论坛底层软件J3 板子,run_body.sh 如何使用ar0233——1280P摄像头,谢谢
yangqiao2021-12-28
206
root@j3dvbj3-micron4G-3200:/userdata/deploy# sh run_body.sh
Have set HORIZON_APP_PATH, and have /userdata/.horizon//ai_express_webservice_display, use it.
/userdata/deploy
rm: can't remove 'grp_id_fifo': No such file or directory
rm: can't remove 'jpu_id_fifo': No such file or directory
log_level: w
Choose lunch platform type menu...pick a combo:
1. x3 platform
2. j3 platform
Which would you like?
You choose 2:j3 platform
Choose lunch x3 vio type menu...pick a combo:
1. mipi camera
You choose 1:mipi_camera
Choose lunch camera sensor menu...pick a combo:
1. mipi camera: ov10635_yuv_720p_1pipe
2. mipi camera: ov10635_yuv_720p_4pipes
3. mipi camera: ar0233_raw12_pwl_1080p_1pipe
4. mipi camera: ar0233_raw12_pwl_1080p_5pipes
You choose 4:ar0233_raw12_pwl_1080p_5pipes
sensor is ar0233, default resolution 1080P, 1080P J3 JPEG Codec...
vio_cfg_file: ./configs/j3_video_source.json.mipi_cam
turn on mallopt
use bpu native engine
log_level = 7
(rtsp_server_plugin.cc:32): RTSP Plugin smart config file:configs/rtsp_plugin.json
(video_source.cc:286): log level has been set, log_level: 4
(video_source_produce.cc:99): log level has been set, log_level: 4
[HBRT] set log level as 0. version = 3.13.14
[BPU_PLAT]BPU Platform Version(1.3.0)!
ioctl read error, ret = -1 error = 5
keros_i2c_read failed
ioctl write error, ret = -1 error = 5
keros_i2c_write failed
[000:000] (keros_util.cpp:99): keros_authentication failed, ret = 0
[000:001] (task_scheduler.cpp:193): Keros key init failed.
[DNN] Runtime version = 1.3.2_(3.13.14 HBRT)
(inference_engine_dnn.cc:200): found model: personMultitask
(inference_engine_dnn.cc:200): found model: faceAgeGender
RTSP server use auth: 0 username: admin password 123456
Failed to create RTSP Server: bind() error (port number: 555): Address already in use
(video_source.cc:379): =========================================================
(video_source.cc:380): VideoSource VERSION: 1.0.15 Mon Nov 15 19:47:50 2021
(video_source.cc:381): =========================================================
[ERROR]["LOG"][src/hb_vin.c:44] mipi config file size is zero !!
[ERROR]["LOG"][src/hb_camera.c:405] cam hb_mipi_parse_cfg /etc/cam/hb_mipi_ar0233_raw12_%dfps_%dP_2Lane.json failed
[ERROR]["LOG"][src/hb_camera.c:559] hb_port_parse_cfg port 0 failed
[ERROR]["LOG"][src/hb_camera.c:672] cam parser configs/video_source/j3dev/vin/mipi_cam/hb_xj3dev_user.json failed
# Fatal error in /home/jenkins/workspace/ess_ai_express_component_1.0.15b/video_source/src/video_source/vin/mipi_cam/j3/mipi_cam_vin_module_vapi.cc, line 47
# last system error: 2
# Check failed: ret == 0
# hb_cam_init failed, ret: -2 cam_index: 3 cam_cfg_file: configs/video_source/j3dev/vin/mipi_cam/hb_xj3dev_user.json
==== C stack trace ===============================
1: rtc::FatalMessage::~FatalMessage()
./lib/libvideo_source_plugin.so(+0x1a40c8) [0x7f99a520c8]
./lib/libvideo_source_plugin.so(+0x1a5514) [0x7f99a53514]
./lib/libvideo_source_plugin.so(+0x1a54d8) [0x7f99a534d8]
./lib/libvideo_source_plugin.so(+0x1a539c) [0x7f99a5339c]
./lib/libvideo_source_plugin.so(+0x1a53d4) [0x7f99a533d4]
./lib/libvideo_source_plugin.so(+0x1a53f0) [0x7f99a533f0]
/lib/libpthread.so.0(+0xf9b4) [0x7f96bcd9b4]
./lib/libvideo_source_plugin.so(+0x1a3e4c) [0x7f99a51e4c]
./lib/libvideo_source_plugin.so(+0x1a5490) [0x7f99a53490]
11: videosource::J3MipiCamVinModule::Init(std::shared_ptr<videosource::JsonConfigWrapper> const&)
12: videosource::VideoSource::J3Init()
13: videosource::VideoSource::Init()
14: xproto::VideoSourceProduce::Init()
15: xproto::VideoSourcePlugin::Start()
16: main
17: __libc_start_main
./multitask_perception/multitask_perception() [0x578b20]
Aborted (core dumped)
  • Horizon_guosheng
    您好,开发者社区无法提供征程系列支持,抱歉。您可以和商务咨询下对接的同学,寻求支持
    2021-12-29
