论坛算法工具链video_box的demo程序崩溃
video_box的demo程序崩溃
random2022-01-13
56
运行video_box demo时,有个致命错误导致程序崩溃
相关日志如下:
(media_pipeline.cc:86): vdec in grp:0 ret:0
(media_pipeline.cc:105): vdec out grp:0 ret:0
(media_pipeline.cc:138): vps in grp:0 ret:0
(media_pipeline.cc:146): vps out grp:0 ret:0
(convert.cc:48): vio message, frame_id = 135
(convert.cc:60): Input Frame ID = 135, Timestamp = 0
(convert.cc:78): input name:image
(runtime_monitor.cc:38): PushFrame frame_id = 135
(mot_method.cc:71): MOTMethod::DoProcess
(mot_method.cc:78): mot
(merge_method.cc:116): Head body Mode
(head_body.cc:145): Process HeadBodyStrategy output
(facesnap_filter_method.cc:102): filter mode
(snapshot_method.cc:57): SnapShotMethod::DoProcess
(snapshot_method.cc:97): Select Mode
(first_num_best.cc:45): SnapShot Mode
(first_num_best.cc:153): Post Track Size:0
(snapshot_method.cc:64): DoProcess cost(ms):0.103163
(runtime_monitor.cc:62): Pop frame 135
(runtime_monitor.cc:69): chn 0 erase:135
(rtsp_message.cc:47): call ~ImageVioMessage
(plot_smart_data.cc:230): recog fail,ch:0,track_id:22
(plot_smart_data.cc:230): recog fail,ch:0,track_id:1
(plot_smart_data.cc:230): recog fail,ch:0,track_id:20
(convert.cc:48): vio message, frame_id = 136
(convert.cc:60): Input Frame ID = 136, Timestamp = 0
(runtime_monitor.cc:38): PushFrame frame_id = 136
(first_num_best.cc:153): Post Track Size:1
(snapshot_method.cc:64): DoProcess cost(ms):0.172786
(smart_plugin.cc:278): snap_v size:1
(runtime_monitor.cc:62): Pop frame 136
(runtime_monitor.cc:69): chn 0 erase:136
(convert.cc:1102): Capture target num is 1
(convert.cc:1104): feature target num is 1
Segmentation fault (core dumped)
  • Horizon_guosheng
    您好,修改了哪些内容呢?做的具体操作是?
    2022-01-14
    • random回复Horizon_guosheng:
      没有修改任何代码。只是修改了配置文件。
      具体修改如下:
      1把video_box_config.json里的enable_recog改为了true。
      2rtsp.json里的流地址改为实际的RTSP流地址。
      3ware_config.json里的 is_recognize 改为true,
      video_box_config.json参考如下:
      "xstream_workflow_file": "./video_box/configs/body_detection.json",
      "xstream_workflow_file_pic": "./video_box/configs/recog_flow.json",
      "xstream_workflow_file_feature": "./video_box/configs/feature_flow.json",
      "enable_recog": true,
      "enable_profile": 0,
      "profile_log_path": "",
      "enable_result_to_json": false,
      "box_face_thr": 0.95,
      "box_head_thr": 0.95,
      "box_body_thr": 0.95,
      "lmk_thr": 0.0,
      "kps_thr": 0.50,
      "box_veh_thr": 0.995,
      "plot_fps": false,
      "rtsp_config_file": "./video_box/configs/rtsp.json",
      "display_config_file": "./video_box/configs/display.json",
      "drop_frame_config_file": "./video_box/configs/drop_frames.json",
      "run_smart": true
      ware_config.json修改如下:
      "is_recognize": true,
      "is_add_record": true
      2022-01-14
  • random
    有技术在吗????
    2022-01-24
  • Horizon_guosheng
    您好,recog 未开放,暂不支持识别
    2022-02-07
