论坛算法工具链J5,BEV_lss,nuscenes数据准备 ,训练求助
L2025-03-26
103
2.天工开物开发包OpenExplorer版本:horizon_j5_open_explorer_v1.1.62-py38_20230802
3.问题定位:bev_mt_lss模型训练出现错误KeyError: 'ego2global_translation'(python3 tools/train.py --config configs/bev/bev_mt_lss_efficientnetb0_nuscenes.py --stage float)
4.问题具体描述:训练BEV时,报TypeError: 'NoneType' object is not subscriptable,这是因为什么?具体log训练日志在附件。
数据路径:
数据路径:
具体报错:`aidisdk` dependency is not available.
2025-03-26 16:22:06,591 ERROR [ddp_trainer.py:463] Node[3] Traceback (most recent call last):
File "/usr/local/lib/python3.8/dist-packages/hat/engine/ddp_trainer.py", line 457, in _with_exception
fn(*args)
File "/xyma/horizon_j5/ddk/samples/ai_toolchain/horizon_model_train_sample/scripts/tools/train.py", line 186, in train_entrance
trainer.fit()
File "/usr/local/lib/python3.8/dist-packages/hat/engine/loop_base.py", line 537, in fit
_, batch = next(self.data_loader_pr)
File "/usr/local/lib/python3.8/dist-packages/hat/profiler/profilers.py", line 223, in profile_iterable
value = next(iterator)
File "/usr/local/lib/python3.8/dist-packages/hat/utils/generator.py", line 15, in prefetch_iterator
last = next(it)
File "/usr/local/lib/python3.8/dist-packages/torch/utils/data/dataloader.py", line 628, in __next__
data = self._next_data()
File "/usr/local/lib/python3.8/dist-packages/torch/utils/data/dataloader.py", line 1333, in _next_data
return self._process_data(data)
File "/usr/local/lib/python3.8/dist-packages/torch/utils/data/dataloader.py", line 1359, in _process_data
data.reraise()
File "/usr/local/lib/python3.8/dist-packages/torch/_utils.py", line 543, in reraise
raise exception
TypeError: Caught TypeError in DataLoader worker process 0.
Original Traceback (most recent call last):
File "/usr/local/lib/python3.8/dist-packages/torch/utils/data/_utils/worker.py", line 302, in _worker_loop
data = fetcher.fetch(index)
File "/usr/local/lib/python3.8/dist-packages/torch/utils/data/_utils/fetch.py", line 58, in fetch
data = [self.dataset[idx] for idx in possibly_batched_index]
File "/usr/local/lib/python3.8/dist-packages/torch/utils/data/_utils/fetch.py", line 58, in <listcomp>
File "/usr/local/lib/python3.8/dist-packages/hat/data/datasets/nuscenes_dataset.py", line 1587, in __getitem__
data = self.sampler(sample)
File "/usr/local/lib/python3.8/dist-packages/hat/data/datasets/nuscenes_dataset.py", line 1716, in __call__
self._get_map_info(sample)
File "/usr/local/lib/python3.8/dist-packages/hat/data/datasets/nuscenes_dataset.py", line 1685, in _get_map_info
sample["location"],
    看日志,环境有问题, aidisdk 也未识别到,你这个之前可以跑吗
    2025-03-31
    • L回复费小财:
      您好,不可以跑,我的环境是直接下载的官方docker镜像
      2025-03-31
    • L:
      不过可以正常生成 .hbm文件 ,
      2025-03-31
    • 费小财回复L:
      那你的这个不是通过官方的docker了?
      2025-03-31
    • L回复费小财:
      是呢,是官方下载的docker
      2025-03-31
    • HuangHui回复L:
      是否能够安装aidisdk呢
      2025-04-03
    • L回复HuangHui:
      并不能,不过这个似乎无关紧要
      2025-04-07
    • 费小财回复L:
      那现在都跑起来了吗,还是有其他的问题的
      2025-04-11
    2025-07-09
