论坛算法工具链03_classification/01_mobilenet上板运行报错
hope2021-08-26
140
horizon_x3_tc_1.1.19e/samples/03_classification/01_mobilenet上板运行报错,打印信息如下:
root@x3sdbx3-samsung2G-3200:/userdata/samples/mobilenetv1_224x224_nv12# sh dev_board_01_infer.sh
./release/bin/example --model_file=./mobilenetv1_224x224_nv12.bin --model_name=mobilenetv1_224x224_nv12 --input_type=image --input_config_string={"image_list_file":"image_list.txt","width":224,"height":224,"data_type":2} --output_type=image --output_config_string={"image_output_dir":"image_out"} --core_num=1 --post_process_config_string={"score_threshold":0} --enable_post_process=true
[1970-01-01 08:13:13 INFO 547961933840 hr_api.cpp:466] HorizonRT version = 1.1.43
[1970-01-01 08:13:13 INFO 547961933840 hr_api.cpp:471] hbrt version = 3.9.9
[HBRT] set log level as 0. version = 3.9.9
[BPU_PLAT]Makesure BPU Core Opened!!!)
[BPU_PLAT]BPU Platform Version(1.2.1)!
[ 793.874074] module id: 4, event id: 1 register err[had registed]
[BPU_PLAT]Makesure BPU Core(1) Opened!!!
[ 793.878785] module id: 4, event id: 2 register err[had registed]
[HorizonRT] The model builder version = 1.3.28
[HorizonRT] Hybrid model hbm_hbrt_version = 3.13.4
I0101 08:13:13.910814 1587 simple_example.cc:74] Model info:Input num:1, input[0]: name:data, data type:BPU_TYPE_IMG_YUV_NV12, shape:(1,3,224,224,), layout:BPU_LAYOUT_NCHW, aligned shape:(1,4,224,224,), layout:BPU_LAYOUT_NCHW, Output num:1, output[0]: name:prob, op:1, data type:BPU_TYPE_TENSOR_F32, shape:(1,1000,1,1,), layout:BPU_LAYOUT_NCHW, aligned shape:(1,1000,1,1,), layout:BPU_LAYOUT_NCHW
E0101 08:13:13.911426 1587 post_process.cc:85] unspport model type:mobilenetv1_224x224_nv12
Segmentation fault (core dumped)
  • admin
    地平线入门教程(四)docke环境使用与demo运行示例
    https://www.bilibili.com/video/BV1HA411c79s/
    21min开始有该处报错的讲解
    2021-08-26
    • hope回复admin:
      Horizon Robotic System Ver:X3SDB_0309_version release x3sdbx3-samsung2G-3200 /dev/ttyS0
      x3sdbx3-samsung2G-3200 login: root
      root@x3sdbx3-samsung2G-3200:~# ls
      root@x3sdbx3-samsung2G-3200:~# cd /userdata/
      root@x3sdbx3-samsung2G-3200:/userdata# ls
      F37_lib cache deploy log lost+found output sample samples samples_r warehouse.db ws_test
      root@x3sdbx3-samsung2G-3200:/userdata# cd samples
      root@x3sdbx3-samsung2G-3200:/userdata/samples# ls
      lenet_data lenet_gray mobilenetv1_224x224_nv12 test_data
      root@x3sdbx3-samsung2G-3200:/userdata/samples# cd mobilenetv1_224x224_nv12/
      root@x3sdbx3-samsung2G-3200:/userdata/samples/mobilenetv1_224x224_nv12# ls
      dev_board_01_infer.sh dev_board_03_perf.sh env.conf image_out release
      dev_board_02_eval.sh dev_board_kill.sh image_list.txt mobilenetv1_224x224_nv12.bin
      我的路径下是有模型的。
      2021-08-27
    • Horizon_guosheng回复hope:
      报错显示模型类别不对,可以把您的原模型与量化模型发给我们测试下,微信即可
      2021-08-29
