论坛算法工具链F37正常运行solution_zoo 实例, opencv无法打开video8
xulanshuai01232021-11-20
120
# 按照b站视频的教程编写代码
#include <algorithm>
#include <iomanip>
#include <iostream>
#include <iterator>
#include <queue>
#include <utility>
#include "dnn/hb_dnn.h"
#include "gflags/gflags.h"
#include "glog/logging.h"
#include "opencv2/core/mat.hpp"
#include "opencv2/highgui.hpp"
using namespace std;
using namespace cv;
int main(){
cout << "start================================"<< endl;
//create videocpature object
VideoCapture cap;
//open the camera
cap.open(8);
//judge whether open or not
if (!cap.isOpened()){
return -1;
Mat frame;
for(int i; i<100; i++){
String name = to_string(i) + ".jpg";
cap >> frame;
if(frame.empty()){
return -1;
imwrite(name,frame);
cout << "get a image and save!" << endl;
// release the camera
cap.release();
return 0;
# read_img.sh 也是跟视频一样的代码
bin=../aarch64/bin/read_img
lib=../aarch64/lib
export LD_LIBRARY_PATH=${lib}:${LD_LIBRARY_PATH}
export BMEM_CACHEABLE=true
${bin}
但是运行显示
root@x3sdbx3-samsung2G-3200:/userdata/test/xj3/script/04_read_img# sh read_img.sh
VIDEOIO ERROR: V4L2: Unable to capture video memory.VIDEOIO ERROR: V4L: can't open camera by index 8
/dev/video8 does not support memory mapping
求助是什么原因导致的呢,
root@x3sdbx3-samsung2G-3200:/userdata/test/xj3/script/04_read_img# ls -l /dev |grep video*
crw-rw---- 1 root video 29, 0 Jan 1 08:00 fb0
crw-rw---- 1 root video 491, 0 Jan 1 08:00 iar_cdev
crw-rw---- 1 root video 490, 0 Jan 1 08:00 iar_channel_0
crw-rw---- 1 root video 490, 1 Jan 1 08:00 iar_channel_1
crw-rw---- 1 root video 490, 2 Jan 1 08:00 iar_channel_2
crw-rw---- 1 root video 490, 3 Jan 1 08:00 iar_channel_3
crw-rw---- 1 root video 81, 0 Jan 1 08:00 v4l-subdev0
crw-rw---- 1 root video 81, 1 Jan 1 08:00 v4l-subdev1
crw-rw---- 1 root video 81, 2 Jan 1 08:00 v4l-subdev2
crw-rw---- 1 root video 81, 3 Jan 1 08:00 v4l-subdev3
crw-rw---- 1 root video 81, 4 Jan 1 08:00 v4l-subdev4
crw-rw---- 1 root video 81, 5 Jan 1 08:00 video0
crw-rw---- 1 root video 81, 6 Jan 1 08:00 video1
crw-rw---- 1 root video 81, 7 Jan 1 08:00 video2
crw-rw---- 1 root video 81, 8 Jan 1 08:00 video3
crw-rw---- 1 root video 81, 9 Jan 1 08:00 video4
crw-rw---- 1 root video 81, 10 Jan 1 08:00 video5
crw-rw---- 1 root video 81, 11 Jan 1 08:00 video6
crw-rw---- 1 root video 81, 12 Jan 1 08:00 video7
crw-rw---- 1 root video 81, 13 Jan 1 08:00 video8
  • Horizon_guosheng
    opencv 调用的是usb camera
    这里使用的是f37camera
    两个不一样哈
    2021-11-22
    • casiatao回复Horizon_guosheng:
      x请问opencv可以调用F37camera吗
      2022-08-19
