论坛底层软件no tuning point found
danyxnever2022-12-08
75
单板报no tuning point found错误,在这之前会卡上2~3分钟。
uboot命令执行mmc info正常,
执行mmc dev会报同样的错误
Hobot# mmc info
Device: sdhc@0x48030000
Manufacturer ID: 15
OEM: 100
Serial: 0xc57353c4
Bus Speed: 200000000
Mode : HS200 (200MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 59.6 GiB(124993536 sectors)
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 59.6 GiB WRREL
Boot Capacity: 31.9 MiB ENH
RPMB Capacity: 4 MiB ENH
Hobot# mmc list
sdhc@0x48030000: 0 (eMMC)
sdhc@0x48040000: 1
Hobot# mmc
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
arguments (sizes in 512-byte blocks):
[user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
[gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
[check|set|complete] - mode, complete set partitioning completed
WARNING: Partitioning is a write-once setting once it is set to complete.
Power cycling is required to initialize partitions after set to complete.
mmc setdsr <value> - set DSR register value
Hobot# mmc dev
switch to partitions #0, OK
mmc0(part 0) is current device
评论5
  • ughost
    您好。
    mmc read 试一下,看看读数据能不能成功。
    从log看hs 200 tuning失败了,找不到合适的数据采样点。
    可能原因是(1)芯片焊接问题(emmc或者J5)(2)硬件布线emmc是否符合规范
    从图中看SPL可以正常加载uboot,故emmc至少可以运行在8线high speed模式。
    建议尝试思路:
    (1)软件:降低速度,跑emmc high speed或者emmc legacy,或者降低位宽。(通过修改uboot config配置或者uboot设备树)
    (2)硬件:更换emmc颗粒,或者重新焊接emmc
    2022-12-08
    • danyxnever回复ughost:
      Hobot# mmc read 0x90000000 0x2a00 0x1000
      MMC read: dev # 0, block # 10752, count 4096 ... 4096 blocks read: OK
      Hobot# mmc write 0x90000000 0x2a00 0x1000
      MMC write: dev # 0, block # 10752, count 4096 ... 4096 blocks written: OK
      read write都正常
      2022-12-08
  • danyxnever
    Hobot# mmc info
    Manufacturer ID: 15
    OEM: 100
    Serial: 0xc57353c4
    Bus Speed: 50000000
    Mode : MMC High Speed (52MHz)
    Rd Block Len: 512
    MMC version 5.1
    High Capacity: Yes
    Bus Width: 4-bit
    Hobot# mmc info
    Manufacturer ID: 15
    OEM: 100
    Serial: 0xc57353c4
    Rd Block Len: 512
    MMC version 5.1
    High Capacity: Yes
    Bus Width: 4-bit
    谢谢各位,降低速度和降低位宽都可解决卡2~3分钟问题
    2022-12-09
    • 费小财回复danyxnever:
      收到,有其他问题欢迎随时交流
      2023-01-15
    • 新手村回复danyxnever:
      不客气,我们内部倒没碰到过这种问题,不过谢谢你的反馈
      2023-01-15
    板子的硬件都过吗,看硬件问题吧,板子信号不太好,uboot hs200跑不了。尝试降速或者降位宽处理
    2022-12-08
    no tuning point found是BL31 BIST测试报的,说明eMMC tuning失败,卡2~3分钟是EMMC自行降频处理;
  • Daitao
    可以通过示波器测试一下SDIO信号的建立保持时间,确认一下信号的完整性。
    如果信号质量不满足spec,可以尝试一下修改sdio的驱动能力。
