论坛底层软件j5点亮ovx3b时bus error
j5点亮ovx3b时bus error
anshi2023-04-07
141
14
1.硬件获取渠道:
2.当前系统镜像版本:
j5点亮ovx3c时bus error:
tztek@TADC-D52:/userdata/pushcamera# ./start.sh
poc power off
deserial power off
poc power on
deserial power on
j5 cam reset ok
Bus error (core dumped)
logcat
logcat test start !!!
--------- beginning of /dev/log_main
I/ ( 530): [2.819475]hb_vcs_set_oom_score_adj[2261] L: action: echo -1000 > /proc/530/oom_score_adj ret:0
I/ ( 530): [3.502283]main[2291] L: vio service start pid 530
I/ ( 1638): [61.023126]hb_vio_init[643] L: vio process mode:0 [0:signal, 1:multi]
I/ ( 1638): [61.024506][VPM pipeline]:[vio_pipeline_parser][111]Vpm pipeline parse done.
I/ ( 1638): [61.024868][VPM pipeline]:[vio_pipeline_create][538]pipe (0) create done!
I/ ( 1638): [61.024899][VPM pipeline]:[vio_pipeline_entity_create][292]pipe(0) vio_pipeline_entity_create in
E/ ( 1638): [61.024982][ISP]:[cjson_string_dup][545]json file path /system/etc/cam/lib_COX3CGB_pwl12_OF_Fov99.so length 45 limit 100
I/ ( 1638): [61.025021][PYM]:[pym_entity_create][406]pipe(0) pym entity_create done !
D/ ( 1638): pipeline_id = 0, hw_id = 0, ctx_id = 0, open end!
D/ ( 1638): hb_mem_module_open success version: 0.2.0
I/ ( 1638): [61.056705][ISP]:[isp_entity_init][297]Pipe(0) hw_id = 0, set isp_dev_sched_mode 0
I/ ( 1638): [61.056728][ISP]:[isp_entity_init][310]Pipe(0) isp entity init done.
I/ ( 1638): [61.058128][PYM]:[pym_entity_init_req_buf][560]Pipe(0) Pym 0 otf mode 1 configed.
I/ ( 1638): [61.058155][PYM]:[pym_entity_init][653]Pipe(0) Pym 0 entity init done.
I/ ( 1638): [61.081264][GDC]:[gdc_entity_init][533]Pipe(0) Gdc entity init done.
I/ ( 1638): [61.081322][VPM pipeline]:[vio_pipeline_init][507]pipe(0) pipeline_init success out
I/ ( 1638): [61.081371][VPM interface]:[hb_vpm_init_pipeline][117]pipeline(0) init done !
I/ ( 1638): [61.081589][VIN]:[hb_vin_init][929]cam init begin cam_index 0 cfg_file ./cfg/hb_j5dev.json
I/ ( 1638): [61.082287][VIN]:[hb_vin_deserial_parse_cfg][283]deserial_index 0 deserial_name = max9296
I/ ( 1638): [61.082367][VIN]:[hb_vin_port_parse_cfg][543]port_index 0 deserial_port = 0, NO. 1 attached to desrial max9296
I/ ( 1638): [61.082394][hb mipi]:mipi cfg: ./cfg/hb_mipi_ovx3c_yuyv_30fps_1280P.json
I/ ( 1638): [61.082905][hb_i2c]:[hb_vin_i2c_init][58]bus 1 cam_bus_cnt[bus] 1 cam_fd[bus] 36
I/ ( 1638): [61.084179][hb cim]:cim cfg: ./cfg/cim_config.json
I/ ( 1638): [61.084671][cim hal]:pipe(0) cim_entity_init in.
I/ ( 1638): [61.084835][cim hal]:pipe(0) cim_entity_init out.
I/ ( 1638): [61.084873][hb_i2c]:[hb_vin_i2c_init][58]bus 1 cam_bus_cnt[bus] 2 cam_fd[bus] 36
6.需要提供的解决方案:
    logcat只要这边一点吗
    你可以通过gdb /log/coredump/ /对应的脚本, 可以定位core dump的dumptrace的
    2023-04-07
    • anshi回复费小财:
      对,这是全部的logcat了
      I/ ( 534): [2.771554]hb_vcs_set_oom_score_adj[2261] L: action: echo -1000 > /proc/534/oom_score_adj ret:0
      I/ ( 534): [3.465262]main[2291] L: vio service start pid 534
      I/ ( 1648): [43.864579]hb_vio_init[643] L: vio process mode:0 [0:signal, 1:multi]
      I/ ( 1648): [43.865227][VPM pipeline]:[vio_pipeline_parser][111]Vpm pipeline parse done.
      I/ ( 1648): [43.865559][VPM pipeline]:[vio_pipeline_create][538]pipe (0) create done!
      I/ ( 1648): [43.865593][VPM pipeline]:[vio_pipeline_entity_create][292]pipe(0) vio_pipeline_entity_create in
      E/ ( 1648): [43.865688][ISP]:[cjson_string_dup][545]json file path /system/etc/cam/lib_x3cRGGB_Pwl12_SY_Fov106.so length 46 limit 100
      I/ ( 1648): [43.865719][PYM]:[pym_entity_create][406]pipe(0) pym entity_create done !
      D/ ( 1648): pipeline_id = 0, hw_id = 0, ctx_id = 0, open end!
      D/ ( 1648): hb_mem_module_open success version: 0.2.0
      I/ ( 1648): [43.897503][ISP]:[isp_entity_init][297]Pipe(0) hw_id = 0, set isp_dev_sched_mode 2
      I/ ( 1648): [43.897526][ISP]:[isp_entity_init][310]Pipe(0) isp entity init done.
      I/ ( 1648): [43.898857][PYM]:[pym_entity_init_req_buf][560]Pipe(0) Pym 0 otf mode 1 configed.
      I/ ( 1648): [43.898907][PYM]:[pym_entity_init][653]Pipe(0) Pym 0 entity init done.
      I/ ( 1648): [43.921177][GDC]:[gdc_entity_init][533]Pipe(0) Gdc entity init done.
      I/ ( 1648): [43.921234][VPM pipeline]:[vio_pipeline_init][507]pipe(0) pipeline_init success out
      I/ ( 1648): [43.921253][VPM interface]:[hb_vpm_init_pipeline][117]pipeline(0) init done !
      I/ ( 1648): [43.921463][VIN]:[hb_vin_init][929]cam init begin cam_index 0 cfg_file ./cfg/hb_j5dev.json
      I/ ( 1648): [43.921757][VIN]:[hb_vin_deserial_parse_cfg][283]deserial_index 0 deserial_name = max9296
      I/ ( 1648): [43.921837][VIN]:[hb_vin_port_parse_cfg][543]port_index 0 deserial_port = 0, NO. 1 attached to desrial max9296
      I/ ( 1648): [43.921864][hb mipi]:mipi cfg: ./cfg/hb_mipi_ovx3c_raw12_30fps_1280P.json
      I/ ( 1648): [43.922108][hb_i2c]:[hb_vin_i2c_init][58]bus 1 cam_bus_cnt[bus] 1 cam_fd[bus] 36
      I/ ( 1648): [43.923447][hb cim]:cim cfg: ./cfg/cim_config.json
      I/ ( 1648): [43.923611][cim hal]:pipe(0) cim_entity_init in.
      I/ ( 1648): [43.923775][cim hal]:pipe(0) cim_entity_init out.
      I/ ( 1648): [43.923809][hb_i2c]:[hb_vin_i2c_init][58]bus 1 cam_bus_cnt[bus] 2 cam_fd[bus] 36
      这是gdb时追踪的信息:
      (gdb) bt
      #0 0x0000fffff7fe574c in ?? () from /lib/ld-linux-aarch64.so.1
      #1 0x0000fffff7fd1408 in ?? () from /lib/ld-linux-aarch64.so.1
      #2 0x0000fffff7fd427c in ?? () from /lib/ld-linux-aarch64.so.1
      #3 0x0000fffff7fde500 in ?? () from /lib/ld-linux-aarch64.so.1
      #4 0x0000fffff78b03a0 in _dl_catch_exception () from /lib/libc.so.6
      #5 0x0000fffff7fddf3c in ?? () from /lib/ld-linux-aarch64.so.1
      #6 0x0000fffff77271a4 in ?? () from /lib/libdl.so.2
      #7 0x0000fffff78b03a0 in _dl_catch_exception () from /lib/libc.so.6
      #8 0x0000fffff78b044c in _dl_catch_error () from /lib/libc.so.6
      #9 0x0000fffff77278a0 in ?? () from /lib/libdl.so.2
      #10 0x0000fffff772722c in dlopen () from /lib/libdl.so.2
      #11 0x0000fffff7c7c6d0 in hb_vin_cam_utility () from /system/lib/libcam.so
      #12 0x0000fffff7c762f0 in hb_vin_init () from /system/lib/libcam.so
      #13 0x0000fffff7e232d0 in hb_cam_init (cfg_index=, cfg_file=) at hb_vio_interface.c:76
      #14 0x0000aaaaaaaa5318 in inIt (pCtx=) at src/main.cpp:165
      #15 0x0000aaaaaaaa26c4 in main (argc=, argv=) at src/main.cpp:186
      (gdb)
      之后就没有了,能给出建议吗?
      2023-04-07
    • 费小财回复anshi:
      dlopen 少了一个so库把
      2023-04-07
    • anshi回复费小财:
      这个应该从哪里开始查找呢?
      2023-04-09
    • 费小财回复anshi:
      另外有个问题,J5上是由现成的x3c的示例的,你有跑过吗
      2023-04-10
    • 费小财回复anshi:
      看着是dlopen失败了,json怎么配的啊?sensor name带std不?
      2023-04-10
    • anshi回复费小财:
      驱动代码中有看到ovx3c的代码,json配置没有看到完整的示例
      2023-04-10
    • 费小财回复anshi:
      /app/bin/vps/vpm/vio_test_case.sh quad_sen_cim_isp0_pym0_1280p
      这个就是,4个ovx3c 接在rx1上,直接能跑得
      2023-04-10
    • anshi回复费小财:
      你好,sensor name带std是什么意思啊。我在hb_j5dev.json是这样配置的"sensor_name":"ovx3c"
      2023-04-11
    • 费小财回复anshi:
      你用上面默认的示例跑跑看
      2023-04-11
    • anshi回复费小财:
      您好,我现在只有一个ovx3c,我在配置文件做出相应修改放到pushcamera目录后,./init ./start仍然是bus error
      2023-04-12
    • 费小财回复anshi:
      改下脚本,/app/bin/vps/vpm/vio_test_case.sh 找到对应case quad_sen_cim_isp0_pym0_1280p, 把15改成1 就是1路了
      2023-04-12
    • anshi回复费小财:
      依旧是bus error
      2023-04-12
    • anshi回复费小财:
      您好,ovx3c的serial_addr1怎么设置呢?驱动中poc_power_reset()函数调用不成功
      2023-04-12
