论坛算法工具链J5 Open Explorer hb_mapper checker报错
Darth Nihilus2026-05-14
140
11
报错如下:sudo docker run -it --rm -v /open_explorer -v ./dataset:/data/horizon_j5/data openexplorer/ai_toolchain_ubuntu_20_j5_cpu:v1.1.77-py38
[sudo] password for openexplorer:
root@72665e89a381:/open_explorer# cd ..
root@72665e89a381:/# hb_mapper checker --model-type onnx --model /data/horizon_j5/data/yolov5n.onnx --march bayes
/usr/local/lib/python3.8/dist-packages/paramiko/pkey.py:100: CryptographyDeprecationWarning: TripleDES has been moved to cryptography.hazmat.decrepit.ciphers.algorithms.TripleDES and will be removed from this module in 48.0.0.
"cipher": algorithms.TripleDES,
/usr/local/lib/python3.8/dist-packages/paramiko/transport.py:259: CryptographyDeprecationWarning: TripleDES has been moved to cryptography.hazmat.decrepit.ciphers.algorithms.TripleDES and will be removed from this module in 48.0.0.
"class": algorithms.TripleDES,
2026-05-14 14:42:01,498 INFO log will be stored in //hb_mapper_checker.log
2026-05-14 14:42:01,498 INFO Start hb_mapper....
2026-05-14 14:42:01,498 INFO hbdk version 3.49.13
2026-05-14 14:42:01,498 INFO horizon_nn version 1.0.9
2026-05-14 14:42:01,498 INFO hb_mapper version 1.24.1
2026-05-14 14:42:01,518 INFO Model type: onnx
2026-05-14 14:42:01,519 INFO input names []
2026-05-14 14:42:01,519 INFO input shapes {}
2026-05-14 14:42:01,519 INFO Begin model checking....
2026-05-14 14:42:01,530 INFO Start to Horizon NN Model Convert.
2026-05-14 14:42:01,561 INFO Loading horizon_nn debug methods:[]
2026-05-14 14:42:01,562 INFO The specified model compilation architecture: bayes.
2026-05-14 14:42:01,563 INFO The specified model compilation optimization parameters: [].
2026-05-14 14:42:01,563 INFO Start to prepare the onnx model.
2026-05-14 14:42:01,598 INFO Input ONNX Model Information:
ONNX IR version: 8
Opset version: ['ai.onnx v17', 'horizon v1']
Producer: pytorch v1.14.0
Domain: None
Model version: None
Graph input:
images: shape=[1, 3, 640, 640], dtype=FLOAT16
Graph output:
output0: shape=[1, 25200, 85], dtype=FLOAT16
2026-05-14 14:42:01,601 ERROR *** ERROR-OCCUR-DURING {horizon_nn.build_onnx} ***, error message: The opset version of the model is 17, the maximum supported version is 11.
2026-05-14 14:42:01,601 INFO End to prepare the onnx model.
2026-05-14 14:42:01,601 INFO End to Horizon NN Model Convert.
社区活动征程5
  • YCJ
    问题出在“2026-05-14 14:42:01,601 ERROR *** ERROR-OCCUR-DURING {horizon_nn.build_onnx} ***, error message: The opset version of the model is 17, the maximum supported version is 11.”,J5 量化编译只支持opset版本为11及以下,建议你导出onnx时候加上opset版本参数为11
    2026-05-14
    • Darth Nihilus回复YCJ:
      我是直接下载的官方onnx文件。目前我没有找到支持11版本的yolo的onnx。机器性能可能不大支撑我自己导出。我问了咱们天工平台,给出的修改opset的方法好像都不大行。
      2026-05-14
    • YCJ回复Darth Nihilus:
      需要的话我可以转一个给您
      2026-05-14
      您转我一个吧~感谢感谢ganbei_org.svg
      2026-05-14
      2026-05-14
      好滴好滴,感谢老师~另外,我做模型转化的时候运行与报错:
      2026-05-15 09:49:15,806 ERROR Parse 'calibration_parameters' failed!
      2026-05-15 09:49:15,806 ERROR yaml file parse failed. Please double check your config file inputs
      2026-05-15 09:49:15,808 ERROR Wrong cal_dir num given, cal_dir num 0 is not equal to input num 1这个是为什么呢?想请教下~感谢啦
      2026-05-15
      2026-05-15
      2026-05-15
      yaml文件如下:
      model_parameters:
      onnx_model: '/data/horizon_j5/data/yolov5n.onnx'
      march: "bayes"
      layer_out_dump: False
      working_dir: '../model_output'
      output_model_file_prefix: 'yolov5n-det'
      remove_node_type: "Dequantize"
      node_info: {"/model.10/m/m.0/attn/Softmax": {'ON': 'BPU','InputType': 'int8','OutputType': 'int8'}}
      input_parameters:
      input_name: 'images'
      input_shape: '1x3x640x640'
      input_type_rt: 'nv12'
      input_type_train: 'rgb'
      input_layout_train: 'NCHW'
      mean_value: '0.0 0.0 0.0'
      scale_value: '0.00392157 0.00392157 0.00392157'
      calibration_parameters:
      cal_dir: '/data/horizon_j5/data/calib_data'
      compiler_parameters:
      compile_mode: 'latency'
      core_num: 1
      optimize_level: 'O2'
      jobs: 8
      2026-05-15
      cal_data_dir参数名写错了,工具链没识别到校准集
      2026-05-15
      解决啦~感谢啦~
      2026-05-20
