论坛算法工具链RDKX5用grid_sample在检查模型时报错
z2025-07-21
198
48
用的是RDKX5,具体使用代码是
grid = self.normgrid(pos, H, W).unsqueeze(-2).to(x.dtype)
x = F.grid_sample(x, grid, mode = self.mode , align_corners = False)
这里我把输入的x输出了,输出大小是
torch.Size([1, 1, 288, 384])
torch.Size([1, 1, 36, 48])
torch.Size([1, 64, 36, 48])
值都正常,但是在运行01_check.sh报错如下
2025-07-21 09:57:27,466 INFO log will be stored in /open_explorer/xfeat/hb_mapper_checker.log
2025-07-21 09:57:27,466 INFO Start hb_mapper…
2025-07-21 09:57:27,466 INFO hbdk version 3.49.15
2025-07-21 09:57:27,466 INFO horizon_nn version 1.1.0
2025-07-21 09:57:27,466 INFO hb_mapper version 1.24.3
2025-07-21 09:57:27,480 INFO Model type: onnx
2025-07-21 09:57:27,480 INFO input names
2025-07-21 09:57:27,480 INFO input shapes {}
2025-07-21 09:57:27,480 INFO Begin model checking…
2025-07-21 09:57:27,491 INFO Start to Horizon NN Model Convert.
2025-07-21 09:57:27,570 INFO Loading horizon_nn debug methods:set()
2025-07-21 09:57:27,571 INFO The activation calibration parameters:
calibration_type: fixed
2025-07-21 09:57:27,571 INFO The specified model compilation architecture: bayes-e.
2025-07-21 09:57:27,571 INFO The specified model compilation optimization parameters: .
2025-07-21 09:57:27,572 INFO Start to prepare the onnx model.
2025-07-21 09:57:27,600 INFO Input ONNX Model Information:
ONNX IR version: 6
Opset version: [‘ai.onnx v11’, ‘horizon v1’]
Producer: pytorch v1.13.0
Domain: None
Version: None
Graph input:
image0: shape=[1, 3, 300, 400], dtype=FLOAT32
image1: shape=[1, 3, 300, 400], dtype=FLOAT32
Graph output:
mkpts0: shape=[‘num_keypoints’, ‘Gathermkpts0_dim_1’], dtype=FLOAT32
mkpts1: shape=[‘num_keypoints’, ‘Gathermkpts1_dim_1’], dtype=FLOAT32
2025-07-21 09:57:27,600 INFO Modify argmax output element type from int32 to int64 to make sure this onnx model will be valid.
2025-07-21 09:57:27,735 INFO End to prepare the onnx model.
2025-07-21 09:57:27,766 INFO Saving model to: ./.hb_check/original_float_model.onnx.
2025-07-21 09:57:27,766 INFO Start to optimize the onnx model.
2025-07-21 09:57:28,828 INFO End to optimize the onnx model.
2025-07-21 09:57:28,853 INFO Saving model to: ./.hb_check/optimized_float_model.onnx.
2025-07-21 09:57:28,853 INFO Start to calibrate the model.
2025-07-21 09:57:28,994 WARNING The input0 of Node(name:/GridSample_1, type:GridSample) does not support data type: int16
2025-07-21 09:57:28,995 WARNING The input0 of Node(name:/interpolator/GridSample, type:GridSample) does not support data type: int16
2025-07-21 09:57:28,995 WARNING The input0 of Node(name:/GridSample_3, type:GridSample) does not support data type: int16
2025-07-21 09:57:28,996 WARNING The input0 of Node(name:/interpolator_1/GridSample, type:GridSample) does not support data type: int16
2025-07-21 09:57:28,996 WARNING The output of Node(name:/net/heatmap_head/heatmap_head.3/Sigmoid) is int16, then requantized to int8
2025-07-21 09:57:28,996 WARNING The output of Node(name:/Div_mul) is int16, then requantized to int8
2025-07-21 09:57:28,997 INFO There are 1 samples in the data set.
2025-07-21 09:57:28,997 INFO Run calibration model with fixed thresholds method.
Layer /GridSample
/GridSample layer, feature size in axis 1 should in range [1, 4096]. But given size 4294967295
Layer /GridSample_1
/GridSample_1 layer, feature size in axis 1 should in range [1, 4096]. But given size 4294967295
2025-07-21 09:57:29,073 WARNING The output of Node(name:/net/heatmap_head/heatmap_head.3_1/Sigmoid) is int16, then requantized to int8
2025-07-21 09:57:29,073 WARNING The output of Node(name:/Div_3_mul) is int16, then requantized to int8
2025-07-21 09:57:29,077 ERROR *** ERROR-OCCUR-DURING {horizon_nn.build_onnx} ***, error message: ERROR: The size of specified_perm is different with input dim
The error model has been saved as complement_calibration_node_for_graph_input_pass_fail.onnx
2025-07-21 09:57:29,077 INFO End to calibrate the model.
2025-07-21 09:57:29,078 INFO End to Horizon NN Model Convert.
这个怎么解决?是量化到整形时溢出之类的吗,这个4294967295,值超大了
技术深度解析
  • z
    在netron可视化里发现出现了unk,会是这个导致的吗,unk是啥意思,
    2025-07-21
    你好,根据报错来看可能是动态 shape 未被正确解析。
    2025-07-21
    • z回复HuangHui:
      我shape是固定的呀
      2025-07-21
    • z:
      这里三个输出是因为调用了三次插值
      2025-07-21
    • HuangHui回复z:
      要不你把模型与导出onnx的代码 发过来看看,这里光看这些也看不出来啥
      2025-07-21
    你尝试下使用tracing 导出 ONNX ,
    2025-07-21
    • z回复HuangHui:
      我用的是horizon的导出
      export_onnx(xfeat, (image0, image1), output_path,verbose=False, opset_version=11,do_constant_folding=True,input_names=["image0", "image1"],output_names=["mkpts0", "mkpts1"],dynamic_axes=dynamic_axes,)
      2025-07-21
    • z:
      torch的导出不了11版本的gird sample
      2025-07-21
    • HuangHui回复z:
      的用地平线的导出onnx工具导出
      2025-07-21
    • z回复HuangHui:
      嗯嗯我用的就是啊
      2025-07-21
    • HuangHui回复z:
      我记得上周给过那个解决方案呀,没导出成功吗/
      2025-07-21
    • z:
      dynamic_axes是false
      2025-07-21
    • z回复HuangHui:
      导出成功了,检查报错
      2025-07-21
    • HuangHui回复z:
      就是报的这个错吗
      2025-07-21
    • z回复z:
      Layer /GridSample /GridSample layer, feature size in axis 1 should in range [1, 4096]. But given size 4294967295 /GridSample layer, feature size in axis 1 should in range [1, 4096]. But given size 4294967295 Layer /GridSample_1 /GridSample_1 layer, feature size in axis 1 should in range [1, 4096]. But given size 4294967295 /GridSample_1 layer, feature size in axis 1 should in range [1, 4096]. But given size 4294967295 2025-07-21 11:07:45,462 ERROR *** ERROR-OCCUR-DURING {horizon_nn.build_onnx} ***, error message: ERROR: The size of specified_perm is different with input dim
      一直找不到这个报错原因
      2025-07-21
    • z回复HuangHui:
      对的
      2025-07-21
    • HuangHui回复z:
      要不你把导出代码跟原始模型发出来吧 ,我去验证下
      2025-07-21
    • HuangHui:
      这里不实验下,也找不到原因
      2025-07-21
    • z回复HuangHui:
      好的,稍等
      2025-07-21
    • z回复HuangHui:
      【快传】我给你发了 rdk, 快来看看 https://www.alipan.com/t/APCbyIOp5bTJ8u7tfWl7 点击链接即可保存。「阿里云盘」APP ,无需下载极速在线查看,视频原画倍速播放。
      这里麻烦了=看下
      2025-07-21
    • HuangHui回复z:
      这个不能添加附件吗?
      2025-07-21
    • z回复HuangHui:
      有好几个文件,直接传附件不好组织,我重新组织下再传附件?
      2025-07-21
    • z回复HuangHui:
      可以加,但最多3个,文件超3个人
      2025-07-21
    • z回复HuangHui:
      百度网盘方便吗?
      2025-07-21
    • HuangHui回复z:
      下载挺慢要会员
      2025-07-21
    • HuangHui回复z:
      发帖时候不能添加附件吗
      2025-07-21
    • z回复HuangHui:
      可以了,我发了压缩文件
      2025-07-21
    • z回复HuangHui:
      有看到我上传的附件吗
      2025-07-21
    • HuangHui回复z:
      没有呀 ,
      2025-07-21
    • z回复HuangHui:
      添加不上去呀,试好几次了
      2025-07-21
    • HuangHui回复z:
      那还是百度网盘吧
      2025-07-21
    • z回复HuangHui:
      好的,在这,通过网盘分享的文件:test 链接: https://pan.baidu.com/s/1irPA6NKkdrRqyLjLOzbdzA?pwd=g24g 提取码: g24g
      2025-07-21
    • HuangHui回复z:
      哪个onnx模型是你生成出来下一步要用的?
      2025-07-21
    • z回复HuangHui:
      xfeat_e2e_300x400_sim.onnx
      2025-07-21
    • z:
      这是 xfeat_e2e_300x400.onnx用了onnxsim import simplify简化后的,这两个都可以
      2025-07-21
    • z回复HuangHui:
      这个报错是因为onnx里有if算子,我把所有if算子去掉后能进一步执行了,但是又遇到了girdsample相关的错误了
      2025-07-21 15:00:59,706 ERROR {/Where_1} unsupported broadcast mode. 2025-07-21 15:00:59,711 ERROR *** ERROR-OCCUR-DURING {runtime.runtime_model_generation} ***, error message: HorizonRT not support these cpu operators: GridSample NonZero
      2025-07-21
    • HuangHui回复z:
      我这边hb_compile没跑通
      2025-07-21
    • HuangHui回复z:
      要不再找一找有没有替代方案?
      2025-07-21
    • z回复HuangHui:
      什么的替换方案啊?
      2025-07-21
    • HuangHui回复z:
      gridsample算子
      2025-07-21
    • HuangHui回复z:
      你好,这个为题定位到了 ,目前平台不支持NoZero算子,要改这个算子的
      2025-07-21
    • HuangHui回复z:
      2025-07-21
    • HuangHui回复z:
      你看下能不能把NonZero那里的维度给固定下来
      2025-07-21
    • z回复HuangHui:
      好嘞
      2025-07-21
    • z回复z:
      我怎么换都有nonzero咋办,改成torch,where也有,是具体用了什么操作onnx就会导出nonzero呢
      2025-07-21
    • z回复HuangHui:
      你们有解决过nonzero去除的问题吗,我怎么改都去不掉啊
      2025-07-22
    • HuangHui回复z:
      2025-07-22
    • HuangHui回复z:
      你试试用masked_fill
      2025-07-22
