论坛算法工具链yolov8在板端运行时,报错slice operator axes' size must be the same ........
andeluleidisi2023-03-28
131
我复现论坛yolov8那篇文章,模型转换过程很顺利没有报错
但是使用文章里面的部署文件时发生报错
报错信息如下
[HBRT] set log level as 0. version = 3.14.5
[DNN] Runtime version = 1.9.7_(3.14.5 HBRT)
tensor type: NV12_SEPARATE
data type: uint8
layout: NCHW
shape: (1, 3, 416, 416)
[E][DNN][slice.cpp:90](1679747511866) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747511867) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747511996) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747511997) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512120) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512233) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512347) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512464) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512578) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512694) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512812) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512813) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747512929) slice operator axes' size must be the same with input tensor dim size when missing steps
[E][DNN][slice.cpp:90](1679747514520) slice operator axes' size must be the same with input tensor dim size when missing steps
File "inference.py", line 214, in <module>
results = nms(*results)
File "inference.py", line 157, in nms
indices = cv2.dnn.NMSBoxes(boxes, confidences, score_thres, iou_thres).flatten()
AttributeError: 'tuple' object has no attribute 'flatten'
【INFO】: Offload model "ppyolo_tiny_416x416_nv12" Successfully.
    你好,根据报错提示,将.flatten()去掉后可以成功运行哈,如下图所示:
    2023-03-29
    • andeluleidisi回复颜值即正义:
      ok,感谢
      2023-03-29
    • andeluleidisi回复andeluleidisi:
      运行是能运行了,但是
      这个是什么问题,他老提示
      是不是我的模型不是NWHC,我好像转换失败了
      2023-03-29
    • 颜值即正义回复andeluleidisi:
      我这边根据那篇文章验证过,没有问题哈
      2023-03-29
    • HunterZhou回复andeluleidisi:
      我也有这个提示,请问你解决了吗?
      2023-04-22
  • andeluleidisi
    ppyolo_tiny_416x416_nv12这个不是ppyolo模型,是yolov8,我上次模型转换了没改名字
    2023-03-28
  • wunuo
    您好,建议您这边先检查一下代码问题哈,或者可以在参考文章下留言询问一下作者
    2023-03-29
