论坛底层软件请问XJ3的芯片,mipi输入支持连续时钟模式(continuous_clock)的mipi csi2信号吗?
zzycas2026-06-04
71
1.硬件获取渠道:基于X3开发板,通过mipi_host0/2输入自定义的红外相机
2.当前系统镜像版本:
3.当前天工开物版本:OE2.3.3
4.问题定位:配置后,无法接入数据,打印如下:
set_sensor_param
bus_num 2
bus_type 0
sensor_name lt9211
reg_width 8
sensor_mode 1
sensor_addr 0x3c
serial_addr 0x0
resolution 512
hb sensor init success...
hb isp init success...
hb mipi init success...
devId: 0 snsinfo.sensorInfo.entry_index:0
camera_info->mipi_attr.mipi_host_cfg.lane: 2
[ERROR]["vio_devop"][utils/dev_ioctl.c:280] [193.599459]dev_get_buf_timeout[280]: pipe(0)TIME OUT ,sec(1699889185)usec(30864)!
[ERROR]["vio_devop"][utils/dev_ioctl.c:283] [193.599491]dev_get_buf_timeout[283]: pipe(0)Get buf sem_timedwait failed Connection timed out!
[ERROR]["vin"][vin/hb_vin_api.c:1381] [193.599530]HB_VIN_GetDevFrame[1381]: devId 0 GetDevFrame BUFFER_OUT_DONE timeout
HB_VIN_GetDevFrame error!!!
********************** Command Lists *************************
q -- quit
g -- get one frame
l -- get a set frames
h -- print help message
Command: Command: [ERROR]["vio_core"][commom_grp/binding_main.c:1025] [195.799886]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [195.999949]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [196.200032]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [196.400097]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [196.600161]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [196.800252]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [197.000318]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [197.200383]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [197.400449]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [197.600487]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [197.800535]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [198.000587]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
[ERROR]["vio_core"][commom_grp/binding_main.c:1025] [198.200650]comm_dq_no_data[1025]: G0 MIPI_SIF_MODULE module dq too much timeout error_detail -3
通过其他硬件解码参数对比,确定前端是continuous连续时钟模式,XJ3的例程都是非连续模式时钟的配置方法
5.开发的demo/案例:SDK中的sample/get_sif_data例程
6.需要提供的解决方案:希望能提供相关的配置方法
技术深度解析征程3
    理论上时钟应该是连续的,特别是带解串器的模组,可以查阅解串器的相关的寄存器进行确认,另外你这边不连续是该的模组的吗,换成连续的就能跑了?
    2026-06-12
