论坛算法工具链bev_sparse_det_maptr_flashocc_henet_tinym_nuscenes导出onnx文件报错
加利福尼亚不下雨2026-04-01
293
File "/open_explorer/samples/ai_toolchain/horizon_model_train_sample/scripts/shell/bev/../../tools/export_onnx.py", line 44, in <module>
cfg = Config.fromfile(args.config)
File "/usr/local/lib/python3.10/dist-packages/hat/utils/config.py", line 76, in fromfile
mod = import_module(module_name)
File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
return bootstrap.gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in gcdimport
File "<frozen importlib._bootstrap>", line 1027, in findand_load
File "<frozen importlib._bootstrap>", line 1006, in findand_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in loadunlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in callwith_frames_removed
File "/open_explorer/samples/ai_toolchain/horizon_model_train_sample/scripts/configs/bev/bev_sparse_det_maptr_flashocc_henet_tinym_nuscenes.py", line 928, in <module>
sensitive_table = load_ckpt(os.path.join(table_dir, k))
File "/open_explorer/samples/ai_toolchain/horizon_model_train_sample/scripts/configs/bev/bev_sparse_det_maptr_flashocc_henet_tinym_nuscenes.py", line 912, in load_ckpt
ckpt = torch.load(ckpt, map_location="cpu", weights_only=False)
File "/usr/local/lib/python3.10/dist-packages/torch/serialization.py", line 1425, in load
with openfile_like(f, "rb") as opened_file:
File "/usr/local/lib/python3.10/dist-packages/torch/serialization.py", line 751, in openfile_like
return openfile(name_or_buffer, mode)
File "/usr/local/lib/python3.10/dist-packages/torch/serialization.py", line 732, in init
super().__init__(open(name, mode))
FileNotFoundError: [Errno 2] No such file or directory: './tmp_models/bev_sparse_det_maptr_flashocc_henet_tinym_nuscenes/quant_analysis/output_det.classification_L1_sensitive_ops.pt'
