论坛底层软件J3 user app demo
J3 user app demo
开发者村2023-01-18
26
Hello 地平线专家:
3.当前天工开物版本:1.27.
4.问题定位:编译错误
当前想跑一个user_app main.cc demo,目前编译时候报错如下:
-- The C compiler identification is GNU 6.5.0
-- The CXX compiler identification is GNU 6.5.0
-- Check for working C compiler: /opt/gcc-linaro-6.5.0-2018.12-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc
-- Check for working C compiler: /opt/gcc-linaro-6.5.0-2018.12-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /opt/gcc-linaro-6.5.0-2018.12-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++
-- Check for working CXX compiler: /opt/gcc-linaro-6.5.0-2018.12-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Build type: Release
CMake Error at CMakeLists.txt:33 (target_link_libraries):
Cannot specify link libraries for target "user_app" which is not built by
this project.
-- Configuring incomplete, errors occurred!
See also "/root/ddk/samples/solution_zoo/solution_example/xxxx_example/build_arm/CMakeFiles/CMakeOutput.log".
make: *** No targets specified and no makefile found. Stop.
  • 开发者村
    add_executable(user_app_main.cc)
    target_link_libraries(user_app
    ${BPU_libs}
    pthread
    rt
    dl)
    pthread、rt、dl这些库的路径还需要单独指定吗?
    2023-01-18
