论坛算法工具链关于x3开发板使用usb摄像头报错的问题
skynetAI2021-04-12
262
使用x3开发板,然后使用了usb摄像头,运行之后,出现如下的错误,同时已经运行了 /sys/class/video4linux/ -all
Error opening device /dev/video0: neither video capture nor video output supported.
(vioproduce.cpp:2008): camer_open /dev/video0 failed, try to open /dev/video0
##function camera_open in
(vioproduce.cpp:2012): camer_open /dev/video0 failed, try to open /dev/video8
Error opening device /dev/video8: 2.
(vioproduce.cpp:2019): camera_open failed
# Fatal error in /home/hyl/hyl-disk/horizon_x3/AI-EXPRESS/source/solution_zoo/common/xproto_plugins/iotvioplugin/src/vioplugin/vioproduce.cpp, line 1778
# last system error: 9
# Check failed: InitUvc(dev_name) >= 0
==== C stack trace ===============================
1: rtc::FatalMessage::~FatalMessage()
2: horizon::vision::xproto::vioplugin::UsbCam::Run()
3: horizon::vision::xproto::vioplugin::Executor::Run()
/usr/lib/libstdc++.so.6(+0xb922c) [0x7fad07322c]
/lib/libpthread.so.0(+0x78e4) [0x7fad44b8e4]
[ 1222.165301] [S0] ipu last process close disable channels
[ 1222.166054] [S1] ipu last process close disable channels
[ 1222.166745] [S2] ipu last process close disable channels
[ 1222.167434] [S3] ipu last process close disable channels
Aborted (core dumped)
以下是经过验证的了。
1、从github上同步的AIexpress,重新编译下载,跑feedback例程可以的。
2、跑外接usb摄像头失败。
请问是哪里问题呢。
