论坛底层软件88EA1512无clk输出给J5
88EA1512无clk输出给J5
danyxnever2022-12-12
56
1.硬件获取渠道:基于matrix5.1自制
2.当前系统镜像版本:
a、单板问题。
b、网口灯不亮。
c、Hobot# setenv ipaddr 10.10.16.12
Hobot# ping 10.10.16.11
ethernet@59120000: EQOS_DMA_MODE_SWR stuck
ethernet@59120000: FAILED: -110
ethernet@59110000: EQOS_DMA_MODE_SWR stuck
ethernet@59110000: FAILED: -110
ping failed; host 10.10.16.11 is not alive
d、
Hobot# mii dev ethernet@59120000
Hobot# mii dump 0x0E 0-2
0. (1140) -- PHY control register --
(8000:0000) 0.15 = 0 reset
(4000:0000) 0.14 = 0 loopback
(2040:0040) 0. 6,13 = b10 speed selection = 1000 Mbps
(1000:1000) 0.12 = 1 A/N enable
(0800:0000) 0.11 = 0 power-down
(0400:0000) 0.10 = 0 isolate
(0200:0000) 0. 9 = 0 restart A/N
(0100:0100) 0. 8 = 1 duplex = full
(0080:0000) 0. 7 = 0 collision test enable
(003f:0000) 0. 5- 0 = 0 (reserved)
1. (7969) -- PHY status register --
(8000:0000) 1.15 = 0 100BASE-T4 able
(4000:4000) 1.14 = 1 100BASE-X full duplex able
(2000:2000) 1.13 = 1 100BASE-X half duplex able
(1000:1000) 1.12 = 1 10 Mbps full duplex able
(0800:0800) 1.11 = 1 10 Mbps half duplex able
(0400:0000) 1.10 = 0 100BASE-T2 full duplex able
(0200:0000) 1. 9 = 0 100BASE-T2 half duplex able
(0100:0100) 1. 8 = 1 extended status
(0080:0000) 1. 7 = 0 (reserved)
(0040:0040) 1. 6 = 1 MF preamble suppression
(0020:0020) 1. 5 = 1 A/N complete
(0010:0000) 1. 4 = 0 remote fault
(0008:0008) 1. 3 = 1 A/N able
(0004:0000) 1. 2 = 0 link status
(0002:0000) 1. 1 = 0 jabber detect
(0001:0001) 1. 0 = 1 extended capabilities
2. (0141) -- PHY ID 1 register --
(ffff:0141) 2.15- 0 = 321 OUI portion
e、测量电源复位正常。
f、测量J5A_RGMII1_RX_CLK无125MHz时钟。
6.需要提供的解决方案:
看起来mii dump已经可以访问88ea1512了,phy输出的125MHz还有什么依赖项
    麻烦请先检查88ea1512的参考时钟和供电情况。
    2022-12-12
  • tao03wang
    麻烦check一下 phy的外围电路,比如phy参考时钟,phy的的供电电压
    2022-12-12
  • Daitao
    可以确认一下88EA1512 RSET的电阻是不是贴装的4.99Kohm。
    你这个看起来是芯片工作异常的,有检查过pyh的硬件链接是否正常吗
    2022-12-19
