论坛算法工具链deepv3plus模型转换问题
deepv3plus模型转换问题
driverli2023-05-17
70
14
1.芯片型号:J3
2.天工开物开发包OpenExplorer版本:XJ3_OE_1.15.2
3.问题定位:模型转换
4.问题具体描述:利用sh 03_build.sh脚本转换模型过程中,共发现了如下4个问题
4.1 模型读取到我的output维度为 [0, 0, 0, 0],但是我看量化完后的onnx模型维度也是正确的,不知道这对我模型的转换是否有影响。log部分如下所示:
ONNX IR version: 7
Opset version: [11]
Producer: pytorch1.10
Domain: none
Input name: input, [1, 3, 512, 512]
Output name: output, [0, 0, 0, 0]
4.2 在Default calibration in progress处,log打印如下,这对于模型转换是否有影响呢?
Default calibration in progress: 0%| | 0/13 [00:00<?, ?it/s]2023-05-17 10:58:41.851822862 [E:onnxruntime:, sequential_executor.cc:183 Execute] Non-zero status code returned while running Resize node. Name:'Resize_140' Status Message: /home/jenkins/agent/workspace/model_convert/onnxruntime/onnxruntime/core/providers/cpu/tensor/upsample.h:299 void onnxruntime::UpsampleBase::ScalesValidation(const std::vector&, onnxruntime::UpsampleMode) const scales.size() == 2 || (scales.size() == 4 && scales[0] == 1 && scales[1] == 1) was false. 'Linear' mode and 'Cubic' mode only support 2-D inputs ('Bilinear', 'Bicubic') or 4-D inputs with the corresponding outermost 2 scale values being 1 in the Resize operator
Default calibration in progress: 0%| | 0/13 [00:10<?, ?it/s]
2023-05-17 10:58:41,852 INFO Above info is caused by batch mode infer and can be ignored
2023-05-17 10:58:41,852 INFO Reset batch_size=1 and execute calibration again...
Default calibration in progress: 100%|████████████████████████████████████| 100/100 [03:34<00:00, 2.14s/it]
2023-05-17 11:03:09,197 INFO Select max-percentile:percentile=0.99995 method.
4.3 在我的模型中,有3处resize算子,但是前两处是在BPU上处理的,最后一处显示在CPU上,如何让最后一处resize算子也在BPU上运算呢
Conv_130 BPU id(0) HzSQuantizedConv 0.998633 142.221069
Resize_140 BPU id(0) HzQuantizedRoiResize 0.998626 180.959702
Concat_141 BPU id(0) Concat 0.997866 180.959702
Conv_142 BPU id(0) HzSQuantizedConv 0.997683 180.959702
Resize_152 BPU id(0) HzQuantizedRoiResize 0.997761 130.957626
Concat_153 BPU id(0) Concat 0.997822 130.957626
Conv_154 BPU id(0) HzSQuantizedConv 0.997123 130.957626
Conv_156 BPU id(0) HzSQuantizedConv 0.999196 122.873146
Resize_165 CPU -- Resize 0.999227
4.4 我的onnx模型能正常推理,但是在量化完成后,利用生成的optimized_float_model.onnx模型推理都不正确,不知道是4.1和4.2的问题还是其他原因呢?
因为上传限制原因,现将模型放在百度网盘上,链接如下
链接: https://pan.baidu.com/s/1Ovk0570AVjUuwHycpxPFKg 提取码: errp 复制这段内容后打开百度网盘手机App,操作更方便哦
    你好,
    针对问题1,建议使用新版OE1.16.2c对应的docker再次尝试一下,获取链接为:https://developer.horizon.ai/forumDetail/136488103547258769
    针对问题2,日志是转换过程中的一些优化尝试,不影响模型转换
    针对问题3,在新的docker中进行尝试一下,若依旧在cpu上,可以使用run_on_BPU这个yaml中的参数配置一下看看效果,也可以查看算子支持列表看看是否是因为不满足BPU的约束。
    针对问题4,尝试新版工具链后,可以参考这篇文章进行问题定位:https://developer.horizon.ai/forumDetail/71036815603174578
    2023-05-17
    • driverli回复颜值即正义:
      你好,
      针对问题1,我已经更新到新版OE1.16.2c对应的docker,在执行OE包中的deeplabv3示例时候,发现log如下
      ONNX IR version: 7
      Opset version: [11]
      Domain: none
      Input name: input.1, [1, 3, 1024, 2048]
      Output name: 705, [0, 1, 0, 0]
      其中output输出维度也没有正常显示,虽然也不影响模型的转换(我的模型也能正常转换),算不算一个小bug呢。
      针对问题3,我还没有找到run_on_BPU的位置,能否告知其具体位置呢?
      针对问题4,我按照提供的链接,把我的原始模型放在docker模型用HB_ONNXRuntime里面推理,发现推理的结果不对,如第二张图所示(在我的环境中推理结果如第一张图),是不是对这个模型的某些节点支持不好呢。
      我看了下,aspp结构中dilations参数官方为[6, 12, 18], 由于只支持2的指数,我将其改为[4,8,16]并重新训练的模型。而你们提供的模型dilations参数官方为[2, 4, 8],并且8是由两个dilations参数为4的卷积组成的。这么更改的原因是否你们也发现了dilations参数过大时效果不好呢?
      如果可以的话能否提供你们用于训练deeplabv3puls的仓库呢?
      2023-05-18
    • 颜值即正义回复driverli:
      1. 关于输出shape未成功解析到,已经复现,我们这边看一下哈~
      2. 关于run_on_bpu这个参数可以在手册中yaml中参数详细解读有写,位置可能稍微有点区别:
      3. 关于模型训练,我们这边是有进行了一些些改进的,都是源码开发的,可以在下图中位置找到训练脚本
      2023-05-18
    • driverli回复颜值即正义:
      对于模型转换以及模型推理
      1、按照我的理解,如果我在模型转换中的yaml中norm_type: 配置为'no_preprocess',且输入为rgb,那么对于onnx模型的推理,在我环境中的代码和docker环境中的代码前后处理代码应该是基本相同的,只有推理接口要换成HB_ONNXRuntime推理,并且设置input_offset=128即可。
      2、基于1的理解下,我自己环境中推理onnx模型没问题的,但是在docker环境中转换后用optimized_float_model.onnx模型推理却没有任何结果,应该如何解决呢?
      2023-05-19
    • 颜值即正义回复driverli:
      使用original_float_model.onnx呢?
      2023-05-19
    • driverli回复颜值即正义:
      也没有结果
      2023-05-19
    • 颜值即正义回复driverli:
      此时就是前处理和使用方式的问题,建议再仔细检查一下哈,因为original_float_model.onnx我们并没有做其它的操作了
      2023-05-19
    • 颜值即正义回复driverli:
      还有就是后处理,建议先看一下模型输出能否对齐
      2023-05-19
    • driverli回复颜值即正义:
      但是初始的onnx模型和original_float_model.onnx模型推理所有代码都是一样的,只不过将onnxruntime推理接口换成HB_ONNXRuntime推理接口。而且在模型转换时,为了避免前处理节点的问题,我还将yaml中norm_type: 配置为'no_preprocess',这样所有的数据处理都是通过代码实现的。
      2023-05-19
    • 颜值即正义回复driverli:
      麻烦再确认一下准备的输入数据类型是int8还是float的,用的是sess.run还是sess.run_feature,input_offset是0还是128,在yaml配置中input_type_rt/input_layout_rt和自己准备的数据是一致的。
      2023-05-22
    • driverli回复颜值即正义:
      我明白了,在input_type_rt中我配置的是nv12,但是输入数据却是rgb。已解决。谢谢您的解答
      2023-05-22
    • 颜值即正义回复driverli:
      不客气,记得填一下问卷哈~
      2023-05-22
    也可以参考OE包中的示例哈:
    2023-05-17
