论坛算法工具链定点模型上板测试
定点模型上板测试
wangning2020-12-08
129
定点模型上板测试 第一步
运行 sh 01_build.sh 出现错误
-- The C compiler identification is GNU 6.5.0
-- The CXX compiler identification is GNU 6.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Build for platform arm
-- LINARO_GCC Tool Chain: /usr/bin/gcc
-- Build type: Release
-- Configuring done
-- Generating done
-- Build files have been written to: /data/x3/x3_tc_1.1.17e/x3-toolchain-1.1.17e.tar/horizon_x3_tc_1.1.17e/samples/02_runtime_src/build_arm_lenet_gray
Scanning dependencies of target common
[ 10%] Building CXX object 3_common/CMakeFiles/common.dir/protocol/meta.pb.cc.o
[ 10%] Building CXX object 3_common/CMakeFiles/common.dir/protocol/zmq_msg.pb.cc.o
[ 10%] Building CXX object 3_common/CMakeFiles/common.dir/protocol/common.pb.cc.o
[ 10%] Building CXX object 3_common/CMakeFiles/common.dir/protocol/meta_data.pb.cc.o
[ 12%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/classification_post_process.cc.o
[ 17%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/rfcn_post_process.cc.o
[ 17%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/s3fd_post_process.cc.o
[ 20%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/post_process.cc.o
[ 23%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/fasterrcnn_post_process.cc.o
/bin/sh: /usr/bin/gcc/bin/aarch64-linux-gnu-g++: Not a directory
3_common/CMakeFiles/common.dir/build.make:140: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/fasterrcnn_post_process.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/fasterrcnn_post_process.cc.o] Error 126
make[2]: *** Waiting for unfinished jobs....
3_common/CMakeFiles/common.dir/build.make:88: recipe for target '3_common/CMakeFiles/common.dir/protocol/meta_data.pb.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/protocol/meta_data.pb.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:114: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/post_process.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/post_process.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:62: recipe for target '3_common/CMakeFiles/common.dir/protocol/zmq_msg.pb.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/protocol/zmq_msg.pb.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:75: recipe for target '3_common/CMakeFiles/common.dir/protocol/meta.pb.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/protocol/meta.pb.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:166: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/s3fd_post_process.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/s3fd_post_process.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:153: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/rfcn_post_process.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/rfcn_post_process.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:101: recipe for target '3_common/CMakeFiles/common.dir/protocol/common.pb.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/protocol/common.pb.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:127: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/classification_post_process.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/classification_post_process.cc.o] Error 126
[ 25%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/segment_post_process.cc.o
[ 28%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/ssd_post_process.cc.o
3_common/CMakeFiles/common.dir/build.make:179: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/segment_post_process.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/segment_post_process.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:192: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/ssd_post_process.cc.o' failed
[ 30%] Building CXX object 3_common/CMakeFiles/common.dir/src/post_process/yolo2_post_process.cc.o
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/ssd_post_process.cc.o] Error 126
3_common/CMakeFiles/common.dir/build.make:205: recipe for target '3_common/CMakeFiles/common.dir/src/post_process/yolo2_post_process.cc.o' failed
make[2]: *** [3_common/CMakeFiles/common.dir/src/post_process/yolo2_post_process.cc.o] Error 126
CMakeFiles/Makefile2:90: recipe for target '3_common/CMakeFiles/common.dir/all' failed
make[1]: *** [3_common/CMakeFiles/common.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
[ 2%] Building CXX object 3_common/CMakeFiles/common.dir/protocol/zmq_msg.pb.cc.o
  • bin.fei
    您好,根据编译的log提示错误信息:
    如果您使用的是本地交叉编译工具链可以尝试软链接到/usr/bin/gcc/下试试。
    2020-12-08
