论坛算法工具链优化过程中多个softmax被转换成同一个名称了
liuyang2020-10-23
179
2020-10-23 14:29:02,996 INFO Start hb_mapper....
2020-10-23 14:29:02,997 INFO hb_mapper version 1.1.19
2020-10-23 14:29:03,202 INFO Start Model Convert....
2020-10-23 14:29:03,259 INFO Parsing the calibration parameter
2020-10-23 14:29:03,273 INFO HorizonNN version: 0.7.3
2020-10-23 14:29:03,273 INFO HBDK version: 3.12.3
2020-10-23 14:29:03,273 INFO Start to convert the caffe model.
2020-10-23 14:29:04,986 INFO The caffe model was converted successfully.
2020-10-23 14:29:05,860 INFO Saving the original float model: lenet_gray_original_float_model.onnx.
2020-10-23 14:29:05,860 INFO Start to optimize the model.
2020-10-23 14:29:06,248 INFO The model was optimized successfully.
2020-10-23 14:29:06,768 INFO Saving the optimized model: lenet_gray_optimized_float_model.onnx.
2020-10-23 14:29:06,769 INFO Start to calibrate the model.
2020-10-23 14:29:06,943 INFO Run calibration model with kl method.
2020-10-23 14:29:07,537 ERROR [ONNXRuntimeError] : 1 : FAIL : This is an invalid model. Error: two nodes with same node name (_hzsoftmax).
  • liuyang
    链接: https://pan.baidu.com/s/1-aZ5rEdClPlaZGaNKRvXJw 提取码: 7kgv
    以上是复现问题的caffe model和配置文件,请查收
    2020-10-23
    • anming回复liuyang:
      好的,正在排查
      2020-10-23
    • anming回复liuyang:
      你好,这个问题会在后续工具链版本修复
      2020-10-23
    • liuyang回复anming:
      下一个版本大概什么时候能出来?
      2020-10-26
