论坛算法工具链模型量化没有报错,但是输出和onnx很不一样
fa1232022-12-06
104
15
我的模型转onnx是成功的,也验证过了
现在onnx转 .bin文件失败
遇到的问题:
1.我的模型输入是mel频谱图 , 输入是float32 , 值域不在0-255
请问efficientnet_lite0_config.yaml (见附件)应该怎么改?
2.或者,能否不进行量化,直接将onnx转 .bin文件
03.build.sh 输出的过程如下, 貌似转成功了,但是输出和onnx 的很不一样,无法使用
022-12-06 14:52:46,872 INFO Reset batch_size=1 and execute calibration again...
2022-12-06 14:58:15,422 INFO Select max method.
2022-12-06 14:58:15,776 INFO [Tue Dec 6 14:58:15 2022] End to calibrate the model.
2022-12-06 14:58:15,777 INFO [Tue Dec 6 14:58:15 2022] Start to quantize the model.
2022-12-06 14:58:37,202 INFO [Tue Dec 6 14:58:37 2022] End to quantize the model.
2022-12-06 14:58:42,803 INFO Saving the quantized model: efficientnet_lite0_224x224_nv12_quantized_model.onnx.
2022-12-06 14:58:52,130 INFO [Tue Dec 6 14:58:52 2022] Start to compile the model with march bernoulli2.
2022-12-06 14:58:56,280 INFO Compile submodel: torch-jit-export_subgraph_0
2022-12-06 14:59:02,053 INFO hbdk-cc parameters:['--core-num', '1', '--fast', '--O3', '--input-layout', 'NHWC', '--output-layout', 'NCHW', '--input-source', 'ddr']
2022-12-06 14:59:02,111 INFO INFO: "-j" or "--jobs" is not specified, launch 16 threads for optimization
[==================================================] 100%
2022-12-06 14:59:06,362 INFO consumed time 4.27701
2022-12-06 14:59:06,838 INFO FPS=32.75, latency = 30534.8 us (see torch-jit-export_subgraph_0.html)
2022-12-06 14:59:06,844 INFO Compile submodel: torch-jit-export_subgraph_1
2022-12-06 14:59:07,695 INFO hbdk-cc parameters:['--core-num', '1', '--fast', '--O3', '--input-layout', 'NHWC', '--output-layout', 'NHWC', '--input-source', 'ddr']
2022-12-06 14:59:07,728 INFO INFO: "-j" or "--jobs" is not specified, launch 16 threads for optimization
2022-12-06 14:59:07,872 INFO consumed time 0.146057
2022-12-06 14:59:07,952 INFO FPS=1798.18, latency = 556.1 us (see torch-jit-export_subgraph_1.html)
2022-12-06 14:59:09,823 INFO [Tue Dec 6 14:59:09 2022] End to compile the model with march bernoulli2.
2022-12-06 14:59:09,825 INFO The converted model node information:
Node ON Subgraph Type Cosine Similarity Threshold
Transpose_0 CPU -- Transpose
BatchNormalization_1 CPU -- BatchNormalization 1.000000 --
Conv_3 BPU id(0) HzSQuantizedConv 0.994158 4.039474
Conv_5 BPU id(0) HzSQuantizedConv 0.988520 73.934135
AveragePool_8 BPU id(0) HzSQuantizedConv 0.991906 21.153534
Conv_9 BPU id(0) HzSQuantizedConv 0.983432 8.645608
Conv_11 BPU id(0) HzSQuantizedConv 0.984774 31.801315
AveragePool_14 BPU id(0) HzSQuantizedConv 0.987688 22.935102
Conv_15 BPU id(0) HzSQuantizedConv 0.988757 13.219603
Conv_17 BPU id(0) HzSQuantizedConv 0.986877 15.482847
AveragePool_20 BPU id(0) HzSQuantizedConv 0.987965 17.494753
Conv_21 BPU id(0) HzSQuantizedConv 0.986419 14.433695
Conv_23 BPU id(0) HzSQuantizedConv 0.984016 24.406654
AveragePool_26 BPU id(0) HzSQuantizedConv 0.980193 28.904232
Conv_27 BPU id(0) HzSQuantizedConv 0.982191 26.671112
Conv_29 BPU id(0) HzSQuantizedConv 0.980930 21.382399
AveragePool_32 BPU id(0) HzSQuantizedConv 0.982146 20.134457
Conv_33 BPU id(0) HzSQuantizedConv 0.964356 14.805241
Conv_35 BPU id(0) HzSQuantizedConv 0.980975 58.668331
AveragePool_38 BPU id(0) HzSQuantizedConv 0.980975 0.960493
ReduceMean_39 CPU -- ReduceMean 0.983716 --
ReduceMean_39_reshape CPU -- Reshape
ReduceMax_40 CPU -- ReduceMax 0.989400 --
ReduceMean_41 CPU -- ReduceMean 0.986529 --
Add_42 CPU -- Add 0.989427 --
Gemm_43_pre_reshape CPU -- Reshape
Gemm_43 BPU id(1) HzSQuantizedConv 0.998293 0.857610
Gemm_45 BPU id(1) HzSQuantizedConv 0.999911 5.329660
Gemm_45_NHWC2NCHW_LayoutConvert_Output0_reshape CPU -- Reshape
2022-12-06 14:59:09,825 INFO The quantify model output:
Node Cosine Similarity L1 Distance L2 Distance Chebyshev Distance
Gemm_45 0.999911 0.107928 0.005794 0.441083
2022-12-06 14:59:09,827 INFO [Tue Dec 6 14:59:09 2022] End to Horizon NN Model Convert.
2022-12-06 14:59:12,512 INFO start convert to *.bin file....
2022-12-06 14:59:12,548 INFO ONNX model output num : 1
2022-12-06 14:59:12,549 INFO ############# model deps info #############
2022-12-06 14:59:12,549 INFO hb_mapper version : 1.9.9
2022-12-06 14:59:12,550 INFO hbdk version : 3.37.2
2022-12-06 14:59:12,550 INFO hbdk runtime version: 3.14.14
2022-12-06 14:59:12,551 INFO horizon_nn version : 0.14.0
2022-12-06 14:59:12,551 INFO ############# model_parameters info #############
2022-12-06 14:59:12,551 INFO onnx_model : /data/samples/ai_toolchain/horizon_model_convert_sample/03_classification/05_efficientnet_lite0_onnx/mapper/super_resolution.onnx
2022-12-06 14:59:12,551 INFO BPU march : bernoulli2
2022-12-06 14:59:12,552 INFO layer_out_dump : False
2022-12-06 14:59:12,552 INFO log_level : DEBUG
2022-12-06 14:59:12,552 INFO working dir : /data/samples/ai_toolchain/horizon_model_convert_sample/03_classification/05_efficientnet_lite0_onnx/mapper/model_output
2022-12-06 14:59:12,553 INFO output_model_file_prefix: efficientnet_lite0_224x224_nv12
2022-12-06 14:59:12,553 INFO ############# input_parameters info #############
2022-12-06 14:59:12,553 INFO ------------------------------------------
2022-12-06 14:59:12,554 INFO ---------input info : input ---------
2022-12-06 14:59:12,554 INFO input_name : input
2022-12-06 14:59:12,554 INFO input_type_rt : featuremap
2022-12-06 14:59:12,555 INFO input_space&range : regular
2022-12-06 14:59:12,555 INFO input_layout_rt : NHWC
2022-12-06 14:59:12,555 INFO input_type_train : featuremap
2022-12-06 14:59:12,555 INFO input_layout_train : NCHW
2022-12-06 14:59:12,556 INFO norm_type : no_preprocess
2022-12-06 14:59:12,556 INFO input_shape : 1x1x201x64
2022-12-06 14:59:12,556 INFO cal_data_dir : /data/samples/ai_toolchain/horizon_model_convert_sample/03_classification/05_efficientnet_lite0_onnx/mapper/calibration_data_rgb_f32
2022-12-06 14:59:12,557 INFO ---------input info : input end -------
2022-12-06 14:59:12,557 INFO ------------------------------------------
2022-12-06 14:59:12,557 INFO ############# calibration_parameters info #############
2022-12-06 14:59:12,558 INFO preprocess_on : False
2022-12-06 14:59:12,558 INFO calibration_type: : default
2022-12-06 14:59:12,558 INFO cal_data_type : float32
2022-12-06 14:59:12,559 INFO ############# compiler_parameters info #############
2022-12-06 14:59:12,559 INFO hbdk_pass_through_params: --core-num 1 --fast --O3
2022-12-06 14:59:12,559 INFO input-source : {'input': 'ddr', '_default_value': 'ddr'}
2022-12-06 14:59:12,588 WARNING Except for Quanitze/Dequantize and transpose, all other op's are treated as nchw layout by default!!!
2022-12-06 14:59:12,588 INFO NCHW to NHWC transpose node will be added for input 0 in bin model
2022-12-06 14:59:13,697 INFO Convert to runtime bin file sucessfully!
2022-12-06 14:59:13,698 INFO End Model Convert
    你好,可以使用featuremap形式的输入。转换的参考示例在ddk/samples/ai_toolchain/horizon_model_convert_sample/05_miscellaneous/02_resnet50_feature,部署的参考示例在ddk/samples/ai_toolchain/horizon_runtime_sample/code/03_misc/resnet_feature
    2022-12-07
    • fa123回复颜值即正义:
      收到
      2022-12-07
    • fa123回复颜值即正义:
      大佬,能否帮忙解答一下 ,我的问题可能在哪?我觉得我的模型转onnx 都成功了, 后面的应该没什么问题的 ,结果。。。
      2022-12-07
    • fa123回复颜值即正义:
      请问可以直接onnx转bin文件吗? 不进行其他操作,比如量化之类的。 我的模型转onnx是完全没有问题的,我只是想要bpu加速而已。现在我转好的bin文件 输出和onnx输出差很多。
      如果不行,请问有没有更详细的资料?
      2022-12-07
    • 颜值即正义回复fa123:
      您好,BPU上加速的话,是需要进行模型转换量化的,建议您尝试使用featuremap输入,资料的话,参考我们的产品手册以及OE包中的示例去开发会快很多,经过多轮迭代,工具链精度不会有问题哒~
      2022-12-07
    • fa123回复颜值即正义:
      请问为什么我的配置文件也没有什么错, 量化模型的时候余弦相似度也很高, 但是最后生成的.bin文件和onnx文件输出(验证过没有问题的) 很不一样
      2022-12-08
    • fa123回复fa123:
      示例和手册都看了,我都已经找不到其他方向 查找问题了,能提示一下吗?
      2022-12-08
    • fa123回复fa123:
      关于输入时featuremap 的示例貌似不是很详细,请问没有能转成功的例子吗?
      2022-12-08
    • fa123回复颜值即正义:
      这样的警告用不用管的?
      2022-12-08
    • 颜值即正义回复fa123:
      建议您参考这个帖子进行排查哈:https://developer.horizon.ai/forumDetail/71036815603174578
      2022-12-08
    • 颜值即正义回复fa123:
      是的,这个警告不用管哒~
      2022-12-08
    • 颜值即正义回复fa123:
      其实本质上都是一样的哈,只是输入有一些变化而已
      2022-12-08
  • fa123
    比如,某一个输入是这样的:
    float32
    shape:(1, 201, 64, 1)
    最大值:23.625504 ,最小值-47.673203
    2022-12-06
  • fa123
    onnx转.bin ,是成功的,没有报错,但是转出来的.bin文件预测时输出不对。目前怀疑是量化过程有问题。
    2022-12-06
  • fa123
    下面的这段是从论坛里面找的,感觉会不会是padding的问题?
    我的模型输入是shape:(1, 201, 64, 1)
    配置文件也选了 featuremap
    -------------------来自论坛里面的-----------------------
    其中,featuremap输入时较为特殊,由于预测库不会对featuremap数据做padding操作,因此当您的模型输入为featuremap时,需在预处理时完成数据对齐,参考代码如下
    if (input_w == out_w) {
    memcpy(out, input, static_cast(input_h * input_w) * data_size);
    } else {
    for (int i = 0; i < input_h; i++) {
    memcpy(out, input, static_cast(input_w) * data_size);
    input += input_w;
    out += out_w;
    2022-12-06
