芯片型号:J6m
开发包:3.8.1-py310_20260326
测试了12个小时一直没有导出,内存没有变化
2026-04-29 16:05:36,844 INFO {'type': 'HbirCompiler', 'march': 'nash-m', 'opt': 0, 'jobs': 144, 'debug': False, 'max_time_per_fc': 0.0, 'only_export': False, 'out_path': './lidar_data/ztao/port_train/pointpillars_5class_swmotion_v4/compile/model.hbm', 'progress_bar': True, 'advice': 1000000, 'input_source': ['ddr'], 'transpose_dim': defaultdict(<class 'dict'>, {}), 'split_dim': defaultdict(<class 'dict'>, {}), 'layer_details': False, 'hbdk3_compatible_mode': False, 'enable_vpu': True, 'model_path': './lidar_data/ztao/port_train/pointpillars_5class_swmotion_v4/qat.bc'}
2026-04-29 16:05:37,868 WARNING wrap usage has been changed, please pass necessary args
@autocast(enabled=False)
2026-04-29 16:05:38,095 WARNING The pytree support of plugin is deprecated and will be removed soon, please use native pytree to get better experience.
2026-04-29 16:05:38,095 INFO build_from_registry(HbirCompiler) took 1.25s (HBIR load + constructor runs here)
2026-04-29 16:05:38,095 INFO HBIR already loaded from ./lidar_data/ztao/port_train/pointpillars_5class_swmotion_v4/qat.bc (load took 0.11s). Stages: graph edits → convert → save compile_hbir.bc → compile()→HBM.
2026-04-29 16:05:38,103 INFO Input node : points, compiled with ddr!!transpose_dim: None
2026-04-29 16:05:38,104 INFO Start convert hbir
2026-04-29 16:05:41,221 INFO Convert Succeed
2026-04-29 16:05:41,222 INFO convert(hbir → march=nash-m, enable_vpu=True) took 3.12s
Remove op type b30vpu.dequantize successfully, delete node type list ['Quantize', 'Dequantize']
2026-04-29 16:05:41,521 INFO remove_io_quant + save(compile_hbir.bc) took 0.30s
2026-04-29 16:05:41,521 INFO Compiled hbir saved: ./lidar_data/ztao/port_train/pointpillars_5class_swmotion_v4/compile/compile_hbir.bc
2026-04-29 16:05:41,521 INFO Starting hbdk compile() → ./lidar_data/ztao/port_train/pointpillars_5class_swmotion_v4/compile/model.hbm (opt=0, jobs=144, progress_bar=True, advice=1000000us). This step often takes minutes on large models; use progress_bar or a positive advice threshold for more toolchain output.
2026-04-29 16:05:41,521 INFO [hbdk compile] pid=1477730 — heartbeat every 30s (disable with --compile_heartbeat_sec 0).
[================- ]33%
