论坛底层软件求OX08B40点亮代码
求OX08B40点亮代码
soon2k2022-12-27
80
86
请问地平线或开发者中有调试过OV的camera sensor OX08B40吗?可以共享camera点亮的代码吗?
征程3技术深度解析
    这个实现我们在很多平台都调试过的,但是J3 release的时候并未合入
    如果需要共享的话是不是要走官方驱动去获取呢
    2022-12-27
    • soon2k回复费小财:
      好的谢谢,现在我这边调试时遇到dphy_fatal问题,目前linelength和framelength无法确定,试了一些值,还是有dphy_fatal,mipi信号大致测了一下应该没问题,应该是参数不对,请问您那边这两个参数设置的是什么?我们用的是raw12 HDR4的settings?或者需要如何debug一下吗?
      2022-12-27
    • 费小财回复soon2k:
      这个是我们这边的配置,你看看
      2022-12-27
    • 费小财回复soon2k:
      linelenth framelenth的值不是卡的特别死,上下错一些也没关系,报phy fatal可能是settle值不对
      2022-12-27
    • felicia回复费小财:
      我们用了这组参数,还是phy fatal, 只是不一样的settle phy fatal 的值有变化,如下是3个phy fatal:
      [ 8409.684070] vps mipi_host1: irq status 0x10001
      [ 8409.684680] vps mipi_host1: phy_fatal: 0x5
      [ 8409.685234] vps mipi_host1: phy: 0x1
      [ 8409.685734] vps mipi_host1: irq status 0x1
      [ 8409.686266] vps mipi_host1: phy_fatal: 0xd
      [ 8409.686822] vps mipi_host1: irq status 0x1
      [ 8409.687353] vps mipi_host1: phy_fatal: 0x5
      [ 8409.687909] vps mipi_host1: irq status 0x1
      [ 8409.688440] vps mipi_host1: phy_fatal: 0x5
      [ 8409.688996] vps mipi_host1: irq status 0x10001
      [ 8409.689571] vps mipi_host1: phy_fatal: 0x5
      [ 8409.690125] vps mipi_host1: phy: 0x3
      [ 8409.690614] vps mipi_host1: irq status 0x1
      [ 8409.691145] vps mipi_host1: phy_fatal: 0xd
      [ 8409.691701] vps mipi_host1: irq status 0x10001
      [ 8409.692276] vps mipi_host1: phy_fatal: 0xd
      [ 8409.692830] vps mipi_host1: phy: 0x3
      [ 8409.693319] vps mipi_host1: irq status 0x1
      [ 8409.693850] vps mipi_host1: phy_fatal: 0x5
      [ 8409.694406] vps mipi_host1: irq status 0x10001
      [ 8409.694981] vps mipi_host1: phy_fatal: 0x5
      [ 8409.695534] vps mipi_host1: phy: 0x3
      [ 8409.696023] vps mipi_host1: irq status 0x1
      [ 8409.696554] vps mipi_host1: phy_fatal: 0x5
      [ 8409.697109] vps mipi_host1: irq status 0x1
      [ 8409.697640] vps mipi_host1: phy_fatal: 0xd
      [ 8409.698198] vps mipi_host1: irq status 0x1
      [ 8409.698729] vps mipi_host1: phy_fatal: 0x5
      [ 8422.138362] cancel by gstop1
      [ 8497.194329] alloc_contig_range: 23354 callbacks suppressed
      [ 8498.603742] vps mipi_host1: irq status 0x10001
      [ 8498.604347] vps mipi_host1: phy_fatal: 0x3
      [ 8498.604922] vps mipi_host1: phy: 0xc
      [ 8498.605454] vps mipi_host1: irq status 0x10001
      [ 8498.606048] vps mipi_host1: phy_fatal: 0x3
      [ 8498.606618] vps mipi_host1: phy: 0xc
      [ 8498.607127] vps mipi_host1: irq status 0x10001
      [ 8498.607720] vps mipi_host1: phy_fatal: 0xf
      [ 8498.608291] vps mipi_host1: phy: 0xc
      [ 8498.608798] vps mipi_host1: irq status 0x10001
      [ 8498.609391] vps mipi_host1: phy_fatal: 0x3
      [ 8498.609961] vps mipi_host1: phy: 0xc
      [ 8498.610469] vps mipi_host1: irq status 0x10001
      [ 8498.611062] vps mipi_host1: phy_fatal: 0x3
      [ 8498.611632] vps mipi_host1: phy: 0xc
      [ 8498.612140] vps mipi_host1: irq status 0x10001
      [ 8498.612733] vps mipi_host1: phy_fatal: 0xf
      [ 8498.613303] vps mipi_host1: phy: 0xc
      [ 8498.613810] vps mipi_host1: irq status 0x10001
      [ 8498.614394] vps mipi_host1: phy_fatal: 0x3
      [ 8498.614947] vps mipi_host1: phy: 0xc
      [ 8498.615437] vps mipi_host1: irq status 0x10001
      [ 8498.616012] vps mipi_host1: phy_fatal: 0x7
      [ 8498.618338] vps mipi_host1: irq status 0x1
      [ 8498.618880] vps mipi_host1: phy_fatal: 0xf
      [ 8498.619444] vps mipi_host1: irq status 0x10001
      [ 8498.620020] vps mipi_host1: phy_fatal: 0x3
      [ 8498.620576] vps mipi_host1: phy: 0xc
      [ 8498.621074] vps mipi_host1: irq status 0x10001
      [ 8498.621655] vps mipi_host1: phy_fatal: 0x3
      [ 8498.622210] vps mipi_host1: phy: 0xc
      [ 8498.622708] vps mipi_host1: irq status 0x10001
      [ 8498.623286] vps mipi_host1: phy_fatal: 0x3
      [ 8498.623839] vps mipi_host1: phy: 0xc
      [ 8845.054717] vps mipi_host1: phy_fatal: 0xf
      [ 8845.055312] vps mipi_host1: irq status 0x10001
      [ 8845.055906] vps mipi_host1: phy_fatal: 0xf
      [ 8845.056477] vps mipi_host1: phy: 0xf
      [ 8845.056986] vps mipi_host1: irq status 0x10001
      [ 8845.057579] vps mipi_host1: phy_fatal: 0xf
      [ 8845.058149] vps mipi_host1: phy: 0xf
      [ 8845.058657] vps mipi_host1: irq status 0x10001
      [ 8845.059249] vps mipi_host1: phy_fatal: 0xf
      [ 8845.059819] vps mipi_host1: phy: 0xf
      [ 8845.060327] vps mipi_host1: irq status 0x10001
      [ 8845.060920] vps mipi_host1: phy_fatal: 0xf
      [ 8845.061490] vps mipi_host1: phy: 0xf
      [ 8845.061997] vps mipi_host1: irq status 0x10001
      [ 8845.062590] vps mipi_host1: phy_fatal: 0xf
      [ 8845.063160] vps mipi_host1: phy: 0xf
      [ 8845.063667] vps mipi_host1: irq status 0x10001
      [ 8845.064259] vps mipi_host1: phy_fatal: 0xf
      [ 8845.064830] vps mipi_host1: phy: 0xf
      [ 8845.065337] vps mipi_host1: irq status 0x10001
      [ 8845.065930] vps mipi_host1: phy_fatal: 0xf
      [ 8845.066492] vps mipi_host1: phy: 0xf
      [ 8845.066981] vps mipi_host1: irq status 0x10001
      [ 8845.067556] vps mipi_host1: phy_fatal: 0xf
      [ 8845.068110] vps mipi_host1: phy: 0xf
      [ 8845.068599] vps mipi_host1: irq status 0x10001
      [ 8845.069174] vps mipi_host1: phy_fatal: 0xf
      [ 8845.069728] vps mipi_host1: phy: 0xf
      [ 8845.070217] vps mipi_host1: irq status 0x10001
      [ 8845.070792] vps mipi_host1: phy_fatal: 0xf
      [ 8845.071345] vps mipi_host1: phy: 0xf
      [ 8845.071838] vps mipi_host1: irq status 0x10001
      [ 8845.072413] vps mipi_host1: phy_fatal: 0xf
      [ 8845.072967] vps mipi_host1: phy: 0xf
    • 费小财回复felicia:
      速率配的对吗,解串器mipi输出的速率与mipi的配置mipiclk匹配吗,这些参数需要都检查下输出端的值是否匹配的
      2022-12-27
    • soon2k回复费小财:
      我们解串器配的是750M,平台端试过750,1500,4800都试过,一样报错
      2022-12-27
    • 费小财回复soon2k:
      上面的配置是我们X8b的配置的,其他的话感觉只能再多做做实验了
      2022-12-28
    • soon2k回复费小财:
      请问你们用解串器是9296吗?解串器上设的mipi clock是多少?看一下9296寄存器0x0320的设置
      2022-12-28
    • 费小财回复soon2k:
      是的,9296,我们这边设置的是设置的0x2c,也就是每lane1.2G
      2022-12-28
    • soon2k回复费小财:
      谢谢王工,我们按这个配置先试一下。另外能不能再帮忙确认一下你们那边配置的sensor的output interface是什么?我们用的是HDR4 COMB-PWL12Bbit
      2022-12-28
    • felicia回复soon2k:
      我们下面这块配制的不一样,您是用的两路vc, 我们用的一路vc,请问题您那的sensor mode 是DOL2么?我们这边是按linear配制的
      2022-12-28
    • felicia回复felicia:
      2022-12-28
    • 费小财回复soon2k:
      我们应该也是这个的
      2022-12-28
    • felicia回复费小财:
      上面这个您的,我们配制是
      "vc_num": 1,
      "vc0_index": 0
      不知道这个有没有影响?
      2022-12-28
    • 费小财回复felicia:
      你不是PWL的吗,为啥要按linear配置呢?
      2022-12-28
    • 费小财回复felicia:
      如果只有一路写1 写2都没关系的,因为最终也只用1路
      2022-12-28
    • felicia回复费小财:
      fae说在sensor中合成一路输出的,我不太理解,就配制成linear了,不知道对不对
      2022-12-29
    • 费小财回复felicia:
      不对, 你这个是一个pwl得sensor “我们用的是HDR4 COMB-PWL12Bbit” 不能用linear得
      2022-12-29
    • 新手村回复felicia:
      sensor端多帧合成的模式,我们称之为PWL模式,linear是指单帧曝光输出;
      2022-12-29
    • soon2k回复费小财:
      HDR combine是在8B4内置的ISP里做的,mipi输出的是linear image data
      2022-12-29
    • 费小财回复soon2k:
      不是把,如果是12bit得话按照他给得话 HDR4 COMB-PWL12Bbit,就是pwl得数据,通过ISP得解压来处理这部分数据得
      2022-12-29
    • soon2k回复费小财:
      ok,那我理解解压是需要配置ISP,mipi传输上用一个VC应该是没问题的吧?现在我们还是报phy_err,各种参数都检查过了,请帮忙看看还需要怎么debug.
      关于HDR4 COMB-PWL12Bbit数据,ISP怎么配置有说明文档吗?
      2022-12-29
    • 费小财回复soon2k:
      错误信息是上面一样的吗?那应该还是要检查mipi的配置的
      ISP的配置应该有对应的vio配置说明的,hdrmode参数设置的
      2022-12-29
    • soon2k回复费小财:
      关于ISP解压追问一下,8B4的HDR4 模式是由24bit PWL到12bit,J3 ISP的 Decompander模块可以处理吗?
      2022-12-29
    • 费小财回复soon2k:
      可以的,车载ISP都具备这个能力的
      2022-12-29
    • felicia回复费小财:
      您好,现在我们可以把这个sensor点亮了,但是不稳定,偶尔能点亮,大部分情况不能点亮,不能点亮的时候,isp driver报以下error, 请您帮忙分析一下,谢谢
      2023-01-05
    • felicia回复felicia:
      2023-01-05
    • 费小财回复felicia:
      错误在哪里了呢?
      2023-01-05
    • 费小财回复felicia:
      sensor的输出数据尺寸是对的吗
      2023-01-05
    • felicia回复费小财:
      sensor的输出有点问题,这个错误并不影响出图,影响出图的是下面这个信息
      2023-01-05
    • felicia回复felicia:
      2023-01-05
    • felicia回复felicia:
      能正常出图的时候没有这些信息
      2023-01-05
    • 费小财回复felicia:
      对,看上去因为isp收到得的数据跟预期的不一样导致ISP无法处理了
      2023-01-05
    • felicia回复费小财:
      但就是不知道具体是什么导致的,我按文档提示设置实际输出试过,也不行;所以请您分析一下看看是什么原因导致的
      2023-01-05
    • 费小财回复felicia:
      这个从ISP看确实就是sensor给到ISP的数据不对导致的,你那边能下载到pilot的代码吗,可以直接从pilot上把sensor so弄过来试试
      2023-01-05
    • felicia回复费小财:
      以上图中第一次获取的宽高参数和之后获取的宽高参数不一样,当第一次获取的宽高参数和真实的参数差别不大时,可以出图,当差的比较多时,就会报这样的错误,这个参数应该是从 reg:[SIF_MIPI_RX_STATUS4]中读取的吧?为什么会有这样的差别呢?
      2023-01-05
    • felicia回复felicia:
      pilot代码有具体版本么?我问一下看看
      2023-01-05
    • 费小财回复felicia:
      这个差别看上去是来自sensor的,后面模块不会处理单个pixel的
      2023-01-05
    • 费小财回复felicia:
      应该最新的代码就有的,你可以去最新的代码上看看
      2023-01-05
    • felicia回复费小财:
      reg:[SIF_MIPI_RX_STATUS4]这个是平台的reg,那这个参数是从sensor的什么地获取的呢?从log 上看,有可能是一开始状态不稳定造成的,有没有可能做些延时什么的把这个问题规避一下?
      2023-01-05
    • felicia回复费小财:
      pilot上的so不能用,接口对不上
      2023-01-05
    • 费小财回复felicia:
      你可以该该sensor的设置看看,比如settle啊 啥 或者blank的值
      2023-01-05
    • felicia回复费小财:
      您好,再请教一个问题,我们现在需要在driver实现tuning接口,请问题在J3平台上应用层回调这种方式是可用的么?我在utility/sensor/下面没有发现有用到这种方式实现的,都是驱动注册的方式,这种方式好像没用过
      2023-01-06
    • 费小财回复felicia:
      没太明白,但是肯定时可以的,tuning接口是ISP的能力不是sensor的能力,你找代码的话应该也去ISP相关的目录找
      2023-01-06
    • felicia回复费小财:
      2023-01-06
    • 费小财回复felicia:
      这个是3a接口,不是tuning接口
      看代码实现上都是需要自己手动增加callback函数就可以了
      2023-01-06
    • felicia回复费小财:
      我说的就是这个,可能是表述不准确,这些在现有的driver代码里没有实现的,我们想用,不知道这条路是否通了,所以确认一下
      2023-01-06
    • 费小财回复felicia:
      恩,照着加应该就可以实现得
      2023-01-06
    • felicia回复费小财:
      hi, 我们针对这个sensor在做tunning,遇到了以下问题,麻烦您给看一下:
      1 有时候图像颜色是正常的,有时候颜色发紫,用的是一样的参数
      2 当开启自动曝光时,曝光起作用,again和dgain可以写入 sensor寄存器;但是当通过control tool 开起手动设置曝光值时,again和dgain值可以传入到 sensor driver,但寄存器的值没有变化,也没有报任何error,手动设置曝光不起作用
      以上麻烦您帮忙分析一下,谢谢!
      2023-01-10
    • 费小财回复felicia:
      1.发紫的图片发我们看下,便于分析,sensor的 cfa pattern 设置的对吗
      2.手动曝光要先把manual ae打开后,设置才能生效
      2023-01-10
    • felicia回复费小财:
      1 发紫的图片稍候上传,cfa pattern设置的对,确认过了
      2 我们是在control tool中打开的,如下截图,不知道和您说的打开manual ae是不是一回事
      2023-01-10
    • felicia回复felicia:
      这是JPG
      2023-01-10
    • 费小财回复felicia:
      我看你control tool是连着的,紫色的话,你可以通过hardware的接口中该下 cfg pattern和 rgb start,调整下看看效果
      2023-01-10
    • 费小财回复felicia:
      SYSTEM_MANUAL_EXPOSURE,SYSTEM_MANUAL_INTEGRATION_TIME 这2个也需要manual住
      2023-01-10
    • felicia回复费小财:
      好的,多谢!
      2023-01-10
    • felicia回复felicia:
      王工您好,我们还有两个问题,请您再给分析一下:
      1 tunning tool 跑起来后,用hobot player 预览画面时,画面卡顿
      2 hobot player连接预览后,uart 会输出如下 log:
      [ 42.003168] hobot_dev_ipu: FS and FE occur at same time
      [ 54.125076] hobot_dev_ipu: FS and FE occur at same time
      [ 60.170552] hobot_dev_ipu: FS and FE occur at same time
      [ 64.827742] hobot_dev_ipu: FS and FE occur at same time
      [ 74.506880] hobot_dev_ipu: FS and FE occur at same time
      [ 80.715183] hobot_dev_ipu: FS and FE occur at same time
      [ 92.047340] hobot_dev_ipu: FS and FE occur at same time
      [ 99.676698] hobot_dev_ipu: FS and FE occur at same time
      [ 111.438637] NOHZ: local_softirq_pending 80
      [ 113.316963] hobot_dev_ipu: FS and FE occur at same time
      [ 114.234610] pwm_gpio: PWM
      [ 119.862109] NOHZ: local_softirq_pending 80
      [ 134.161670] hobot_dev_ipu: FS and FE occur at same time
      [ 146.645504] hobot_dev_ipu: FS and FE occur at same time
      [ 152.921360] hobot_dev_ipu: FS and FE occur at same time
      [ 162.500444] hobot_dev_ipu: FS and FE occur at same time
      [ 182.352266] hobot_dev_ipu: FS and FE occur at same time
      2023-01-12
    • felicia回复felicia:
      另外 还偶现如下log:
      [ 344.481530] FE overflow 16 mux_index 4 temp_flow 0x0
      [ 344.482226] [S0][V0] sif_video_dqbuf (p0) complete empty.
      [ 344.482292] hobot_dev_ipu: FS and FE occur at same time
      [ 344.483824] pwm_gpio: PWM>25ms: 37ms
      [ 344.494779] pwm_gpio: PWM
      [ 344.560173] sys_report 0x0 current buffer index = 0x300, buffer owner = 0x0
      [ 344.560173]
      [ 344.561277] input buffer overflow(0x10) temp_flow 0x10
      [ 344.561955] overflow FE mux_index 4
      [ 344.562433] overflow FE mux_index 4
      [ 344.562901] FE overflow 16 mux_index 4 temp_flow 0x0
      [ 344.563599] [S0][V0] sif_video_dqbuf (p0) complete empty.
      [ 344.563662] hobot_dev_ipu: FS and FE occur at same time
      [ 344.565178] pwm_gpio: PWM>25ms: 48ms
      [ 344.617478] sys_report 0x0 current buffer index = 0x0, buffer owner = 0x0
      这个是偶现的,触发条件目前还不清楚,按相关文档说明,也调节了sensor的vts寄存器,好像没有什么效果。
      2023-01-12
    • 费小财回复felicia:
      你不连卡吗,hbplayer是通过网络传输的,对网络要求比较高,当网络不好的时候会影响到系统性能的,所以打开hbplay,可以考虑降低sensor尺寸和fps
      2023-01-12
    • 费小财回复felicia:
      对的,问题应该都是因为hbplayer影响了系统的性能导致的
      2023-01-12
    • 新手村回复felicia:
      IPU FS and FE occur at same time是正常的log,表示N帧FE和N+1帧FS一起来了,你打开hbplayer显示,会导致系统负载高,从而响应中断延迟高了;
      2023-01-12
    • felicia回复费小财:
      我们这个板子上没有显示系统,请问用什么方法可以验证一下不连接是否卡顿?另外我们的网络是直连的,1G的网口,按照3840*2160*30*2*8/1024/1024 = 3796.875Mbps, 从这个结果来看,是不是理论网速就不够了?
      2023-01-12
    • 费小财回复felicia:
      你hbplayer不点击连接,就是不看图,就不会有发送的动作
      对网络是够的,只是传递数据会占用系统资源的
      2023-01-12
    • felicia回复费小财:
      不连接hobot player确实不会有以上那些信息,但是tunning的话,还是需要看图的,这个问题怎么解呢?
      2023-01-12
    • 费小财回复felicia:
      卡的不能tuning的吗,如果卡到不能tuning的话就要考虑要不走直连方式,配置稍微有点复杂,要不就降低fps
      2023-01-12
    • felicia回复费小财:
      我试了降低fps到15(把tunning tool的启动脚本中的fps都改为15,除此之外还有别的地方需要改么?),但还是一样的效果,一连接hobotplayer就出以上信息,画面还是卡
      直连方式怎么配制呢?我们想试一下
    • 费小财回复felicia:
      这个配置我需要确认下,本身我没试过
      另外还有一个点,就是我从我们tuning团队获取到的信息是他们没碰到卡顿的,所以他们想问下你用的网线是千兆网线吗
      2023-01-12
    • felicia回复费小财:
      是千兆网,确认过了
      2023-01-12
    • 费小财回复felicia:
      恩 cat.6的线
      刚才问了下,直连的话直接连上电脑,然后2遍的网络配置为同一个网段就行,你可以试试
      2023-01-12
    • felicia回复费小财:
      我们现在就是这种连接方法
      2023-01-12
    • felicia回复费小财:
      我们现在就是这种连接方法
      2023-01-12
    • 新手村回复felicia:
      画面卡是正常现象,用hbplayer显示,千兆网卡下,4K只能8fps左右,显示延迟也大,都是正常现象;除非你把分辨率改成720P
      2023-01-12
    • felicia回复新手村:
      好的,谢谢您的解释
      2023-01-12
    • felicia回复felicia:
      您好,再请教一个问题,tuning_tool 在跑的过程中,会偶现以下信息,在我们拿到的软件中没有搜到hb_isp.c这个文件,还请帮忙分析一下:
      [ERROR]["LOG"][isp/hb_isp.c:623] ioctl GET_CTX failed, errno is Bad address.
    • 新手村回复felicia:
      这个信息意思是:ISP还没初始化就去get ctx了,如果tuning tool能正常工作,可忽略
      2023-01-13
    • 费小财回复felicia:
      ret = ioctl(fd, ISPIOC_GET_CTX, &ctx);
      if (ret < 0) {
      isp_log("ioctl GET_CTX failed, errno is %s.", strerror(errno));
      return -1;
      这个操作的时候发现地址不对把,你定位到操作了哪个参数吗,可能是底层不支持,需要dmesg日志
      2023-01-13
    • felicia回复费小财:
      这个信息出现的比较随机,有时候刚run tuning_tool就出现,有时候连接hobot player出现 ,tuning 调试时也出现,没有比较固定的场景,出现时一般情况下不影响操作,有时候control tool会失去响应。但是control tool在不出现这个信息时也会有卡住的问题,所以我们也不好判断是在什么操作下出现的,我们后面再跟一下,同时收集一下dmesg再给您反馈吧,谢谢支持!
      2023-01-13
    • 费小财回复felicia:
      好的,有分析的时候提供下dmesg就行
      2023-01-13
    • 费小财回复felicia:
      你好,顺便问一句,你的x8b驱动相关的代码是通过什么渠道获取的,可以记录一下获取方式的
      2023-01-16
    • soon2k回复费小财:
      从地平线和金脉获取的,两份都不能直接在J3上用,我们自己改过的
      2023-01-17
    • 费小财回复soon2k:
      好的好的,多谢分享
      2023-01-17
    请问一下,现在OVX8B已经能够点亮了吗?
    2023-01-17
    • soon2k回复新手村:
      点亮了,正在做效果调试。顺便感谢sunkaikai和ping01wang两位对其他帖子的快速回复?
      2023-01-17
    • 新手村回复soon2k:
      解决了就行,有其他问题再讨论;
      2023-01-17
    • felicia回复新手村:
      您好,我们现在遇到一个tuning相关的问题,我们之前在driver中实现3a回调接口时参考了J5的实现接口,但awb_cct_control这个接口中 color_temper这个参数J3 上没有,所以现在我们在tunning时无法根据环境的真实色温调节awb参数,导致tuning效果颜色异常,请指导一下,多谢!
      2023-01-30
    点亮过改款sensor,不过代码需要你找我司与贵司的接口人获取,我们社区没办法直接提供源码;
    2022-12-27
