论坛底层软件双目数据采集丢帧问题
双目数据采集丢帧问题
默认664962026-06-24
127
RDKx5 按指定分辨率(1920x1080)打开双目摄像头,并将摄像头采集到的数据进行编码,camera出现丢帧,错误码-268435443是什么错误
2026-06-12 12:12:59.044] [cam1] [INFO] heartbeat frames=2242 bytes=80018452 run_ms=75012 avg_fps_x1000=29888 max_frame_gap_ms=36
[2026-06-12 12:13:04.041] [cam0] [INFO] heartbeat frames=2394 bytes=82256017 run_ms=80009 avg_fps_x1000=29921 max_frame_gap_ms=36
[2026-06-12 12:13:04.045] [cam1] [INFO] heartbeat frames=2394 bytes=85422325 run_ms=80013 avg_fps_x1000=29920 max_frame_gap_ms=36
2026/06/12 12:13:07.553 ERROR [vp_codec_set_input][0730]hb_mm_mc_dequeue_input_buffer failed ret = -268435443
2026/06/12 12:13:07.554 ERROR [WorkFunc][0070]Module Camera SetImageFrame failed
[2026-06-12 12:13:09.043] [cam0] [INFO] heartbeat frames=2546 bytes=87494352 run_ms=85011 avg_fps_x1000=29949 max_frame_gap_ms=36
[2026-06-12 12:13:09.466] [cam1] [INFO] heartbeat frames=2430 bytes=86689208 run_ms=85433 avg_fps_x1000=28443 max_frame_gap_ms=4268
[2026-06-12 12:13:14.046] [cam0] [INFO] heartbeat frames=2698 bytes=92733658 run_ms=90014 avg_fps_x1000=29973 max_frame_gap_ms=36
[2026-06-12 12:13:14.050] [cam1] [INFO] heartbeat frames=2580 bytes=92009140 run_ms=90018 avg_fps_x1000=28660 max_frame_gap_ms=4268
[2026-06-12 12:13:19.048] [cam0] [INFO] heartbeat frames=2850 bytes=97986851 run_ms=95016 avg_fps_x1000=29994 max_frame_gap_ms=36
技术深度解析社区活动DSP征程5
    可以贴下完整的驱动日志跟上层日志的
    2026-06-29
    • 默认66496回复费小财:
      丢帧问题找到了,是两个线程有资源竞争
      2026-06-30
