论坛算法工具链horizon_plugin_pytorch哪里下载?
jalymo2023-04-25
137
请问:horizon_plugin_pytorch哪里下载到?
ot@f40f1c19bda5:/open_explorer/horizon_model_convert_sample/ModelZoo/customer# python customer_train.py
File "customer_train.py", line 9, in <module>
import horizon_plugin_pytorch as horizon
ModuleNotFoundError: No module named 'horizon_plugin_pytorch'
    你好,使用plugin的话,建议使用GPU docker。
    然后直接答复你的问题,horizon_plugin_pytorch.whl在OE包路径ddk/package/host/ai_toolchain/horizon_plugin_pytorch-1.4.4+cu111.torch1102-cp38-cp38-linux_x86_64.whl
    2023-04-26
    • jalymo回复颜值即正义:
      我本机没有cuda和gpu卡,纯cpu的也可以用这个horizon plugin pytorch吗?
      2023-04-27
    • 颜值即正义回复jalymo:
      纯CPU不太行哈
      2023-04-27
  • jalymo
    您好,请问:bev_release_package-1.6.29/bev_release_package一定要用gpu吗?我本地只有cpu而且也是下载的cpu镜像docker_openexplorer_ubuntu_20_j5_cpu_v1.1.52a.tar.gz,没有运行报错如下:bev_release_package-1.6.29/bev_release_package# python3 tools/train.py
    File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/extension.py", line 35, in _register_extensions
    torch.ops.load_library(ext_specs.origin)
    File "/root/.local/lib/python3.8/site-packages/torch/_ops.py", line 110, in load_library
    ctypes.CDLL(path)
    File "/usr/lib/python3.8/ctypes/__init__.py", line 373, in __init__
    self._handle = _dlopen(self._name, mode)
    OSError: libcuda.so.1: cannot open shared object file: No such file or directory
    During handling of the above exception, another exception occurred:
    File "tools/train.py", line 10, in
    File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/__init__.py", line 8, in
    from . import extension, jit, nn, quantization # noqa: F401
    File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/extension.py", line 42, in
    _register_extensions()
    File "/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/extension.py", line 37, in _register_extensions
    raise RuntimeError(
    RuntimeError: Fail to load libhorizon_ops, origin msg is
    2023-06-10
    • 颜值即正义回复jalymo:
      你好,训练用CPU不ok的,需要用GPU~
      2023-06-10
    • jalymo回复颜值即正义:
      您好,我现在要把模型转成Device端运行的也不行,请问:cpu docker如何进行bev模型转换?
      log如下:
      bev_release_package-1.6.29# python3 tools/compile_perf.py --config configs/bev/bev_mt_ipm.py --out-dir ./ --opt 3
      ctypes.CDLL(path)
      File "tools/compile_perf.py", line 10, in
      raise RuntimeError(
      2023-06-10
