论坛算法工具链yolov3_mobilenetv2_example
AI2021-11-08
250
运行solution_zoo中的yolov3_mobilenetv2_example出现了下面的问题:
fb_cfg_func::platform is x3dev
fb_cfg_func::fb_res is 1080_fb
fb_cfg_func::vio_cfg_file is ./configs/x3_video_source.json.rtsp
sh: write error: No such device
/usr/bin/adbd is not runnning
Detecting platform:
board : Hobot XJ3 SOC SDB
udc : b2000000.dwc3
usb-gadget is already running
after start uvc
resolution 1080P feedback start, 1080P X3 JPEG Codec...
vio_cfg_file: ./configs/x3_video_source.json.rtsp
(vps_manager.cc:369): create vps manager fifo success, this is main process
(vps_manager.cc:430): write input group id to fifo success, write_bytes_num: 32 fifo_fd: 5
(video_source_produce.cc:99): log level has been set, log_level: 4
[HBRT] set log level as 0. version = 3.13.11
[BPU_PLAT]BPU Platform Version(1.3.0)!
[DNN] Runtime version = 1.1.4_(3.13.11 HBRT)
[HorizonRT] The model builder version = 1.3.38
(inference_engine_dnn.cc:84): found model: yolov3_416x416_nv12
[HorizonRT] The model builder version = 1.1.35
(inference_engine_dnn.cc:84): found model: MOBILENET_V2_hybrid
(video_source.cc:308): =========================================================
(video_source.cc:309): VideoSource VERSION: 1.0.13 Sun Sep 26 17:02:41 2021
(video_source.cc:310): =========================================================
[rtsp @ 0x7f78000e60] decoding for stream 0 failed
(rtsp_client_vin_module.cc:222): ffmpeg init success, cost_time: 278ms
(rtsp_client_vin_module.cc:397): connect rtsp link success, try_time: 0 max_try_limit_time: 20
(vin_module.cc:1253): enter update vin module: 32 vin_buf_cfg format: 32 vin_sync_state: 0 channel_id: 0
ion allocator open success m_ionClient :16 !
(vin_module.cc:337): vin buffer queue init success, cost_time: 11ms
(decode_manager.cc:178): mkfifo vpu_id_fifo cost_time: 0ms
mkfifo decode manager: File exists
(decode_manager.cc:196): create decoder manager fifo failed, ret: -1 fifo maybe has been created
read vpu fifo: Resource temporarily unavailable
(decode_manager.cc:201): try test fifo failed, ret: -1
(decode_manager.cc:189): create decode manager, input_fifo_name: vpu_id_fifo success, this is main process
(decode_manager.cc:426): get decode_chn: 0 from vpu_id_fifo success...
(decode_module.cc:184): stream buffer init success, cost_time: 14ms
(vin_module.cc:1268): update init vinmodule success, cost_time: 31ms new vin image width: 1280 new vin image height: 720
(vin_module.cc:517): find key frame, drop frame in encode_queue before IDR frame
(video_source.cc:424): start dynamic load vps module, chn_id: 0
(vps_module_hapi.cc:1250): ipu output disable, ipu_chn_num: 0 group_id: 0
(video_source.cc:445): update vpsmodule success, cost_time: 238ms image width from: 0 to 1280 image height from: 0 to 720
(video_source_produce.cc:534): Push Drop Image message, chn_id: 0 frame_id: 10
(video_source_produce.cc:534): Push Drop Image message, chn_id: 0 frame_id: 11
(video_source_produce.cc:534): Push Drop Image message, chn_id: 0 frame_id: 12
(video_source_produce.cc:534): Push Drop Image message, chn_id: 0 frame_id: 13
(video_source_produce.cc:534): Push Drop Image message, chn_id: 0 frame_id: 14
Segmentation fault (core dumped)
  • admin
    您好,您的具体操作流程是?
    2021-11-08
    • AI回复admin:
      我使用自己训练的口罩识别的模型对rtsp流进行识别时出现了这个问题
      2021-11-09
    • admin回复AI:
      使用自带的模型是否可以正确识别呢?
      2021-11-09
    • AI回复admin:
      自带的模型是可以的
      2021-11-09
    • Horizon_guosheng回复AI:
      模型转化的时候应该是一些配置没有同步,可以使用板端自带的工具进行查验
      2021-11-10
