yaml的解析错误,文件在附件中,输入为img和points_norm节点,我尝试了rgb;featuremap和featuremap;featuremap
两种方式都不行。能否提供一个可行的yaml参考,谢谢
祝好!
    你好,附件中的yaml配置主要存在以下问题:
    1.模型存在多个输入时,参考配置需要用;隔开,即input_layout_rt: 'NCHW; NHWC',而不是input_layout_rt: 'NCHW‘; ’NHWC',此问题在你的yaml中普遍存在,请逐一修改;
    2. bev_ipm参考算法是使用yuv444数据训练的,需要把设置input_type_train: 'yuv444; featuremap';
    3.模型有两个输入,所以需要设置norm_type: 'data_mean_and_scale; no_preprocess',同时要设置mean_value: 0.485 0.456 0.406;NULL scale_value: 0.229 0.224 0.225 ;NULL ;
    2023-06-28
    • 颜值即正义回复颜值即正义:
      # Copyright (c) 2020 Horizon Robotics.All Rights Reserved.
      # The material in this file is confidential and contains trade secrets
      # of Horizon Robotics Inc. This is proprietary information owned by
      # Horizon Robotics Inc. No part of this work may be disclosed,
      # reproduced, copied, transmitted, or used in any way for any purpose,
      # without the express written permission of Horizon Robotics Inc.
      # 模型转化相关的参数
      # model conversion related parameters
      model_parameters:
      # ONNX浮点网络数据模型文件
      # the model file of floating-point ONNX neural network data
      onnx_model: 'ipm.onnx'
      # 适用BPU架构
      # the applicable BPU architecture
      march: "bayes"
      # 指定模型转换过程中是否输出各层的中间结果,如果为True,则输出所有层的中间输出结果,
      # specifies whether or not to dump the intermediate results of all layers in conversion
      # if set to True, then the intermediate results of all layers shall be dumped
      layer_out_dump: False
      # 模型转换输出的结果的存放目录
      # the directory in which model conversion results are stored
      working_dir: 'model_output'
      # 模型转换输出的用于上板执行的模型文件的名称前缀
      # model conversion generated name prefix of those model files used for dev board execution
      output_model_file_prefix: 'bev_256x704_img_128x128_ipm'
      # 模型输入相关参数, 若输入多个节点, 则应使用';'进行分隔, 使用默认缺省设置则写NULL
      # model input related parameters,
      # please use ";" to seperate when inputting multiple nodes,
      # please use NULL for default setting
      input_parameters:
      # (选填) 模型输入的节点名称, 此名称应与模型文件中的名称一致, 否则会报错, 不填则会使用模型文件中的节点名称
      # (Optional) node name of model input,
      # it shall be the same as the name of model file, otherwise an error will be reported,
      # the node name of model file will be used when left blank
      input_name: 'input.1; points'
      # 网络实际执行时,输入给网络的数据格式,包括 nv12/rgb/bgr/yuv444/gray/featuremap,
      # the data formats to be passed into neural network when actually performing neural network
      # available options: nv12/rgb/bgr/yuv444/gray/featuremap,
      # input_type_rt: 'rgb'; 'featuremap'
      input_type_rt: 'nv12;featuremap'
      # 网络实际执行时输入的数据排布, 可选值为 NHWC/NCHW
      # 若input_type_rt配置为nv12,则此处参数不需要配置
      # the data layout formats to be passed into neural network when actually performing neural network, available options: NHWC/NCHW
      # If input_type_rt is configured as nv12, then this parameter does not need to be configured
      # 网络训练时输入的数据格式,可选的值为rgb/bgr/gray/featuremap/yuv444
      # the data formats in network training
      # available options: rgb/bgr/gray/featuremap/yuv444
      # input_type_rt: 'featuremap'; 'featuremap'
      # 网络训练时输入的数据排布, 可选值为 NHWC/NCHW
      # the data layout in network training, available options: NHWC/NCHW
      input_layout_train: 'NCHW; NHWC'
      # (选填) 模型网络的输入大小, 以'x'分隔, 不填则会使用模型文件中的网络输入大小,否则会覆盖模型文件中输入大小
      # (Optional)the input size of model network, seperated by 'x'
      # note that the network input size of model file will be used if left blank
      # otherwise it will overwrite the input size of model file
      input_shape: '6x3x512x960; 6x128x128x2'
      # 网络实际执行时,输入给网络的batch_size, 默认值为1
      # the data batch_size to be passed into neural network when actually performing neural network, default value: 1
      # input_batch: 1
      # 网络输入的预处理方法,主要有以下几种:
      # no_preprocess 不做任何操作
      # data_mean 减去通道均值mean_value
      # data_scale 对图像像素乘以data_scale系数
      # data_mean_and_scale 减去通道均值后再乘以scale系数
      # preprocessing methods of network input, available options:
      # 'no_preprocess' indicates that no preprocess will be made
      # 'data_mean' indicates that to minus the channel mean, i.e. mean_value
      # 'data_scale' indicates that image pixels to multiply data_scale ratio
      # 'data_mean_and_scale' indicates that to multiply scale ratio after channel mean is minused
      # 图像减去的均值, 如果是通道均值,value之间必须用空格分隔
      # the mean value minused by image
      # note that values must be seperated by space if channel mean value is used
      # 图像预处理缩放比例,如果是通道缩放比例,value之间必须用空格分隔
      # scale value of image preprocess
      # note that values must be seperated by space if channel scale value is used
      # 模型量化相关参数
      # model calibration parameters
      calibration_parameters:
      # 模型量化的参考图像的存放目录,图片格式支持Jpeg、Bmp等格式,输入的图片
      # 应该是使用的典型场景,一般是从测试集中选择20~100张图片,另外输入
      # 的图片要覆盖典型场景,不要是偏僻场景,如过曝光、饱和、模糊、纯黑、纯白等图片
      # 若有多个输入节点, 则应使用';'进行分隔
      # the directory where reference images of model quantization are stored
      # image formats include JPEG, BMP etc.
      # should be classic application scenarios, usually 20~100 images are picked out from test datasets
      # in addition, note that input images should cover typical scenarios
      # and try to avoid those overexposed, oversaturated, vague,
      # pure blank or pure white images
      # use ';' to seperate when there are multiple input nodes
      cal_data_dir: './calibration_data/calibrate_imgs;./calibration_data/calibrate_points'
      # 校准数据二进制文件的数据存储类型,可选值为:float32, uint8
      # calibration data binary file save type, available options: float32, uint8
      cal_data_type: 'uint8;float32'
      # 如果输入的图片文件尺寸和模型训练的尺寸不一致时,并且preprocess_on为true,
      # 则将采用默认预处理方法(skimage resize),
      # 将输入图片缩放或者裁减到指定尺寸,否则,需要用户提前把图片处理为训练时的尺寸
      # In case the size of input image file is different from that of in model training
      # and that preprocess_on is set to True,
      # shall the default preprocess method(skimage resize) be used
      # i.e., to resize or crop input image into specified size
      # otherwise user must keep image size as that of in training in advance
      # preprocess_on: False
      # 模型量化的算法类型,支持default、mix、kl、max、load,通常采用default即可满足要求
      # 如不符合预期可先尝试修改为mix 仍不符合预期再尝试kl或max
      # 当使用QAT导出模型时,此参数则应设置为load
      # 相关参数的技术原理及说明请您参考用户手册中的PTQ原理及步骤中参数组详细介绍部分
      # The algorithm type of model quantization, support default, mix, kl, max, load, usually use default can meet the requirements.
      # If it does not meet the expectation, you can try to change it to mix first. If there is still no expectation, try kl or max again.
      # When using QAT to export the model, this parameter should be set to load.
      # For more details of the parameters, please refer to the parameter details in PTQ Principle And Steps section of the user manual.
      calibration_type: 'skip'
      # 编译器相关参数
      # compiler related parameters
      compiler_parameters:
      # 编译策略,支持bandwidth和latency两种优化模式;
      # bandwidth以优化ddr的访问带宽为目标;
      # latency以优化推理时间为目标
      # compilation strategy, there are 2 available optimization modes: 'bandwidth' and 'lantency'
      # the 'bandwidth' mode aims to optimize ddr access bandwidth
      # while the 'lantency' mode aims to optimize inference duration
      compile_mode: 'latency'
      # 设置debug为True将打开编译器的debug模式,能够输出性能仿真的相关信息,如帧率、DDR带宽占用等
      # the compiler's debug mode will be enabled by setting to True
      # this will dump performance simulation related information
      # such as: frame rate, DDR bandwidth usage etc.
      debug: False
      # 编译模型指定核数,不指定默认编译单核模型, 若编译双核模型,将下边注释打开即可
      # specifies number of cores to be used in model compilation
      # as default, single core is used as this value left blank
      # please delete the "# " below to enable dual-core mode when compiling dual-core model
      # core_num: 2
      # 优化等级可选范围为O0~O3
      # O0不做任何优化, 编译速度最快,优化程度最低,
      # O1-O3随着优化等级提高,预期编译后的模型的执行速度会更快,但是所需编译时间也会变长。
      # 推荐用O2做最快验证
      # optimization level ranges between O0~O3
      # O0 indicates that no optimization will be made
      # the faster the compilation, the lower optimization level will be
      # O1-O3: as optimization levels increase gradually, model execution, after compilation,
      # shall become faster while compilation will be prolonged
      # it is recommended to use O2 for fastest verification
      optimize_level: 'O3'
      2023-06-28
    • 颜值即正义回复颜值即正义:
      由于我本地没有校准数据,所以采用了skip的校准方式
      2023-06-28
    • Durrrrui回复颜值即正义:
      谢谢!问题解决了!
      2023-06-29
    • 颜值即正义回复Durrrrui:
      问卷链接:地平线算法工具链使用满意度反馈
      2023-07-10
  • 默认38336
    您好,请问可以提供一下您量化好的ipm的onnx模型文件吗?谢谢
    2025-04-14
