论坛底层软件EfficientDet目标检测算法onnx转换j3 bin文件失败
noname2022-10-31
54
在地平线官方提供的最新docker容器内部操作,对应软件包版本如下:
  1. 2022-10-31 11:49:36,138 INFO hbdk version 3.37.2
  2. 2022-10-31 11:49:36,139 INFO horizon_nn version 0.14.0
  3. 2022-10-31 11:49:36,139 INFO hb_mapper version 1.9.9
执行脚本内容如下:
  1. model_type="onnx"
  2. #onnx_model="/mnt/y/files/projects/horizon_model_conversion/effdet/models/input/trained_effdet_sim.onnx"
  3. onnx_model="./models/input/trained_effdet_sim.onnx"
  4. output="./logs/fcos_checker.log"
  5. march="bernoulli2"
  6. hb_mapper checker --model-type ${model_type} \
  7. --model ${onnx_model} \
  8. --output ${output} --march ${march}
错误信息如下:
2022-10-31 11:49:36,696 ERROR There is an error in pass:fuse_div_into_conv. Error message:/home/jenkins/workspace/model_convert/onnx/onnx/common/ir.h:1166: eraseOutput: Assertion `outputs_[i]->uses().empty()` failed.
  • noname
    2022-11-19 17:34:36,466 file: hb_mapper.py func: hb_mapper line No: 70 Start hb_mapper....
    2022-11-19 17:34:36,466 file: hb_mapper.py func: hb_mapper line No: 71 log will be stored in /data//files/projects/horizon_model_conversion/effdet/hb_mapper_checker.log
    2022-11-19 17:34:36,466 file: hb_mapper.py func: hb_mapper line No: 72 hbdk version 3.26.8
    2022-11-19 17:34:36,466 file: hb_mapper.py func: hb_mapper line No: 73 horizon_nn version 0.12.5
    2022-11-19 17:34:36,466 file: hb_mapper.py func: hb_mapper line No: 74 hb_mapper version 1.4.4
    2022-11-19 17:34:36,466 file: hb_mapper.py func: hb_mapper line No: 76 parameter [output] is deprecated
    2022-11-19 17:34:36,499 file: helper.py func: helper line No: 124 Model input names: ['input']
    2022-11-19 17:34:36,501 file: hb_mapper_checker.py func: hb_mapper_checker line No: 104 Model type: onnx
    2022-11-19 17:34:36,501 file: hb_mapper_checker.py func: hb_mapper_checker line No: 105 march: bernoulli2
    2022-11-19 17:34:36,501 file: hb_mapper_checker.py func: hb_mapper_checker line No: 110 input names []
    2022-11-19 17:34:36,501 file: hb_mapper_checker.py func: hb_mapper_checker line No: 111 input shapes {}
    2022-11-19 17:34:36,501 file: hb_mapper_checker.py func: hb_mapper_checker line No: 117 Begin model checking....
    2022-11-19 17:34:36,501 file: build.py func: build line No: 36 [Sat Nov 19 17:34:36 2022] Start to Horizon NN Model Convert.
    2022-11-19 17:34:36,501 file: dict_parser.py func: dict_parser line No: 26 The input parameter is not specified, convert with default parameters.
    2022-11-19 17:34:36,501 file: dict_parser.py func: dict_parser line No: 480 The hbdk parameter is not specified, and the submodel will be compiled with the default parameter.
    2022-11-19 17:34:36,501 file: build.py func: build line No: 146 HorizonNN version: 0.12.5
    2022-11-19 17:34:36,501 file: build.py func: build line No: 150 HBDK version: 3.26.8
    2022-11-19 17:34:36,501 file: build.py func: build line No: 36 [Sat Nov 19 17:34:36 2022] Start to parse the onnx model.
    2022-11-19 17:34:36,624 file: onnx_parser.py func: onnx_parser line No: 146 ONNX model info:
    ONNX IR version:  6
    Opset version:    11
    Input name:       input, [1, 3, 300, 300]
    2022-11-19 17:34:36,790 file: build.py func: build line No: 39 [Sat Nov 19 17:34:36 2022] End to parse the onnx model.
    2022-11-19 17:34:36,796 file: build.py func: build line No: 263 Model input names: ['input']
    2022-11-19 17:34:36,831 file: build.py func: build line No: 524 Saving the original float model: ./.hb_check/original_float_model.onnx.
    2022-11-19 17:34:36,831 file: build.py func: build line No: 36 [Sat Nov 19 17:34:36 2022] Start to optimize the model.
    2022-11-19 17:34:37,038 file: tool_utils.py func: tool_utils line No: 116 exception in command: checker
    2022-11-19 17:34:37,039 file: tool_utils.py func: tool_utils line No: 117 Traceback (most recent call last):
      File "/data//anaconda3/envs/horizon_py3.6/lib/python3.6/site-packages/horizon_tc_ui/utils/tool_utils.py", line 114, in __decorator
        func(*args, **kargs)
      File "/data//anaconda3/envs/horizon_py3.6/lib/python3.6/site-packages/horizon_tc_ui/hb_mapper.py", line 84, in checker
        input_shape).run(__version__)
      File "/data//anaconda3/envs/horizon_py3.6/lib/python3.6/site-packages/horizon_tc_ui/hb_mapper_checker.py", line 131, in run
        **addtional_param)
      File "/data//anaconda3/envs/horizon_py3.6/lib/python3.6/site-packages/horizon_nn/build.py", line 900, in check_onnx
        return builder.build_model(original_model, save_model)
      File "/data//anaconda3/envs/horizon_py3.6/lib/python3.6/site-packages/horizon_nn/build.py", line 530, in build_model
        optimized_model = self.optimize_model(original_model)
      File "/data//anaconda3/envs/horizon_py3.6/lib/python3.6/site-packages/horizon_nn/build.py", line 379, in optimize_model
    self.node_dict)
      File "/data//anaconda3/envs/horizon_py3.6/lib/python3.6/site-packages/horizon_nn/horizon_onnx/quantizer.py", line 185, in optimize
        optimized_model_str = C.optimize(model_str, march, node_dict)
    RuntimeError: There is an error in pass:fuse_div_into_conv. Error message:/home/jenkins/workspace/model_convert/onnx/onnx/common/ir.h:1166: eraseOutput: Assertion `outputs_[i]->uses().empty()` failed.
    2022-11-19 17:34:37,040 file: tool_utils.py func: tool_utils line No: 118 There is an error in pass:fuse_div_into_conv. Error message:/home/jenkins/workspace/model_convert/onnx/onnx/common/ir.h:1166: eraseOutput: Assertion `outputs_[i]->uses().empty()` failed.
    2022-11-19 17:34:37,040 file: build.py func: build line No: 39 [Sat Nov 19 17:34:37 2022] End to optimize the model.
    2022-11-19 17:34:37,040 file: build.py func: build line No: 39 [Sat Nov 19 17:34:37 2022] End to Horizon NN Model Convert.
    2022-11-19
    • 颜值即正义回复noname:
      您好,方便提供一下onnx模型吗?我们去复现一下这个问题
      2022-12-07
    • noname回复颜值即正义:
      某度网盘:https://pan.baidu.com/s/145OIk-LXzxsB6WtofVCLEQ
      提取码:7r4h
      2022-12-12
  • OpenExplorer
    您好,麻烦提供一下完整的log日志,方便我们定位问题~
    2022-11-16
