论坛底层软件J5如何将camera数据流通过mipi tx输出到屏端显示
木木布姆2023-03-02
209
当前硬件环境数据流:
当前输入图片格式:3840x2160 yuv422(uyvy) 30fps
当前mipitx设置输出格式0x1E(yuv422)
当前已经可以通过hbplayer工具显示camera视频图像
问题分析:
这边想把csirx接受到的camera数据通过csitx0->max96717->视频接口B gmsl输出到hdmi接口的显示屏上(用gmsl转HDMI设备)。用的vpm_gtest应用,idu.json使用默认的,mipi json配好dev相关(如附件)。目前显示屏没有任何图像显示。相关log也没有报错的情况,如附件。96717相关是否需要做修改配置呢?代码具体在哪儿修改?能否通过96717控制gmsl转HDMI设备中的解串器?
评论6
  • 木木布姆
    • 木木布姆回复木木布姆:
      附件没转上去,就看评论吧
      2023-03-02
  • 木木布姆
    vio_test_case.sh中增加:
    elif test "$1" == "tuning_ar0820cphFov120_cim_pym0_4k_2pipe"; then
    echo "========= Run $1"
    $COMMON_DIRvpm_gtest -v "/app/bin/vps/vpm/cfg/tuning/tuning_ar0820cph_yuv_cim_rx0_pym0/vpm_config.json" -e 0 -D 1 -r 1000 -c "/app/bin/vps/vpm/cfg/tuning/tuning_ar0820cph_yuv_cim_rx0_pym0/hb_j5dev.json" -M 1 \
    -x $cam_rstart -X $vio_rstart \
    --gtest_filter=VpmScenarioTest.multi_streams_pym \
    # --gtest_output=xml:$OUTPUT_DIR_PREFIXoutput/vps_$1_test_result.xml
    app log:
    /app/bin/vps/vpm/vio_test_case.sh tuning_ar0820cphFov120_cim_pym0_4k_2pipe
    J5 2.0 Board Test
    ========= Run tuning_ar0820cphFov120_cim_pym0_4k_2pipe
    Note: Google Test filter = VpmScenarioTest.multi_streams_pym
    [==========] Running 1 test from 1 test suite.
    [----------] Global test environment set-up.
    [----------] 1 test from VpmScenarioTest
    [ RUN ] VpmScenarioTest.multi_streams_pym
    ------- Test case VpmPymTest multi_streams_pym -----
    [16:47:32]dump_server_thread_start[287] viomonitor L: wait new socket connect.
    Test prepare pipe TestContext(0).
    Pipe(0) layer0 idu0 init default cfg /app/bin/vps/vpm/cfg/idu_cfg/idu.json
    pipe(0)Test pym work thread 281473018847680---running.
    pipe(0)Test(pym_v2)pym_data_worker_thread Ready !
    Try to get Pipe(0) data type(21)(pym_v2)
    Pipe(0) hb_vpm_pym_flush sucess
    idu0 Display done.
    pym layer 0 info for idu set done
    2023-03-02
    • 木木布姆回复木木布姆:
      2023-03-02
    您这里的场景需求是:
    SENSOR(8M)->RX0->CIM/ISP/PYM(GS/BL:1080P)->IDU0->TX0->96717->GMSL2HDMI->显示器(1080P)
    此处TX0后级的96717及再之后的GMSL2HDMI芯片应该要自行配置。
    该类场景可参考: idutx -i 0 -o 1 -u 1 -m 0xc
    其会有idu及加串的配置动作,该命令源码位于hbre/camera/tools/idutx.c
    使用libdummy.so库,具体实现在utility/sensor/dummy_utility.c
    此处除了加串配置外,可能还需配置GMSL2HDMI,通过GMSL连接理论上是可以通过I2C访问到的,该芯片的配置需自行参考手册完成配置。
    谢谢~
    2023-03-07
    • 木木布姆回复只蓝片羽:
      好的,这边试一下,感谢!
      2023-03-07
  • 木木布姆
  • 木木布姆
    有大佬帮忙解惑吗?
    2023-03-06
  • 嘻依以~喜
    哥,请问你们现在可以将图像输到显示屏上了吗,使用的是什么方案呀?
    2024-06-02
