论坛算法工具链模型在板端perf测试hang问题
模型在板端perf测试hang问题
进击白加黑2026-05-14
271
J6E板子,测试模型性能,发现hang住了,/sys/devices/system/bpu/bpu0/task_running/sys/devices/system/bpu/bpu0/task_running p_time一直持续增加,
终端log:
bin,/tmp/input_7.bin,/tmp/input_8.bin,/tmp/input_9.bin,/tmp/input_10.bin,/tmp/input_11.bin,/tmp/input_12.bin,/tmp/input_13.bin,/tmp/input_14.bin --frame_count 1 --thread_num 1 <
[UCP]: log level = 3
[UCP]: UCP version = 3.3.3
[VP]: log level = 3
[DNN]: log level = 3
[HPL]: log level = 3
ls: /dev/vdsp*: No such file or directory
[UCPT]: log level = 6
[DSP]: log level = 3
./app/hrt_tools/hrt_model_exec perf --model_file /data/ykf/htt_tools/e2e_model/model_0429.hbm --input_file /tmp/input_0.bin,/tmp/input_1.bin,/tmp/input_2.bin,/tmp/input_3.bin,/tmp/input_4.bin,/tmp/input_5.bin,/tmp/input_6.bin,/tmp/input_7.bin,/tmp/input_8.bin,/tmp/input_9.bin,/tmp/input_10.bin,/tmp/input_11.bin,/tmp/input_12.bin,/tmp/input_13.bin,/tmp/input_14.bin --frame_count 1 --thread_num 1
[BPU][[BPU_MONITOR]][281472974241760][INFO]BPULib verison(2, 0, 5)[]!
CLIENT: SO_SNDBUF changed from 212992 to 262144
[DNN] HBTL_EXT_DNN log level:6
[DNN]: 3.3.3_(4.1.17 HBRT)
Load model to DDR cost 391.994ms.
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[0] stride is dynamic, but you did not specify the stride, set as (180224,704,1,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[1] stride is dynamic, but you did not specify the stride, set as (90112,704,2,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[2] stride is dynamic, but you did not specify the stride, set as (180224,704,1,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[3] stride is dynamic, but you did not specify the stride, set as (90112,704,2,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[4] stride is dynamic, but you did not specify the stride, set as (180224,704,1,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[5] stride is dynamic, but you did not specify the stride, set as (90112,704,2,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[6] stride is dynamic, but you did not specify the stride, set as (180224,704,1,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[7] stride is dynamic, but you did not specify the stride, set as (90112,704,2,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[8] stride is dynamic, but you did not specify the stride, set as (180224,704,1,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[9] stride is dynamic, but you did not specify the stride, set as (90112,704,2,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[10] stride is dynamic, but you did not specify the stride, set as (180224,704,1,1)
[I][17544][01-01][00:44:02:700][tensor_util.cpp:293][hrt_model_exec][HRT_MODEL_EXEC] Input[11] stride is dynamic, but you did not specify the stride, set as (90112,704,2,1)
[I][17544][01-01][00:44:02:700][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_0.bin length: 180224
[I][17544][01-01][00:44:02:700][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_1.bin length: 90112
[I][17544][01-01][00:44:02:700][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_2.bin length: 180224
[I][17544][01-01][00:44:02:700][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_3.bin length: 90112
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_4.bin length: 180224
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_5.bin length: 90112
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_6.bin length: 180224
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_7.bin length: 90112
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_8.bin length: 180224
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_9.bin length: 90112
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_10.bin length: 180224
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_11.bin length: 90112
[I][17544][01-01][00:44:02:701][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_12.bin length: 192
[I][17544][01-01][00:44:02:702][file_util.cpp:150][hrt_model_exec][HRT_MODEL_EXEC] Input [/tmp/input_12.bin] will padding, validShape: (6,4,4), stride: (32,8,2)
[I][17544][01-01][00:44:02:702][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_13.bin length: 8448
[I][17544][01-01][00:44:02:702][file_util.cpp:150][hrt_model_exec][HRT_MODEL_EXEC] Input [/tmp/input_13.bin] will padding, validShape: (1,384,11), stride: (12288,32,2)
[I][17544][01-01][00:44:02:702][file_util.cpp:128][hrt_model_exec][HRT_MODEL_EXEC] read file /tmp/input_14.bin length: 98304
[VP]: log level = 3
dmesg log如下:
tail -f dmesg_hang.log
[ 2621.444551] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2621.445264] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2621.623677] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2621.623684] RR data: 0x150f.
[ 2622.623917] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2622.623924] RR data: 0x150f.
[ 2623.624162] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2623.624169] RR data: 0x150f.
[ 2624.624414] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2624.624421] RR data: 0x150f.
[ 2625.624654] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2625.624660] RR data: 0x150f.
[ 2626.445938] data_callback: 4166 callbacks suppressed
[ 2626.445945] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.446890] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.446954] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.447289] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.447662] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.456726] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.456786] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.457138] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.461699] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.461800] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2626.624896] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2626.624903] RR data: 0x150f.
[ 2627.625141] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2627.625148] RR data: 0x150f.
[ 2628.625399] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2628.625406] RR data: 0x150f.
[ 2629.625644] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2629.625652] RR data: 0x150f.
[ 2630.625908] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2630.625915] RR data: 0x150f.
[ 2631.456718] data_callback: 4161 callbacks suppressed
[ 2631.456725] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.456779] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.457127] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.461682] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.461786] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.461893] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.462078] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.462162] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.462273] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.462343] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2631.626155] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2631.626161] RR data: 0x150f.
[ 2632.626386] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2632.626393] RR data: 0x150f.
[ 2633.626620] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2633.626627] RR data: 0x150f.
[ 2634.626861] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2634.626867] RR data: 0x150f.
[ 2635.627106] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2635.627126] RR data: 0x150f.
[ 2636.461689] data_callback: 4160 callbacks suppressed
[ 2636.461696] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.461783] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.461895] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.462080] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.462162] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.462271] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.462343] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.462473] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.464434] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.464873] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2636.627368] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2636.627375] RR data: 0x150f.
[ 2637.627601] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2637.627608] RR data: 0x150f.
[ 2638.627842] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2638.627848] RR data: 0x150f.
[ 2639.628084] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2639.628091] RR data: 0x150f.
[ 2639.782238] [diag_set_stl_location:838]set module_id:376 stl location KERNEL_SPACE
[ 2639.782255] [diag_register_module_to_list, 1365]### module: 376 is registering ###
[ 2639.782257] [diag_fusa_func_register, 1749]###module: 376 registered succ! ###
[ 2639.782259] [diag_fusa_run_selfcheck, 1706]module: 376 begin selfcheck
[ 2639.782931] [diag_fusa_run_selfcheck, 1717]module: 376 end selfcheck_cb
[ 2639.801919] [diag_selfcheck_result_show, 1568]Stl(module_id: 376) run the selfcheck case successfully
[ 2639.954389] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x400390000, 0xfff000000, 0x1000000
[ 2639.954399] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x400200000, 0xffef00000, 0x100000
[ 2639.964560] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x401390000, 0xfebd00000, 0x10
[ 2640.084218] [A][time_1 :2640 s, 82 ms] FCHM Int occur (19, 619, 22231)
[ 2640.084238] bpu-stl: BPU stl fusa(19, 619) occur syscount(105708091914)
[ 2640.084254] [A][time_2 :2640 s, 82 ms] [K] Rcv_Occur_msg: 376-4-NCF-Occur (19, 619, 22231)payload(16 2 0 0 0 0 0 0 10 122 177 156 24 0 0 0)
[ 2640.084264] [diag_ncf_event_ipc_send:421]ncf_ipc_init is not OK
[ 2640.097990] module: 376, will be unregistered
[ 2640.098005] [diag_fusa_func_unregister,1804]module_id = 376 has be unregisted successfully
[ 2640.226300] [diag_set_stl_location:838]set module_id:376 stl location KERNEL_SPACE
[ 2640.226318] [diag_register_module_to_list, 1365]### module: 376 is registering ###
[ 2640.226321] [diag_fusa_func_register, 1749]###module: 376 registered succ! ###
[ 2640.226324] [diag_fusa_run_selfcheck, 1706]module: 376 begin selfcheck
[ 2640.226994] [diag_fusa_run_selfcheck, 1717]module: 376 end selfcheck_cb
[ 2640.245903] [diag_selfcheck_result_show, 1568]Stl(module_id: 376) run the selfcheck case successfully
[ 2640.245928] [A][time_5 :2640 s, 244 ms] [K] Rcv_Fixed_msg: 376-4-NCF-Fixed (19, 619, 22231)payload(0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0)
[ 2640.245936] [diag_ncf_event_ipc_send:421]ncf_ipc_init is not OK
[ 2640.397081] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x400390000, 0xfff000000, 0x1000000
[ 2640.397092] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x400200000, 0xffef00000, 0x100000
[ 2640.407308] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x40b670000, 0xffee60000, 0x10
[ 2640.409514] bpu-core 28108000.bpu: TO recovery bpu core0
[ 2640.464524] [A][time_1 :2640 s, 462 ms] FCHM Int occur (19, 619, 22317)
[ 2640.464543] bpu-stl: BPU stl fusa(19, 619) occur syscount(105723304130)
[ 2640.464560] [A][time_2 :2640 s, 462 ms] [K] Rcv_Occur_msg: 376-4-NCF-Occur (19, 619, 22317)payload(16 2 0 0 0 0 0 0 194 152 153 157 24 0 0 0)
[ 2640.464571] [diag_ncf_event_ipc_send:421]ncf_ipc_init is not OK
[ 2640.464573] [A][time_5 :2640 s, 462 ms] [K] Rcv_Fixed_msg: 376-4-NCF-Fixed (19, 619, 22317)payload(0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0)
[ 2640.464578] [diag_ncf_event_ipc_send:421]ncf_ipc_init is not OK
[ 2640.628332] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2640.628339] RR data: 0x150f.
[ 2641.461903] data_callback: 4159 callbacks suppressed
[ 2641.461910] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.462093] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.462171] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.462281] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.462348] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.462482] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.463551] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.463646] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.466813] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.466896] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2641.628573] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2641.628579] RR data: 0x150f.
[ 2642.628840] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2642.628849] RR data: 0x150f.
[ 2643.629106] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2643.629114] RR data: 0x150f.
[ 2644.629354] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2644.629360] RR data: 0x150f.
[ 2645.629600] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2645.629607] RR data: 0x150f.
[ 2646.192739] [A][time_1 :2646 s, 190 ms] FCHM Int occur (19, 521, 22318)
[ 2646.192760] bpu-stl: BPU stl fusa(19, 521) occur syscount(105952432799)
[ 2646.192775] [A][time_2 :2646 s, 190 ms] [K] Rcv_Occur_msg: 376-4-NCF-Occur (19, 521, 22318)payload(4 0 0 0 0 0 0 0 159 210 65 171 24 0 0 0)
[ 2646.192786] [diag_ncf_event_ipc_send:421]ncf_ipc_init is not OK
[ 2646.198013] module: 376, will be unregistered
[ 2646.198026] [diag_fusa_func_unregister,1804]module_id = 376 has be unregisted successfully
[ 2646.326233] [diag_set_stl_location:838]set module_id:376 stl location KERNEL_SPACE
[ 2646.326252] [diag_register_module_to_list, 1365]### module: 376 is registering ###
[ 2646.326255] [diag_fusa_func_register, 1749]###module: 376 registered succ! ###
[ 2646.326257] [diag_fusa_run_selfcheck, 1706]module: 376 begin selfcheck
[ 2646.326984] [diag_fusa_run_selfcheck, 1717]module: 376 end selfcheck_cb
[ 2646.345936] [diag_selfcheck_result_show, 1568]Stl(module_id: 376) run the selfcheck case successfully
[ 2646.345963] [A][time_5 :2646 s, 344 ms] [K] Rcv_Fixed_msg: 376-4-NCF-Fixed (19, 521, 22318)payload(0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0)
[ 2646.345972] [diag_ncf_event_ipc_send:421]ncf_ipc_init is not OK
[ 2646.466722] data_callback: 4165 callbacks suppressed
[ 2646.466728] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.466783] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.467137] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.476706] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.476767] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.477120] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.481679] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.481773] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.481882] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.482069] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2646.497005] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x400390000, 0xfff000000, 0x1000000
[ 2646.497015] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x400200000, 0xffef00000, 0x100000
[ 2646.507182] bpu-core 28108000.bpu: bpu core mem alloc mem addr addr = 0x0000000000000000, 0x40b670000, 0xfebd10000, 0x10
[ 2646.509389] bpu-core 28108000.bpu: TO recovery bpu core0
[ 2646.629854] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2646.629873] RR data: 0x150f.
[ 2647.630133] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2647.630139] RR data: 0x150f.
[ 2648.630379] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2648.630386] RR data: 0x150f.
[ 2649.630624] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2649.630631] RR data: 0x150f.
[ 2650.630867] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2650.630874] RR data: 0x150f.
[ 2651.476747] data_callback: 4160 callbacks suppressed
[ 2651.476753] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.476805] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.477159] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.481726] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.481818] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.481923] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.482102] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.482182] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.482300] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.482363] ipc-shm-hal: data_callback()[855]: [8][1] irq/22-29f00000(77) put_data_tofifo failed
[ 2651.631117] (LOG RR): devAddr 0x01, regAddr 0x00,
[ 2651.631123] RR data: 0x150f.tail -f dmesg_hang.log
    UCP version = 3.3.3是个上古版本,建议先获取最新的OE工具链吧,比如 OE 3.8.1 OE 3.7.0等等
    2026-05-15
    • Somnus゛回复DR_KAN:
      但是同时由OE 3.7.0版本工具链编译的两个模型,一个可以在这个板子上跑,另一个出现了上述问题,是不是可以侧面印证不是版本的问题,而是模型的问题,那这种情况下应该从哪个方向来排查这个问题呢
      2026-05-20
    • DR_KAN回复Somnus゛:
      板端的运行库也要配合升级,要用OE 3.7.0编译出的hrt_model_exec
      2026-05-25
    2026-07-03
