论坛算法工具链Quanti onnx and Arm result Strict check FAILED
malakas2022-10-25
57
用户您好,请详细描述您所遇到的问题:
  1. 系统软件版本: x3_ubuntu_v1.1.0
  2. OE版本号:ai_toolchain_2.3.3
  3. 问题涉及的技术领域: ai
  4. 问题描述:板端验证bin,结果和docker中的不一致。docker中通过inference.sh测试quantized onnx结果和origin onnx基本一直。hb_model_verifier测试结果也显示不一致。
  5. 复现概率:必现
  6. 提供必要的问题日志:
2022-10-25 14:58:18,873 INFO ================== Sim infer log end ==========================
2022-10-25 14:58:18,873 INFO Sim infer finish
2022-10-25 14:58:18,873 INFO Result compare starts
2022-10-25 14:58:20,223 INFO mismatch line num: 10078
2022-10-25 14:58:20,223 INFO total line num: 10080
2022-10-25 14:58:20,224 INFO mismatch rate: 1.0
2022-10-25 14:58:20,224 WARNING Quanti onnx and Arm result Strict check FAILED
2022-10-25 14:58:21,571 INFO mismatch line num: 9920
2022-10-25 14:58:21,572 INFO total line num: 10080
2022-10-25 14:58:21,572 INFO mismatch rate: 0.984
2022-10-25 14:58:21,572 WARNING Quanti onnx and Sim result Strict check FAILED
2022-10-25 14:58:21,812 INFO mismatch line num: 1334
2022-10-25 14:58:21,813 INFO total line num: 10080
2022-10-25 14:58:21,813 INFO mismatch rate: 0.132
2022-10-25 14:58:21,813 WARNING Arm and Sim result Strict check FAILED
2022-10-25 14:58:21,813 INFO Result compare finish
docker中我是参考horizon_model_convert_sample/04_detection/yolov3_darknet53中的代码修改并运行的我的模型。
板端代码是修改的horizon_runtime_sample/code/00_quick_start的代码。
附件无法上传大于10m的文件,我的模型是30mb。
  • Horizon_guosheng
    你好,可以把hb_model_verifier 的日志发出来,我们进行验证
    2022-10-27
    • malakas回复Horizon_guosheng:
      2022-10-28 14:00:35,535 INFO Model Verifier Starts...
      2022-10-28 14:00:35,535 INFO verifier tool version 1.9.9
      2022-10-28 14:00:35,535 INFO PLEASE NOTE: Verifier tool only works for single input model
      2022-10-28 14:00:35,535 INFO PLEASE NOTE: Verifier tool will only check the first model output
      2022-10-28 14:00:35,697 WARNING Please note: this model has been modified, comparison results may not be correct
      2022-10-28 14:00:35,697 INFO check dnn tool version on host machine
      2022-10-28 14:00:36,057 INFO check dnn tool version on arm board
      The authenticity of host '192.168.200.10 (192.168.200.10)' can't be established.
      ECDSA key fingerprint is SHA256:8q+y1ZW0IgoK2LdZJFs/yKcbzyE5J/7gQWu58mBozgQ.
      Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
      Warning: Permanently added '192.168.200.10' (ECDSA) to the list of known hosts.
      root@192.168.200.10's password:
      2022-10-28 14:00:45,493 INFO ================== input info parsed =============================
      2022-10-28 14:00:45,493 INFO quantized onnx model: ./model_output/pp_nv12_quantized_model.onnx
      2022-10-28 14:00:45,493 INFO bin model: ./model_output/pp_nv12.bin
      2022-10-28 14:00:45,493 INFO march: bernoulli2
      2022-10-28 14:00:45,494 INFO actual input type : nv12
      2022-10-28 14:00:45,494 INFO actual input layout: NHWC
      2022-10-28 14:00:45,494 INFO model train input data type: rgb
      2022-10-28 14:00:45,494 INFO model train input data layout: NCHW
      2022-10-28 14:00:45,494 INFO input shape: ['?', 384, 640, 3]
      2022-10-28 14:00:45,494 INFO compare digits: 5
      2022-10-28 14:00:45,494 INFO ================== input info end ==========================
      2022-10-28 14:00:45,610 INFO Quanti infer starts
      2022-10-28 14:00:50,346 INFO Quanti infer finish
      2022-10-28 14:00:50,346 INFO Arm infer starts
      2022-10-28 14:00:50,404 INFO shell file generated
      2022-10-28 14:01:10,181 INFO ================== Arm infer log start ==========================
      2022-10-28 14:01:10,182 INFO + dirname /userdata/model_verifier_test/infer.sh
      + cd /userdata/model_verifier_test
      + hrt_model_exec infer --model_file=pp_nv12.bin --input_file=input.bin --enable_dump=true --dump_format=txt --dump_precision=5
      I0000 00:00:00.000000 3468 vlog_is_on.cc:197] RAW: Set VLOG level for "*" to 3
      [BPU_PLAT]BPU Platform Version(1.3.1)!
      [HBRT] set log level as 0. version = 3.14.14
      [DNN] Runtime version = 1.9.9_(3.14.14 HBRT)
      Load model to DDR cost 159.912ms.
      file length: 368640
      I1028 14:01:07.655822 3468 main.cpp:758] get model handle success
      I1028 14:01:07.656008 3468 main.cpp:764] get model input count success
      I1028 14:01:07.656612 3468 main.cpp:780] read file success!
      I1028 14:01:07.656678 3468 main.cpp:786] get model output count success
      I1028 14:01:07.656823 3468 main.cpp:792] prepare output tensor success
      I1028 14:01:07.657794 3468 main.cpp:812] infer success
      ---------------------Frame 0 begin---------------------
      I1028 14:01:07.690109 3468 main.cpp:818] task done
      Infer time: 33.195 ms
      ---------------------Frame 0 end---------------------
      I1028 14:01:10.038221 3468 main.cpp:887] Dump path: ./model_infer_input_0.txt
      I1028 14:01:10.103890 3468 main.cpp:971] Dump path: ./model_infer_output_0.txt
      2022-10-28 14:01:10,183 INFO ================== Arm infer log end ==========================
      2022-10-28 14:01:12,787 INFO Arm infer finish
      2022-10-28 14:01:12,788 INFO Sim infer starts
      2022-10-28 14:01:12,805 INFO shell file generated
      2022-10-28 14:01:18,383 INFO ================== Sim infer log start ==========================
      2022-10-28 14:01:18,384 INFO ++ dirname /data/ping/model_verifier_output/sim_model/infer.sh
      + cd /data/ping/model_verifier_output/sim_model
      I0000 00:00:00.000000 173 vlog_is_on.cc:197] RAW: Set VLOG level for "*" to 3
      core[0] open!
      core[1] open!
      Load model to DDR cost 129.673ms.
      I1028 14:01:13.106722 173 main.cpp:758] get model handle success
      I1028 14:01:13.106810 173 main.cpp:764] get model input count success
      file length: 368640
      I1028 14:01:13.107219 173 main.cpp:780] read file success!
      I1028 14:01:13.107228 173 main.cpp:786] get model output count success
      I1028 14:01:13.107270 173 main.cpp:792] prepare output tensor success
      I1028 14:01:13.107301 173 main.cpp:812] infer success
      WARNING: cnn_core_fc_avl_cap is ignored in pseudo_firmware
      I1028 14:01:17.601486 173 main.cpp:818] task done
      Infer time: 4494.19 ms
      I1028 14:01:18.355247 173 main.cpp:887] Dump path: ./model_infer_input_0.txt
      I1028 14:01:18.376161 173 main.cpp:971] Dump path: ./model_infer_output_0.txt
      2022-10-28 14:01:18,384 INFO ================== Sim infer log end ==========================
      2022-10-28 14:01:18,384 INFO Sim infer finish
      2022-10-28 14:01:18,384 INFO Result compare starts
      2022-10-28 14:01:19,794 INFO mismatch line num: 10079
      2022-10-28 14:01:19,794 INFO total line num: 10080
      2022-10-28 14:01:19,794 INFO mismatch rate: 1.0
      2022-10-28 14:01:19,794 WARNING Quanti onnx and Arm result Strict check FAILED
      2022-10-28 14:01:21,167 INFO mismatch line num: 9920
      2022-10-28 14:01:21,168 INFO total line num: 10080
      2022-10-28 14:01:21,168 INFO mismatch rate: 0.984
      2022-10-28 14:01:21,168 WARNING Quanti onnx and Sim result Strict check FAILED
      2022-10-28 14:01:21,406 INFO mismatch line num: 1348
      2022-10-28 14:01:21,407 INFO total line num: 10080
      2022-10-28 14:01:21,407 INFO mismatch rate: 0.134
      2022-10-28 14:01:21,407 WARNING Arm and Sim result Strict check FAILED
      2022-10-28 14:01:21,407 INFO Result compare finish
      2022-10-28
    • Horizon_guosheng回复malakas:
      你好,可以加我一下,扫右下角的二维码,我们check一下
      2022-11-01
