论坛底层软件J6摄像头点亮解串器初始化配置提示无权限
进击白加黑2025-03-07
92
【问题】J6开发板,点亮摄像头sample程序,解串器初始化时io操作提示“Operation not permitted”
【信息】
摄像头型号:ox8B40 (海康)
串行器:MAX96717
【log】
打印信息如下(详见log.txt文件):
[22487.173828][deserial_dev]:[camera_deserial_dev_info_init][288] deserial0 max96712 i2c0@0x29 dev info init
[22487.173828][camera_vpf]:[camera_vpf_vin_get_gpio][981] gpio des_pwdn get as gpio424 level 0 [22487.173828][deserial_dev]:[camera_deserial_dev_ioctl][238] deserial0 max96712 ioctl DESERIAL_DATA_INIT 0xffff93d1e320 ret -1: Operation not permitted
[22487.173828][deserial_dev]:[camera_deserial_dev_info_init][365] deserial0 max96712 DESERIAL_DATA_INIT error -1
[22487.173828][deserial_lib]:[camera_deserial_init][1162] deserial0 max96712 dev info init error -65671
[22487.173828][camera_i2c]:[camera_i2c_deinit][282] i2c0 deinit as fd 28
[22487.173828][deserial_dev]:[camera_deserial_dev_close][163] close /dev/deserial_0 max96712 as 27
[22487.173828][camera_run]:[camera_attach_deserial_to_vin][2818] deserial0 max96712 init error -65671
[22487.173828][camera_diag_gpioe]:[diag_gpioe_deinit][362] sub_thid 0x0, thread_id 0x0
i2cdet查询信息如下:
[驱动log]见附件dmesg_log.txt
    驱动日志有没有
    2025-03-07
    • 进击白加黑回复费小财:
      您好!请教一下,如何获取驱动日志呢
      2025-03-07
    • 费小财回复进击白加黑:
      dmesg -w
      2025-03-07
    • 进击白加黑回复费小财:
      感谢!补充了驱动日志
      2025-03-07
    [ 36.144177] [E|DES|hobot_deserial_ops.c+1738]:[DESERIAL0]: ioctl cmd 0x42687300 is err
    你的测试脚本跟你的版本不匹配
    2025-03-07
    您好:目前这个报错信息来看,可能是上层用的库(libcam等)与底层驱动(hobot_deserial)的版本不匹配导致,是否调试时替换了上层库操作? 可以检查一下当前的系统版本及当前调试用的SDK版本,确认一下:cat /etc/version
    2025-03-10
  • 小助手
