论坛算法工具链3.8.1 oe 工具链中resnet50 用例segmentation fault
110
root@f90c9f3d213e:/open_explorer/horizon_j6_open_explorer_v3.8.1-py310_20260326/samples/ai_toolchain/horizon_model_convert_sample/03_classification/03_resnet50# free -h
total used free shared buff/cache available
Mem: 62Gi 26Gi 3.0Gi 275Mi 32Gi 34Gi
Swap: 8.0Gi 7.5Gi 485Mi
root@f90c9f3d213e:/open_explorer/horizon_j6_open_explorer_v3.8.1-py310_20260326/samples/ai_toolchain/horizon_model_convert_sample/03_classification/03_resnet50# bash 01_check.sh
++ dirname 01_check.sh
+ cd .
+ onnx_model=../../01_common/model_zoo/mapper/classification/resnet50/resnet50.onnx
+ march=nash-e
+ hb_compile --model ../../01_common/model_zoo/mapper/classification/resnet50/resnet50.onnx --march nash-e
2026-07-07 10:22:21,362 INFO The log will be stored in /open_explorer/horizon_j6_open_explorer_v3.8.1-py310_20260326/samples/ai_toolchain/horizon_model_convert_sample/03_classification/03_resnet50/hb_compile.log
2026-07-07 10:22:21,362 INFO Start hb_compile...
2026-07-07 10:22:21,362 INFO hbdk version: 4.9.7
2026-07-07 10:22:21,362 INFO hmct version: 2.7.3
2026-07-07 10:22:21,362 INFO hb_compile version: 3.5.11
01_check.sh: line 15: 34 Segmentation fault (core dumped) hb_compile --model ${onnx_model} --march ${march}
root@f90c9f3d213e:/open_explorer/horizon_j6_open_explorer_v3.8.1-py310_20260326/samples/ai_toolchain/horizon_model_convert_sample/03_classification/03_resnet50# h
h2ph hash hb_config_generator hb_verifier hbrt4-run-model-nash head hexdump hmct-info hrt_model_exec huggingface-cli
h2xs hb_analyzer hb_eval_preprocess hbcm-module-entry hbrt4-toolkit help history hostid htop humanfriendly
hardlink hb_compile hb_model_info hbrt4-disas hd helpztags hmct-debugger hostname httpx hwclock
root@f90c9f3d213e:/open_explorer/horizon_j6_open_explorer_v3.8.1-py310_20260326/samples/ai_toolchain/horizon_model_convert_sample/03_classification/03_resnet50# hb_compile --model ../../01_common/model_zoo/mapper/classification/resnet50/resnet50.onnx --march nash-e
2026-07-07 10:23:09,602 INFO The log will be stored in /open_explorer/horizon_j6_open_explorer_v3.8.1-py310_20260326/samples/ai_toolchain/horizon_model_convert_sample/03_classification/03_resnet50/hb_compile.log
2026-07-07 10:23:09,602 INFO Start hb_compile...
2026-07-07 10:23:09,602 INFO hbdk version: 4.9.7
2026-07-07 10:23:09,602 INFO hmct version: 2.7.3
2026-07-07 10:23:09,602 INFO hb_compile version: 3.5.11
  • YCJ
    看起来像环境问题呢,检查一下版本是否对应上
    2026-07-07
    • 200803回复YCJ:
      应该没问题,最开始用3.9.0版本也是这样, docker 启动如下
      ThinkStation-P3-Tower:~/oe$ docker run --memory=64g --memory-swap=64g -it -v /home/xxx/oe/:/open_explorer openexplorer/ai_toolchain_ubuntu_22_j6_gpu:v3.8.1
      2026-07-07
  • YCJ
    2026-07-07
  • 金属货机
    您设置了 --memory=64g --memory-swap=64g。在 Docker 中,--memory-swap 表示 内存 + Swap 的总和。当 --memory-swap 等于 --memory 时,意味着 容器内禁用 Swap,此外您没有去挂载GPU。参考的指令如下:
    docker run \
    --memory=50g \
    --memory-swap=80g \
    --shm-size=8g \
    --gpus all \
    -it \
    -v /home/xxx/oe/:/open_explorer \
    openexplorer/ai_toolchain_ubuntu_22_j6_gpu:v3.8.1 \
    /bin/bash
    2026-08-07
