论坛算法工具链bev_sparse_henet_tinym_nuscenes 工程文件缺失
加利福尼亚不下雨2026-04-13
111
运行上述代码,报错:
File "/open_explorer/samples/ai_toolchain/horizon_model_train_sample/scripts/shell/bev/bev_sparse_henet_tinym_nuscenes/../../../tools/calops.py", line 91, in <module>
total_ops, total_params = calops(
File "/open_explorer/samples/ai_toolchain/horizon_model_train_sample/scripts/shell/bev/bev_sparse_henet_tinym_nuscenes/../../../tools/calops.py", line 67, in calops
model = build_from_registry(model_cfg)
File "/usr/local/lib/python3.10/dist-packages/hat/registry.py", line 412, in build_from_registry
return _impl(x)
File "/usr/local/lib/python3.10/dist-packages/hat/registry.py", line 370, in _impl
build_x = dict(((key, _impl(value)) for key, value in x.items())) # noqa
File "/usr/local/lib/python3.10/dist-packages/hat/registry.py", line 370, in <genexpr>
File "/usr/local/lib/python3.10/dist-packages/hat/registry.py", line 397, in _impl
obj = build_from_cfg(OBJECT_REGISTRY, x)
File "/usr/local/lib/python3.10/dist-packages/hat/registry.py", line 248, in build_from_cfg
instance = obj_cls(**cfg)
File "/usr/local/lib/python3.10/dist-packages/hat/models/task_modules/sparsebevoe/memory_bank.py", line 40, in init
super(MemoryBankOE, self).__init__(**kwargs)
File "/usr/local/lib/python3.10/dist-packages/hat/models/task_modules/sparsebevoe/instance_bank.py", line 90, in init
anchor = np.load(anchor)
File "/usr/local/lib/python3.10/dist-packages/numpy/lib/npyio.py", line 390, in load
fid = stack.enter_context(open(os_fspath(file), "rb"))
FileNotFoundError: [Errno 2] No such file or directory: './tmp_data/nuscenes/nuscenes_kmeans900.npy'
下载的文件包里面没有这个:nuscenes_kmeans900.npy
    • 加利福尼亚不下雨回复HuangHui:
      FileNotFoundError: [Errno 2] No such file or directory: './tmp_orig_data/nuscenes/kmeans_map_100.npy'
      这个也没有
      2026-04-13
    • HuangHui回复加利福尼亚不下雨:
      收到,确实看了一下FTP上也没有这个文件,我先确认一下是否发布的是否漏掉了这个文件哈,稍后给您答复哈
      2026-04-13
  • little fish
  • zyhang
    您好,鉴于长时间未收到你的答复,我们暂将该问题做关闭处理,如您仍有相同问题,请在新的帖子中重新发起提问,祝您工作愉快!
    2026-05-07
